Results 1 to 8 of 8
Thread: Remove UserForm's TitleBar And Frame
    Quote Originally Posted by birdieman View Post
    Rick
    To adapt your code above to also run/work on a 64-bit excel, would "PtrSafe" need to be added between the words Declare... Function each time it is mentioned above? Is that all that is needed?
    I don't have the 64-bit version of Excel, so I cannot check, but as far as I know, yes, that all you need to do.
  1. Remove Special Characters From Text Or Remove Numbers From Text
  2. One userform and 60 Combo Boxes
    By k0st4din in forum Excel Help
    Last Post: 04-25-2013, 09:55 AM
  3. Multiple graph in userform
    By Tony in forum Excel Help
    Last Post: 10-20-2012, 09:32 AM
  4. Replies: 3
    Last Post: 12-07-2011, 09:59 PM
  5. Userform With DataGrid or FlexGrid
    Last Post: 04-09-2011, 09:05 AM
