Thread: VBA Code Works Only in debug Mode.
    Nov 2011
    Hi All,
    Today I came across a very intresting problem ie I wrote a line of code for sorting my data on the worksheet but line of code is not working Automatically.It is working only when i debug the same line. I dont know what is going on and why it is happening.
    My Line of code is :
    ThisWorkbook.Worksheets("TempCoverage").Range("A1").CurrentRegion.Sort Range("A2"), xlAscending, , , , , , xlYes
    Thanks.
    I think your problem is revolving around your worksheet references... your sort range is referencing your TempCoverage worksheet whereas your Key1 argument is referencing the active sheet... if those two worksheets are the same, then the code works fine, but if the active sheet is not TempCoverage, then Excel generates an error (if you don't see an error message, it might be hidden behind an On Error trap... you didn't post enough code for us to know for sure or not). Try changing your posted line of code to this and I think it should work fine afterwards....
    ThisWorkbook.Worksheets("TempCoverage").Range("A1").CurrentRegion.Sort ThisWorkbook.Worksheets("TempCoverage").Range("A2"), xlAscending, , , , , , xlYes
    Although if you have other code that needs to reference the same worksheet within your procedure, it might be better to wrap everything using a With/End With block...
    With ThisWorkbook.Worksheets("TempCoverage")
      .Range("A1").CurrentRegion.Sort .Range("A2"), xlAscending, , , , , , xlYes
    '  other code needing to reference the same worksheet (note the leading dot in case With/End With is new to you)
    EDIT NOTE
    By the way, I am guessing your code worked in debug mode because you went to the TempCoverage worksheet "to see what was wrong" thus making it the active worksheet.
    Can i know more about VBA code?
  1. Combobox Not Working In Excel Workbook Shared Mode
    Last Post: 06-03-2013, 01:25 PM
  2. Changing Slideshow viewing mode to kiosk using vba
    By Times in forum Powerpoint Help
    Last Post: 05-10-2013, 12:37 AM
  3. VBA Code to extract subtotals
    Last Post: 12-02-2012, 01:15 PM
  4. VBA Code to Extract data
    Last Post: 07-24-2012, 11:37 PM
  5. VBA Code to Clear the Immediate Window.
    By technicalupload in forum Excel and VBA Tips and Tricks
    Last Post: 09-02-2011, 03:04 PM
