Results 1 to 5 of 5
Thread: Mailing a Range or Selection in the Body of an E-Mail Message - Help
    Aug 2011
    I have the below code to send a range using outlook. But while compiling it is giving error and highlighting .HTMLBody = RangetoHTML(rng)
    Please help.
    Rajesh
    Sub Mail_Selection_Range_Outlook_Body()
    ' You need to use this module with the RangetoHTML subroutine.
    ' Works in Excel 2000, Excel 2002, Excel 2003, Excel 2007, Excel 2010, Outlook 2000, Outlook 2002, Outlook 2003, Outlook 2007, and Outlook 2010.
        Dim rng As Range
        Dim OutApp As Object
        Dim OutMail As Object
        Set rng = Nothing
        ' Only send the visible cells in the selection.
        Set rng = Selection.SpecialCells(xlCellTypeVisible)
        ' You can also use a range with the following statement.
        ' Set rng = Sheets("YourSheet").Range("D4:D12").SpecialCells(xlCellTypeVisible)
        If rng Is Nothing Then
            MsgBox "The selection is not a range or the sheet is protected. " & _
                   vbNewLine & "Please correct and try again.", vbOKOnly
        With Application
            .EnableEvents = False
            .ScreenUpdating = False
        Set OutApp = CreateObject("Outlook.Application")
        Set OutMail = OutApp.CreateItem(0)
        With OutMail
            .To = "ron@debruin.nl"
            .CC = ""
            .BCC = ""
            .Subject = "This is the Subject line"
            ' In place of the following statement, you can use ".Display" to
            ' display the e-mail message.
            .Send
        With Application
            .EnableEvents = True
            .ScreenUpdating = True
        Set OutMail = Nothing
        Set OutApp = Nothing
    Hi Rajesh,
    Thanks for sharing the solution.
    Please use code tags while posting codes
    Getting an error msg "RangetoHTML" sub or function not defined. Using Excel 2010
    RangetoHTML is a Function. Get the code from the link Rajesh posted above.
  1. Replies: 12
    Last Post: 12-10-2019, 09:56 PM
  2. Copy and Past as picture/bitmap in email body form excel.
    Last Post: 12-05-2012, 09:56 PM
  3. Message Box Before Saving Document
    By Lucero in forum Excel Help
    Last Post: 04-15-2012, 07:09 AM
  4. Replies: 3
    Last Post: 04-08-2012, 08:05 AM
  5. Mail Range or Selection using VBA
    Last Post: 11-03-2011, 09:00 AM
