Thread: Concatenate multiple values
    Aug 2012
    Lightbulb Concatenate multiple values
    super helpful...I'm attempting to do a modification of this.
    I'd like to concatenate ID numbers from all related rows within the table itself. See the attachment.
    Counting and Summing for all related values is in the table (see column D), but a reporting of the values themselves? Unsure how to do this. Any great ideas? Thanks.
    concat values.xlsx
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgxesLhWNr_zNP0GUdh4AaABAg. 9hI1CQJMLLo9hWn2pGBeSS
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgzkRujoMw9PblmXDQ14AaABAg. 9hJRnEjxQrd9hJoCjomNI2
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgzPZbG7OvUkh35nXDd4AaABAg. 9hJOZEEZa6p9hJqLC7El-w
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgwUcEpm8u6ZW3uOHXx4AaABAg. 9hIlxxGY7t49hJsB2PWxC4
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgyvDj6NWT1Gxyy2JyR4AaABAg. 9hIKlNPeqDn9hJskm92np6
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=Ugwy7qx_kG9iUmMVO_F4AaABAg. 9hI2IGUdmTW9hJuyaQawqx
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgxesLhWNr_zNP0GUdh4AaABAg. 9hI1CQJMLLo9hJwTB9Jlob
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg. 9h740K6COOA9iHOYYpaAbC
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgxuL6YCUckeUIh9hoh4AaABAg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwGTEyefOX7msIh1wZ4AaABAg. 9h4sd6Vs4qE9h7G-bVm8_-
    Try this UDF.
    Function KCONCAT(ByRef ConcatRange, Optional ByVal blnUnique As Boolean = False, _
                                    Optional ByVal Delim As String = ",") As String
        ' Function by Krishnakumar @ ExcelFox.com
        ' ConcatRange   : Could be either a Range or array
        ' Delim         : By default the delimiter is ","
        ' blnUnique     : If it's TRUE, return only unique values
        ' Limitation    : Works only single row/column or single dimension array
        Dim UpperDimension As Long, i As Long, x
        If TypeOf ConcatRange Is Range Then
            If (ConcatRange.Rows.Count > 1) * (ConcatRange.Columns.Count = 1) Then
                KCONCAT = Join$(Application.Transpose(ConcatRange.Value), Delim)
            ElseIf (ConcatRange.Rows.Count = 1) * (ConcatRange.Columns.Count > 1) Then
                KCONCAT = Join$(Application.Transpose(Application.Transpose(ConcatRange.Value)), Delim)
            ElseIf (ConcatRange.Rows.Count > 1) * (ConcatRange.Columns.Count > 1) Then
                KCONCAT = CVErr(xlErrNA)
        ElseIf IsArray(ConcatRange) Then
            UpperDimension = UBound(ConcatRange, 2)
            If UpperDimension = 0 Then
                KCONCAT = Join$(Application.Transpose(Application.Transpose(ConcatRange)), Delim)
                KCONCAT = Join$(Application.Transpose(ConcatRange), Delim)
            KCONCAT = Replace(Replace(KCONCAT, Delim & "False", ""), "False" & Delim, "")
        If blnUnique Then
            With CreateObject("scripting.dictionary")
                .comparemode = 1
                x = Split(KCONCAT, Delim)
                For i = 0 To UBound(x)
                    .Item(x(i)) = Empty
                If .Count Then KCONCAT = Join$(.keys, Delim)
    and try
    in E2 and copied down,
    =KCONCAT(IF($B$2:$B$11=B2,$A$2:$A$11),,", ")
    It's an array formula. Conformed with CTRL + SHIFT + ENTER
    Quote Originally Posted by mcpizzle View Post
    You can use the UDF (user defined function) that I posted here to do that...
    LookUp Value and Concatenate All Found Results
    HOW TO INSTALL UDFs
    If you are new to UDFs, they are easy to install and use. To install it, simply press ALT+F11 to go into the VB editor and, once there, click Insert/Module on its menu bar, then copy/paste the code from the above linked article into the code window that just opened up. That's it.... you are done. You can now use LookUpConcat just like it was a built-in Excel function. For the question you asked, put this formula in E2 and copy it down to E11...
    =LookUpConcat(B2,B$2:B$11,A$2:A$11,", ")
    There are a couple of other optional parameters available for this function which do not appear to be needed for the question you asked, but you should read the above linked article to see what they are in case things change for your situation.
    Aug 2012
    Brilliant. My first UDF. I grokked the code of Rick's a bit more than Admin's, so I started there, and it worked like a charm.
  1. Replies: 7
    Last Post: 05-15-2013, 02:56 PM
  2. Loop to two columns and Concatenate values
    By ivandgreat in forum Excel Help
    Last Post: 04-14-2013, 08:20 PM
  3. Function to Concatenate Values
    Last Post: 12-13-2012, 11:38 AM
  4. Concatenate Multiple Lookup Values in Single Cell
    Last Post: 04-06-2012, 09:07 PM
  5. Pass Values Between Multiple Userforms
    Last Post: 07-24-2011, 03:25 AM
