Results 1 to 5 of 5
Thread: Calling another macro in same workbook
    Aug 2011
    Hi I have two following macros in one wrokbook:
    1- FormatSheet
    2- DeleteData
    I wants to trigger DeleteData macro while running FormatSheet macro when in Sheet2 J4 cell value is 0. So it woukd be somthing like this:
    run DeleteData if Sheet 2 cell value =0 , if not continue with FormatSheet macro
    Rajesh
    Quote Originally Posted by Rajesh Kr Joshi View Post
    1- FormatSheet
    2- DeleteData
    It would probably help if we could see your FormatSheet macro (probably seeing the DeleteData macro would be helpful as well) and indicate where in the FormatSheet macro you think you want to run the DeleteData macro at. Posting a copy of your workbook with the macro installed in it would be even better.
    I second Rick on that one. Keeps any assumptions out of the window, thus increasing the chances of a more accurate solution.
    From what I gather, is this what you are looking for
    If Worksheets("Sheet2").Range("J4").Value = 0 Then
    Call DeleteData
    Call DeleteData
    The reason I hesitated in giving the OP an answer is I'm kind of sensing there is a loop iterating in FormatSheet and I wasn't sure if the If..Then you showed should be wrapped around the loop or embedded within it, hence my desire for more information.
    Aug 2011
    Thanks Rick and Admin
    This code helped.
    Rajesh
  1. Replies: 4
    Last Post: 07-02-2013, 11:32 AM
  2. Open And Activate Workbook Before Runing Macro
    Last Post: 06-04-2013, 07:23 PM
  3. Replies: 0
    Last Post: 04-20-2013, 10:07 AM
  4. How To Save Macro To Personal Workbook
    By NITIN SHETTY in forum Excel Help
    Last Post: 04-07-2013, 01:07 PM
  5. Selecting workbook to run macro
    Last Post: 08-24-2012, 08:21 PM
