Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: Word Tests. Useful older stuff. Older versions. Chris stuff etc
  1. #11
    Word File Save As ___.htm
    At this stage, I would like to check what happens in terms of produced files and folders for some different files
    The OP’s file
    _ as he gave it, named 2. KEEP DUPLICATE RECORDS.docx
    _ name changed to 2_ KEEP DUPLICATE RECORDS.docx
    _ name changed to the Office 97 – 2003 format 2_ KEEP DUPLICATE RECORDS.doc
    _ the file with all images removed
    _ the file with everything removed
    _ a new virgin file
    I will do all that programmatically, for convenience and consistency since I might repeat the experiment in different Excel versions. ( So far most of my work is in Office 2007 )
    As a prelude to that, to help get some syntaxes, I will do some of that manually first, whilst running a macro recorder
    This is approximately what the macro recorder gave me. I have simplified it a bit and added some 'comments
    Sub Makro7()
    ' Makro7 Makro   https://excelfox.com/forum/showthread.php/2348-Just-Testing-Passing-info-between-Word-and-Excel?p=15643&viewfull=1#post15643
    '  OPs  original file
        ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\"
        Documents.Open Filename:="""2. KEEP DUPLICATE RECORDS.docx""", ConfirmConversions:=False, ReadOnly:=False, AddToRecentFiles:=False, PasswordDocument:="", PasswordTemplate:="", Revert:=False, WritePasswordDocument:="", WritePasswordTemplate:="", Format:=wdOpenFormatAuto, XMLTransform:="", DocumentDirection:=wdLeftToRight
        ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\Original OP File\"
        ActiveDocument.SaveAs Filename:="2. KEEP DUPLICATE RECORDS.docx", FileFormat:=wdFormatXMLDocument, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
        ActiveDocument.SaveAs Filename:="2. KEEP DUPLICATE RECORDS.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
        ActiveWindow.View.Type = wdWebView
        ActiveDocument.Close ' close the  .htm file
    '  OPs file with dot in name changed to underscore
        RecentFiles(3).Open
        ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\Ops File with dot in name changed to underscore\"
        ActiveDocument.SaveAs Filename:="2_ KEEP DUPLICATE RECORDS.docx", FileFormat:=wdFormatXMLDocument, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
        ActiveDocument.SaveAs Filename:="2_ KEEP DUPLICATE RECORDS.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    ' File in Office 97 - 2003 format
        RecentFiles(3).Open
        ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\Ops file in 97 -2003 format\"
        ActiveDocument.SaveAs Filename:="2_ KEEP DUPLICATE RECORDS.doc", FileFormat:=wdFormatDocument, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    ' Ops file no images
        RecentFiles(3).Open
        Selection.MoveDown Unit:=wdLine, Count:=6
        Selection.TypeBackspace
        Selection.MoveDown Unit:=wdLine, Count:=2
        Selection.MoveDown Unit:=wdLine, Count:=4
        ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\Ops File no images\"
        ActiveDocument.SaveAs Filename:="2. KEEP DUPLICATE RECORDS no images.docx", FileFormat:=wdFormatXMLDocument, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
        ActiveDocument.SaveAs Filename:="2. KEEP DUPLICATE RECORDS no images.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    ' Empty OP file
        RecentFiles(3).Open
        Selection.WholeStory
        ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\OPs file empty\"
        ActiveDocument.SaveAs Filename:="2. KEEP DUPLICATE RECORDS empty.docx", FileFormat:=wdFormatXMLDocument, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
        ActiveDocument.SaveAs Filename:="2. KEEP DUPLICATE RECORDS empty.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    '  Virgin file
        Documents.Add Template:="Normal", NewTemplate:=False, DocumentType:=0 ' make file
        ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\Virgin empty file\"
        ActiveDocument.SaveAs Filename:="Dok2.docx", FileFormat:=wdFormatXMLDocument, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
        ActiveDocument.SaveAs Filename:="Dok2.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    Here is the files produced
    ' OPs original file
    ' Empty OP file
    ' Virgin file
    We seem to have some inconstancy with the files and folders produced by the original OP macro, ( https://excelfox.com/forum/showthrea...ll=1#post15623 ) , so in the next post I had better check that first..
    The inconstancy seems to be that a .htm file was not produced – instead some strange file was there , one with no extension shown, and the new file folder produced did not have the full name 2. KEEP DUPLICATE RECORDS-Files , instead it came out as 2-Files
    Attachment 3625Attachment 3626
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgxzpgHWTLGj0C3q3gx4AaABAg.9gxsUMU53al9k5c8W6QG E8
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg.9gxDYq2iiZ89h4ISxLD1 7d
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg.9gxDYq2iiZ89h4LdsDET im
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg.9gxDYq2iiZ89h32czjty R_
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugw_smEwvNffCPr_nrB4AaABAg.9gvyL53lI1l9gxwd_9-V6z
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugy7vmiHsQ0oUt2QCPZ4AaABAg.9gvoy4OW6lU9gxwxC5-rL9
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgzuX3uYmqJRtsZIbqF4AaABAg.9gth61YhXKB9gxxCMdRL A0
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgxcPC64RQGmXwO5rft4AaABAg.9gtQLXaeg0e9gxxNuc5C CM
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwCY8vOs1DFHgYSJwF4AaABAg.9godrFcyWYw9gxy1odpi Rj
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgyL5nh_j8w70-YBoUt4AaABAg.9goMcRjwjtc9gxyslvuZKx
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwwWRgmRZNqJKptHR14AaABAg.9go-DbayTZa9gxzPbefHXf
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwF3wECwc8tVoRmz6B4AaABAg.9go-5xLQM8P9gxzmB7nkVQ
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgyRDmGTHnMdT7dl_qx4AaABAg
  2. #12
    We seem to have some inconstancy with the files and folders produced by the original OP macro, ( https://excelfox.com/forum/showthrea...ll=1#post15623 ) , and those in the last post, so I will look into that here.
    The inconstancy seems to be that a .htm file was not produced by the original OP macro– instead some strange file was there , one with no extension shown, and the new file folder produced did not have the full name 2. KEEP DUPLICATE RECORDS-Files , instead it came out as 2-Files
    I had a little play around, and it looks I have tracked down the problem.
    To demo:-
    The following macro doers three Save As .htm code lines. The first does something similar to the original OP’s
    The second has replaced the first _ . _ in the file name with a _ _ _
    The final code line does the code line what the macro recorder gave.
    Looking at the three results, it is obvious what’s probably going on: The missing .htm in the OP’s code line is causing the problem. Although we are saving as FileFormat:=wdFormatHTML , it gets no extension on the file name.
    Without knowing exactly how Microsoft organised the working things, I cannot say exactly what is going on, but then file shown with no extension is clearly the htm file – we can prove this by opening with word, and it appears exactly the same as any of the 2. KEEP DUPLICATE RECORDS.htm files that we have been producing. The little discrepancy fact that the folder containing the images gets a name like 2-xxxx instead of like 2-2. KEEP DUPLICATE RECORDS xxxx , is probably because the workings are somehow mistaking the first _ . _ as the extension _ . _.
    That discrepancy does not appear when we replace the _ . _ with some other character, as in the second Save As .htm code line
    In fact, we also get a normal .htm extension as well. So this suggests that the workings are somehow confusing that first _ . _ as meaning that the extension is _ KEEP DUPLICATE RECORDS
    So the conclusion is:
    Most important you should add the .htm extension on the given file name.
    It is probably good practice to not have an extra _ . _ in any file name
    Results:
    ActiveDocument.SaveAs FileName:=strPath & "Temp1" & "" & "2. KEEP DUPLICATE RECORDS", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:= True
    ActiveDocument.SaveAs FileName:=strPath & "Temp2" & "" & "2_ KEEP DUPLICATE RECORDS", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False
    ActiveDocument.SaveAs FileName:=TempFolder & "" & "2. KEEP DUPLICATE RECORDS.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False ', EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    Sub OPsFileMakesStrangeFiles()  '   https://excelfox.com/forum/showthread.php/2348-Just-Testing-Passing-info-between-Word-and-Excel?p=15644&viewfull=1#post15644
    Dim strPath As String: Let strPath = "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\"
     Documents.Open Filename:="F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\2. KEEP DUPLICATE RECORDS.docx" ' This wont error if document file is already open
        If Dir(strPath & "Temp1", vbDirectory) = "" Then MkDir strPath & "Temp1"
     ActiveDocument.SaveAs Filename:=strPath & "Temp1" & "\" & "2. KEEP DUPLICATE RECORDS", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=True
        If Dir(strPath & "Temp2", vbDirectory) = "" Then MkDir strPath & "Temp2"
     ActiveDocument.SaveAs Filename:=strPath & "Temp2" & "\" & "2_ KEEP DUPLICATE RECORDS", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False
        If Dir(strPath & "Temp3", vbDirectory) = "" Then MkDir strPath & "Temp3"
     ActiveDocument.SaveAs Filename:=TempFolder & "\" & "2. KEEP DUPLICATE RECORDS.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False ', EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    upload pictures
    test
    Mein Deutsch nicht so gut ist, da ich Engländer bin, aber ich werde es versuchen...
    Dies hängt mit einigen anderen ungelösten Dingen zusammen ( https://www.dsl-forum.de/threads/251...line-verbunden
    https://telekomhilft.telekom.de/t5/T...s/td-p/5342695 )
    Seit etwa einem Monat funktioniert meine Internetverbindung nicht mehr. Anfangs dachte man, es könnte ein Problem mit meinem alten Speedport W504V-Router sein.
    Ich war daran interessiert, weiter zu experimentieren, um diesen Verdacht zu bestätigen.
    Die Ergebnisse sind etwas seltsam:
    Ich habe noch ein paar andere Speedport W504Vs bekommen, die normal funktionierten, vor sie nicht mehr benutz, bzw. nicht mehr gebraucht war, und auch ein neues originalverpacktes, das nie benutzt wurde.
    Sie weisen alle das gleiche Problem auf wie ursprünglich bei meinem alten Speedport W504V: Sie verbinden sich alle erfolgreich, gehen online, aber das Internet funktioniert nicht und sie antworten weder auf 192.168.2.1 noch auf https://speedport.ip in der Adressleiste
    Hier sind typische Ergebnisse einer erfolgreichen Verbindung für eine direkte LAN-Kabelverbindung:
    https://i.postimg.cc/8CKFTQzM/Speedp...-LAN-Kable.jpg
    und hier sind typische Ergebnisse für eine erfolgreiche WLAN-Verbindung
    https://i.postimg.cc/fRsSKfPt/First-...-Connected.jpg
    https://i.postimg.cc/FRYYRWYq/First-...ssel-Geben.jpg
    https://i.postimg.cc/TYgWg4tv/First-...-Connected.jpg
    https://i.postimg.cc/VNLryLmz/First-...ed-working.jpg
    Aber danach bekommt man kein funktionierendes Internet, und beim IP 192.168.2.1 oder https://speedport.ip in die Adresszeile eingebe, kommt nur "Fehler: Netzwerk-Zeitüberschreitung - Der Server unter speedport.ip braucht zu lange, um eine Antwort zu senden." Egal mit welchem Browser oder Computer
    Das Überprüfen von Dingen wie ipconfig usw. bestätigt alle Gateway 192.168.2.1, wie es für den Speedport erwartet wird
    Der ganz neue Speedport reagierte bei der ersten Verbindung etwas anders, wie es sich gehört: Ein neuer Speedport bewirkt ein anfängliches Öffnen eines Browser-Tabs direkt beim anfänglichen Einrichtungsvorgang:
    https://i.postimg.cc/CMJGdtrP/New-Sp...connection.jpg
    https://i.postimg.cc/Xq2dhGyS/New-Sp...re-warning.jpg
    https://i.postimg.cc/7hPSmMhn/New-Sp...figuration.jpg
    Aber das scheitert beim ersten Schritt: Ich tippe hier das richtige Passwort ein, aber ich bekomme eine Fehlermeldung und komme nicht weiter.
    https://i.postimg.cc/FRVjynrK/New-Sp...t-Password.jpg
    Was das Ganze noch seltsamer macht, ist, dass ich einige alte Speedport W723s habe und sie alle normal funktionieren, mir ein funktionierendes Internet geben und auch wie erwartet reagieren, wenn sie 192.168.2.1 oder https://speedport.ip in die Adressleiste eingeben
    Andere Router, die ich habe, funktionieren auch normal.
    Ich habe meine Experimente mit vielen verschiedenen Computern mit unterschiedlichen Betriebssystemen wiederholt und die Ergebnisse sind immer gleich.
    Es ist nicht möglich, dass alle meine Speedport W504v kaputt sind. Ich gehe davon aus, dass sie alle so funktionieren, wie sie ursprünglich entwickelt wurden.
    Es scheint, dass etwas Seltsames passiert ist, so dass kein Speedport W504V mehr funktioniert???
    Habe die Telekom eine grundlegende Änderung vorgenommen, wonach ein Speedport W504V nun nie mehr funktioniert???
    Direct link for forum
    [url=https://postimages.org/][img]https://i.postimg.cc/QC7swWy4/Here-Excel-forum-colors-ohne-rand.jpg[/img][/url]
    [url=https://postimages.org/][img]https://i.postimg.cc/7PJxfpZ3/Here-Excel-fox-colors-ohne-rand.jpg[/img][/url]
    now change link to post imagers to the link you want it to got to
    Hello Chris, ( and Stuart )
    In Excel things occasionally go out of whack in my VB Editor and I am buggered if I can ever find a way to get them back normally using any conventional method. Usually the docking of windows getting corrupted has been to blame.
    So far the sledgehammer approach explained has always put the VB Editor back to normal for me.
    ( In case that old post link does not work, or they insist on you logging in and you don’t want to, I just put a copy of that post for you )
    ( you might need to look at a slightly different path in the registry. Someone else said they found it here: Computer\HKEY_CURRENT_USER\Software\Microsoft\VBA\ 7.1\Common
    _.______________
    Here
    Here
    ExcelFox
    ExcelFox
    Here
    Here
    https://www.excelforum.com/excel-programming-vba-macros/343845-docking-project-explorer-vertically.html#post4545938
    https://i.postimg.cc/9Rf6XHnm/Here-link-Bild.jpg[/img]
    _.____________________
    _.______________
    vorschor bild for forum
    _.__________________________-
    direct link for forum complete
    or 0r
    Now change link to postimages.org to the link you want it to go to
    or or
  5. #15
    ABADB
  6. #16
  7. #17
    ascsaasd
  8. #18
    XBAmba
  9. #19
    BDAdbABD
  10. #20
    A;;MBABDA
  1. Class Stuff: VBA Custom Classes & Objects, Class Modules
    By DocAElstein in forum Excel and VBA Tips and Tricks
    Last Post: 06-02-2024, 01:49 PM
  2. Gif Image Video stuff testies
    Last Post: 09-06-2021, 01:07 PM
  3. Test my rights , to do stuff
    By TestAccount in forum Test Area
    Last Post: 10-07-2020, 11:49 AM
  4. Replies: 25
    Last Post: 03-10-2020, 01:28 PM
    Last Post: 04-02-2019, 03:04 PM
