Below is an example of code I use to find values - if a value exists more than once - then you have to loop - just be carefull as it will continue to loop back to where you started. My code below looks in a configuration sheet - then reads the value of that variable - two columns over - so modify the code to suit. But if you Google Foundcell - you will see lots of examples.
https://www.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHACode:Astr = ValueToFind RangeVal = "A1:" & Split(Cells(1, ColLast).Address, "$")(1) & LastRow With .Range(RangeVal) Set LastCell = .Cells(.Cells.Count) End With Set FoundCell = .Range(RangeVal).Find(What:=(Astr), after:=LastCell) If FoundCell Is Nothing Then Astr = ValueToFind Call Message106(Astr) Else ColDefault = FoundCell.Column + 2 RowDefault = FoundCell.Row ReadValue = .Cells(FoundCell.Row, FoundCell.Column + 2) End If
