Results 1 to 10 of 10
Thread: How to Extracting dates and days between 2 dates.
    Aug 2011
    Hi Rick,
    This code is working fine, excpet if I delete the dates in B3 or C3 (this is required to input fresh dates). Its give me run time 1004, Application defined or object defined error and highlights .Offset(1).AutoFill Destination:=.Offset(1).Resize(, NumberOfDays), Type:=xlFillDefault line.
    Rajesh
    Quote Originally Posted by Rajesh Kr Joshi View Post
    Hi Rick,
    I'm confused. The code I posted is a macro which means it does not run unless you deliberately run it. Why would you run it if you do not have a date in both B3 and C3? Given the purpose of the code, what output would you expect from it if you don't have two dates in those cells?
    Aug 2011
    Hi Rick,
    Thanks, I got the point, i will add button to run it.
    Rajesh
    Aug 2011
    Hi Rick,
    Rajesh
    Jut one thing, is it possible to shift and date plotter to sheet2? I mean insted of C9 , Target is sheet2 C9.
    I think this code will do what you want...
    Sub FillInStartEndDates()
      Dim BeginDate As Date, StopDate As Date, NumberOfDays As Long, WS1 As Worksheet, WS2 As Worksheet
      Const StartDateCell As String = "C9"
      Set WS1 = Worksheets("Sheet1")
      Set WS2 = Worksheets("Sheet2")
      BeginDate = WS1.Range("B3").Value
      StopDate = WS1.Range("C3").Value
      NumberOfDays = StopDate - BeginDate + 1
      WS2.Range(StartDateCell).Resize(2).EntireRow.Clear
      With WS2.Range(StartDateCell)
        .Offset(1).Value = BeginDate
        .Offset(1).NumberFormat = "d-mmm"
        With WS2.Range(StartDateCell).Resize(, NumberOfDays)
          .Interior.Color = 10147522
          .Offset(1).Interior.Color = 15261110
          .FormulaR1C1 = "=TEXT(R[1]C,""ddd"")"
          .Resize(2).HorizontalAlignment = xlCenter
    Note that the code has variables for the source sheet (WS1) and the target sheet (WS2) which are set to Sheet1 and Sheet2 now, but can be changed if need be in the future.
    Aug 2011
    Thanks Rick, as usual Perfect ..Working fine
  1. List of Dates In DropDown Starting From Today()
    Last Post: 04-10-2013, 05:58 PM
    Last Post: 02-23-2013, 09:18 PM
  3. Formula to Display Month and Dates Using Spin Button
    Last Post: 11-21-2012, 10:19 PM
  5. Visual Plotter basis given dates and activity
    Last Post: 03-07-2012, 02:37 PM
