Page 46 of 61 FirstFirst ... 36444546474856 ... LastLast
Results 451 to 460 of 604
  1. #451
    In support of this post
    https://excelfox.com/forum/showthrea...5230#post15230
    _____ Workbook: Test Paper.xlsb ( Using Excel 2007 32 bit )
    TEST-1
    Name of the Student : Rizwana
    Reg. No. : 256
    Class X
    Worksheet: Test
    If the value of D3 and D4 of Test Sheet is matches with column C & D of Result sheet then, display a message "You are already submitted the test paper and you have secured (D3 and D4 of Test sheet match with column E of Result Sheet) marks".
    TEST-1 RESULT ANALYSIS
    Sl. No.
    Name of the Student
    Reg. No.
    Class
    Obtained Marks
    Rukhsar banu
    256
    X
    02
    Abdulkhadar
    123
    X
    03
    Rizwana
    256
    X
    04
    Rizwana
    256
    X
    05
    Rizwana
    256
    X
    Worksheet: Result
  2. #452
    TEST-1
    Reg. No. : 256
    Class X
    Worksheet: Test
    Sl. No.
    Name of the Student
    Reg. No.
    Class
    Obtained Marks
    Rukhsar banu
    256
    X
    02
    Abdulkhadar
    123
    X
    03
    Rizwana
    256
    X
    04
    Rizwana
    256
    X
    05
    Rizwana
    256
    X
    Worksheet: Result
  3. #453
    TEST-1
    Reg. No. : 256
    Class X
    Worksheet: Test
    Sl. No.
    Name of the Student
    Reg. No.
    Class
    Obtained Marks
    Rukhsar banu
    256
    X
    02
    Abdulkhadar
    123
    X
    03
    Rizwana
    256
    X
    04
    Rizwana
    256
    X
    05
    Rizwana
    256
    X
    Worksheet: Result
  4. #454
    TEST-1
    Reg. No. : 256
    Class X
    Worksheet: Test
    Sl. No.
    Name of the Student
    Reg. No.
    Class
    Obtained Marks
    Rukhsar banu
    256
    X
    02
    Abdulkhadar
    123
    X
    03
    Rizwana
    256
    X
    04
    Rizwana
    256
    X
    05
    Rizwana
    256
    X
    Worksheet: Result
  5. #455
    macro for last two posts
    Sub Transfer_marasAlan_3()  '   https://www.excelforum.com/excel-programming-vba-macros/1338596-transferring-data.html#post5460624
    Dim a(), cls_v() As String, Rws(), aSum(), arrOut__(), JagdDikIt()
    Dim Rng As Range, Rng_v As Range, cel As Range
    Dim Wrbk As Workbook, Rw As Long
    Dim Pth As String
     Let Pth = ThisWorkbook.Path & Application.PathSeparator  '       Const pth = "C:\Users\L026936\Desktop\Excel\"      '<---- use own path
    Const Wnm = "Workbook2_3.xlsx"                             'your workbook name
    '    Application.ScreenUpdating = False
    Rem 1 the main data range from source
        With ThisWorkbook.Sheets("Sheet1")
         Set Rng = .Range("a1:ai" & 36 & "")    '   main data range    hard coded to 36  for testing and  demonstration         .UsedRange.Rows.Count)
         Let a() = Rng.Value                    '   all data values in the source.  This will end up in the tyopical    arrOut()=AppIndex( a(), Rws(),  Clms() )
         Set Rng_v = Rng.Columns(2).SpecialCells(xlCellTypeVisible)  '  this gives us the range we see , (it is likely as a collection of areas) in the ID column
            If Rng_v.Count > 1 Then
       Rem 2 Make the sums column array, aSum() , and while we are looping we will collect the seen row indicies, Rws()
    '       ' ddddddddddddddddddddddd Dictionaray bit ------
            '  Dictionaray    -   The only reason to use this is that its a convenient way to get a unique list thing, or a unique set of things.
            Dim Dik As Object: Set Dik = CreateObject("Scripting.Dictionary")   '      https://excelmacromastery.com/vba-dictionary/
            'Dim d As Scripting.Dictionary: Set d = New Scripting.Dictionary
            Dim aTp() As Variant: ReDim aTp(1 To 3) ' This is a temporary array used to fill the dictionary  Items   it must be dynamic and variant type  - see note +++ below
                For Each cel In Rng_v  '   we effectivelly are going down all the seen rows
                    If cel.Row > 1 And cel.Value <> "" Then
                     Let Rw = cel.Row
                        If Not Dik.exists(a(Rw, 2)) Then ' -Case we don't yet have any dictionaray item with this ID  key
                         Let aTp(1) = Rw                                          '  row number
                         Let aTp(2) = a(Rw, 35)                                   '  grangtotal for this row
                         Let aTp(3) = .Evaluate("=Sum(o" & Rw & ": z" & Rw & ")") ' Our  column Sums
                         Dik.Add Key:=a(Rw, 2), Item:=aTp() '   The key becomes the ID  ,      The Item is a three element array of      the row number     the columns sum for this row    the gradtotal for this row                              shothand way to do this line is  d(a(r, 2)) = atp
                        Else '                           ' -Case we already have a dictionary item with this key
                         Let aTp() = Dik.Item(a(Rw, 2)) ' we are returning an item that is an array, so the recieving array variable must be dynamic.  the returned element type3s are  Variant   +++
                            If a(Rw, 35) > aTp(2) Then  '  If the grand total for this row and  ID  is  greater than a previous, then ....
                                Let aTp(1) = Rw                                        '   we are replacing ..
                                Let aTp(2) = a(Rw, 35)                                 '    .. the item with the relavent  ..
                                Let aTp(3) = .Evaluate("=Sum(o" & Rw & ": z" & Rw & ")") '    .. info from this row
                                Dik(a(Rw, 2)) = aTp()  '  shorthand version for   Dik.Add  Key:=a(Rw, 2), Item:=aTp()
                        End If ' end of making or replacing  a dictiuonary item
            ' at this point we have a dictionary that has one  Item  for each  ID
            ' in this last  Dik  bit we use the first and third part  of the 3 element items  in  a pseudo   arrOut()=AppIndex( arrUnjaggedJaged(), Rws() , Clms() )    '    https://www.ozgrid.com/forum/index.php?thread/1227920-slicing-a-2d-array/&postID=1239241#post1239241
                If Dik.Count Then
                    'Let JagdDikIt() = Application.Transpose(Dik.items()) '    we can treat an unjagged jagged array  that is a 1 D array of 1 D arrays as if it was a  2 D array  ...   https://eileenslounge.com/viewtopic.php?p=266691#p266691
                    Let JagdDikIt() = Dik.items()
                    'Let Rws() = Application.Index(JagdDikIt(), 1, Evaluate("row(1:" & UBound(JagdDikIt(), 2) & ")"))                                          '   Application.Transpose(Application.Transpose(Application.Index(v, 1, Evaluate("row(1:" & UBound(v, 2) & ")"))))
                    Let Rws() = Application.Index(JagdDikIt(), Evaluate("row(1:" & UBound(JagdDikIt()) + 1 & ")"), 1)                                        '   Application.Transpose(Application.Transpose(Application.Index(v, 1, Evaluate("row(1:" & UBound(v, 2) & ")"))))
                    'Let aSum() = Application.Index(JagdDikIt(), 3, Evaluate("row(1:" & UBound(JagdDikIt(), 2) & ")"))                         'Application.Transpose(Application.Transpose(Application.Index(v, 3, Evaluate("row(1:" & UBound(v, 2) & ")"))))
                    Let aSum() = Application.Index(JagdDikIt(), Evaluate("row(1:" & UBound(JagdDikIt()) + 1 & ")"), 3)                       'Application.Transpose(Application.Transpose(Application.Index(v, 3, Evaluate("row(1:" & UBound(v, 2) & ")"))))
    '       ' ddddddddddddddddddddddddd -----------------------------
            Else ' case only a header row to be seen
        If Rng_v.Count = 1 Or Dik.Count = 0 Then
            MsgBox "No rows to transfer."
        On Error Resume Next   '   https://eileenslounge.com/viewtopic.php?f=30&t=35861&start=20
         Set Wrbk = Workbooks(Wnm)
            If Wrbk Is Nothing Then
             Workbooks.Open Filename:=Pth & Wnm
             Workbooks(Wnm).Activate
        With ActiveWorkbook
            With .Sheets("Sheet1")
            Dim vTemp As Variant ' just for demo purposes
             Let vTemp = .UsedRange.Rows(1)
             ' { empty ,  Unique ID  , Gap ,Name  ,  Title ,  Platform  ,  Salary , Gap, Total ,  copy1  , copy2 ,  copy3 ,  copy4  , copy5 ,  copy6 ,  copy7 ,  copy2 ,  copy3 ,  copy4 ,  copy5  , copy6 ,  copy7 ,  Formula7   , Formula8 ,   Formula9  }
             Let vTemp = Rng.Rows(1)
             ' { Number , ID , Name ,   Title ,  Platform ,   Filter  ,  ,  ,   ,    ,Salary ,   ,    ,   ,Add1  ,  Add2 ,   Add3  ,  Add4  ,  Add5 ,   Add6 ,   Add7  ,  Add8 ,   Add9 ,   Add10 ,  Add11 ,  Add12 ,  copy1 ,  copy2 ,  copy3 ,  copy4 ,  copy5  , copy6 ,  copy7  , Total ,  grandtotal  }
             Let vTemp = Application.Match(.UsedRange.Rows(1), Rng.Rows(1), 0) '  This gives a 1 D array and each element has either the position of the header in the destination workbook, or an error if it did not find it
             '  { 2 ,  error  , 3  , 4 ,  5 ,  11  , error  , 34 ,  27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33 , 28 , error ,error ,error ,error ,error ,error ,error ,error ,error ,   }
             ' So the above line tells us where there is an error in a match with the header names
             Let vTemp = Application.IfError(vTemp, "x") ' Instead of the vbError , a text of  "x"  is put into the array
             '  { 2 ,  x   , 3  , 4 ,  5 ,  11  , x , 34  ,  27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33 , x ,x ,x ,x ,x ,x ,x ,x ,x ,  }
             Let vTemp = Filter(vTemp, "x", False, 0) ' take out the  "x"s
             '  { 2    , 3  , 4 ,  5 ,  11   , 34,  27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33  }
             Let cls_v() = Filter(Application.IfError(Application.Match(.UsedRange.Rows(1), Rng.Rows(1), 0), "x"), "x", False, 0)
             '  { 2   , 3  , 4 ,  5 ,  11  ,   27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33  }
                With .Range("B2")  '   .UsedRange.Offset(1)
                 ' .Resize(, 15).ClearContents
                 Let arrOut__() = Application.Index(a(), Rws(), cls_v())
                 .Resize(UBound(Rws()), 1) = arrOut__()
                 Let Rws() = Evaluate("row(1:" & UBound(Rws()) & ")") '  Using the variable  Rws()  for a sequential indicie list  1; 2; 3 ... etc for all rows in the  arrOut__()
                 .Offset(, 2).Cells(1).Resize(UBound(Rws()), 4).Value = Application.Index(arrOut__(), Rws(), Array(2, 3, 4, 5))  '  columns   D - G
                 .Offset(, 7).Cells(1).Resize(UBound(Rws())) = aSum()  '  columm I
                 .Offset(, 8).Cells(1).Resize(UBound(Rws()), 7).Value = Application.Index(arrOut__(), Rws(), Array(6, 7, 8, 9, 10, 11, 12))  ' Column J to P
    '        .Save
    '    Set Rng = Nothing
    '    Set Rng_v = Nothing
    '    Set cel = Nothing
        Set Dik = Nothing
    Links relavent to the last 9 posts
    ' https://www.excelforum.com/excel-programming-vba-macros/1338596-transferring-data.html#post5458446
    ' _  First i wanted to filter column G from workbook 1 to "Filter 2" and transfer only filter 2 data to workbook 2.
    ' _  Then transferring like i wanted to transfer column C (source) to column B (destination) , column D to D, Column L to Column G, etc.
    ' _  I wanted to sum from column P to colum AA and transfer those sum to destination at column H
    ' _ Then copy from column AB to AH and paste in I to O in destination
    Sub Transfer_maras_1()
    Here is a before and after…
    https://excelfox.com/forum/showthrea...ll=1#post15278
    https://excelfox.com/forum/showthrea...ll=1#post15279
    Macro
    https://excelfox.com/forum/showthrea...ll=1#post15277
    Files
    Transfer data_marasAlan_1.xlsm : https://app.box.com/s/p8kf5vo8jesql3n47sd1bzgm57qdpwdv
    Workbook2_1.xlsx : https://app.box.com/s/3d9gmeb2nlyr4gg9q802kk5mjgze8cl5
    _.________________________________________________ _________________________________________________
    Sub Transfer_marasAlan_2() '
    https://excelfox.com/forum/showthrea...ll=1#post15276
    https://excelfox.com/forum/showthrea...ll=1#post15273
    Macro
    https://excelfox.com/forum/showthrea...ll=1#post15272
    Files
    Transfer data_marasAlan_2.xlsm : https://app.box.com/s/749a78z2ku4m1s1tg3fvgs1z1ud4s325
    Workbook2_2.xlsx : https://app.box.com/s/13yh30a77spsluauck3nif309pic8fuz
    https://excelfox.com/forum/showthrea...ll=1#post15269
    https://excelfox.com/forum/showthrea...ll=1#post15270
    Macro
    https://excelfox.com/forum/showthrea...ge42#post15271
    Files
    https://excelfox.com/forum/showthrea...ge42#post15233
    Transfer data_marasAlan_3.xlsm : https://app.box.com/s/p8kf5vo8jesql3n47sd1bzgm57qdpwdv
    Workbook2_3.xlsx : https://app.box.com/s/y3rwvhfk3bo1rp9t7cgbk8yz3krymh23
  7. #457
    Dim Pth As String
                     Let Rw = cel.Row
                If Dik.Count Then
        With ActiveWorkbook
    '        .Save
    '    Set Rng = Nothing
    '    Set cel = Nothing
        Set Dik = Nothing
    Dim Pth As String
                     Let Rw = cel.Row
                If Dik.Count Then
        With ActiveWorkbook
    '        .Save
    '    Set Rng = Nothing
    '    Set cel = Nothing
        Set Dik = Nothing
    In suppot of this thread
    https://excelfox.com/forum/showthrea...5292#post15292
    Input data
    _____ Workbook: VBA3.xls ( Using Excel 2007 32 bit )
    Find word 1Abc 2wer# 3smar 4chris
    AP1k AP1k, 6-9| AP1k, 10-13
    ForCome ForCome, 13-19
    Double Double, 14-16 | Double, 14-16| Double, 14-16 Double, 14-16| Double, 14-16 Double, 14-16| Double, 14-16
    Worksheet: inputA
    Wanted Output
    Output
    1Abc
    2wer# AP1k, 6-9
    2wer# AP1k, 10-13
    2wer# Double, 14-16
    2wer# Double, 14-16
    2wer# Double, 14-16
    3smar ForCome, 13-19
    3smar Double, 14-16
    3smar Double, 14-16
    4chris Double, 14-16
    Worksheet: OutputB
    Results after running macro in next post
    1Abc
    2wer# AP1k, 6-9
    2wer# AP1k, 10-13
    2wer# Double, 14-16
    2wer# Double, 14-16
    2wer# Double, 14-16
    3smar Double, 14-16
    3smar Double, 14-16
    Worksheet: Output
    Macro for last post
    Sub StartOffvbadumbarse()
    Rem 1 Worksheets info
    Dim WsIn As Worksheet, WsOut As Worksheet
     Set WsIn = ThisWorkbook.Worksheets.Item(1): Set WsOut = ThisWorkbook.Worksheets.Item(2)
    Dim arrIn() As Variant: Let arrIn() = WsIn.Range("B1:F5").Value2
    '2b
    Dim Clm As Long
        For Clm = 1 To 5 Step 1
            If arrIn(1, Clm) = "" Then
            ' Nothing to do for no header
            Dim Itms As String: Let Itms = arrIn(1, Clm)
            Dim RwDta As Long
                For RwDta = 2 To 5 Step 1
                Dim strFndWd As String
                    If arrIn(RwDta, Clm) = "" Then
                    ' no data
                        If InStr(1, arrIn(RwDta, Clm), "|", vbBinaryCompare) > 0 Then ' we must have two or more datas seperatied by a  |
                        Dim CelDts As Long
                            For CelDts = 0 To UBound(Split(arrIn(RwDta, Clm), "|", -1, vbBinaryCompare))
                             Let strFndWd = strFndWd & Split(arrIn(RwDta, Clm), "|", -1, vbBinaryCompare)(CelDts) & vbCr & vbLf
                            Next CelDts
                        Else ' case single data
                         Let strFndWd = strFndWd & arrIn(RwDta, Clm) & vbCr & vbLf  ' effectively a single row is added for this data
                Next RwDta
            '2e we have been through the data, so time to see what we got and fill our two strings appropriately
            Dim strOutA As String, strOutB As String
                If strFndWd = "" Then ' case we had no data
                 Let strFndWd = strFndWd & vbCr & vbLf ' effectively adds an empty row
                 Let strOutA = strOutA & Itms & vbCr & vbLf ' a single row with header
                Else ' we have data, so need do add some rows to strOutA ( strOutB effecively has all the rows determined by the number of  vbCr & vbLf   added
                Dim RwCnt As Long: Let RwCnt = UBound(Split(strFndWd, vbCr & vbLf, -1, vbBinaryCompare)) + 1 - 1 ' The number of  vbCr & vbLf  gives us the number rows
                    For CelDts = 1 To RwCnt
                    Next CelDts
         Let strOutB = strOutB & strFndWd
         Let strFndWd = ""
        Next Clm
    ' I can view my data in a message box or in the immediate window
     MsgBox Prompt:=strOutA: Debug.Print strOutA
     MsgBox Prompt:=strOutB: Debug.Print strOutB
    Rem 3 outout
    Dim arrOutA() As String: Let arrOutA() = Split(strOutA, vbCr & vbLf, -1, vbBinaryCompare) '  Excel has the convention of taking a  1D  array as being "horizontal" for spreadsheet purposes, so will consider it as a row of data values if applied to a worksheet range
    Dim arrOutB() As String: Let arrOutB() = Split(strOutB, vbCr & vbLf, -1, vbBinaryCompare)
    ' Let WsOut.Range("A2").Resize(UBound(arrOutA()), 1).Value = Application.Transpose(arrOutA())
     Let WsOut.Range("A2").Resize(UBound(arrOutA()), 1).Value = Application.Index(arrOutA(), Evaluate("=row(1:" & UBound(arrOutA()) & ")/row(1:" & UBound(arrOutA()) & ")"), Evaluate("=row(1:" & UBound(arrOutA()) & ")"))
    ' Let WsOut.Range("B2").Resize(UBound(arrOutB()), 1).Value = Application.Transpose(arrOutB())
     Let WsOut.Range("B2").Resize(UBound(arrOutB()), 1).Value = Application.Index(arrOutB(), Evaluate("=row(1:" & UBound(arrOutB()) & ")/row(1:" & UBound(arrOutB()) & ")"), Evaluate("=row(1:" & UBound(arrOutB()) & ")"))
  4. Concatenating your Balls
