Results 1 to 9 of 9
Thread: Reverse Vlookup Using Choose Function
    Rick, I was only trying to emphasize that you can reverse the position of a columns in a lookup array by passing the index also as an array. The idea is that VLOOKUP can be used to lookup at a column that is on the right side of the column from which we expect the output.
    Okay, I can see what you are saying, but doesn't presenting the table array produced by the CHOOSE function in normal order do the same thing? Note that we both used 2 as the lookup column even though (supposedly) your table array is the reverse of mine. I think Excel may be "straightening out" (reordering) the table array it presents to VLOOKUP behind the scenes, similar to what happnes if you enter a range backward in a formula, for example, enter =SUM(B1:A10) and Excel will straighten that reference out so that it reads A1:B10. Of course that is just speculation on my part as formulas are not my main strength in Excel (I'd like to think VBA coding is).
  1. Replies: 2
    Last Post: 04-16-2013, 01:36 PM
  2. Reverse name in excel with upper case,edit formula
    By shrinivasmj in forum Excel Help
    Last Post: 09-11-2012, 01:31 PM
  3. Choose from several sheets
    Last Post: 08-29-2012, 02:46 AM
  4. Replies: 4
    Last Post: 08-14-2012, 03:17 AM
  5. How to Get Comment by Vlookup Function :
    Last Post: 10-13-2011, 05:55 PM
