Page 54 of 61 FirstFirst ... 4445253545556 ... LastLast
Results 531 to 540 of 604
  1. #531
    jADHKJASHDKJahdjkAHD
  2. #532
  3. #533
    khskjhkshhhfhfhfslhafhalfh
  4. #534
    In support of these issues
    https://excelfox.com/forum/showthrea...ge51#post12784 https://www.youtube.com/watch?v=dKM8ZScbic8&t=75s
    Winget issues https://github.com/ChrisTitusTech/wi...770ae56d3b6e85
    https://github.com/ChrisTitusTech/wi...b236f3ecf290db
    06.07.2021 The Best Windows Utility ( second nice shade of grey GUI )
    Write-Host "Checking winget..."
    Try{
    	# Check if winget is already installed
    	$er = (invoke-expression "winget -v") 2>&1
    	if ($lastexitcode) {throw $er}
    	Write-Host "winget is already installed."
    Catch{
    	# winget is not installed. Install it from the Github release
    	Write-Host "winget is not found, installing it right now."
    	$download = "https://github.com/microsoft/winget-cli/releases/download/v1.0.11692/Microsoft.DesktopAppInstaller_8wekyb3d8bbwe.msixbundle"
    	$output = $PSScriptRoot + "\winget-latest.appxbundle"
    	Write-Host "Dowloading latest release"
    	Invoke-WebRequest -Uri $download -OutFile $output
    	Write-Host "Installing the package"
    	Add-AppxPackage -Path $output
    Finally {
    	# Start installing the packages with winget
    	#Get-Content .\winget.txt | ForEach-Object {
    	#	iex ("winget install -e " + $_)
    The Ultimate Windows Utility Upgrade 29 09 2021
    Try{
    Catch{
    	# winget is not installed. Install it from the Microsoft Store
    	Start-Process "ms-appinstaller:?source=https://aka.ms/getwinget"
    	$nid = (Get-Process AppInstaller).id
    	Wait-Process -Id $nid
    Finally {
    A commit a bit later by mrhaydendp to simplify a bit https://github.com/ChrisTitusTech/wi...0db?diff=split
    # Check if winget is installed
    if (Test-Path ~\AppData\Local\Microsoft\WindowsApps\winget.exe){
        'Winget Already Installed'
    else{
        # Installing winget from the Microsoft Store
    	Write-Host "Winget not found, installing it now."
    	$nid = (Get-Process AppInstaller).Id
    	Write-Host Winget Installed
  5. #535
    Test
    17-121-114-118.applebot.apple.com
    header1 header2 A Header Last Column Header
    SubItem SubItem SubItem SubItem <-- This is a ListView Item. It has an Item number of 0 and an Item idenitfier/name of 345
    SubItem SubItem SubItem SubItem <-- This is a ListView Item. It has an Item number of 1 and an Item idenitfier/name of 232
    SubItem SubItem SubItem SubItem <-- This is a ListView Item. It has an Item number of 2 and an Item idenitfier/name of 36
    [size]
    SubItem SubItem SubItem <-- This brown thing is a ListView Item. It has an Item number of 0 and an Item idenitfier/name of 345
    SubItem SubItem SubItem <-- This blue thing is a ListView Item. It has an Item number of 1 and an Item idenitfier/name of 232
    SubItem SubItem SubItem <-- This purple thing is a ListView Item. It has an Item number of 2 and an Item idenitfier/name of 36
    header1 header2 A Header Last Header <-- This bit with the created “column” is part of the main ListView object
    0\ 345
    SubItem SubItem SubItem <-- This brown thing is a ListViewItem object. It has an Item number of 0,
    and an Item identifier/name of 345
    1\ 232
    SubItem SubItem SubItem <-- This blue thing is a ListViewItem object. It has an Item number of 1,
    and an Item identifier/name of 232
    2\ 36
    SubItem SubItem SubItem <-- This purple thing is a ListViewItem object. It has an Item number of 2
    and an Item identifier/name of 36
    __
    In the above schematic we are showing 4 objects. The last three belong to the first one, ( after they have been ned to it ).
    The values in the first column somehow belong to the main ListView object.
    SubItems are Added to the ListViewItems
    In support of this Thread https://eileenslounge.com/viewtopic.php?f=30&t=38110
    https://eileenslounge.com/viewtopic....294721#p294721
    Vertical to Horizontal,
    This to this
    Part 1 The main data Vertical to Horizontal
    An idea I have is to build up the single string that we know can be put into the Windows Clipboard, and then pasted out into Excel. ( http://www.eileenslounge.com/viewtop...242941#p242941 )
    I basically build that up with some Do While Loopy stuff
    The Full Story
    The usual worksheets defining and data getting information stuff.
    ( We capture one extra empty row, because, past experience with these sort of Do While Loopy stuff has shown that it can help simplify some conditional comparison things and/ or help prevent arrays doing out of bounds by one row.
    The purpose of this is to get that maximum Amounts or Notes count, ( the biggest group ) ( which is 4 in the given example )
    But its worth looking at how that works since the basic Do While Loop is then used in the next main ( Rem 2 ) section.
    The #### Main Outer Loop keeps us going through all data rows
    Within that the ' ---- Inner Loop that takes us through a group
    This loop adds the things in the group, and after each loop is finished we check If the count was the biggest group so far.
    This is the main meat of the solution.
    First, exactly as before we have a #### Main Outer Loop keeps us going through all data rows
    Within that Main Outer Loop we now have 2 inner loops.
    '2a
    The '2a The first inner loop one does something similar to before. It loops for a group. This time within it we build up two strings that we need for a line in the output.
    As example, for the first group we are basically trying to build up these two strings, ( Just before we start that loop, we tack onto the string at the start the group name, which is A in the first group example.
    This is what we would see, for example in the immediate window, for querying the string content after, in this example, the the loops for that inner loop
     ?  strClipL
    A   vbTab  10 vbTab     20 vbTab     30
    ?    strClipR
      vbTab    N1  vbTab  N2  vbTab  N3
    ( For the sake of clarity I use a vbTab to indicate the “invisible” vbTab characters, which is actually on those strings )
    '2b
    The purpose of '2b the second inner loop is to ,( if necessary ), give us effectively extra empty cells, ( achieved by adding a vbTab of the strings.
    Using the same example, we would see that the loop is needed to be done once, and at the end of that single loop, our strings are modifies such:
     ?  strClipL
    A   vbTab  10 vbTab     20 vbTab     30   vbTab
    ?    strClipR
      vbTab    N1  vbTab  N2  vbTab  N3  vbTab
    '2c
    At this point we combine the two strings and add a line separator so that this row data can be added onto by the next row data
    So as to be sure what I have and demonstrate it more clearly, I added a line in testing which calls a function of mine , ( https://excelfox.com/forum/showthrea...ll=1#post15522 ) , which checks that line screen,
    Here is the result
    "A" & vbTab & "10" & vbTab & "20" & vbTab & "30" & vbTab & vbTab & "N1" & vbTab & "N2" & vbTab & "N3" & vbTab & vbTab & "GroupA" & vbCr & vbLf
    That looks about correct.
    Doing a few other tests, suggest to me that I have the final result that I need:
     ? strclip
    A   10  20  30      N1  N2  N3      GroupA
    B   40  50  60  70  N4  N5  N6  N7  GroupB
    C   80              N8              GroupC
    D   90  100         N9  N10         GroupD
    "A" & vbTab & "10" & vbTab & "20" & vbTab & "30" & vbTab & vbTab & "N1" & vbTab & "N2" & vbTab & "N3" & vbTab & vbTab & "GroupA" & vbCr & vbLf & "B" & vbTab & "40" & vbTab & "50" & vbTab & "60" & vbTab & "70" & vbTab & "N4" & vbTab & "N5" & vbTab & "N6" & vbTab & "N7" & vbTab & "GroupB" & vbCr & vbLf & "C" & vbTab & "80" & vbTab & vbTab & vbTab & vbTab & "N8" & vbTab & vbTab & vbTab & vbTab & "GroupC" & vbCr & vbLf & "D" & vbTab & "90" & vbTab & "100" & vbTab & vbTab & vbTab & "N9" & vbTab & "N10" & vbTab & vbTab & vbTab & "GroupD" & vbCr & vbLf
    ' Ref
    ' http://www.eileenslounge.com/viewtop...=31395#p242941
    ' http://www.eileenslounge.com/viewtop...=31489#p243731
    ' http://www.eileenslounge.com/viewtop...=31938#p247681
    ' http://www.eileenslounge.com/viewtop...art=20#p246887
    ' http://web.archive.org/web/202001241...ms-dataobject/
    ' https://stackoverflow.com/questions/...60767#54960767
    ' https://stackoverflow.com/questions/...12342#59812342
    https://www.myonlinetraininghub.com/excel-clipboard https://support.microsoft.com/en-us/...&fromar=1#bm2b
    https://www.thespreadsheetguru.com/b...nal-macro-file
    https://excelribbon.tips.net/T009810...Clipboard.html
    https://www.excelforum.com/excel-pro...t-working.html
    https://www.thespreadsheetguru.com/b...-the-clipboard
    https://excelribbon.tips.net/T010691...Clipboard.html
    https://excel.tips.net/T003111_Cant_...Workbooks.html
    ' VBA to clear the Office Clipboard http://www.eileenslounge.com/viewtop...634c64#p246838
  7. #537
    Coding so far , for last post, https://excelfox.com/forum/showthrea...ll=1#post16529
    '  https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=16529&viewfull=1#post16529
    '  http://www.eileenslounge.com/viewtopic.php?f=30&t=38110&p=294692#p294692
    Sub Stantial()
    Rem 0 data
    Dim Ws1 As Worksheet: Set Ws1 = ThisWorkbook.Worksheets("Sheet1")
    Dim RngPlus1 As Range
     Set RngPlus1 = Ws1.Cells.Item(1).CurrentRegion.Resize(Ws1.Cells.Item(1).CurrentRegion.Rows.Count + 1, Ws1.Cells.Item(1).CurrentRegion.Columns.Count)
    Dim vArr() As Variant: Let vArr() = RngPlus1.Value2
    Rem 1 determine the biggest group ( that maximum Amounts or Notes count )
    Dim Cnt As Long, Cnt2 As Long, Mx As Long: Let Mx = 1: Let Cnt = 1
        Do  '            ############################# Main Outer Loop keeps us going through all data rows
            Do  '                           -----------------  Inner Loop that takes us through a group
             Let Cnt = Cnt + 1 ' Cnt is the main data row number
             Let Cnt2 = Cnt2 + 1
            Loop While vArr(Cnt + 1, 1) = vArr(Cnt, 1) ' ----  Inner Loop that takes us through a group
            If Cnt2 > Mx Then Let Mx = Cnt2
         Let Cnt2 = 0
        Loop While Cnt < UBound(vArr(), 1) - 1 '  #### Main Outer Loop keeps us going through all data rows
    Rem 2 '            ############################# Main Outer Loop keeps us going through all data rows
     Let Cnt = 1
        Do
        Dim HrCnt As Long: Let HrCnt = 1
        Dim strClipR As String, strClipL As String: Let strClipL = strClipL & vArr(Cnt + 1, 1)
            Do                                         '2a The first inner loop
             Let Cnt = Cnt + 1
             Let HrCnt = HrCnt + 1
             Let strClipL = strClipL & vbTab & vArr(Cnt, 2)
             Let strClipR = strClipR & vbTab & vArr(Cnt, 3)
            Loop While vArr(Cnt + 1, 1) = vArr(Cnt, 1) '   The first inner loop
            Do While HrCnt < Mx + 1                    '2b the second inner loop
            Loop                                       '   the second inner loop
        '2c Finishing off the strings, and final string for an output line, after the inner loops
         Let strClipR = strClipR & vbTab & vArr(Cnt, 4) ' add the group name
        Dim strClip As String: Let strClip = strClip & strClipL & strClipR & vbCr & vbLf  ' join the strings and add a line seperator to the output row string
        'Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(strClip)
        Let strClipL = "": strClipR = ""
    '2d paste  strClip  out via the windows Clipboard
    Dim objDataObject As Object: Set objDataObject = GetObject("New:{1C3B4210-F441-11CE-B9EA-00AA006B1A69}")   '     http://web.archive.org/web/20200124185244/http://excelmatters.com/2013/10/04/late-bound-msforms-dataobject/
     objDataObject.SetText Text:=strClip
     objDataObject.PutInClipboard
     Ws1.Paste Destination:=Ws1.Range("G2")
    Spare post for later
  9. #539
    Following on from posts,
    https://excelfox.com/forum/showthrea...ll=1#post16530 https://excelfox.com/forum/showthrea...ll=1#post16529
    http://www.eileenslounge.com/viewtop...294692#p294692
    The header row,
    Group Amount1 Amount2 Amount3 Amount4 Notes1 Notes2 Notes3 Notes4 Name
    , we could make partially dynamic, as is needed, since we don’t know the maximum number of amounts ( = maximum number of Notes ) , before seeing the data.
    We do have the information needed, since Mx contains, in our current example, the required value of 4
    Evaluate Range techniques are a convenient way to get these sort of things.
    We start by considering spreadsheet formulas such as this,
    ={"Amount" & COLUMN(A1:D1)}
    , which returns us an array, which applied across a range , would give us like
    Taking that general idea and a few other steps we can finally get at our heading like in this demo coding
    ' https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=16532&viewfull=1#post16532
    Sub MakeHeadings()
    Dim Mx As Long: Let Mx = 4
    Dim Amounts() As Variant
     Let Amounts() = Evaluate("=""Amount"" & COLUMN(A1:D1)")
     Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:D)")
     Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:" & "D" & ")")
    ' We need to get   D  from what we know,  Mx
    Dim vTemp As Variant
     vTemp = Cells(1, 4).Address
     vTemp = Split(vTemp, "$", 3, vbBinaryCompare)
     vTemp = vTemp(1)
    ' Or
     vTemp = Split(Cells(1, 4).Address, "$", 3, vbBinaryCompare)(1)
    ' Or
     vTemp = Split(Cells(1, 4).Address, "$")(1)
     vTemp = Split(Cells(1, Mx).Address, "$")(1)
    Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:" & vTemp & ")")
    Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")")
    ' We want this array as a string with   vbTabs seperating the array elements
    Dim strAmounts As String
     Let strAmounts = Join(Amounts(), vbTab)
     Let strAmounts = Join(Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab)
    ' similarly for the  notes
    Dim strNotes As String
     Let strNotes = Join(Evaluate("=""Note"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab)
    ' To get our final heading string,
    Dim strHd As String
     Let strHd = "Group" & vbTab & Join(Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & Join(Evaluate("=""Note"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & "Notes"
     objDataObject.SetText Text:=strHd
     Ws1.Paste Destination:=Ws1.Range("G1")
    In the next post , https://excelfox.com/forum/showthrea...ll=1#post16533 , is that integrated into the main coding in Rem 3
  10. #540
    Coding for these posts
    https://excelfox.com/forum/showthrea...ll=1#post16532
    Sub Stantially()
    Rem 0 data
             Let Cnt2 = Cnt2 + 1
         Let Cnt2 = 0
     Let Cnt = 1
        Do
             Let Cnt = Cnt + 1
    Rem 3 headers
    Dim strHd As String
     Let strHd = "Group" & vbTab & Join(Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & Join(Evaluate("=""Note"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & "Name"
  4. Concatenating your Balls
