Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Insane Viewings of excelfox, (Tens of Thousands)
    From Middle August ( File August SummaryRequestsIPsAllsAugust2025.xlsm )
    Wednesday 20 August - Friday 22 August
    The waves came back around late Wednesday 20 August. Still Viewing User profileS
    Creeping up a bit to a bit over 8500 on the highs
    The ferocity went down a bit on Friday, as did the high peak which was typically a bit over 2000. It took a break Friday evening
    20 21 22 User Profiles
    752	member.php?u=9041/DocAElstein
    689	member.php?u=807/Rick Rothstein
    669	member.php?u=1/Excel Fox
    537	member.php?u=2722/jamilm
    528	member.php?u=422/LalitPandey87
    521	member.php?u=2/Admin
    480	member.php?u=586/sa.1985
    454	member.php?u=533/PcMax
    438	member.php?u=16893/DorianGrey2000
    432	member.php?u=940/Transformer
    380	member.php?u=11037/steve400243
    365	member.php?u=1338/snb
    341	member.php?u=1919/mrmmickle1
    334	member.php?u=324/littleiitin
    328	member.php?u=15/Rasm
    324	member.php?u=319/rajasekhar
    304	member.php?u=463/Rajan_Verma
    43.135.19.183	19
    43.157.18.35	19
    43.159.196.51	18
    43.166.141.114	18
    43.156.185.245	16
    43.132.221.245	16
    43.130.174.70	15
    43.128.11.112	15
    124.156.151.60	15
    162.62.217.118	13       Tencent cloud computing   Germany       ISP:Aceville Pte.Ltd.        Services:Data Center/Transit
    |43|157|	1383  7.4%
    |162|62|	935  5%
    |43|134|	812  4.3%
    |43|156|	800  4.3%
    |43|154|	766  4.1%
    |43|131|	687  3.7%
    |43|163|	684  3.7%
    |43|167|	633  3.4%
    |43|128|	586  3.1%
    Low 21 22Aug
    57.141.6.15	8
    57.141.6.18	8
    8.210.126.188	8
    66.249.66.71	8
    |57|141|	115  14.4%
    |47|128|	87  10.9%
    |8|210|	86  10.8%
    |114|119|	62  7.8%
    |46|250|	34  4.3%
    |101|44|	25  3.1%
    |111|119|	24  3%
    |159|138|	23  2.9%
    |66|249|	21  2.6%
    Saturday 23 August - Tuesday 26 August 2025
    It took a good rest
    ( I sent a second Email to Kris)
  2. #22
    Taking a rest Saturday 23 August - Tuesday 26 August 2025
    Low 21 22Aug
    37.27.130.11	8  Hetzner Online GmbH    Helsinki  Finland
    57.141.6.15	8 Facebook Georgia
    57.141.6.18	8
    8.210.126.188	8  Alibaba    Hong Kong
    66.249.66.71	8  Google Bot US
    |57|141|	115  14.4%
    |47|128|	87  10.9%
    |8|210|	86  10.8%
    |114|119|	62  7.8%
    |46|250|	34  4.3%
    |101|44|	25  3.1%
    |111|119|	24  3%
    |159|138|	23  2.9%
    |66|249|	21  2.6%
    It took a good rest
    Rest Sat 23 – Tu 26 Aug
    66.249.66.72	12
    114.119.146.117	11
    114.119.140.87	9
    114.119.158.94	9
    57.141.0.6	9
    57.141.6.15	9
    |57|141|	273  26.3%
    |114|119|	164  15.8%
    |47|128|	97  9.3%
    |66|249|	31  3%
    |40|77|	31  3%
    |162|128|	25  2.4%
    |124|243|	22  2.1%
    |46|250|	21  2%
  3. #23
    Tuesday 26 August 2025 – Friday 29 August 2025
    Waving to about 1000 with long rest periods
    Tuesday 26 August 2025 it work up and started waving at unknown locations, with viewing peaks at approximately 950
    Wednesday 27 August 2025 it took a good rest
    Thursday 28 August 2025 it work up and started waving at unknown locations, with wild short peaking peaks at over a thousand
    Friday 29 August 2025 slow waving, doing a lot of Viewing ….things… The highest level seems to be creeping up a bit, started at about a thousand, and I saw one at 3000
    26-28 Aug around 1000
     8.160.131.176	12    ISP:Alibaba Cloud (Singapore) Private Limited           Services:Data Center/Transit
    8.160.130.59	11
    8.160.130.134	10
    8.160.132.39	10
    8.160.132.88	10
    8.160.132.10	10
    8.160.132.71	10
    8.160.130.56	10
    8.160.130.154	9
    8.160.130.161	9
    8.160.130.190	9
    8.160.132.47	9
    8.160.129.180	9
    8.160.131.116	9
    8.160.130.163	9
    8.160.129.70	8
    8.160.128.202	8
    57.141.0.13	8
    |8|160|	2169  67.8%
    |57|141|	127  4%
    |114|119|	105  3.3%
    |47|128|	85  2.7%
    |43|157|	41  1.3%
    |162|62|	37  1.2%
    This had a few views showthread.php?t=1579/Test Whether A Point Is In A Polygon Or Not
    |8|160|131|	64
    |8|160|130|	49
    |8|160|129|	46
    |8|160|132|	30
    |8|160|128|	20
    |47|93|11|	1
    Network Part
    |8|160|	209
    |47|93|	1
    Unknown locations was busy, specially this one /forum/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthre/forum/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthread.php/showthre
    |8|160|130|	165
    |8|160|131|	144
    |8|160|129|	114
    |8|160|128|	60
    |8|160|	577
    26-28 Aug Lows
    114.119.137.224	8
    114.119.128.129	7
    114.119.130.67	7
    66.249.66.72	6
    57.141.0.16	6
    114.119.130.136	6
    |114|119|	102  25.5%
    |57|141|	76  19%
    |47|128|	58  14.5%
    |18|97|	21  5.3%
    |66|249|	17  4.3%
    Friday 29 August 2025 (Andreas Article night) – Saturday 30 August
    Getting a bit more Normal / varied in what it is looking at, only waving a bit, but peaking at approximately 2500
    29-30Aug Few thousand
    8.160.128.152
    43.153.216.70
    43.157.50.189
    129.226.81.151
    49.51.138.201
    162.62.117.64
    43.130.157.45
    8.160.130.97
    |8|160|	864  15.6%
    |43|157|	400  7.2%
    |162|62|	237  4.3%
    |43|134|	230  4.2%
    |43|131|	202  3.6%
    |43|156|	185  3.3%
    |43|167|	184  3.3%
    |43|154|	165  3%
    /forum/forum.php/Excel, Access, PowerPoint and Word VBA Macro Automation Help was high
     |162|62|117|64|	7
    |5|114|144|1|	7
    |152|59|89|97|	5
    |43|135|112|139|	5
    |162|62|226|8|	5
    |110|226|204|231|	5
    |43|133|10|134|	5
    |43|157|118|3|	5
    |43|157|	52
    |162|62|	49
    |43|131|	47
    |43|154|	38
    |43|134|	37
    |43|167|	28
    |43|166|	27
    /forum/faq.php had a lot as well
     |43|166|178|246|	5
    |43|132|247|151|	4
    |43|159|196|51|	4
    |43|132|210|118|	4
    |43|132|227|219|	4
    |148|230|199|70|	4
    |43|134|109|249|	3
    |43|132|	18
    |129|226|	13
    |162|62|	13
    |43|166|	12
    |43|154|	12
    |119|28|	12
    |43|163|	12
    29-30Aug Low
     4	"66.249.66.72	"
    3	"47.128.124.43	"
    3	"47.128.54.197	"
    3	"57.141.0.14	"
    3	"57.141.0.9	"
    3	"8.210.119.205	"
    |47|128|	40  28.6%
    |57|141|	31  22.1%
    |8|160|	12  8.6%
    |18|97|	10  7.1%
  4. #24
    Sunday 31 August – Saturday 6 September 2025
    In this period mostly low or taking a rest. There may be some short waves, even high ones, that I may have missed
    Mostly taking a break on Sunday 31 August
    Not doing so much on Monday either but sometimes waving up to about a thousand.
    Taking a rest on Tuesday and Wednesday and Thursday and Friday
    Saturday 6 September the wave peaks started getting a bit high
    Sun 31Aug-Sat 6 Sept, Some very lows
     114.119.136.175	9
    114.119.141.228	8
    114.119.132.207	7
    114.119.131.105	6
    114.119.156.154	6
    57.141.6.21	6        Meta Platforms Ireland        US     State/Region:Georgia       City:Atlanta
    |57|141|
    |114|119|
    |47|128|
    |18|97|
    https://i.postimg.cc/d0dRqwhM/57-141.jpg
    A bit of waving Sun 31Aug-Sat 6 Sept
    150.109.40.165	6
    114.119.157.103	6
    47.243.23.220	6
    124.156.209.70	5
    167.253.67.14	5
    |57|141|	100  8.6%
    |114|119|	58  5%
    |43|157|	55  4.7%
    |47|243|	38  3.3%
    Share ‘SummaryRequestsIPsAllsAugust2025.xlsm’ https://app.box.com/s/1m92xpvc5wswji3i2hjr1q83bhjqu0en
  5. #25
    Starting with September file, SummaryRequestsIPsAllsSept2025.xlsm
    ( This post has some strange untypical behaviour, and we might find later that it has something to do with some Bots lost in Unknown Locations )
    114.119.136.175	9
    114.119.141.228	8
    114.119.132.207	7
    114.119.131.105	6
    114.119.156.154	6
    |57|141|
    |114|119|
    |47|128|
    |18|97|
    150.109.40.165	6
    114.119.157.103	6
    47.243.23.220	6
    124.156.209.70	5
    167.253.67.14	5
    |57|141|	100  8.6%
    |114|119|	58  5%
    |43|157|	55  4.7%
    |47|243|	38  3.3%
    Saturday 6 September – Friday 12 September
    Erratic short peaks: Some varied occasionally high peaks then long break. We don't seem to get much under a thousand, and then a few hundred
    Sunday 7 September it was waving a bit up to a few hundred, but not much. Then Sunday evening it woke up a bit (after Andreas posted a bit)
    Monday it peaked occasionally at over a thousand, but seemed to be settling on a few hundred
    Tuesday it had some quick waves to almost 3000
    Wednesday waving slowly, up to a peak a bit over 1000, and troughs a few hundred
    Thursday a few hundred then a quick wave at 2500
    Friday Was most a few hundred, maybe sometimes around 6000, then Friday evening did a 7200er, then a 11500er!! Before settling a bit over 6000
    6-12 Sept few thousands
    An awful lot of forum stuff, especially forumdisplay.php?f=___________
     8	14.226.237.176	39
    6	103.129.68.131	28
    6	113.184.112.113	24
    6	14.187.178.56	21
    5	14.191.93.164	21
    5	177.112.41.0	21
    5	138.117.169.6	20
    5	187.180.167.116	19
    |57|141|	672  2.5%
    |14|191|	580  2.2%
    |47|242|	274  1%
    |114|119|	233  0.9%
    |47|128|	157  0.6%
    |14|187|	110  0.4%
    |123|21|	105  0.4%
    There seems to be a lot of IP addresses used?
    There is not a lot of height viewed threads, but let us take a look at a few…
    .14.187.178.56.  	5    ISP:Vietnam Posts and Telecommunications Group       Services:None detected     Viet Nam    State/Region:Ho Chi Minh    City:Ho Chi Minh City
    .222.242.249.17.	5    ISP:ChinaNet Hunan Province Network      Services:None detected       China    State/Region:Hunan    City:Yueyang
    .2.189.5.142.           5    ISP:Iran Information Technology Company PJSC     Services:Network Sharing Device     Iran (Islamic Republic of)    State/Region:Tehran     City:Tehran
    .43.153.79.218. 	4    ISP:Aceville Pte.Ltd.    Services:Data Center/Transit  US    State/Region:California   City:Santa Clara
    .115.220.137.97.	4    ISP:ChinaNet Zhejiang Province Network      Services:None detected      China     State/Region:Zhejiang        City:Hangzhou
    .113.141.194.125.	4    ISP:ChinaNet Shaanxi Province Network      Services:None detected      China     State/Region:Shaanxi     City:Xi'an
    .209.14.149.62.         4    ISP:Fibranet Brasil      Services:None detected     Brazil     State/Region:Sao Paulo    City:Sao Paulo
    .187.180.167.116.	4    ISP:Claro NXT Telecomunicacoes Ltda     Services:None detected    Brazil    State/Region:Sao Paulo City:Sorocaba
    .138.117.169.6.         4     SP:Claro NXT Telecomunicacoes Ltda     Services:None detected    Brazil    State/Region:Sao Paulo    City:Sorocaba
    . 14.226.237.176.	4    ISP:Vietnam Posts and Telecommunications Group     Services:None detected     Viet Nam    State/Region:Ho Chi Minh    City:Ho Chi Minh City
    .183.204.11.148.	4   ISP:China Mobile Communications Corporation     Services:None detected    China    State/Region:Henan    City:Zhengzhou
    |2|189|	8
    |14|187|	5
    |222|242|	5
    |43|153|	4
    |115|220|	4
    |113|141|	4
    |209|14|	4
    |187|180|	4
    |138|117|	4
    |14|226|	4
    |183|204|	4
    /forum/activity.php
    .103.129.68.131.   5   ISP:PT Cyberindo Aditama       Services:None detected     Indonesia    State/Region:Jawa Timur    City:Surabaya
    .186.244.35.84.    4    ISP:Vtal      Services:None detected    Brazil    State/Region:Rio de Janeiro    City:Rio de Janeiro
    .177.112.41.0.	  4      ISP:Telefonica Brasil S.A     Services:None detected    Brazil   State/Region:Sao Paulo   City:Sao Paulo
    .113.110.146.198.  4     ISP:ChinaNet Guangdong Province Network    Services:None detected    China    State/Region:Guangdong   City:Huizhou
    .111.25.127.82.	   4    ISP:China Mobile Communications Corporation     Services:None detected     China    State/Region:Beijing    City:Beijing
    |47|128|	9
    |103|129|	5
    |119|167|	5
    |115|238|	5
    So there is some unusual activity above, over the time of approximately 6/8 September to 12/13Sept
  6. #26
    From Wednesday 10 September until Sunday 14 September there was an insane number of Unknown Locations
    Friday 12 September - Saturday 13 September
    Some high peaking
    Saturday 13 September was mostly a bit over 6000, maybe a few peak wave a thousand or two higher, then came down to settle around 750
    Fri12-Sat13 Highs
    57.141.0.32	8
    66.249.66.73	7
    114.119.141.228	7
    57.141.0.37	7
    57.141.0.63	7
    57.141.0.75	7
    170.81.202.64	7
    14.191.102.226	      3  ISP:Vietnam Posts and Telecommunications Group     Services:None detected    Viet Nam    State/Region :Ba Ria - Vung Tau      City:Phuoc Lap
    14.191.136.232	     3  ISP:Vietnam Posts and Telecommunications Group     Services:None detected   Viet Nam    State/Region :Bac Ninh    City:Vinh Phuc
    14.191.139.34	 3    ISP:Vietnam Posts and Telecommunications Group      Services:None detected    Viet Nam   State/Region :Ba Ria - Vung Tau    City:Vung Tau
    14.191.193.56	 3   ISP:Vietnam Posts and Telecommunications Group       Services:None detected     Viet Nam     State/Region :Ba Ria - Vung Tau     City:Vung Tau
    14.191.216.220	 3      ISP:Vietnam Posts and Telecommunications Group    Services:None detected    Viet Nam    State/Region :Ho Chi Minh      City:Ho Chi Minh City
    |14|191|	705  2.9%
    |57|141|	276  1.1%
    |123|21|	137  0.6%
    |123|20|	128  0.5%
    |179|125|	124  0.5%
    |14|169|	120  0.5%
    From Wednesday 10 September until Sunday 14 September there was an insane number of Unknown Locations seen in UnknownLocations worksheet of file,
    https://i.postimg.cc/k47Cj883/Insane...-September.jpg
    , - - - Time to do a quick macro to get an ordered list of those IPs getting "lost" in Unknown Location - - -
  7. #27
  1. Attaching a File to a Thread post at excelfox
    Last Post: 02-20-2025, 07:03 PM
  2. Test excelfox Corruptions January 2021 *
    Last Post: 01-25-2021, 08:07 PM
  3. ExcelFox Warning
    By DocAElstein in forum Public News
    Last Post: 08-10-2016, 05:08 PM
  4. Rick Rothstein - New Forum Guru @ ExcelFox community
    By Excel Fox in forum Greetings and Inception
    Last Post: 02-24-2012, 08:09 AM
