Results 1 to 9 of 9
Thread: VB code to Run formula untill blank cell
Rajesh Kr Joshi VB code to Run formula untill... 05-15-2012, 09:57 PM
Rick Rothstein I am not sure how your... 05-16-2012, 12:00 AM
swinnersmusic solution to....filling across... 05-16-2012, 02:44 AM
Rajesh Kr Joshi Hi, Thanks, This code is... 05-16-2012, 03:09 PM
swinnersmusic Rajest: also experiment with... 05-16-2012, 06:46 PM
Rick Rothstein Okay, now I think I see what... 05-16-2012, 07:01 PM
swinnersmusic Rajest, try changing the code... 05-16-2012, 06:40 PM
Rajan_Verma You can also try Autofill ... 05-18-2012, 03:16 PM
littleiitin I think this will serve your... 05-20-2012, 11:08 AM
    Aug 2011
    I would lke to drag a formula in row D27 towards right. It should stop once there is a blank cell.
    Rajesh
    I am not sure how your subject title relates to your actual request (your request deals with formulas, not VB code), but see if this answers your question...
    It doesn't matter whether you drag down or to the right, the standard way to stop outputting visible results is to test the critical formula's cell for being empty and then output the empty string if it is. For example, let's say your formula in A2 was this...
    ="Value: "&A1
    Obviously, as you drag it across, you will output just "Value: " when you run out of data in Row 1. If you modify the formula to this (testing the critical cell for being empty), you will only output something if there is a value in the corresponding Row 1 cell...
    =IF(A1="","","Value: "&A1)
    The general principle is this... see if a cell is blank and, if it is, output the empty string instead of the calculation.
    Junior Member swinnersmusic's Avatar
    May 2012
    Cool solution to....filling across columns using VBA until blank cell is found
    Quote Originally Posted by Rajesh Kr Joshi View Post
    Rajesh
    Hello Rajesh:
    Step one:.....add a new module in the VBA environment
    Step two.....paste in the subroutine below which will be effectively a macro called "fillacross"
    Sub fillacross()
    Dim myrow, mycol As Integer
    mycol = 4 'the D Column
    myrow = 27 'the 27th row
        Do Until Cells(myrow, mycol + 1).Value = "" 'looping aross the columns until blank cell
            'The next code is to copy across the column on the same row
                Cells(myrow, mycol + 1).Value = Cells(myrow, mycol).Value
                mycol = mycol + 1
        Loop
    Step three put some different data in cells D27, E27, F27, G27 .....up to wherever you like but not too far across ...see below
    Step four run the macro called "Fillacross"
    Note:
    This works...I have tested it.
    BUT
    You need an error trapping routine if it all goes wrong and reaches the column limitation of 256 Columns.
    I have a routine for this if you would find it useful
    This macro takes the value of the Cell D27 and overwrites all data in the 27th row from the D column onwards with this until a blank cell is reached
    Aug 2011
    Thanks, This code is copying the value of D27, not the formula. I wants to copy the formula. And also is there a way to include the formula i wants to copy, in the VB code itself.
    Rajesh
    May 2012
    Rajest:
    also experiment with recording a macro.
    here is one that has captured entering a formula and filling it across:
    Sub enterformula()
    ' enterformula Macro
        Range("D6").Select
        ActiveCell.FormulaR1C1 = "4"
        Range("E6").Select
        ActiveCell.FormulaR1C1 = "=100*RC[-1]"
        Range("E6").Select
        Selection.AutoFill Destination:=Range("E6:L6"), Type:=xlFillDefault
        Range("E6:L6").Select
        Range("F9").Select
    regards
    Okay, now I think I see what you want. If I am right, then you can do it using this single line of code...
    Range(Range("D27"), Range("D27").End(xlToRight)).Formula = Range("D27").Formula
    More generally, where the cell reference could change, this macro...
    Sub ExtendFormulaToRight()
      Dim StartCell As Range
      Set StartCell = Range("D27")
      Range(StartCell, StartCell.End(xlToRight)).Formula = StartCell.Formula
    Where I assume you might change the starting cell for your extending the formula to the right... just change the Set code line as needed.
    Last edited by Rick Rothstein; 05-16-2012 at 07:10 PM. Reason: Corrected code to move toward the right to find the blank cell
    May 2012
    Rajest, try changing the code from:
    Do Until Cells(myrow, mycol + 1).value
    to
    Do Until Cells(myrow, mycol + 1).Formula
    Member Rajan_Verma's Avatar
    Sub FillDown()
        Dim rngRange As Range
        Set rngRange = Range("A1:A5")
        rngRange.Cells(1, 1).AutoFill Destination:=rngRange, Type:=xlFillValues
    Rajan verma
    Member littleiitin's Avatar
    Aug 2011
    I think this will serve your purpose.
    Sub FillFormula()
        Dim rngFillRange    As Range
        'Assuming Data is in column A and formula you want in column B
        'Making Dynamic range for filling the data
        'Let say Your first Formula exists in B1 then
        Set rngFillRange = Range("B1:B" & Range("A" & Rows.Count).End(xlUp).Row)
        rngFillRange.FillDown
    HTH
  1. Replies: 13
  2. Removing unused Cell styles - need an efficient code
    By siddharthsindhwani in forum Excel Help
    Last Post: 04-15-2013, 07:12 AM
  3. Autofill the data based on non blank cell in next row?
    Last Post: 11-29-2012, 04:16 PM
  4. Replies: 2
    Last Post: 09-24-2012, 11:19 PM
    Last Post: 04-24-2012, 09:55 PM
