Results 1 to 7 of 7
Thread: Count consecutive value in a range using formula
    Hi All,
    I have some values in a range in which according to criteria i need to count the continuous occurence of this value.
    For ex.:-
    A B A B A A A B
    and the answer is 3 (A A A) continuous occuring.
    Thanks in Advance
    https://eileenslounge.com/viewtopic.php?p=279659#p279659
    https://eileenslounge.com/viewtopic.php?p=279062#p279062
    https://eileenslounge.com/viewtopic.php?p=278940#p278940
    https://eileenslounge.com/viewtopic.php?p=276866#p276866
    https://eileenslounge.com/viewtopic.php?p=276795#p276795
    https://eileenslounge.com/viewtopic.php?p=276983#p276983
    https://eileenslounge.com/viewtopic.php?p=277027#p277027
    https://eileenslounge.com/viewtopic.php?p=277526#p277526
    https://eileenslounge.com/viewtopic.php?p=277523#p277523
    https://eileenslounge.com/viewtopic.php?p=277877#p277877
    https://eileenslounge.com/viewtopic.php?p=278470#p278470
    https://eileenslounge.com/viewtopic.php?p=275430#p275430
    https://eileenslounge.com/viewtopic.php?p=275972#p275972
    https://eileenslounge.com/viewtopic.php?p=276066#p276066
    https://eileenslounge.com/viewtopic.php?p=276065#p276065
    https://eileenslounge.com/viewtopic.php?f=27&t=35521&p=276185#p276185
    https://eileenslounge.com/viewtopic.php?p=276185#p276185
    https://eileenslounge.com/viewtopic.php?p=276673#p276673
    https://eileenslounge.com/viewtopic.php?p=276751#p276751
    https://eileenslounge.com/viewtopic.php?p=276754#p276754
    https://eileenslounge.com/viewtopic.php?f=30&t=35100&p=274367#p274367
    https://eileenslounge.com/viewtopic.php?p=274368#p274368
    https://eileenslounge.com/viewtopic.php?p=274370#p274370
    https://eileenslounge.com/viewtopic.php?p=274578#p274578
    https://eileenslounge.com/viewtopic.php?p=274577#p274577
    https://eileenslounge.com/viewtopic.php?p=274474#p274474
    https://eileenslounge.com/viewtopic.php?p=274579#p274579
    You mean the maximum continuous occurrence of a given value? Or should the character that is repeating the most continuously should be displayed along with the maximum number?
    Yes i mean the maximum continuous occurrence of a value based on criteria.
    For Ex. :-
    A A B A A A A B B C
    In above data range
    if the criteria is "A" then the answer will be 4
    if the criteria is "B" then the answer will be 2
    if the criteria is "C" then the answer will be 1
    Try this array formula
    =MAX(FREQUENCY(IF(A1:H1=J1,COLUMN(A1:H1)),IF(A1:H1 <>J1,COLUMN(A1:H1))))
    Where J1 houses A
    HTH
    Thanks Admin for your quick response.
    This is exactly what i was lookin for.
    Where J1 houses A
    HTH
    Nov 2012
    Tried the same formula but it didn't work!
    Where J1 houses A
    HTH
    Hello,
    I tired the same formula but it I got a #VALUE!
    Hi Al@ICP,
    Welcome to ExcelFox !!
    It's an array formula. So confiirmed with CTRL+SHIFT+ENTER
  1. Count Colored Cells Using Excel Formula
    Last Post: 06-15-2013, 11:37 AM
  2. Replies: 1
    Last Post: 12-04-2012, 05:30 PM
  3. counting consecutive values in an array
    By 5ko in forum Excel Help
    Last Post: 12-04-2012, 03:49 AM
  4. Replies: 3
    Last Post: 04-08-2012, 09:44 AM
  5. Unique Count on a Filtered Range
    Last Post: 08-14-2011, 04:29 AM
