Results 1 to 10 of 14
Thread: Convert Series into Range.
    Member ayazgreat's Avatar
    Mar 2012
    Dear Krishnakumar
    I require your help here again regarding to mentioned below link
    Convert different series into its Start and End Range - Page 3 - MrExcel Message Board
    Thanks in Advance
    Hi Ayaz,
    Welcome to ExcelFox !!
    try
    Sub kTest()
        Dim ka, k(), i As Long, n As Long, c As Long
        ka = Range("a1").CurrentRegion.Resize(, 2)
        ReDim k(1 To UBound(ka, 1), 1 To 3)
        For i = 2 To UBound(ka, 1)
            If i = 2 Then
                n = n + 1: c = c + 1
                k(n, 1) = ka(i, 1)
                k(n, 2) = ka(i, 1)
                k(n, 3) = c
                If ka(i, 2) - ka(i - 1, 2) = 1 Then
                    c = c + 1
                    k(n, 2) = ka(i, 1)
                    k(n, 3) = c
                    n = n + 1: c = 1
                    k(n, 1) = ka(i, 1)
                    k(n, 2) = ka(i, 1)
                    k(n, 3) = c
        If n Then
            Range("d1:f1") = Array("Start", "End", "Qty Count")
            Range("d2").Resize(n, 3) = k
    Mar 2012
    Thank you very much for your reply, I have just tried your code and found an issue regarding to a single number if a series has only one number with MB number then code does not convert it into range.
    And one thqing more is that if you please once again see my mentioned link result it is from col d to col j in last updated post.
    Upload a sample workbook with actual layout.
    Mar 2012
    I am not able attach Excel file here from mobile but I am attaching a pic view if you could see
    Try
    Sub kTest()
        ReDim k(1 To UBound(ka, 1), 1 To 7)
            If i = 2 Then
                k(n, 1) = ka(i, 1): k(n, 2) = ka(i, 1): k(n, 3) = c
                k(n, 5) = ka(i, 2): k(n, 6) = ka(i, 2): k(n, 7) = c
                    c = c + 1: k(n, 2) = ka(i, 1): k(n, 3) = c
                    n = n + 1: c = 1
        If n Then
            Range("d1:j1") = Array("Start", "End", "Qty Count", "", "MCP Start", "MCP End", "MCP Count")
            Range("d2").Resize(n, 7) = k
    Mar 2012
    Kris there is a problem with a single number in seruies if you see in attached pic there is single 30735609 with MB number 9002 , after running. Code the Qty or count result is 3 , however it is should be 1
    I got the same results what you shown in the picture. So what's no working for you ?
    Mar 2012
    Kris I mean to say if I say there are different numbers in series with their MB number in col b if there is a single number in series like 307392589 then result should be 307392589 to 307392589 equal 1 in Qty or count col but result in your code is equal to 3 not 1
    I'm not getting you. Can you upload a workbook with expected results ?
  1. Replies: 4
    Last Post: 06-10-2013, 01:27 PM
  2. Subtraction Of Series Of Cells' / Array Values
    By PcMax in forum Excel Help
    Last Post: 10-26-2012, 11:55 PM
  3. Graphing a bell curve from an Excel data series
    By larryt1940 in forum Excel Help
    Last Post: 01-24-2012, 06:08 AM
  4. Color Chart Series VBA
    Last Post: 04-29-2011, 11:26 PM
  5. Replies: 4
    Last Post: 04-07-2011, 07:09 AM
