Results 1 to 10 of 19
Thread: Delete One Row From A 2D Variant Array
    Working in VBA with a 2D array in memory that was formed from a worksheet range is much faster than trying to work with the range directly on the worksheet itself. The way the array is formed is quite simple... just assign the range to a Variant variable. So, if you wanted to create an array in memory for range A1:M1000, you would (should) declare a Variant variable, for example...
    Dim DataArr As Variant
    and then assign the range to it...
    DataArr = Range("A1:M1000")
    Okay, with that brief introduction out of the way, I have seen on more than one occasion requests to be able to delete a single specified row from such a 2D Variant array. Finally, I decided to tackle the problem and see what I could come up with... this non-looping function is the result. The function accepts a 2-D Variant array and a row number for its arguments and it returns a 2-D Variant array with that row number removed.
    Function DeleteArrayRow(Arr As Variant, RowToDelete As Long) As Variant Dim Rws As Long, Cols As String Rws = UBound(Arr) - LBound(Arr) Cols = "A:" & Split(Columns(UBound(Arr, 2) - LBound(Arr, 2) + 1).Address(, 0), ":")(0) DeleteArrayRow = Application.Index(Arr, Application.Transpose(Split(Join(Application.Transpose(Evaluate("Row(1:" & (RowToDelete - 1) & ")"))) & " " & Join(Application.Transpose(Evaluate("Row(" & (RowToDelete + 1) & ":" & UBound(Arr) & ")"))))), Evaluate("COLUMN(" & Cols & ")")) End Function
    Note the last line of code is quite long. Here is a macro to test the function with that creates the 2-D Variant array from the range A1:AI1000 (1000 rows by 35 columns), which the macro will fill with data for you, and outputs the array (with row 35 removed) returned by the function to the range starting at cell AK1. Note that the test macro seeds the given range with some data for you so you don't have to do that on your own.
    Sub Test()
      Dim Cell As Range, RemoveRow As Long, Data_Array As Variant, ArrLessOne As Variant
      ' Seed the range with some data
      For Each Cell In Range("A1:AI1000")
        Cell.Value = Cell.Address(0, 0)
      Data_Array = Range("A1:AI1000")
      RemoveRow = 35
      ArrLessOne = DeleteArrayRow(Data_Array, RemoveRow)
      Range("AK1").Resize(UBound(ArrLessOne, 1), UBound(ArrLessOne, 2)) = ArrLessOne
    Nice one Rick. Though, I don't see any performance gain over looping the array.
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgwTUdEgR4bdt6crKXF4AaABAg. 9xmkXGSciKJ9xonTti2sIx
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgwWw16qBFX39JCRRm54AaABAg. 9xnskBhPnmb9xoq3mGxu_b
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgybZfNJd3l4FokX3cV4AaABAg. 9xm_ufqOILb9xooIlv5PLY
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgyWm8nL7syjhiHtpBF4AaABAg. 9xmt8i0IsEr9y3FT9Y9FeM
    I had assumed that avoiding the nested loop would be faster, but you are right... I just set up a test and they both run in approximately the same time... actually, the nested loop might even be a hair faster (it appeared to run about 0.005 seconds faster, on average, given my limited testing). For those wondering about the code for the nested loop version, this is what I used...
    Sub Test2()
      Dim R As Long, C As Long, Idx As Long, RemoveRow As Long, Data_Array As Variant, ArrLessOne As Variant
      RemoveRow = 35
      ReDim ArrLessOne(1 To UBound(Data_Array, 1) - 1, 1 To UBound(Data_Array, 2))
      For R = 1 To UBound(Data_Array)
        If R <> RemoveRow Then
          Idx = Idx + 1
          For C = 1 To UBound(Data_Array, 2)
            ArrLessOne(Idx, C) = Data_Array(R, C)
    https://www.youtube.com/watch?v=kfQC-sQxMcw&lc=UgyCxQWypNIhG2nUn794AaABAg.9q1p6q7ah839t UQl_92mvg
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgyOh-eR43LvlIJLG5p4AaABAg.9isnKJoRfbL9itPC-4uckb
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=Ugy1B1aQnHq2WbbucmR4AaABAg. 9isY3Ezhx4j9itQLuif26T
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgxxajSt03TX1wxh3IJ4AaABAg. 9irSL7x4Moh9itTRqL7dQh
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgwJAAPbp8dhkW2X1Uh4AaABAg. 9iraombnLDb9itV80HDpXc
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgzIzQ6MQ5kTpuLbIuB4AaABAg. 9is0FSoF2Wi9itWKEvGSSq
    I think you can remove the second
    from the code.
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgxzpgHWTLGj0C3q3gx4AaABAg. 9gxsUMU53al9k5c8W6QGE8
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg. 9gxDYq2iiZ89h4ISxLD17d
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg. 9gxDYq2iiZ89h4LdsDETim
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg. 9gxDYq2iiZ89h32czjtyR_
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugw_smEwvNffCPr_nrB4AaABAg. 9gvyL53lI1l9gxwd_9-V6z
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugy7vmiHsQ0oUt2QCPZ4AaABAg. 9gvoy4OW6lU9gxwxC5-rL9
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgzuX3uYmqJRtsZIbqF4AaABAg. 9gth61YhXKB9gxxCMdRLA0
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgxcPC64RQGmXwO5rft4AaABAg. 9gtQLXaeg0e9gxxNuc5CCM
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwCY8vOs1DFHgYSJwF4AaABAg. 9godrFcyWYw9gxy1odpiRj
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgyL5nh_j8w70-YBoUt4AaABAg.9goMcRjwjtc9gxyslvuZKx
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwwWRgmRZNqJKptHR14AaABAg. 9go-DbayTZa9gxzPbefHXf
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwF3wECwc8tVoRmz6B4AaABAg. 9go-5xLQM8P9gxzmB7nkVQ
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgyRDmGTHnMdT7dl_qx4AaABAg
    from the code.
    Fixed... thanks for the head's up (damn last minute edits. )
    https://eileenslounge.com/viewtopic.php?p=244184#p244184
    https://eileenslounge.com/viewtopic.php?p=246586#p246586
    https://eileenslounge.com/viewtopic.php?p=246112#p246112
    https://eileenslounge.com/viewtopic.php?p=245761#p245761
    https://eileenslounge.com/viewtopic.php?p=245722#p245722
    https://eileenslounge.com/viewtopic.php?p=245616#p245616
    https://eileenslounge.com/viewtopic.php?p=247043#p247043
    https://www.excelfox.com/forum/showthread.php/2307-VBA-Range-Sort-with-arrays-Alternative-for-simple-use
    https://eileenslounge.com/viewtopic.php?p=245238#p245238
    https://eileenslounge.com/viewtopic.php?p=245131#p245131
    https://eileenslounge.com/viewtopic.php?f=18&t=31638
    https://eileenslounge.com/viewtopic.php?p=244579#p244579
    https://eileenslounge.com/viewtopic.php?p=244648#p244648
    https://eileenslounge.com/viewtopic.php?p=244647#p244647
    https://eileenslounge.com/viewtopic.php?p=244577#p244577
    https://eileenslounge.com/viewtopic.php?p=245201#p245201
    https://eileenslounge.com/viewtopic.php?p=243975#p243975
    https://eileenslounge.com/viewtopic.php?p=243884#p243884
    https://eileenslounge.com/viewtopic.php?p=242439#p242439
    https://eileenslounge.com/viewtopic.php?p=243595#p243595
    https://eileenslounge.com/viewtopic.php?p=243589#p243589
    https://eileenslounge.com/viewtopic.php?p=243002#p243002
    https://www.eileenslounge.com/viewtopic.php?p=242761#p242761
    https://eileenslounge.com/viewtopic.php?p=242459#p242459
    https://eileenslounge.com/viewtopic.php?p=242054#p242054
    https://eileenslounge.com/viewtopic.php?p=241404#p241404
    https://eileenslounge.com/viewtopic.php?p=229145#p229145
    https://eileenslounge.com/viewtopic.php?p=228710#p228710
    https://eileenslounge.com/viewtopic.php?p=226938#p226938
    https://eileenslounge.com/viewtopic.php?f=18&t=28885
    https://eileenslounge.com/viewtopic.php?p=222689#p222689
    https://eileenslounge.com/viewtopic.php?p=221622#p221622
    https://eileenslounge.com/viewtopic.php?f=27&t=22512
    https://eileenslounge.com/viewtopic.php?f=26&t=26183
    https://eileenslounge.com/viewtopic.php?f=26&t=26030
    https://eileenslounge.com/viewtopic.php?p=202322#p202322
    https://www.excelforum.com/word-formatting-and-general/1174522-finding-a-particular-word-phrase-in-word.html#post4604396
    Hallo,
    Thanks very much for sharing this Rick. I have done some pretty nasty looking Functions based on looping to insert, take out and / or swap around columns and rows in Arrays of different sizes. Included in that set was a Function to Take out a column, again based on looping.
    Excel Help Forum
    Your alternative way will be interesting to consider if I need to take a row out.
    P.s. I notice you have in your first code Window in this thread been able to avoid the dreaded wrapping of code lines in Forum Code Windows and have achieved a horizontal scroll bar.
    Board wish list
    I , like yourself, prefer this form of code window that works similarly to the VB Editor code window.
    Board wish list
    http://www.mrexcel.com/forum/about-b...sh-list-2.html
    Is it possible to explain / share how you achieved this
    https://www.youtube.com/watch?v=QjEWAJ3d-jw
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwCGCesYkcmCcv7tzx4AaABAg
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwCGCesYkcmCcv7tzx4AaABAg.9wbCfWMaaLa9wbLcU jbPCV 3
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwCGCesYkcmCcv7tzx4AaABAg.9wbCfWMaaLa9wbLma sNyaX 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgzxkJD1jksXet8AZYB4AaABAg.9p3jaxCq0AG9wbF__ jtm9w 2
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgxePNoJ9lMOZZIxSI54AaABAg.9n_K6OLzSGt9wbFsa Pa2ym 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwUIM7LhCvJkBpHL4N4AaABAg.9j-vSfzAHrw9wbFzCwVRUo 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwQ_hGXSa1PNKbT-r94AaABAg.9hmiz-Qc-bq9wbG1qa8wKO 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwqWxGrYGjtUAJG6aF4AaABAg.9hI9sgAhykQ9wbG4K JfN91 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgxJL5BeSLbJ-m7BWW54AaABAg.9euWbYmFb169wbG8eMb5Wb 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwaEHwTeazYGD7xHmN4AaABAg.9eWJC0jtPrJ9wbGCR m3IO6 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgySibJeWUXeEn3qez14AaABAg.9dj9CcZAzcq9wbGH5 FhlqO
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgyrMrxE5-AP81sgU8V4AaABAg.9aoKBx9yaE89wbGOGcNnKy 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=Ugw5b6kCEckEbGTccxp4AaABAg.9_Sbwexq-co9wbGW8LbhKp 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgyCQp_ShaVxQui5hJh4AaABAg.9ZBRfgBVmcd9wbGdP 0tnCi 2
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=Ugz_lKW2DNBax4Aemst4AaABAg.9Xjhb-fv4pt9wbGgysEibx
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgxguKtw3d8jE8bkGTB4AaABAg.9UuGKC386629wbGl3 2wvjC 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwLt2hK6AcHVnVlaUl4AaABAg.9HKd-ioHqxM9wbH2o6HYsJ 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=Ugw-IPT7RwxyRo4cbqd4AaABAg.9GqtD5j30Wp9wbH6q7RTJa 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgzLnQG1_LQtmvLQoot4AaABAg.9FvawuMTb-k9wbHFrsug5Z 1
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=Ugys6Ur7BNsRFbH_f_B4AaABAg.9DhZy5EEpKY9wbHfy JkVMG 3
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgxJLVpwY8fIla7G-pN4AaABAg.9BLeCWVhxdG9wbILDvziWr 2
    https://www.youtube.com/watch?v=QjEWAJ3d-jw&lc=UgwgzeOLschepoIO3gx4AaABAg.97v7ND4_6p298-gyUz3MY7 2
    If you want to remove row 12 from array [A1:K20]
    Sub M_snb()
      sp = F_snb([a1:K20], 12)
      Cells(1, 16).Resize(UBound(sp), UBound(sp, 2)) = sp
    Function F_snb(sn, y)
      sn.Name = "snb_002"
      F_snb = Application.Index(sn, Application.Transpose(Split(Trim(Replace(" " & Join([transpose(row(snb_002))]) & " ", " " & y & " ", " ")))), [column(snb_002)])
    For more see: http://www.snb-vba.eu/VBA_Arrays_en.html#L_6.10
    Delete One Row From a ....... group of contiguous cells in a Spreadsheet
    'Coments on snb and Rick codes and further solutuons......
    I have learned a lot in the past from opening up these "One liner" codes from the likes of Rick and snb. These were no exceptions. I did some notes for my own use. I thought I would share them, in case any novices hitting the Thread might find them useful... I will try to keep it as brief as possible but there is a wealth of knowledge "hidden" in there.!!
    Very briefly first:
    Rick's code:
    Rick is working on an Array, what the Thread is about. ( He just happens to make that Array, ( arrIn() = DataArr or Arr ) in a typical way form a Spreadsheet Range "capture" through the .Value Property.
    This .Value Property when applied to a Range for more than one cell returns a Field of Elements of Variant types. These can be assigned directly to a dynamic Array of variant Elements.
    ( That was Ricks comment more or less right at the start of the Thread. )
    _ That Array is sent to the Function which returns the Modified Array. It has to be a Variant Element type as the used .Index method returns a Field on Variant Element Types ( for all but the one 0 argument slicing case ....._
    https://usefulgyaan.wordpress.com/20...ication-index/
    ...._)
    (_.......
    In fact, both codes are similar and are basically using this sort of code line ( what I often refer to as a "Magic" or "neat Code line )
    arrOut() = Application.Index(arrIn(), rwsT(), clms())
    _....)
    snb's Code
    snb is working directly on the Range, ( rngIn = sn ) , - This..
    ... from array [A1:K20].....
    ...maybe is not quite right..... a "cheat"..****..but a lot more about that later
    What he returns from
    arrOut() = Application.Index( sn , rwsT(), clms())
    is also an Array as .Index method returns a Field on Values of Variant Element Types ( for all but the one 0 argument slicing case ) . I will call this a "cheat" just as a convenient reference to the "way" he does it, not to be taken as literally, sort of, as actually after thinking about it, I decided to do something similar in my alternatives ****, which I present later here in this thread......
    (_.... Edit: In fact , I found this "Cheat" and the associated use of a Name for that imputed Range fascinating and got quite side tracked with it !!
    http://www.excelforum.com/excel-prog...acket-for.html _.......)
    _.......
    So...
    My codes look massive compared to the original. Amongst other things I declare a lot of vba Variables.( And I use Option Explicit, to force me to do that ) In the final simplified codes the actual values set by the Variables are substituted into where the variables are used. So the need to declare them is gone_..............
    _.................... You end up then with the final code lines or code line.
    When I have finished I will give my attempt at an alternative ****.
    _.....I "farmed out" my "opened up" codes here, ( to save cluttering up this thread ! )
    Snb Code:
    http://www.excelfox.com/forum/showth...ted=1#post9826
    Rick code:
    http://www.excelfox.com/forum/showth...=9824#post9824
    _ If anyone is interested in my explanation then it might be worth copying the ranges shown below to a spare Worksheet, copying the codes to a spare Code Module and then following it through in Debug ( F8 ) mode as you work through my explanations.
    _I tried to write the explanations and the opened up codes such that both codes and explanations run as much as possible in parallel
    Code Explanations, or rather here,_....
    _........A quick refresh / explanation of the "neat", "Magic" code line in General
    I 'comment at the Function starts along the lines:
    Use here of :.... arrOut() = Application.Index(arrIn(), rwsT(), clms())
    So back to the codes given and discussed in this Thread, but again the use of
    arrIn() we have ( as an Array by Rick or as a spreadsheet "Area" by snb )
    All the "work" in the codes is to get the required rwsT() and clms() indices.
    For no particular reason I am considering this as my Input "Area"
    Using Excel 2007 32 bit
    1 0 10 20 30 40
    2 2 12 22 32 42
    3 4 14 24 34 44
    4 6 16 26 36 46
    5 8 18 28 38 48
    6 10 20 30 40 50
    7 12 22 32 42 52
    8 14 24 34 44 54
    9 16 26 36 46 56
    10 18 28 38 48 58
    Sheet: NPueyoGyanArraySlicing
    And to demo the Array returned by the Functions I will Paste it out here
    M
    N
    O
    P
    Q
    16
    17 0 10 20 30 40
    18 2 12 22 32 42
    19 4 14 24 34 44
    20 6 16 26 36 46
    21 10 20 30 40 50
    22 12 22 32 42 52
    23 14 24 34 44 54
    24 16 26 36 46 56
    25 18 28 38 48 58
    26
    So it follows that the main "work will be to get
    rwsT() = { 1; 2; 3; 4; 6; 7; 8; 9; 10 } ' ( 2 Dimensional 1 "column" "Vertical" Array )
    clms() = { 1, 2, 3, 4, 5 } ' ( 1 Dimension "pseudo Horizonal" Array )
    _................................................. ...
  1. Replies: 6
    Last Post: 03-26-2014, 03:04 PM
  2. Replies: 1
    Last Post: 02-25-2014, 10:55 PM
  3. Delete Entire Row For All Empty Cells In Column
    By johnreid7477 in forum Excel Help
    Last Post: 06-15-2013, 05:50 AM
  4. Delte a specific column and does not delete the top row
    By jffryjsphbyn in forum Excel Help
    Last Post: 06-13-2013, 02:00 PM
  5. Replies: 4
    Last Post: 03-22-2013, 01:47 PM
