Page 32 of 61 FirstFirst ... 22303132333442 ... LastLast
Results 311 to 320 of 604
  1. #311
    In support of this post:
    https://excelfox.com/forum/showthrea...pplied-over-it
    _____ Workbook: address sheet.xlsm ( Using Excel 2007 32 bit )
    Address Door# Direction street name roadtype street name + roadtype City Name
    204 6 AVE NW
    204
    AVE NW
    2510 5 AVE N
    2510
    AVE N
    1 CICADA RD
    CICADA RD
    100 annacis Pkwy
    100
    annacis Pkwy
    100 MAIN ST
    100
    MAIN ST
    10008 107 ST
    10008
    107
    ST
    1001 110 AVE
    1001
    110
    AVE
    10010 102A AVE NW
    10010
    102A AVE NW
    10115 110 AVE
    10115
    110
    AVE
    102 11 AVE S
    102
    S
    AVE
    10205 134 AVE NW
    10205
    134 AVE NW
    13
    10235 101 ST NW
    10235
    101 ST NW
    14
    10365 97 ST NW
    10365
    97 ST NW
    15
    105 MARTIN ST
    105
    MARTIN ST
    16
    10504 100 AVE
    10504
    100
    AVE
    17
    10600 100 ST
    10600
    100
    ST
    Worksheet: Sheet1
    Some notes in support in answering this question: https://excelfox.com/forum/showthrea...ata-if-matches
    If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx and if it matches then copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to sheet 1 of 2.xlsx in the row of the matched value in column A of sheet 1 of 2.xlsx
    i have pasted the result in sheet3 of 2.xlsx but the result should be in sheet1(I have pasted the result in sheet3 only for understanding purpose)
    Before:
    _____ Workbook: Actual File.xlsx ( Using Excel 2007 32 bit )
    J
    K
    NSE ASHOKLEY EQ
    65
    65.35
    60.55
    63.3
    63.3
    NSE BANKBARODA EQ
    62.1
    62.95
    56.15
    56.65
    56.65
    NSE BEL EQ
    66.15
    66.75
    62.4
    65.65
    65.65
    NSE EQUITAS EQ
    82
    82.05
    71
    73.05
    73.05
    NSE FEDERALBNK EQ
    68
    68.45
    62.45
    63.1
    63.1
    NSE GAIL EQ
    85
    88.8
    79.1
    79.95
    79.95
    NSE IDFCFIRSTB EQ
    32.1
    32.35
    27.2
    27.55
    27.55
    Worksheet: Sheet1
    _.................If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx
    _____ Workbook: 2 18May.xlsx ( Using Excel 2007 32 bit )
    Stock Name
    ACC
    ADANIENT
    ADANIPORTS
    ASHOKLEY
    EQUITAS
    L&TFH
    Worksheet: Sheet1
    J
    K
    L
    Worksheet: Sheet2
    _.......copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to sheet 1 of 2.xlsx
    After:
    J
    K
    L
    M
    Stock Name data data data data data data data data data data data data
    ACC
    100
    108
    120
    128
    134
    151
    6534
    30
    90
    97
    103
    ADANIENT
    101
    109
    121
    127
    135
    122
    782
    40
    92
    98
    ADANIPORTS
    102
    110
    122
    16
    137
    177
    93
    99
    104
    ASHOKLEY
    EQUITAS
    AMBUJACEM
    105
    117
    125
    133
    140
    746
    23
    80
    96
    102
    109
    Worksheet: Sheet3
    macro for solution to this Thread:
    ( Remember to include Public Function CL() )
    Sub CopyPaste20()  '   https://excelfox.com/forum/showthread.php/2494-Copy-and-paste-of-data-if-matches
    Rem 1 Worksheets info
    ' 2.xlsx
    Dim Wb2 As Workbook
     Set Wb2 = Workbooks("2.xlsx")
    Dim Ws1 As Worksheet: Set Ws1 = Wb2.Worksheets.Item(1)
    Dim Lr1 As Long
     Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row
    Dim arrA() As Variant: Let arrA() = Ws1.Range("A1:A" & Lr1 & "").Value2          '  2.xlsx sheet1 column A
    Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2)
    Dim Rng22 As Range: Set Rng22 = Ws2.Range("A1").CurrentRegion                    ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx
    ' Actual File.xlsx
    Dim Wb As Workbook, Ws As Worksheet
     Set Wb = Workbooks("Actual File.xlsx")
     Set Ws = Wb.Worksheets.Item(1)
    Dim Jmax As Long: Let Jmax = Ws.Range("J" & Ws.Rows.Count & "").End(xlUp).Row
    Dim arrB() As Variant: Let arrB() = Ws.Range("B1:B" & Jmax & "").Value2          ' Actual File.xlsx sheet1 column B
    Rem 2 do it
    Dim Cnt '                                               this is for - going down column A of 2.xlsx sheet1 looking for a match in  Actual File.xlsx sheet1 column B
        For Cnt = 2 To Jmax
        Dim MtchRes As Variant
         Let MtchRes = Application.Match(arrA(Cnt, 1), arrB(), 0)  '    - going down column A of 2.xlsx sheet1 looking for a match in  Actual File.xlsx sheet1 column B
            If IsError(MtchRes) Then
            ' no match  do nothing
            Else ' Cnt is now at the row number of where  2.xlsx sheet1 column A  was found in  Actual File.xlsx sheet1 column B
            Dim Lc1Cnt As Long: Let Lc1Cnt = Ws1.Cells.Item(Cnt, Ws1.Columns.Count).End(xlToLeft).Column
             Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").ClearContents ' clear row Cnt of all data before pasting
             Rng22.Copy Destination:=Ws1.Range("B" & Cnt & "")                ' copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to the row in  sheet 1 of 2.xlsx  at the row number of the matched value of 2.xlsx sheet1
    '     http://www.excelfox.com/forum/showthread.php/1546-TESTING-Column-Letter-test-Sort
    Notes for question 2 here
    https://excelfox.com/forum/showthrea...ll=1#post13379
    https://excelfox.com/forum/showthrea...ll=1#post13387
    Before is as here ,
    https://excelfox.com/forum/showthrea...ll=1#post13382
    , but ignore Sheet2 - no row is to be copied
    J
    K
    NSE ASHOKLEY EQ
    65
    65.35
    60.55
    63.3
    63.3
    NSE BANKBARODA EQ
    62.1
    62.95
    56.15
    56.65
    56.65
    NSE BEL EQ
    66.15
    66.75
    62.4
    65.65
    65.65
    NSE EQUITAS EQ
    82
    82.05
    71
    73.05
    73.05
    NSE FEDERALBNK EQ
    68
    68.45
    62.45
    63.1
    63.1
    NSE GAIL EQ
    85
    88.8
    79.1
    79.95
    79.95
    NSE IDFCFIRSTB EQ
    32.1
    32.35
    27.2
    27.55
    27.55
    NSE IOC EQ
    93
    93.65
    87.25
    87.9
    87.9
    NSE L&TFH EQ
    90
    91.55
    80.5
    81.65
    81.65
    Worksheet: Sheet1 (2)
    _____ Workbook: 2 (2).xlsx ( Using Excel 2007 32 bit )
    J
    K
    L
    M
    N
    O
    Stock Name data data data data data data data data data data data data data data
    ACC
    100
    108
    120
    128
    134
    151
    6534
    30
    90
    97
    103
    ADANIENT
    101
    109
    121
    127
    135
    122
    782
    40
    92
    98
    ADANIPORTS
    102
    110
    122
    16
    137
    177
    93
    99
    104
    ASHOKLEY
    16
    137
    177
    93
    99
    104
    EQUITAS
    93
    99
    102
    110
    122
    L&TFH
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    Worksheet: Sheet1
    If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx and if it matches then double the value of that row of 2.xlsx
    After
    J
    K
    L
    M
    N
    O
    ACC
    100
    108
    120
    128
    134
    151
    6534
    30
    90
    97
    103
    ADANIENT
    101
    109
    121
    127
    135
    122
    782
    40
    92
    98
    ADANIPORTS
    102
    110
    122
    16
    137
    177
    93
    99
    104
    ASHOKLEY
    274
    354
    20
    100
    186
    198
    208
    EQUITAS
    20
    100
    186
    198
    220
    244
    18
    20
    22
    L&TFH
    22
    24
    26
    28
    30
    32
    34
    36
    38
    40
    42
    44
    46
    Worksheet: Sheet2
    Note: I think your supplied After is wrong! - L&TFH should not be considered from Actual File.xlsx, because J of that row is not 1
    Macro for last post
    Sub CopyPaste20Q2()  ' Question 2  https://excelfox.com/forum/showthread.php/2494-Copy-and-paste-of-data-if-matches
    '    https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=13388&viewfull=1#post13388
    ' 2.xlsx
    Dim Wb2 As Workbook
    Dim Lr1 As Long
     ' Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2)
    ' Dim Rng22 As Range: Set Rng22 =   Ws2.Range("A1").CurrentRegion                    ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx
    ' Actual File.xlsx
    Rem 2 do it
        For Cnt = 2 To Jmax
            ' Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").ClearContents ' clear row Cnt of all data before pasting
            ' Rng22.Copy Destination:=Ws1.Range("B" & Cnt & "")                ' copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to the row in  sheet 1 of 2.xlsx  at the row number of the matched value of 2.xlsx sheet1
             Let Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Value = Ws1.Evaluate("=2*" & Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Address & "") '   then double the value of that row of 2.xlsx
    Macro for this post:
    https://excelfox.com/forum/showthrea...ll=1#post13397
    Sub ConditionalCalcPaste()   '    https://excelfox.com/forum/showthread.php/2495-Conditional-calculation-and-pasting-of-the-data
    '1a)  2.xlsx
    Dim Wb2 As Workbook
    Dim Lr1 As Long
    'Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2)
    'Dim Rng22 As Range: Set Rng22 = Ws2.Range("A1").CurrentRegion                    ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx
    '1b) Actual File.xlsx
    Dim Lr As Long: Let Lr = Ws.Range("A" & Ws.Rows.Count & "").End(xlUp).Row                                                 ' Dim Jmax As Long: Let Jmax = Ws.Range("J" & Ws.Rows.Count & "").End(xlUp).Row
    Dim rngIn As Range: Set rngIn = Ws.Range("A1:S" & Lr & "")
    Dim arrIn() As Variant, arrOut() As Variant: Let arrIn() = rngIn.Value2
    Dim arrB() As Variant: Let arrB() = Ws.Range("B1:B" & Lr & "").Value2            '  Ws.Range("B1:B" & Jmax & "").Value2          ' Actual File.xlsx sheet1 column B
    '1c '  calculate the total value of column Q of ActualFile.xlsx and if it is Greater than S10 of ActualFile.xlsx then
    Dim SomeQ As Double: Let SomeQ = Ws.Evaluate("=SUM(Q2:Q" & Lr & ")") '   total value of column Q of ActualFile.xlsx
     Let SomeQ = Application.WorksheetFunction.Round(SomeQ, 2)
    Dim S10Val As Double: Let S10Val = arrIn(10, 19)                     '   S10 of ActualFile.xlsx
        If SomeQ > S10Val Then      '  total value of column Q of ActualFile.xlsx and if it is Greater than S10 of ActualFile.xlsx then do nothing
        ' do nothing
        ElseIf SomeQ < S10Val Then  ' if it is lower than S10 of ActualFile.xlsx then divide S10 of ActualFile.xlsx with the total value of Column Q of ActualFile.xlsx
        Dim S10dQ As Double: Let S10dQ = S10Val / SomeQ ' Divide S10 of ActualFile.xlsx with the total value of Column Q of ActualFile.xlsx
          Let S10dQ = Int(S10dQ) ' Application.WorksheetFunction.Round(S10dQ, 4)
            For Cnt = 2 To Lr1 '                               Jmax
                 Let Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Value = Ws1.Evaluate("=" & S10dQ & "*" & Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Address & "")  ' Ws1.Evaluate("=2*" & Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Address & "") '   then double the value of that row of 2.xlsx
        ' Sum = S10
        End If ' SumQ>S10
    Share 'Actual File.xlsx' : https://app.box.com/s/9dfaq1997whyyj0jq7ew30sixcmq9zpm
    Share '2.xlsx' : https://app.box.com/s/ij24a4nmnnvi0h4qr13h49ro05aouatk
    Share 'macro.xlsm' : https://app.box.com/s/599q2it3uck3hfwm5kscmmgtn0be66wt
    Test ranges used to answer this post:
    https://excelfox.com/forum/showthrea...ll=1#post13401
    Before:
    J
    K
    L
    M
    N
    O
    P
    Q
    NSE ASHOKLEY EQ
    65
    65.35
    60.55
    63.3
    63.3
    1.055
    1.055
    54
    56.97
    NSE BANKBARODA EQ
    62.1
    62.95
    56.15
    56.65
    56.65
    60
    0.944167
    5.665
    54
    50.985
    NSE BEL EQ
    66.15
    66.75
    62.4
    65.65
    65.65
    60
    1.094167
    6.565
    54
    59.085
    NSE EQUITAS EQ
    82
    82.05
    71
    73.05
    73.05
    1.2175
    1.2175
    54
    65.745
    NSE FEDERALBNK EQ
    68
    68.45
    62.45
    63.1
    63.1
    60
    1.051667
    6.31
    54
    56.79
    NSE GAIL EQ
    85
    88.8
    79.1
    79.95
    79.95
    60
    1.3325
    7.995
    54
    71.955
    NSE IDFCFIRSTB EQ
    32.1
    32.35
    27.2
    27.55
    27.55
    0.459167
    0.459167
    54
    24.795
    NSE IOC EQ
    93
    93.65
    87.25
    87.9
    87.9
    1.465
    1.465
    54
    79.11
    NSE L&TFH EQ
    90
    91.55
    80.5
    81.65
    81.65
    51
    1.60098
    9.605882
    54
    86.45294
    _____ Workbook: 2.xlsx ( Using Excel 2007 32 bit )
    J
    K
    L
    M
    N
    O
    ACC
    100
    108
    120
    128
    134
    151
    6534
    30
    90
    97
    103
    ADANIENT
    101
    109
    121
    127
    135
    122
    782
    40
    92
    98
    ADANIPORTS
    102
    110
    122
    16
    137
    177
    93
    99
    104
    ASHOKLEY
    16
    137
    177
    ANJALIPHARMA
    93
    99
    102
    110
    122
    SUNTECK
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    Worksheet: Sheet1 (5)
    O
    P
    Q
    R
    S
    6.31
    54
    56.79
    7.995
    54
    71.955
    Total Fund Amount
    8387.320769
    54
    24.795
    Current Fund Amount
    9000
    1.465
    54
    79.11
    Fund Allocated
    8000
    54
    86.45294
    Profit Amount
    1000
    Sum is
    551.8879
    Q
    59.085
    65.745
    56.79
    71.955
    79.11
    =SUM(Q2:Q10)
    In this example sum of column Q is less than Range S10 value so nothing is done
    Macro for last post, and to answer this post:
    Sub CopyPaste20Q2b()  ' https://excelfox.com/forum/showthread.php/2494-Copy-and-paste-of-data-if-matches?p=13401&viewfull=1#post13401
    ' 2.xlsx
    Dim Wb2 As Workbook
    Dim Lr1 As Long
    ' Actual File.xlsx
    Dim S10Val As Double: Let S10Val = Ws.Range("S10").Value                     '   S10 of ActualFile.xlsx
        If SomeQ > S10Val Then      '  total value of column Q of ActualFile.xlsx and if it is Greater than S10 of ActualFile.xlsx then this macro should do the process
        Rem 2 do it
        Dim Cnt '                                               this is for - going down column A of 2.xlsx sheet1 looking for a match in  Actual File.xlsx sheet1 column B but only as far as JMax
        ' else do nothing
    Just testing
    ignore all this
    C:\Users
    ror Resume Next
    Set WB1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls")
    If Err <> 0 Then
  4. Concatenating your Balls
