Results 1 to 5 of 5
Thread: SUMIF With Multiple Criteria In The Same Column Criteria Range
    Apr 2012
    I have the following formula in Col C
    =SUMIFS(C$275:C$379,$A275:$A$379,{"Idle Time","Oil stock *"})
    The criteria "Idle Time" & "Oil stock losses" are in Col A.
    I would like to add the values in Col C based on "Idle Time" & "Oil stock losses" which are in Col A
    The formula =SUMIFS(C$275:C$379,$A275:$A$379,{"Idle Time","Oil stock *"}) adds the idle time value correctly, but ignore the values of Oil Stock losses
    It would be appreciated if someone could assist me
    =SUMPRODUCT(((A1:A2="Idle Time")+(Left(A1:A2,10)="Oil stock "))*B1:B2)
    Apr 2012
    Thanks for the help, much appreciated
    You could also try
    =SUMPRODUCT(--(ISNUMBER(SEARCH({"Idle Time","Oil Stock"},A2:A15)))*C2:C15)
    Apr 2012
  1. Replies: 7
    Last Post: 05-15-2013, 02:56 PM
  2. Replies: 7
    Last Post: 05-15-2013, 07:55 AM
  3. Replies: 5
    Last Post: 04-07-2013, 05:11 PM
  4. SUMIFS multiple criteria from same column
    Last Post: 06-30-2012, 01:56 PM
  5. SUM Value With Multiple Criteria In Same Column
    By MarkJohn in forum Excel Help
    Last Post: 05-18-2012, 07:52 AM
