Thread: 2007 PPT Chart Data is not Reflecting In Chart
    Member littleiitin's Avatar
    Aug 2011
    I am Updating 2007 PPT Charts Data using Code in excel. Data files are kept in Separate Excel files.
    Picking excel and updating chart. Data is in Charts Excel Sheet, However new Row or column is not reflecting in Chart.
    Even Using Below Code I am Increasing the Size of Data Range, It is still not reflecting in chart. This Code I am using directly in PPT.
    If I am doing Samething manually it starts Reflecting.
    I am not able to use the setsourcedata Method too.
    Sub Refresh()
        Dim chtObj      As Chart
        Dim wbkCht      As Object
        Dim wksCht      As Object
        Dim objPres     As Object
        Dim objSld      As Object
        Dim objShp      As Object
        Set objPres = ActivePresentation
        With objPres
            For Each objSld In .Slides
                For Each objShp In objSld.Shapes
                    If objShp.Type = msoChart Then
                        Set chtObj = objShp.Chart
                        With objShp.Chart.ChartData
                            .Activate
                            .Workbook.Application.WindowState = -4140
                            Set wbkCht = .Workbook
                            Set wksCht = .Workbook.worksheets(1)
                            'objShp.Chart.SetSourceData wksCht.Range("A1").CurrentRegion                        wksCht.ListObjects("Table1").Resize wksCht.Range("A1").CurrentRegion.Resize(wksCht.Range("A1").CurrentRegion.Rows.Count - 1, wksCht.Range("A1").CurrentRegion.Columns.Count - 1)
    Thanks In advance
    Rahul Kumar Singh
    Is your chart linked to any external data, or is it having it's own source within the data sheet in its own workbook source?
    Aug 2011
    No Charts are not linked , these are normal 2007 Charts and I am Updating the data in data sheet of Chart using external file.
  1. Replies: 1
    Last Post: 11-30-2012, 09:23 AM
  2. Excel Chart Showing Values on Angle: Nightingale Chart
    Last Post: 10-17-2012, 06:39 PM
  3. Replies: 1
    Last Post: 05-20-2012, 12:23 PM
  4. Replies: 3
    Last Post: 05-14-2012, 11:30 AM
  5. Get Chart's Source Data VBA
    Last Post: 11-24-2011, 07:54 AM
