Results 1 to 8 of 8
Thread: Highlight Sequential Cells That Sum Up To A Value
    Aug 2011
    Hi Firend,
    I need macro which has to highlight cells in the particular column up to the extent of the given value.
    The excel sheet has around the 30-50 K rows many columns with value.
    If I want to pick up the value cell which is equal to 10 laksh then it should highlight the cells which total comes to 10 lakhs.
    In case sum of the cells not come exactly to 10 laksh then it should show very near to 10 lakhs.
    I have attached the sample date for your reference.
    Plz do the needful.
    Prabhu.
    Why don't you try conditional formatting....
    =SUM($K$2:$K2)<$L$1 dragged down till the last row
    See attachment
    Aug 2011
    See attachment
    Hi Admin,
    This formula is considering from first cell till near by value.If the value is exceed the value then it shows as false.
    Attached workbooks shows by applying this formula we can get the value of Rs.929383 but if we find manually we can get exact value of 10 L(Highlighted in Green).
    So we need to check entire cells in the particular column and find out very near by value.
    Is there any way to do so(By formula or Macro)?
    Plz help.
    Sub snb()
        j = 1
        Do Until Application.Sum(Cells(2, 11).Resize(j)) >= Cells(1, 12).Value
            j = j + 1
        Loop
        Cells(2, 13).Resize(j - 1).Interior.ColorIndex = 4
    Aug 2011
    Sub snb()
        j = 1
            j = j + 1
        Loop
    Same result am getting.
    It is not hithlighting very near to 10 L.
    Plz fidn the attached working which i have highlighted the cells(Manualy) which is very near to 10 L.
    Kindly do the needful.
    Prabhu
    You must be kidding; it does exactly what you were asking for.
    I fear you have no idea what the code is doing
    You can easily adapt it to:
    Sub snb()
      j = 1
        j = j + 1
      Loop
      Cells(j, 11).Interior.ColorIndex = 4
    Why don't you try =SUM($K$2:$K2)<=$L$1 instead?
  1. Highlight Current Row in Excel (VBA)
    Last Post: 07-31-2013, 06:46 AM
  2. Replies: 13
  3. Replies: 3
    Last Post: 05-23-2013, 11:17 PM
  4. Highlight Active Cell’s Row and Column
    Last Post: 03-19-2013, 03:35 PM
