Hello,
This is really a great script.
Tis is helping me out. what a power to get things arranged.
I have one question.
Do you think it is possible to have in the default example (The XLSM file)
To Add a column that contains a value V (Vertical) the output is paste in a new workbook Vertical (Transpose)
So that I in the ControlSheet can select the column that contains the past direction.
And a second one that contains the value that is in the column for the past direction. If it is True, it will be passed in the new Workbook but then transponse.
