Thread: Adding values less than zero
    Apr 2012
    I would like to add values in col J than are less than zero where the ref in Col D is "GEN"
    Your assistance in this regard is most appreciated
    Give this formula a try...
    =SUMPRODUCT((D2: D13="GEN")*(J2:J13<0)*J2:J13)
    Change the ranges as needed, but make sure each range spans the same number of cells.
    EDIT NOTE: Remove the space between the colon and D13... without it, the "colon D" gets replaced with a smiley emoticon.
    You could also try SUMIFS
    =SUMIFS(J2:J13,D2: D13,"GEN",J2:J13,"<0")
    Apr 2012
    Thanks for the help, much appreciated
  1. Replies: 2
    Last Post: 06-08-2013, 09:32 PM
  2. Vlookup Multiple Values By Adding Formula With Loop In VBA
    Last Post: 04-22-2013, 04:49 PM
  3. Adding charts via code to a protected sheet
    Last Post: 11-14-2012, 05:11 PM
  4. Adding Scroll bar to image box in vba
    Last Post: 12-13-2011, 09:47 PM
  5. Adding A Menu Bar To A User Form
    Last Post: 05-05-2011, 04:05 AM
