Results 1 to 8 of 8
Thread: Fetch Data from multiple sheets based on criteria VBA
    May 2011
    Hello Excelfox community,
    No I again need a help in Excel.
    There are 7 sheets in my workbook. Sheet1 to Sheet6 contains data. 7th sheet is called "Find".
    I have placed a text box field in 'Find' sheet, which allowed multiline with enterkeybehaviour. So user can enter multiple lines. What I am trying to do is,
    There is a combo box which contains only 2 items, "Purchase", "Sales".
    If user select "Purchase" need to SEARCH the entries entered in text box (multiline) in Sheet3 & Sheet4 column_F, If user enter 10 lines, needs to look for these 10 items. If found anything, then copy all the found rows data (Sheet3!A:G, Sheet4!A:G) in the find sheet. If possible to SORT by column B. Sound like "Merge found records from two sheets in to a single sheet"
    Also if possible enter a sheet name where these records found in the last column in 'Find' sheet. eg: in Col_H if ThisRow item found in Shee3, label as Sheet3, if from Sheet4 label as Sheet4
    If user select "Sales" need to SEARCH the entries entered in text box (multiline) only in Sheet4 column_F, If found anything, then copy all the found rows data (A:L) in the find sheet. If possible to SORT by column B
    In Sheet3, 4 & 5 data starts from Row 7 to down. So needs to look it for dynamically. also in 'Find' sheet data to be placed in row 7 to down.
    I really appreciate your assistance
    Raj
    Hi Raj,
    Please find the attachment.
    May 2011
    Thank you Admin for this works great.
    Is it possible to SEARCH for text box entries, instead of it's actual values = sheets.
    eg: if i enter:
    231, xt249, text120, text
    Search for these items in column_F then copy rows to Find sheet. Same like ISNUMBER(SEARCH(txtbox.value,InSheets)) also keep the source format?
    Instead of Private Sub ComboBox1_Change(), possible to make it as SUB for a button. So users can select the sheets, enter textbox entries then can click on the button.
    Thanks ton again for your help
    Hi Raj,
    Try this. Assign this macro on a button.
    Sub SearchData()
        Dim strComboSelection       As String
        Dim lngIndex    As Long, c  As Long
        Dim ShtsPuchase, ShtSales   As String
        Dim ka, k(), i As Long, n   As Long
        Dim x, j  As Long, r        As Long
        Dim m As Long, SearchKeys   As String
        ShtsPuchase = Array("Sheet3", "Sheet4") '<< adjust sheet names
        ShtSales = "Sheet5"                     '<< adjust sheet names
        SearchKeys = Worksheets("find").TextBox1.Value
        If Len(SearchKeys) Then
            SearchKeys = "{""" & Replace(Replace(SearchKeys, Chr(10), """;"""), Chr(13), vbNullString) & """}"
            With Worksheets("find").ComboBox1
                lngIndex = .ListIndex
                strComboSelection = LCase$(.List(lngIndex, 0))
            Select Case strComboSelection
                Case "purchase"
                    ReDim k(1 To 1000, 1 To 8)
                    n = 1
                    For j = LBound(ShtsPuchase) To UBound(ShtsPuchase)
                        With Worksheets(ShtsPuchase(j))
                            r = .Range("a" & .Rows.Count).End(xlUp).Row
                            ka = .Range("a7:g" & r)
                        For c = 1 To UBound(ka, 2): k(1, c) = ka(1, c): Next: k(1, c) = "Label"
                        For i = 2 To UBound(ka, 1)
                            x = False
                            x = Evaluate("isnumber(lookup(9.9999e+307,search(""" & ka(i, 6) & """," & SearchKeys & ")))")
                            If x Then
                                n = n + 1
                                    k(n, c) = ka(i, c)
                                Next: k(n, c) = ShtsPuchase(j)
                        Erase ka
                Case "sales"
                    ReDim k(1 To 1000, 1 To 12)
                    n = 1
                    With Worksheets(ShtSales)
                        ka = .Range("a7:l" & r)
                        x = False
                        If x Then
                            n = n + 1
                                k(n, c) = ka(i, c)
            If n Then
                With Worksheets("Find")
                    .Range("a7", .Cells(7, 1).SpecialCells(11)).ClearContents
                    With .Range("a7").Resize(n, UBound(k, 2))
                        .Value = k
                        .Sort .Cells(2, 2), 1, Header:=1
                        .EntireColumn.AutoFit
                MsgBox "No records found", vbInformation
    May 2011
    Thank you for this Admin.
    I am sorry, this still doesn't search like a wildcard. May be I haven't been explained clearly.
    Eg: The below are the entries in text box multiline. Combo selection "Purchase"
    text710, 313, xt116, 27, 1702
    You can see these values found in Sheet3!F21, Sheet3!F29, Sheet4!F18, Sheet3!F12 & Sheet4!F16 for the first 4 items. The last one doesn't found in two sheets. So I like to copy these rows data to Find.
    Same like Find command with CTRL+F
    Thank you for your assistance Admin.
    Replace this
    with
    x = Evaluate("isnumber(lookup(9.9999e+307,search(" & SearchKeys & ",""" & ka(i, 6) & """)))")
    May 2011
    Admin, awesome.... it works great.
    One last question.
    Some time user leave just enter key in text box, so it produce a wrong result. Is it possible to check If(LEN(TRIM(textbox1))>0 in SearchKeys
    eg: user enter 10 lines. But there may be only 8 or 9 entries. Rest of them they just hit ENTER key: no entries, So CHAR(10) is there. So TRIM the textbox & take only LEN()>1 as SearchKeys
    Thank you for your time
    Replace
    with
    x = Split(SearchKeys, Chr(10))
    SearchKeys = vbNullString
    For j = 0 To UBound(x)
        If Len(Trim$(Replace(x(j), Chr(13), vbNullString))) Then
            SearchKeys = SearchKeys & """;""" & Trim$(Replace(x(j), Chr(13), vbNullString))
    SearchKeys = "{""" & Mid$(SearchKeys, 4) & """}"
  1. Replies: 8
    Last Post: 06-08-2013, 01:24 PM
  2. Sum values based on multiple criteria
    By Jorrg1 in forum Excel Help
    Last Post: 01-07-2013, 03:04 PM
  3. Sum values based on multiple criteria
    By vmath in forum Excel Help
    Last Post: 05-07-2012, 08:53 AM
  4. Fetch multiple values based on criteria
    By Lucero in forum Excel Help
    Last Post: 04-07-2012, 12:35 PM
  5. Printing Sheets Based On Criteria VBA
    Last Post: 05-04-2011, 08:00 PM
