Results 1 to 10 of 10
Thread: How to Apply Payments to Aged Receivables Automatically using Excel VBA
  1. #4
    Life’s a piece of shit, when ya look at it, so always look on the bright side of life
    Quote Originally Posted by hhap View Post
    I was a bit under the weather.
    There is lots of things to feel under the weather about everywhere currently, chin up, .
    Life’s a piece of Shit, when ya look at it, so Always look on the bright side of life
    There are not so many people passing here anyway, and the Email notifications rarely work, so fast responses are not the norm here…
    OK, your last post makes it a lot clearer to me. I think now I either understand fully or I am close
    I will do a simpler coding for you that will work on a single row. If you need help in adapting that to a final coding to suit you better, then let me know.
    The coding is similar to my first attempt for you
    ( Note it is also easy to adapt the coding to run automatically when any entry is made )
    Here is the next coding for you
    Sub ReduceDebtStartingFromRight2() ' https://www.excelfox.com/forum/showthread.php/2953-How-to-Apply-Payments-to-Aged-Receivables-Automatically-using-Excel-VBA?p=24007&viewfull=1#post24007
    Dim RngSelect As Range, SelRow As Long, Ws As Worksheet
     Set Ws = Selection.Parent   ' The  Parent  will get the correct worksheet.
     Let SelRow = Selection.Row
     Set RngSelect = Ws.Range("E" & SelRow & ":I" & SelRow & "")               '   We know the columns, and the row will be that of the selected row
    Dim TPNA As Double ' This will be the  Total Payments Not Applied  something like SUMIF(E4:I4,"<0",E4:I4)
     Let TPNA = -1 * Ws.Range("K" & SelRow & "").Value                      ' Let TPNA = Ws.Evaluate("SUMIF(" & RngSelect.Address & ",""<0""," & RngSelect.Address & ")")
    Dim ClmDebt As Long, Clm As Long
         For Clm = 9 To 5 Step -1 ' ======= Looping columns  9 8 7 6 5 (I H G F E ) ================
          Let ClmDebt = Ws.Cells(SelRow, Clm).Value
            If ClmDebt > 0 Then    ' this will allow empty columns or -ve columns to be ignorred
                If ClmDebt = TPNA Then Let Ws.Cells(SelRow, Clm).Value = "":  Exit For                                             ' we have used up all payment so we are finished
                If ClmDebt > TPNA Then Let Ws.Cells(SelRow, Clm).Value = Ws.Cells(SelRow, Clm).Value - TPNA:  Exit For    ' we have used up all payment so we are finished
            ' If we get this far, then the payment is more than the column debt.
             Let TPNA = TPNA - Ws.Cells(SelRow, Clm).Value
             Let Ws.Cells(SelRow, Clm).Value = ""    ' All debt in this column is removed
            ' Column Debt is 0 or -ve so we do nothing at this column
         Next Clm ' ================================================================================
    '  Empty negative values
        For Clm = 5 To 9 Step 1
            If Ws.Cells(SelRow, Clm).Value < 0 Then Let Ws.Cells(SelRow, Clm).Value = ""
        Next Clm
    To test this, select any cell in a row. Any cell will do. For example, select CharlesP, ( in worksheet Aging Summary 2 in the returned File attached to this post
    https://postimg.cc/1gmtBHvm
    This is what the row looks like initially
    _____ Workbook: Copy of Receivable Ageing Example for VBA 2.xls ( Using Excel 2007 32 bit )
    Row\Col B C D E F G H I J K
    6 CharlesP GA-00020 5,875,488.00 -2,037,344.35 6,547,617.32 1,485,671.86 -706,127.37 585,670.54 -2,743,471.72
    Worksheet: Aging Summary 2
    Now run the macro, Sub ReduceDebtStartingFromRight2()
    That should change the worksheet to look like this
    6 CharlesP GA-00020 5,875,488.00 5,875,488.00 0.00
    See how you get on with that
  1. Replies: 24
    Last Post: 04-18-2020, 10:36 AM
  2. Replies: 5
    Last Post: 06-12-2016, 06:51 AM
  3. Replies: 17
    Last Post: 07-15-2013, 09:56 PM
  4. Automatically Create Multiple Dynamic Named Ranges Using VBA
    Last Post: 04-24-2013, 03:49 PM
    Last Post: 04-14-2013, 08:23 PM
