Results 1 to 6 of 6
Thread: Delete worksheets without loop
    Found an interesting challenge here
    Challenge is, delete all worksheets except one. I guess the one sheet would be the first one. Even if it's not the first one we can move to first.
    Here is my attempt.
    Sub kTest()
        Dim i   As Long, a
        i = Worksheets.Count
        a = Application.Transpose(Evaluate("Row(2:" & i & ")"))
        Worksheets(a).Select
        Application.DisplayAlerts = 0
        Worksheets(a).Delete
        Application.DisplayAlerts = 1
    You can reduce all that down to 3 lines of code...
    Sub DeleteAllButSheet1()
      Worksheets(Application.Transpose(Evaluate("Row(2:" & Worksheets.Count & ")"))).Delete
      Application.DisplayAlerts = True
    If this code will always run alone, that is, it will not be called from within another VB code procedure, then you can reduce the macro down to 2 lines of code...
    as always
    My only suggestion would be to use Sheets instead of WorkSheets
    Sheets(Application.Transpose(Evaluate("Row(2:" & Sheets.Count & ")"))).Delete
    And a good suggestion it is!
    Here is my attempt.
    Sub kTest()
        Dim i   As Long, a
    And my suggestions are:
    - If you use Evaluate, you can bring 'transpose' within the evaluate function.
    - If you use column there's no need to 'transpose'
    - if you use a named range you can use the abbreviated writing style of evaluate:
    Instead of 'Select' you can use 'Delete'
    Sub M_snb()
       Names.Add "snb_001", Columns(1).Resize(, sheets.Count - 1)
       Sheets([column(snb_001)]).Select
       Sheets(Evaluate("Column(offset(A1,,,," & sheets.Count - 1 & "))")).Select
       Sheets(Evaluate("transpose(Row(1:" & sheets.Count - 1 & "))")).Select
  1. Loop to two columns and Concatenate values
    By ivandgreat in forum Excel Help
    Last Post: 04-14-2013, 08:20 PM
  2. Loop Through And Delete Multiple File Types In A Folder
    Last Post: 03-30-2013, 04:47 PM
  3. Loop through a folder and find word
    By k0st4din in forum Excel Help
    Last Post: 12-08-2012, 02:22 PM
  4. Speed up Loop VBA
    By PcMax in forum Excel Help
    Last Post: 04-09-2012, 04:20 PM
  5. Loop in Array
    By stanleydgromjr in forum Excel Help
    Last Post: 07-28-2011, 05:06 PM
