Page 36 of 61 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 604
  1. #351
    post to get the URL - for later use
    Solution1 fo this Thread
    http://www.eileenslounge.com/viewtop...270792#p270792
    Sub VBAArrayTypeAlternativeToFilterInSegs_Solution1()  '     http://www.eileenslounge.com/viewtopic.php?p=270915#p270915               .......... https://eileenslounge.com/viewtopic.php?p=245238#p245238
    Rem Make the two row indicie lists ( string of row indicies seperated witha space )
    Dim arrK() As Variant: Let arrK() = Worksheets("Main workbook").Range("K1:K" & Worksheets("Main workbook").Range("A" & Rows.Count & "").End(xlUp).Row & "").Value
    Dim strSuc As String, strSpit As String
     Let strSuc = "7": Let strSpit = "7"
        For Cnt = 11 To UBound(arrK(), 1)
            If arrK(Cnt, 1) = "Positive" Then  '/////////
             Let strSuc = strSuc & " " & Cnt
             Let strSpit = strSpit & " " & Cnt
    'Debug.Print strSuc
    Rem Part A) modification (via string manipulation)
    Dim TotRws As Long: Let TotRws = (Len(strSuc) - Len(Replace(strSuc, " ", "", 1, -1, vbBinaryCompare))) + 1 ' effectively we are determining the number or spaces between the row indicies, then +1  to give us the number of row indicies
    Dim Segs As Long: Let Segs = Int(TotRws / 27) + 1
        For Cnt = 34 To ((Segs * 27) + ((Segs - 1) * 7) + 7) - 34 Step 34
         Let strSuc = Application.WorksheetFunction.Substitute(strSuc, " ", " 1 1 1 1 1 1 1 ", Cnt - 6) '           https://excelfox.com/forum/showthread.php/2230-Built-in-VBA-methods-and-functions-to-alter-the-contents-of-existing-character-strings
     Debug.Print strSuc
    Dim clms() As Variant: Let clms() = Array(1, 4, 6, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46)
    Dim strRws() As String: Let strRws() = Split(strSuc, " ", -1, vbBinaryCompare)
    Dim Rws() As String: ReDim Rws(1 To UBound(strRws(), 1) + 1, 1 To 1)
        For Cnt = 1 To UBound(strRws(), 1) + 1 ': Debug.Print strRws(Cnt - 1)
         Let Rws(Cnt, 1) = strRws(Cnt - 1)
    Dim arrOut() As Variant: Let arrOut() = Application.Index(Worksheets("Main workbook").Cells, Rws(), clms())
     Let Worksheets("consultant doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)) = arrOut()
    Rem Part B)
    ' Header
     Worksheets("TempSht").Range("A7:X7").Copy
     Worksheets("consultant doctor").Range("A7:X7").PasteSpecial Paste:=xlPasteAll    '     https://docs.microsoft.com/en-us/office/vba/api/excel.range.pastespecial       https://docs.microsoft.com/de-de/office/vba/api/excel.xlpastetype
    ' All formats in one go for each segmant from the temporary blue print worksheet
     Worksheets("TempSht").Range("A8:X41").Copy
     Worksheets("consultant doctor").Range("A8:X" & ((Segs * 27) + ((Segs - 1) * 7) + 7) + 1 & "").PasteSpecial Paste:=xlPasteFormats   '
    ' Formulas
      Worksheets("TempSht").Range("A35:X41").Copy
        For Cnt = 34 To ((Segs * 27) + ((Segs - 1) * 7) + 7) Step 34
         Worksheets("consultant doctor").Range("A" & Cnt & "").Offset(1, 0).Resize(7, 24).PasteSpecial Paste:=xlFormulas '                  Value = Worksheets("TempSht").Range("A35:X41").Formula
    '     Worksheets("consultant doctor").Range("A" & Cnt & "").Offset(-26, 0).Resize(7, 24).Sort key1:=Worksheets("consultant doctor").Range("A" & Cnt & "").Offset(-26, 2), Header:=False   '   sorting here will clear the clipboard
    ' Sorting
    'With Worksheets("consultant doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2))
    '' Let .Value = arrOut()
    '.Sort key1:=Worksheets("consultant doctor").Range("C7"), Header:=True
    '.Font.Name = "Times New Roman"
    '.Font.Size = 13
    '.Columns("D:X").NumberFormat = "0.00"
    '.EntireColumn.AutoFit
    'End With
    ''Let clms() = Array(1, 4, 6, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46)
    ' Let strRws() = Split(strSpit, " ", -1, vbBinaryCompare)
    ' ReDim Rws(1 To UBound(strRws(), 1) + 1, 1 To 1)
    '    For Cnt = 1 To UBound(strRws(), 1) + 1
    '     Let Rws(Cnt, 1) = strRws(Cnt - 1)
    '    Next Cnt
    ' Let arrOut() = Application.Index(Worksheets("Main workbook").Cells, Rws(), clms())
    'With Worksheets("Specialist Doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2))
    'Let .Value = arrOut()
    ''.Sort Key1:=Worksheets("Specialist Doctor").Range("C7"), Header:=True
    '.Font.Size = 13
    'End With
    Solution 2
    Solution for this post:
    https://eileenslounge.com/viewtopic....271047#p271047
    https://eileenslounge.com/viewtopic....271137#p271137
    The main thing is
    Sub DropItIn()
    The first macro, Sub VBAArrayTypeAlternativeToFilterToSegs_Solution2() , which is the one that you run, is almost identical to the very first unmodified macro, Sub VBAArrayTypeAlternativeToFilter() ' https://eileenslounge.com/viewtopic....270792#p270792
    Sub VBAArrayTypeAlternativeToFilterToSegs_Solution2() '               https://eileenslounge.com/viewtopic.php?p=271047&sid=d23ea475322d2edf06b70bfeaa95726b#p271047
    ' Main Data worksheet
    ' Get row indicies for the two output worksheets
    ' First output worksheet
        .Sort Key1:=Worksheets("consultant doctor").Range("C7"), Header:=True
        .Font.Size = 13
        .Borders.LineStyle = xlContinuous
    ' Adding extra rows and stuff for  Worksheets("consultant doctor") ================
    '        Worksheet,data row count, First data row, First break in data, data rows, extra rows to be inserted
     Call DropItIn(Worksheets("consultant doctor"), UBound(strRws(), 1) + 1, 8, 34, 27, 7)                                            '  Worksheet,data row count, First data row, First break in data, data rows, extra rows to be inserted
    ' second output worksheet
         .Font.Size = 13
    ' Adding extra rows and stuff for  Worksheets("Specialist Doctor") ==================
     Call DropItIn(Worksheets("Specialist Doctor"), UBound(strRws(), 1) + 1, 8, 34, 27, 7)                                            '  Worksheet,data row count, First data row, First break in data, data rows, extra rows to be inserted
    Solution 3
    Macros for Solution 3 in this Thread here
    https://eileenslounge.com/viewtopic.php?f=30&t=34878
    Post
    https://eileenslounge.com/viewtopic....271150#p271150
    Sub Solution3_2Workbooks() '
    Rem 1 Worksheets info
    Dim WbM As Workbook, WbData As Workbook
     Set WbM = ThisWorkbook: Set WbData = Workbooks("Example.xlsx")
    Dim arrK() As Variant: Let arrK() = WbData.Worksheets("Main workbook").Range("K1:K" & Worksheets("Main workbook").Range("A" & Rows.Count & "").End(xlUp).Row & "").Value
        With WbData.Worksheets("consultant doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2))
        .Font.Size = 13
     Call DropItIn3(WbData.Worksheets("consultant doctor"), UBound(strRws(), 1) + 1, 8, 34, 27, 7)                                            '  Worksheet,data row count, First data row, First break in data, data rows, extra rows to be inserted
        With WbData.Worksheets("Specialist Doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2))
         .Font.Size = 13
     Call DropItIn3(WbData.Worksheets("Specialist Doctor"), UBound(strRws(), 1) + 1, 8, 34, 27, 7)                                            '  Worksheet,data row count, First data row, First break in data, data rows, extra rows to be inserted
    '  Call '  Worksheet,data row count, First data row, First break in data, data rows, extra rows to be inserted
    'Worksheets("consultant doctor"), UBound(strRws(), 1) + 1 ,    8    ,   34      27,     7
    '                                     88    ,       8      ,         34     ,     27        ,    7
    Sub DropItIn3(Ws As Worksheet, RwsCnt As Long, SttRw As Long, FstBkRw As Long, DtaRws As Long, ExtRws As Long)    '      https://eileenslounge.com/viewtopic.php?p=271047&sid=d23ea475322d2edf06b70bfeaa95726b#p271047
    ' Header
     ThisWorkbook.Worksheets("TempSht").Range("A7:X7").Copy
     Ws.Range("A" & SttRw - 1 & ":X" & SttRw - 1 & "").PasteSpecial Paste:=xlPasteFormats  '     https://docs.microsoft.com/en-us/office/vba/api/excel.range.pastespecial       https://docs.microsoft.com/de-de/office/vba/api/excel.xlpastetype
    ' Insert extra rows
    '  Worksheets("TempSht").Range("A35:X41").Copy
    '    For Cnt = FstBkRw To ((((Int(RwsCnt / DtaRws) + 1) * DtaRws) + (((Int(RwsCnt / DtaRws) + 1) - 1) * ExtRws) + (SttRw - 1))) - (DtaRws + ExtRws) Step DtaRws + ExtRws  '  This misses the last section
        For Cnt = FstBkRw To ((((Int(RwsCnt / DtaRws) + 1) * DtaRws) + (((Int(RwsCnt / DtaRws) + 1) - 1) * ExtRws) + (SttRw - 1))) Step DtaRws + ExtRws
         ThisWorkbook.Worksheets("TempSht").Range("A35:X41").Copy
         Ws.Range("A" & Cnt & "").Offset(1, 0).Resize(7, 24).Insert shift:=xlShiftDown '                  Value = Worksheets("TempSht").Range("A35:X41").Formula
    Solution 4
    Macro for solution 4 for this Thread here
    Post
    https://eileenslounge.com/viewtopic....5c9974#p271181
    Sub VBAArrayTypeAlternativeToFilterSolution4()  '                                                       BY M. Doc.AElstein .......... https://eileenslounge.com/viewtopic.php?p=245238#p245238
    Debug.Print strSuc
    Dim Clms() As Variant: Let Clms() = Array(1, 4, 6, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46)
    ' sorting with Arrays
    Dim strNms() As Variant ' this will be the array of names in the order corresponding to the strRws() indicies
     Let strNms() = Application.Index(Worksheets("Main workbook").Cells, strRws(), 6)
    ' Array sort of Bubble sort, sort of
    Dim rOuter As Long ' ========"Left Hand"=========================Outer Loop=====================================
        For rOuter = 2 To UBound(strNms)
        Dim rInner As Long ' -------Inner Loop-------------"Right Hand"--------------------------
            For rInner = rOuter + 1 To UBound(strNms) ' from just above left hand through all the rest
                If strNms(rOuter) > strNms(rInner) Then
                Dim varTemp As Variant ' I want to Swap those 2 above ( and the corresponding strRws() ) - I cant easilly in any coding change two values simulataneosly. So one of them Element values will put in this temporary place. This Element Values will then be given the other. Finally the other Element will be given this temporary value
                 Let varTemp = strNms(rOuter): Let strNms(rOuter) = strNms(rInner): Let strNms(rInner) = varTemp
                Dim TempRs As String
                 Let TempRs = strRws(rOuter - 1): Let strRws(rOuter - 1) = strRws(rInner - 1): Let strRws(rInner - 1) = TempRs ' the -1 is because strRws() starts at 0  not 1
            Next rInner ' -----------------------------------------------------------------------
        Next rOuter ' ==================End  Outer Loop===============================================================
    ' we must now re make strsuc
     Let strSuc = Join(strRws(), " ")
     Let arrOut() = Application.Index(Worksheets("Main workbook").Cells, Rws(), Clms())
    Rem Part B)
    ' Header
    ' Formulas
    ''' Sorting  NO LONGER NEEDED
    ''    For Cnt = 34 To ((Segs * 27) + ((Segs - 1) * 7) + 7) Step 34
    ''     Worksheets("consultant doctor").Range("A" & Cnt & "").Offset(-26, 0).Resize(7, 24).Sort key1:=Worksheets("consultant doctor").Range("A" & Cnt & "").Offset(-26, 2), Header:=False
    ''    Next Cnt
    '    With Worksheets("consultant doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2))
    '    .Sort Key1:=Worksheets("consultant doctor").Range("C7"), Header:=True
    '    .Font.Name = "Times New Roman"
    '    .Font.Size = 13
    '    .Columns("D:X").NumberFormat = "0.00"
    '    .EntireColumn.AutoFit
    '    End With
    '' second output worksheet
    'Let strRws() = Split(strSpit, " ", -1, vbBinaryCompare)
    'ReDim Rws(1 To UBound(strRws(), 1) + 1, 1 To 1)
    '    Next Cnt
    ' Let arrOut() = Application.Index(Worksheets("Main workbook").Cells, Rws(), Clms())
    '    With Worksheets("Specialist Doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2))
    '     .Sort Key1:=Worksheets("Specialist Doctor").Range("C7"), Header:=True
    '     .Font.Size = 13
    '    End With
    Notes in support of this Thread
    https://excelfox.com/forum/showthrea...ther-workbooks
    Row\Col A B C D E F G H I
    1 Exchange Symbol Series/Expiry Open High Low Prev Close LTP
    2 NSE ADANIENT EQ 151.85 165.45 151.4 151.85 152.35 25
    3 NSE AMARAJABAT EQ 662.5 665.9 642.55 662.5 643.5 100
    Worksheet: 1-Sheet1 6July
    _____ Workbook: ap.xls ( Using Excel 2007 32 bit )
    Row\Col A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
    1 UserId AccountId EntityName Exchg-Seg Symbol Instrument Name Option Type NetBuyValue NetSellValue NetValue NetBuyQty NetSellQty NetQty BEP SellAvgPrice BuyAvgPrice LastTradedPrice MarkToMarket Realized MarkToMarket Unrealized MarkToMarket EL MarkToMarket Trading Symbol Client Context Series/Expiry Strike Price
    2 WC5758 NSE AMBUJACEM EQ 10781.10 10878.30 97.20 54 54 201.45 199.65 201 97.2 97.2 97.2 AMBUJACEM-EQ EQ
    3 WC5758 NSE ADANIENT EQ 420.60 430.50 9.90 2 2 215.25 210.30 210.35 9.9 9.9 9.9 ADANIENT-EQ EQ 25
    4 WC5758 NSE SIEMENS EQ 2609.30 2642.50 33.20 2 2 1321.25 1304.65 1322.7 33.2 33.2 33.2 SIEMENS-EQ EQ
    5 WC5758 NSE RBLBANK EQ 502.10 530.30 28.20 2 2 265.15 251.05 249.75 28.2 28.2 28.2 RBLBANK-EQ EQ
    6 WC5758 NSE NATIONALUM EQ 1768.50 1782.00 13.50 54 54 33.00 32.75 32.75 13.5 13.5 13.5 NATIONALUM-EQ EQ
    7 WC5758 NSE MARICO EQ 1688.40 1713.00 24.60 6 6 285.50 281.40 281.9 24.6 24.6 24.6 MARICO-EQ EQ
    8 WC5758 NSE AMARAJABAT EQ 2429.10 2405.70 -23.40 18 133.65 134.95 135 -23.4 -23.4 -23.4 APOLLOTYRE-EQ EQ 100
    9 WC5758 NSE L&TFH EQ 1765.80 1794.60 28.80 18 18 99.70 98.10 98.25 28.8 28.8 28.8 L&TFH-EQ EQ
    10 WC5758 NSE ITC EQ 360.90 366.10 5.20 2 2 183.05 180.45 180.85 5.2 5.2 5.2 ITC-EQ EQ
    11 WC5758 NSE INFRATEL EQ 10988.00 11180.70 192.70 54 54 207.05 203.48 203.8 192.7 192.7 192.7 INFRATEL-EQ EQ
    12 WC5758 NSE DLF EQ 93069.00 94283.00 1214.00 486 486 194.00 191.50 190.3 1214 1214 1214 DLF-EQ EQ
    Worksheet: ap-Sheet1 6July
    If column I of 1.xls matches with column Z of ap.xls & column K of ap.xls is equals to column L of ap.xls Then
    Look column H of 1.xls & if column H of 1.xls is greater than column D of 1.xls then it has to copy the first row of OrderFormat.xlsx & paste it to BasketOrder.xlsx
    Look column H of 1.xls & if column H of 1.xls is lower than column D of 1.xls then it has to copy the third row of OrderFormat.xlsx & paste it to BasketOrder.xlsx
    _____ Workbook: OrderFormat.xlsx ( Using Excel 2007 32 bit )
    1 NSE EQ NA NA NA 0 0 BUY MARKET NA CLI MIS DAY WC5758 NA 3 NA
    2 NSE EQ NA NA NA 0 0 SELL SL-M CLI MIS DAY WC5758 NA NA NA
    3 NSE EQ NA NA NA 0 0 SELL MARKET NA CLI MIS DAY WC5758 NA 3 NA
    4 NSE EQ NA NA NA 0 0 BUY SL-M CLI MIS DAY WC5758 NA NA NA
    Worksheet: Sheet1
    Given BasketOrder
    _____ Workbook: BasketOrder.xlsx Given by Avinash ( Using Excel 2007 32 bit )
    J
    K
    L
    M
    N
    O
    P
    Q
    R
    S
    T
    U
    NSE EQ NA NA NA
    NA
    Worksheet: Sheet1 6July
    For I of 25 in row 2 of 1.xls, we match with column z / row 3 in ap.xls
    Column K and column L in ap.xls are both = 2 in row 3 in ap.xls So column K of ap.xls is equals to column L of ap.xls
    Column H of row 2 in 1.xls is greater than column D of row 2 of 1.xls , so we copy the first row of of OrderFormat.xlsx & paste it to BasketOrder.xlsx
    So I assume / geuss the given workbook, BasketOrder.xlsx is for After
    Macro solution for this post:
    '  https://excelfox.com/forum/showthread.php/2569-Copy-row-from-one-workbook-to-another-workbook-based-on-conditions-in-two-other-workbooks
    '   Copy row from one workbook to another workbook  based on conditions in two other workbooks
    Sub CopyRowFromWb4ToWb3basedOnConditionsInWb1AndWb2()
    Rem 1 worksheets range info
    Dim Wb1 As Workbook, Wb2 As Workbook, Wb3 As Workbook, Wb4 As Workbook
     Set Wb1 = Workbooks("1.xls")
     Set Wb2 = Workbooks("ap.xls")
     Set Wb3 = Workbooks("BasketOrder.xlsx")
     Set Wb4 = Workbooks("OrderFormat.xlsx")
    Dim Ws1 As Worksheet, Ws2 As Worksheet, Ws3 As Worksheet, Ws4 As Worksheet
     Set Ws1 = Wb1.Worksheets.Item(1)
     Set Ws2 = Wb2.Worksheets.Item(1)
     Set Ws3 = Wb3.Worksheets.Item(1)
     Set Ws4 = Wb4.Worksheets.Item(1)
    Dim Lr1 As Long, Lr2 As Long, Lr3 As Long ', Lr4 As Long
     Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row
     Let Lr2 = Ws2.Range("D" & Ws2.Rows.Count & "").End(xlUp).Row
    Dim Rng1 As Range, Rng2 As Range ', Rng3 As Range, Rng4 As Range
     Set Rng1 = Ws1.Range("A1:I" & Lr1 & "")
     Set Rng2 = Ws2.Range("A1:Z" & Lr2 & "")
    '1b) data ranges for conditions
    Dim arr1() As Variant: Let arr1() = Rng1.Value2
    Dim arr1I() As Variant: Let arr1I() = Rng1.Columns(9).Value2
    Dim arr2() As Variant: Let arr2() = Rng2.Value2
    Dim arr2Z() As Variant: Let arr2Z() = Rng2.Columns("Z").Value2
    Rem 2 Do it
    Dim Cnt
        For Cnt = 2 To Lr1 Step 1
            If arr1I(Cnt, 1) <> "" Then
            Dim MtchRes As Variant
             Let MtchRes = Application.Match(arr1I(Cnt, 1), arr2Z(), 0)
                If IsError(MtchRes) Then
                ' column I 1.xls value is not in column Z of ap.xls
                Else '  column I of 1.xls matches with column Z of ap.xls
                    ' if column K of ap.xls is equals to column L of ap.xls
                    If arr2(MtchRes, 11) = arr2(MtchRes, 12) Then
                    ' If column H of 1.xls is greater than column D of 1.xls then
                        If arr1(Cnt, 8) > arr1(Cnt, 4) Then
                        'copy the first row of OrderFormat.xlsx & paste it to BasketOrder.xlsx
                         Let Ws3.Range("A1:U1").Value2 = Ws4.Range("A1:U1").Value2
                        ElseIf arr1(Cnt, 8) < arr1(Cnt, 4) Then ' If column H of 1.xls is less than column D of 1.xls then
                        'copy the third row of OrderFormat.xlsx & pate it to BasketOrder.xlsx
                         Let Ws3.Range("A1:U1").Value2 = Ws4.Range("A3:U3").Value2
                    ' column K of ap.xls is not equal to column L of ap.xls
            ' empty column I in 1.xls
    Macro for this post
    https://eileenslounge.com/viewtopic....271237#p271237
    https://eileenslounge.com/viewtopic....271255#p271255
    '    https://eileenslounge.com/viewtopic.php?f=30&t=34878&p=271237#p271237
    Sub Solution5()  '                                                     https://eileenslounge.com/viewtopic.php?f=30&t=34878&p=271237#p271237
    Dim arrK() As Variant: Let arrK() = ThisWorkbook.Worksheets("Main workbook").Range("K1:K" & ThisWorkbook.Worksheets("Main workbook").Range("A" & Rows.Count & "").End(xlUp).Row & "").Value
    'Debug.Print strSuc
    ' First half ##
     Let strNms() = Application.Index(ThisWorkbook.Worksheets("Main workbook").Cells, strRws(), 6)
     Let arrOut() = Application.Index(ThisWorkbook.Worksheets("Main workbook").Cells, Rws(), Clms())
     Let ThisWorkbook.Worksheets("consultant doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)) = arrOut()
    'Second half worksheet  Consultant doctor
    ' Main formatting
        With ThisWorkbook.Worksheets("Consultant doctor").UsedRange
        .Font.Size = 13
        ' Most borders
         Let ThisWorkbook.Worksheets("consultant doctor").Range("A" & Cnt & "").Offset(-26, 0).Resize(27, 24).Borders.LineStyle = xlContinuous
        ' Sum formulas
         Let ThisWorkbook.Worksheets("consultant doctor").Range("D" & Cnt + 1 & ":X" & Cnt + 1 & "").Value = "=IF(SUM(R[-28]C:R[-1]C)=0,"""",SUM(R[-28]C:R[-1]C))"
         Let ThisWorkbook.Worksheets("consultant doctor").Range("D" & Cnt + 7 & ":X" & Cnt + 7 & "").Value = "=R[-6]C"
     '     First signature                 Second signature                    third signature                 Fourth signature                    Fifth signature
         Let ThisWorkbook.Worksheets("consultant doctor").Range("A" & Cnt + 2 & ":X" & Cnt + 2 & "").Value = Array("", "First signature", "", "", "", "", "Second signature", "", "", "", "", "Third signature", "", "", "", "", "Fourth signature", "", "", "", "", "Fifth Signature", "", "")
       ' Bold stuff
         Let ThisWorkbook.Worksheets("consultant doctor").Range("A" & Cnt & "").Offset(1, 0).Resize(7, 24).Font.Bold = True
         Let ThisWorkbook.Worksheets("consultant doctor").Range("A" & Cnt + 1 & "").Value = "The total"
         Let ThisWorkbook.Worksheets("consultant doctor").Range("A" & Cnt + 7 & "").Value = "Previous total"
    ' First half##
    ' Second output worksheet  Specialist Doctor
    'Dim Clms() As Variant: Let Clms() = Array(1, 4, 6, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46)
    'Dim strRws() As String
    'Dim strNms() As Variant ' this will be the array of names in the order corresponding to the strRws() indicies
    'Dim rOuter As Long ' ========"Left Hand"========================Outer Loop=====================================
    '    Dim rInner As Long ' -------Inner Loop------------"Right Hand"--------------------------
    '           Dim varTemp As Variant ' I want to Swap those 2 above ( and the corresponding strRws() ) - I cant easilly in any coding change two values simulataneosly. So one of them Element values will put in this temporary place. This Element Values will then be given the other. Finally the other Element will be given this temporary value
    '           Dim TempRs As String
     Let strSpit = Join(strRws(), " ")
    'Dim TotRws As Long
     Let TotRws = (Len(strSpit) - Len(Replace(strSpit, " ", "", 1, -1, vbBinaryCompare))) + 1 ' effectively we are determining the number or spaces between the row indicies, then +1  to give us the number of row indicies
    'Dim Segs As Long
         Let strSpit = Application.WorksheetFunction.Substitute(strSpit, " ", " 1 1 1 1 1 1 1 ", Cnt - 6) '           https://excelfox.com/forum/showthread.php/2230-Built-in-VBA-methods-and-functions-to-alter-the-contents-of-existing-character-strings
    'Dim Rws() As String
    'Dim arrOut() As Variant
     Let ThisWorkbook.Worksheets("Specialist Doctor").Range("A7").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)) = arrOut()
    'Second half worksheet  Specialist Doctor
    ' Main formatting
        With ThisWorkbook.Worksheets("Specialist Doctor").UsedRange
        .Font.Size = 13
        ' Most borders
         Let ThisWorkbook.Worksheets("Specialist Doctor").Range("A" & Cnt & "").Offset(-26, 0).Resize(27, 24).Borders.LineStyle = xlContinuous
        ' Sum formulas
         Let ThisWorkbook.Worksheets("Specialist Doctor").Range("D" & Cnt + 1 & ":X" & Cnt + 1 & "").Value = "=IF(SUM(R[-28]C:R[-1]C)=0,"""",SUM(R[-28]C:R[-1]C))"
         Let ThisWorkbook.Worksheets("Specialist Doctor").Range("D" & Cnt + 7 & ":X" & Cnt + 7 & "").Value = "=R[-6]C"
         Let ThisWorkbook.Worksheets("Specialist Doctor").Range("A" & Cnt + 2 & ":X" & Cnt + 2 & "").Value = Array("", "First signature", "", "", "", "", "Second signature", "", "", "", "", "Third signature", "", "", "", "", "Fourth signature", "", "", "", "", "Fifth Signature", "", "")
       ' Bold stuff
         Let ThisWorkbook.Worksheets("Specialist Doctor").Range("A" & Cnt & "").Offset(1, 0).Resize(7, 24).Font.Bold = True
         Let ThisWorkbook.Worksheets("Specialist Doctor").Range("A" & Cnt + 1 & "").Value = "The total"
         Let ThisWorkbook.Worksheets("Specialist Doctor").Range("A" & Cnt + 7 & "").Value = "Previous total"
    Noptes in support of answer for this Post:
    https://excelfox.com/forum/showthrea...ll=1#post14591
    J
    K
    L
    M
    N
    O
    Exchange Symbol Series/Expiry Open High Low Prev Close LTP Wrong results
    NSE ACC EQ
    1265
    1282.7
    1246.5
    1275.3
    1247
    22
    BUY
    202
    <--Ws1
    NSE ADANIENT EQ
    151.85
    165.45
    151.4
    151.85
    152.35
    25
    BUY
    303
    NSE ADANIPORTS EQ
    348
    348
    338.5
    346.55
    338.85
    15083
    BUY
    output wanted in K of 1.xls which is Ws1 D E F G H I J K L
    Exchange Symbol Series/Expiry Open High Low Prev Close LTP wanted results
    NSE ACC EQ
    1265
    1282.7
    1246.5
    1275.3
    1247
    22
    BUY
    101
    NSE ADANIENT EQ
    151.85
    165.45
    151.4
    151.85
    152.35
    25
    BUY
    202
    NSE ADANIPORTS EQ
    348
    348
    338.5
    346.55
    338.85
    15083
    BUY
    303
    13
    14
    15
    Ws2 - AlertCodes.xlsx B C D E F G H I J K L
    16
    NSE
    22
    100
    A GTT
    17
    NSE
    25
    200
    A GTT
    18
    NSE
    15083
    300
    A GTT
    19
    Worksheet: 1-Sheet1 13July
  4. Concatenating your Balls
