Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Word Tests. Useful older stuff. Older versions. Chris stuff etc
    Some notes and tests in support of possible answer to this Thread:
    http://www.excelfox.com/forum/showth...rom-Excel-Data
    Related also to these posts:
    https://tinyurl.com/y3j3klvo
    https://tinyurl.com/y5n4x7ku
    https://tinyurl.com/y4av8rer
    https://tinyurl.com/y4b34a9g
    Code to make Day list from Excel File and show in Pop up Word .htm File.
    MakeTagList Button , Sub MakeTagList()
    This post gives some Overview notes for later reference to help clarify some other more detailed excelfox Threads.
    MakeTagList Button. Briefly, overview:
    The code Sub MakeTagList(), primarily does two things:
    _ makes a simple text file with the important details from a Daily Diet Protocol
    DailyTextFileForEmailAttatchment.JPG : https://imgur.com/MqEmlDF
    Attachment 2053
    _ makes a long string of HTML coding which if written to a text file, (but with the usually given .txt extension replaced with .htm ), is recognised by Microsoft Word which can open it in a form which looks similar to a normal Word doc
    That Word File is opened temporarily to show a pretty table form of the important details from a Daily Diet Protocol:
    TemporaryWordPopUp.JPG : https://imgur.com/ZFhsdaQ
    Attachment 2054
    _.___________
    arrNuts()
    The start point is that an array is made of used food products from daily pro, arrNuts()
    arrNuts()
    is the = Items() array from a Dictionary. So it is a one dimension array starting at arrNuts(0). Each Element is a row from the from the Daily Excel Diet Protocol File, "ProAktuellex8600x2.xlsm". It is built up from a line like pseudo
             Key:=ProRow with Entry in C column, Item:=Array(FoodProduct in 1st Column A , amount eaten from 3rd Column C  , Kcal total in 9th column I  , Fett , Eiweiß  …. Etc.
    ( The Key is not used currently )
    Rem 5 Text File
    A text file is made from the array with a pipe, _ | _ , as separator like from:
    arrNuts(0)(0) & "|" & arrNuts(0)(1) & "|" & arrNuts(0)(2) ……..etc..
    arrNuts(1)(0) & "|" & arrNuts(1)(1) & "|" & arrNuts(1)(2) ……..etc..
    arrNuts(2)(0) & …..etc..
    The final text file is stored in the same Folder as most of the files to do with daily protocols, that is to say, the currently used main Folder . It is given a name something of the form pseudo
    "MonatsUebersichtAnhang " & Date in format like "mmmm yyyy" & ".txt"
    As example for any day in April, 2018, it will be like
    "MonatsUebersichtAnhang April 2018.txt"
    The main purpose of this text file is to have a file that can be attached to an Email which at the receiving end can then be for recording and using the important daily nutrition values in a graphic
    I use the standard VBA type code lines for this , pseudo like
    Open C: \ __ \ _ \ ¬¬¬-___"MonatsUebersichtAnhang April 2018.txt" For __ As __
    _.___________
    _ makes a long string of HTML coding which if written to a text file, (but with the usually given .txt extension replaced with .htm ), is recognised by Microsoft Word and can opens it in a form which looks similar to a normal Word doc
    Rem 6 .htm Word Template File
    An empty or almost empty .htm Word file, "DailyProtable.htm " , ( which should be in the main currently used Folder already , - ( download from box if necessary ) ) is converted into a single very long String variable , TotalFile
    I use the fairly standard VBA way often used to get this long string from a .txt file. It seems to work equally well for a .htm file
    Rem 6 get Template File as long HTML string . Template file is an almost empty Word .htm file.
    Dim FileNum As Long: Let FileNum = FreeFile(1)    ' https://msdn.microsoft.com/en-us/vba/language-reference-vba/articles/freefile-function
     Let PathAndFileName = ThisWorkbook.Path & "\" & "DailyProtable.htm" ' Template file never changes
      Open PathAndFileName For Binary As #FileNum 'Open Route to data. Binary is a fundemental type data input...
        TotalFile = Space(LOF(FileNum)) '....and wot recives it hs to be a string of exactly the right length
        Get #FileNum, , TotalFile
      Close #FileNum
    Rem 7 modify main body text section of the template file
    Rem 7
    Things start getting a bit complicated now. It may help at this point to give a summary of the overall goal:
    The final aim of this code and the associated code usually done just after, Sub PetrasDailyProWay1_COM_Way() , is to get a pretty summary table in a HTML code such as it is in a form that can be used for two things:
    _ Temporarily in a Word .htm file which is opened temporarily to show the current stand of a finished or almost finished protocol,
    _ part of that ( the main body part ) can be isolated into a functioning variable , MyLengthyStreaming , and used in the typical LECMO technology code lines of the form
    CDO.Message.HTMLBody = MyLengthyStreaming
    CDO.Message.Send
    ( In actual fact the entire Word.htm HTML string, TotalFile , could usually be used, but I do not do this as
    _ TotalFile has a lot of unnecessary text, presumably needed for Word .htm file recognition
    as well as
    _ there are some subtle problems which need to be addresses with the string before it can be used with German Telekom, as it appears that a Bug means that the German Telekom does not quite recognise correctly that standard HTML coding ( gmail and AOL seem not to have this problem ) https://telekomhilft.telekom.de/t5/E...136416#M129791
    What basically needs to be done is to modify the TotalFile at the main body part. This Part of the text is almost empty at this stage. That almost empty main body part is replaced by a made pretty HTML table
    It is all done in a bit of a messy way, and it is easy to lose track of what is going on. Once again, the purpose of this code:
    In Rem 7 we basically embed a Table ( in HTML coding form ) by doing a simple Replace of the start part of the main body in the string from the Template .htm file which looks like this
    <div class=WordSection1> ( You can see that yourself if you open up the .htm file using a simple text editor, and look towards the end MainWordSectionBody.JPG : https://imgur.com/HWjHTyz )
    That existing HTML coding, <div class=WordSection1> , is Replaced by
    <div class=WordSection1> & A made HTML table done in a Function
    That Function is called using the arrNuts() thus:
    ProTble(arrNuts())
    Function ProTble()
    By a bit of trial and error and learning some basic HTML coding I was able to write this function which based on the data given in arrNuts() gives a lot of HTML coding which a Browser ( or Word when it has it included in the long HTML string opened using a .htm extension file ) can understand and produce a table formatted as I want:
    Rem 8
    Back in the main code we now have our original full file text string of HTML coding, TotalFile , modified to include in it the pretty table
    The string is printed out to a text file in the usually way but with the .htm extension instead of the usual .txt extension. This file is currently given the name
    "DailyProtableFilled.htm"
    Rem 8 Over write the last ( likely yesterdays ) filled file,  with the modified template file which is mainly still that what Word recognises as we only modified a bit of the main text body
    Dim HighwayToHelloPro As Long ' For rewrite of modified DailyProtable.htm as DailyProtable.htm2
     Let HighwayToHelloPro = FreeFile(0)
     Open ThisWorkbook.Path & "\" & "DailyProtableFilled.htm" For Output As #HighwayToHelloPro ' Will be made if not there, and overwritten as Output rahter than Append
     Print #HighwayToHelloPro, TotalFile
     Close #HighwayToHelloPro
    Rem 9 get Word using Excel
    Rem 9
    The final part of the code, Sub MakeTagList() , which is initiated by the Button, MakeTagList , brings up the file, "DailyProtableFilled.htm" , temporarily in Microsoft Word.
    _.___________
    Required Files:
    Daily Diet Protocol :
    "ProAktuellex8600x2.xlsm" :
    https://app.box.com/s/fpztob9pcp92fl6hh81zgpzumw9ntcp0 ( Current )
    https://www.magentacloud.de/share/38m-zuc2y3#$/ ( April 2018 )
    Main Makro File:
    "NeuProAktuelleMakros.xlsm" :
    https://app.box.com/s/e93u19xidygreeeenlxyupm750dxe33f ( Current )
    Usually in practical use, the execution of the last coding would be followed by the sending of the EMail using the Send Pro Mail Button.
    Ref:
    http://www.eileenslounge.com/viewtop...=29556#p228710
    http://www.excelfox.com/forum/showth...0528#post10528
    Coding in support of this Thread
    http://www.excelfox.com/forum/showth...1384#post11384
    'Sub LateEarlyBinding()
    ' On Error Resume Next ' If it is always there you get  Name steht in Konflikt mit vorhandenem Modul, Projekt oder vorhandener Objektbibliothek  RuntimeError32813.JPG : https://imgur.com/N0BN7m2     If it is not there then usually it does not error, but will in Debug F8 mode  Change to the hold mode is not possible at this time.JPG : https://imgur.com/v9inlwM but it works anyway and ignores the error handler in this case
    ' ThisWorkbook.VBProject.References.AddFromguid GUID:="{420B2830-E718-11CF-893D-00A0C9054228}", major:=1, Minor:=0
    ' Debug.Print Err.Description
    ' On Error GoTo 0 ' Clears exception and the   Err.Description   also is cleared
    'End Sub
    Sub MakeTagList() ' A Table  is made and embedded in the main body text of an existing .htm Word readable file which must already exist and be in the same folder as this workbook. That is set to pop up in word briefly. (The main body of the htm file can  then used later as the .HTMLBody in an email )
    '                                            Call LateEarlyBinding ' Microsoft Scripting Runtime
    Rem 4 Array from range
    Dim arrNuts() As Variant: Let arrNuts() = ThisWorkbook.Worksheets.Item(1).Range("A2:B3").Value
    Rem 6 get Template File as long HTML string . Template file is an almost empty Word .htm file with just    "I would like to put here Table1. Here is some other text"  .
     Let PathAndFileName = ThisWorkbook.Path & "\" & "WordFile.htm" ' Template file never changes
      Close #FileNum
     Debug.Print TotalFile
    '7a) Start bit, and call of HTML table genarator Function
    Dim MyLengthyStreaming As String
     Let MyLengthyStreaming = "<p></p><p></p>" & MyLengthyStreaming & ProTble(arrNuts())
     Let TotalFile = Replace(TotalFile, "Table:_1.<o:p></o:p></span></i></p>", "Table:_1.<o:p></o:p></span></i></p>" & vbCrLf & MyLengthyStreaming, 1, 1, vbTextCompare)
    '7b) anything after table
    Dim sT As String, aFt As String: Let sT = "Bit after table to aid in adding stuff in main code" ' This string was put on the end od the final HTML table so as to have a thing to replace with something like the end of th table
     Let aFt = "<p>" & ThisWorkbook.Worksheets.Item(1).Range("A1").Value & "</p><p>.</p>" ' Put table Header under table
    ' Let aFt = "<p><span style=""color: #ff00ff;"">'_---Table made " & Format(Now(), "DD MMMM YYYY") & " " & Now() & " ====Daily Foods Table End ======</span></p>"
     Let TotalFile = Replace(TotalFile, sT, aFt, 1, 1, vbBinaryCompare)
    ' Debug.Print TotalFile
    Rem 8 Make new file with modified long HTML string
     Open ThisWorkbook.Path & "\" & "WordFile2.htm" For Output As #HighwayToHelloPro ' Will be made if not there, and overwritten as Output rahter than Append
    Dim appWord As Object                           '  Dim appWord As Word.Application
     Set appWord = CreateObject("Word.Application") '   Set appWord = New Word.Application '
     appWord.Visible = True
     appWord.Documents.Open Filename:=ThisWorkbook.Path & "\" & "WordFile2.htm", ConfirmConversions:=False, ReadOnly:=False, AddToRecentFiles:=False, PasswordDocument:="", PasswordTemplate:="", Revert:=False, WritePasswordDocument:="", WritePasswordTemplate:="", Format:=0, XMLTransform:="", DocumentDirection:=0
     appWord.Documents("WordFile2.htm").Activate
     Application.WindowState = xlMinimized
     Application.OnTime Now + TimeSerial(0, 0, 5), "Modul1.GetWordObjClose"
    '9b) Some Word Formatting
    'Windows("ProAktuellex8600x211.3.xlsm").Activate
    'Dim docMsg As Document '
    ' Set docMsg = ActiveDocument ' Documents("DailyProtableFilled")
    ' docMsg.Range(0, 100).Select
    '  Selection.WholeStory
    '    With Selection.ParagraphFormat
    '     .SpaceBeforeAuto = False
    '     .SpaceAfterAuto = False
    '    End With
    Sub GetWordObjClose() ' Close the daily pro in word
     Application.WindowState = xlNormal
     Set appWord = GetObject(, "Word.Application"): appWord.Visible = True ' This will open new instance of word and make it visible ( with no document). If one is open then it will be set to the appWord variable
    Dim Dock As Variant
        For Each Dock In appWord.Documents
         Dock.Save
         Dock.Close
        Next Dock
    ' appWord.ActiveDocument.Save
    ' appWord.ActiveDocument.Close
     appWord.Quit
     'Application.Windows("" & ProWb.Name & "").Activate
     'Application.Windows("" & ProWb.Name & "").WindowState = xlNormal
     'ActiveWindow.WindowState = xlNormal
    Function ProTble(ByRef arrNuts() As Variant) As String
    ' Table start
    Let ProTble = _
    "<table width=800" & vbCrLf & _
    "<col width=400" & vbCrLf & _
    "<col width=400>" & vbCrLf & vbCrLf
    Dim iCnt As Long, jCnt As Long ' data "rows" , "columns"
        For jCnt = 1 To UBound(arrNuts(), 1)
        Dim LisRoe As String
         Let LisRoe = LisRoe & "<tr height=16>" & vbCrLf
            For iCnt = 1 To UBound(arrNuts(), 2)
             Let LisRoe = LisRoe & "<td>" & arrNuts(jCnt, iCnt) & "</td>" & vbCrLf
            Next iCnt
         Let LisRoe = LisRoe & "</tr>" & vbCrLf & vbCrLf
         Let ProTble = ProTble & LisRoe
         Let LisRoe = ""
        Next jCnt
    Let ProTble = ProTble & "</table>" ' table end
    ' Bit after table to aid in adding stuff in main code
     Let ProTble = ProTble & "Bit after table to aid in adding stuff in main code"
    "WordFile.htm" : https://app.box.com/s/xl1l7noo2nf7znnzyz6evqaeiuu37gcz
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg. 9h740K6COOA9iHOYYpaAbC
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgxuL6YCUckeUIh9hoh4AaABAg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwGTEyefOX7msIh1wZ4AaABAg. 9h4sd6Vs4qE9h7G-bVm8_-
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=Ugw3nF0C04AGt73H1BB4AaABAg. 9h6VhNCM-DZ9h7EqbG23kg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwGTEyefOX7msIh1wZ4AaABAg. 9h4sd6Vs4qE9h7KvJXmK8o
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=Ugw3nF0C04AGt73H1BB4AaABAg. 9h6VhNCM-DZ9h7E1gwg4Aq
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgywFtBEpkHDuK55r214AaABAg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg. 9h5lFRmix1R9h79hNGvJbu
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg. 9h5lFRmix1R9h79YAfa24T
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg. 9h5lFRmix1R9h79M1SYH1E
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg. 9h5lFRmix1R9h78SxhXTnR
    Get the Color shade you want to come out in Final Post
    I expect there is a better way to do this, but I just hit on a way that works quite well, so I will document and share that now , and edit and update later if I come up with a more scientific and/ or automated way.
    As an example , say I have seen this: _ shade _ somewhere, as you see it here, ( there ) . Lets assume I want to post that word in a Forum editor which accepts BB Code tags, ( BB Code tags: http://www.excelfox.com/forum/misc.php?do=bbcode ) such that I get that _ shade _ in the final post just as you see it here ( there )
    Here is a way to do it:
    _1 ) Use Word to get the shade of shade that you want,
    :for example,
    _ 1A) highlight any text and experiment with its color:
    Word Text Color 0.JPG : https://imgur.com/xpCoo8B
    Word Text Color 1 2.JPG : https://imgur.com/agdUo2f
    Word Text Color 3.JPG : https://imgur.com/H5czlGV
    Word Text Color 4.JPG : https://imgur.com/2ff71Xq
    ( Hit OK when finished to change selection color)
    Attachment 1981Attachment 1982Attachment 1983Attachment 1984
    _ 1B) As an alternative start point, you can find any text color anywhere, for example in the internet, paste into Word and adjust it in Word as per _ 1A)
    _2 ) Copy the final Text to the clipboard.
    Search the internet for any Word to HTML converter, there are many free ones available. Typically you can paste anything into a Visual Editor and then choose to obtain the HTML code
    WordVisualToHTML.JPG : https://imgur.com/T19SMxG
    Attachment 1980
    _3 ) In the given HTML code will typically be some part referring to the text shade,_..
    HTML Code:
     <p><span style="font-size: 11pt; line-height: 115%; font-family: Verdana, sans-serif; color: #417394;">shade</span></p>
    _.. here for example, the number of interest is _ color: #417394
    _4 ) I assume the number used in the square bracket [ BB Code Color Tags ] pair is the same as in pointy bracket < HTML > code Tags color bit. It appears to be.
    So for our example shade you would use this in a forum post_..
    ____ [color=#417394] shade [/color]
    _.. which would come out like this:
    __________________ shade
    ( If you want to keep the indent, as I did here (there), and avoid the forum editor “eating” spaces of more than one, ( as most forum editors do this ) ) , then use the white character trick: Post something like this:
    [color=white]_ Any_White_Profanity Text [/color] [color=#417394] shade [/color]
    DocAElstein
    [color=#417394]
    [B][u]DocAElstein[/u][/B][/color]
    https://imgur.com/MKMjW0b
    http://www.excelfox.com/forum/showth...plete-Document
    https://wordtohtml.net/
    http://services.runescape.com/m=foru...9,877,64690220
    http://www.excelfox.com/forum/showth...age2#post10131
    Some notes in support of this Thread: https://excelfox.com/forum/showthrea...ll=1#post15623
    Compare an empty Word document with a Word document with some arbitrary text, when both are saved in the .htm format.
    To help with later programming, I will run the macro recorder while making the two files.
    So this is a walk through it…
    _ Start the macro recorder
    _ make a new file
    _ save it as docHTML1.htm
    _ close it
    _ make a new file
    _ add the text some arbitrary text
    ¬_ save it as docHTML2.htm
    _ close it
    This is the basic macro produced by recorder. ( I changed/ rearranged a few things and added a few 'comments, but it is the same basic coding
    Sub Makro5()
     Documents.Add Template:="Normal", NewTemplate:=False, DocumentType:=0 ' _ make a new file
     ActiveDocument.SaveAs Filename:="docHTML1.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False  '  _ save it as docHTML1.htm
     ActiveWindow.View.Type = wdWebView
     ActiveDocument.Close ' _ close it
     Selection.TypeText Text:="some arbritrary text"     '  _ add the text some arbitrary text
     ActiveDocument.SaveAs Filename:="docHTML2.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False  '  _ save it as docHTML2.htm
    This is what I see appear as a result of doing the above:
    If I now open those two htm files with a text editor, I see this ( I am only showing the last bits below as there is more than the post limit allows )
    docHTML1.htm: https://app.box.com/s/l16u4vxavd8kjd1lzo3arb97rw4yoww1
    	mso-hansi-font-family:Calibri;
    	mso-hansi-theme-font:minor-latin;
    	mso-fareast-language:EN-US;}
    </style>
    <![endif]--><!--[if gte mso 9]><xml>
     <o:shapedefaults v:ext="edit" spidmax="2050"/>
    </xml><![endif]--><!--[if gte mso 9]><xml>
     <o:shapelayout v:ext="edit">
      <o:idmap v:ext="edit" data="1"/>
     </o:shapelayout></xml><![endif]-->
    </head>
    <body lang=DE style='tab-interval:35.4pt'>
    <p class=MsoNormal><o:p>&nbsp;</o:p></p>
    </div>
    </body>
    docHTML2.htm: https://app.box.com/s/quzanrhoopgdyzvk9dc5cbj9y0quuk4x
    	font-family:"Calibri","sans-serif";
    	mso-ascii-font-family:Calibri;
    	mso-ascii-theme-font:minor-latin;
    </style>
    </head>
    <p class=MsoNormal><span class=SpellE>some</span> <span class=SpellE>arbritrary</span>
    text</p>
    </div>
    </body>
    </html>
    What is going on there is that the lot of complicated html stuff ( of which I only show a bit ) is how a simple Microsoft Word document looks like if written in html. So for example, if you wanted to view your word document using an internet browser, then you would give the browser something like that. You can actually try that:
    Here for comparison is a file I used to give some summary in a Word doco. This is the file without yet any info in it, ( as a text file )
    DailyProtable.txt : https://app.box.com/s/q0tyxq8qptdb50oxxxtplbf9ur3xaeu2
    </style>
     <o:shapedefaults v:ext="edit" spidmax="4098"/>
    </head>
    <p class=MsoNormal><b><span style='color:#D99594;mso-themecolor:accent2;
    mso-themetint:153'>X <span class=SpellE>x</span> <span class=SpellE>x</span> <span
    class=SpellE>x</span> <span class=SpellE>x</span> <o:p></o:p></span></b></p>
    </div>
    </body>
    </html>
    This is the same file again with the information filled in it:
    DailyProtableFilled.txt : https://app.box.com/s/l16u4vxavd8kjd1lzo3arb97rw4yoww1
    <style>
     /* Font Definitions */
     @font-face
    	{font-family:"Cambria Math";
    	panose-1:2 4 5 3 5 4 6 3 2 4;
    	mso-font-charset:1;
    	mso-generic-font-family:roman;
    	mso-font-format:other;
    	mso-font-pitch:variable;
    	mso-font-signature:0 0 0 0 0 0;}
    @font-face
    	{font-family:Calibri;
    	panose-1:2 15 5 2 2 2 4 3 2 4;
    	mso-font-charset:0;
    	mso-generic-font-family:swiss;
    	mso-font-signature:-1610611985 1073750139 0 0 159 0;}
     /* Style Definitions */
     p.MsoNormal, li.MsoNormal, div.MsoNormal
    	{mso-style-unhide:no;
    	mso-style-qformat:yes;
    	mso-style-parent:"";
    	margin-top:0cm;
    	margin-right:0cm;
    	margin-bottom:10.0pt;
    	margin-left:0cm;
    	line-height:115%;
    	mso-pagination:widow-orphan;
    	font-size:11.0pt;
    	mso-fareast-font-family:Calibri;
    	mso-fareast-theme-font:minor-latin;
    	mso-bidi-font-family:Arial;
    	mso-bidi-theme-font:minor-bidi;
    span.SpellE
    	{mso-style-name:"";
    	mso-spl-e:yes;}
    .MsoChpDefault
    	{mso-style-type:export-only;
    	mso-default-props:yes;
    	font-size:10.0pt;
    	mso-ansi-font-size:10.0pt;
    	mso-bidi-font-size:10.0pt;
    @page WordSection1
    	{size:595.3pt 841.9pt;
    	margin:70.85pt 70.85pt 2.0cm 70.85pt;
    	mso-header-margin:35.4pt;
    	mso-footer-margin:35.4pt;
    	mso-paper-source:0;}
    div.WordSection1
    	{page:WordSection1;}
    </style>
    <!--[if gte mso 10]>
    <style>
     table.MsoNormalTable
    	{mso-style-name:"Normale Tabelle";
    	mso-tstyle-rowband-size:0;
    	mso-tstyle-colband-size:0;
    	mso-style-noshow:yes;
    	mso-style-priority:99;
    	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    	mso-para-margin:0cm;
    	mso-para-margin-bottom:.0001pt;
    	font-size:10.0pt;
    </style>
    </head>
    <p><span style="color: #ff00ff;">'_-Start=========== 02 April 2018 02.04.2018 21:55:52 ------------------------------------</span></p><table width=800
    <col width=200
    <col width=50>
    <col width=50>
    <col width=50>
    <col width=50>
    <col width=50>
    <col width=50>
    <col width=50>
    <col width=50>
    <col width=50>
    <col width=50>
    <tr height=17>
    <td>Food Product</td>
    <td>g</td>
    <td>Kcal</td>
    <td style="color:red;background:#F2DDDC">Fett</td>
    <td style="color:blue;background:#DBE5F1">Protein</td>
    <td style="background:#D8D8D8">Koh</td>
    <td style="color:silver;background:#D8D8D8">Zucker</td>
    <td style="color:brown;background:#DDD9C3">Ballastoffe</td>
    <td style="color:green;background:#EAF1DD">Wasser</td>
    <td style="color:purple;background:#E5E0EC">kalium</td>
    <td style="background:#DBEEF3">Natrium+</td>
    </tr><tr height=17>
    <td>NescafeEntkoffinieret</td>
    <td>14g</td>
    <td>16.52</td>
    <td style="color:red;background:#F2DDDC">0.028</td>
    <td style="color:blue;background:#DBE5F1">1.092</td>
    <td style="background:#D8D8D8">0.434</td>
    <td style="color:silver;background:#D8D8D8">0.434</td>
    <td style="color:brown;background:#DDD9C3">4.774</td>
    <td style="color:green;background:#EAF1DD"></td>
    <td style="color:purple;background:#E5E0EC"></td>
    <td style="background:#DBEEF3">0.014</td>
    </tr>
    <tr height=17>
    <td>G&GSuessstoffTabletten</td>
    <td>0.2g</td>
    <td>0.04</td>
    <td style="color:red;background:#F2DDDC"></td>
    <td style="color:blue;background:#DBE5F1"></td>
    <td style="background:#D8D8D8">0</td>
    <td style="color:silver;background:#D8D8D8">0</td>
    <td style="color:brown;background:#DDD9C3">0</td>
    <td style="background:#DBEEF3">0.0274</td>
    </tr>
    <tr height=17>
    <td>SuessliStevia(Flussig)</td>
    <td>0.2g</td>
    <td>0.001</td>
    <td style="background:#D8D8D8"></td>
    <td style="color:silver;background:#D8D8D8"></td>
    <td style="color:brown;background:#DDD9C3"></td>
    <td style="background:#DBEEF3"></td>
    </tr>
    <tr height=17 style="color:darkblue;background:pink">
    <td>Pro For Montag 02 April 02 04 2018</td>
    <td>14.4g</td>
    <td style="color:orange;background:white;height:21">17Kcal</td>
    <td style="color:red;background:white">0.028</td>
    <td style="color:blue;background:white">1.092</td>
    <td style="background:white">0.434</td>
    <td style="color:silver;background:white">0.434</td>
    <td style="color:brown;background:white">4.774</td>
    <td style="color:green;background:white"></td>
    <td style="color:purple;background:white"></td>
    <td style="background:white">0.041</td>
    </tr>
    <td>Main Foods</td>
    <td>14.4g</td>
    <td>16.561</td>
    <td style="background:#DBEEF3">0.0414</td>
    </tr>
    <tr height=17>
    <td>Fruit</td>
    <td>0g</td>
    <td></td>
    </tr>
    <tr height=17>
    <td>Veg</td>
    <td>0g</td>
    <td></td>
    </tr>
    </table><p><span style="color: #ff00ff;">'_---Table made 02 April 2018 02.04.2018 21:55:52 ====Daily Foods Table End ======</span></p>
    </div>
    </body>
    </html>
    Just for my memory revision , in the macro I use ( e.g. xxxxx ) , this is the code line which adds my stuff ( which I have in a variable, MyLengthyStreaming ) so as to make DailyProtableFilled from DailyProtable
     Let TotalFile = Replace(TotalFile, "<div class=WordSection1>", "<div class=WordSection1>" & vbCrLf & MyLengthyStreaming, 1, 1, vbTextCompare)
    So we see what is going on – we are adding stuff at the word section.
    Lets take a look now at the OP’s file …. In next post
    _...continued from last post
    I will open it, save it as extension type .htm at some temporary place, close it, and then take a look at the .htm file produced with a text editor.
    ( Once again I will run a macro recording so as to get some coding for future reference )
    This is the basic coding produced:
    Sub Makro6()
     ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\"
     Documents.Open Filename:="""2. KEEP DUPLICATE RECORDS.docx""", ConfirmConversions:=False, ReadOnly:=False, AddToRecentFiles:=False, PasswordDocument:="", PasswordTemplate:="", Revert:=False, WritePasswordDocument:="", WritePasswordTemplate:="", Format:=wdOpenFormatAuto, XMLTransform:="", DocumentDirection:=wdLeftToRight
     ChangeFileOpenDirectory "F:\Excel0202015Jan2016\ExcelFox\Word\prkhan56\Temporary Folder\"
     ActiveDocument.SaveAs Filename:="2. KEEP DUPLICATE RECORDS.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    Here is a look at part of the htm file
    2. KEEP DUPLICATE RECORDS.txt : https://app.box.com/s/7ezpcmytjctxvqdodosys62nsdn80y45
    _... see next post
    _... continued
    </head>
    <body lang=DE style='tab-interval:36.0pt'>
    <p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;text-align:
    justify;line-height:normal;mso-outline-level:2;background:white;vertical-align:
    baseline'><b><span lang=EN-US style='font-size:12.0pt;font-family:"Times New Roman","serif";
    mso-fareast-font-family:"Times New Roman"'>2. Keep Duplicate Records<o:p></o:p></span></b></p>
    justify;line-height:normal;background:white;vertical-align:baseline'><u><span
    mso-fareast-font-family:"Times New Roman"'>Power Query</span></u><span
    mso-fareast-font-family:"Times New Roman"'> lets you perform a series of steps
    to transform your Excel data.<span style='mso-spacerun:yes'>  </span>One of the
    steps it allows you to take is to<b> keep duplicate records</b>.<o:p></o:p></span></p>
    justify;line-height:normal;background:white;vertical-align:baseline'><span
    mso-fareast-font-family:"Times New Roman"'>We usually remove duplicate lines
    but if we need to keep and check what the duplicates are, Excel allows us to do
    that too!<o:p></o:p></span></p>
    mso-fareast-font-family:"Times New Roman"'>Let’s suppose you have this set of
    data. You can see that the marked ones are duplicate values, let us keep them!<o:p></o:p></span></p>
    style='font-size:12.0pt;font-family:"Times New Roman","serif";mso-fareast-font-family:
    "Times New Roman";mso-ansi-language:DE;mso-fareast-language:DE;mso-no-proof:
    yes'><!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600"
     o:spt="75" o:preferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f"
     stroked="f">
     <v:stroke joinstyle="miter"/>
     <v:formulas>
      <v:f eqn="if lineDrawn pixelLineWidth 0"/>
      <v:f eqn="sum @0 1 0"/>
      <v:f eqn="sum 0 0 @1"/>
      <v:f eqn="prod @2 1 2"/>
      <v:f eqn="prod @3 21600 pixelWidth"/>
      <v:f eqn="prod @3 21600 pixelHeight"/>
      <v:f eqn="sum @0 0 1"/>
      <v:f eqn="prod @6 1 2"/>
      <v:f eqn="prod @7 21600 pixelWidth"/>
      <v:f eqn="sum @8 21600 0"/>
      <v:f eqn="prod @7 21600 pixelHeight"/>
      <v:f eqn="sum @10 21600 0"/>
     </v:formulas>
     <v:path o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/>
     <o:lock v:ext="edit" aspectratio="t"/>
    </v:shapetype><v:shape id="Picture_x0020_38" o:spid="_x0000_i1030" type="#_x0000_t75"
     alt="Keep Duplicates Using Power Query or Get &amp; Transform" style='width:122.25pt;
     height:121.5pt;visibility:visible;mso-wrap-style:square'>
     <v:imagedata src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image001.png"
      o:title="Keep Duplicates Using Power Query or Get &amp; Transform"/>
    </v:shape><![endif]--><![if !vml]><img width=163 height=162
    src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image002.jpg"
    alt="Keep Duplicates Using Power Query or Get &amp; Transform" v:shapes="Picture_x0020_38"><![endif]></span><span
    mso-fareast-font-family:"Times New Roman"'><o:p></o:p></span></p>
    justify;line-height:normal;background:white;vertical-align:baseline'><b><u><span
    mso-fareast-font-family:"Times New Roman"'>STEP 1</span></u></b><span
    mso-fareast-font-family:"Times New Roman"'>: Select your data and turn it into
    an Excel Table by pressing the shortcut <b>Ctrl + T </b>or by going to<b>
    Insert &gt; Table</b><o:p></o:p></span></p>
    yes'><!--[if gte vml 1]><v:shape id="Picture_x0020_39" o:spid="_x0000_i1029"
     type="#_x0000_t75" alt="Keep Duplicates Using Power Query or Get &amp; Transform"
     style='width:105pt;height:132pt;visibility:visible;mso-wrap-style:square'>
     <v:imagedata src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image003.png"
    </v:shape><![endif]--><![if !vml]><img width=140 height=176
    src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image004.jpg"
    alt="Keep Duplicates Using Power Query or Get &amp; Transform" v:shapes="Picture_x0020_39"><![endif]></span><span
    mso-fareast-font-family:"Times New Roman"'><o:p>&nbsp;</o:p></span></p>
    mso-fareast-font-family:"Times New Roman"'>STEP 2</span></u></b><span
    mso-fareast-font-family:"Times New Roman"'>: Go to <b><i>Power Query &gt; Excel
    Data &gt; From Table</i>:</b><o:p></o:p></span></p>
    justify;line-height:normal;background:white;vertical-align:baseline'><a
    name="_GoBack"></a><span style='font-size:12.0pt;font-family:"Times New Roman","serif";
    mso-fareast-font-family:"Times New Roman";mso-ansi-language:DE;mso-fareast-language:
    DE;mso-no-proof:yes'><!--[if gte vml 1]><v:shape id="Picture_x0020_41" o:spid="_x0000_i1028"
     style='width:291pt;height:48pt;visibility:visible;mso-wrap-style:square'>
     <v:imagedata src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image005.png"
    </v:shape><![endif]--><![if !vml]><img width=388 height=64
    src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image006.jpg"
    alt="Keep Duplicates Using Power Query or Get &amp; Transform" v:shapes="Picture_x0020_41"><![endif]></span><span
    mso-fareast-font-family:"Times New Roman"'>STEP 3: </span></u></b><span
    mso-fareast-font-family:"Times New Roman"'>This will open up the Power Query
    Editor.<o:p></o:p></span></p>
    mso-fareast-font-family:"Times New Roman"'>Go to <b><i>Home &gt; Keep Rows &gt;
    Keep Duplicates</i></b><o:p></o:p></span></p>
    yes'><!--[if gte vml 1]><v:shape id="Picture_x0020_42" o:spid="_x0000_i1027"
     style='width:198pt;height:163.5pt;visibility:visible;mso-wrap-style:square'>
     <v:imagedata src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image007.png"
    </v:shape><![endif]--><![if !vml]><img width=264 height=218
    src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image008.jpg"
    alt="Keep Duplicates Using Power Query or Get &amp; Transform" v:shapes="Picture_x0020_42"><![endif]></span><span
    justify;line-height:normal;background:white;vertical-align:baseline'><b><span
    mso-fareast-font-family:"Times New Roman"'>STEP 4: </span></b><span lang=EN-US
    "Times New Roman"'>Click <b>Close &amp; Load</b> from the <b>Home</b> tab and
    this will <b>open up a brand new worksheet</b> in your Excel workbook with the
    updated table.<o:p></o:p></span></p>
    yes'><!--[if gte vml 1]><v:shape id="Picture_x0020_43" o:spid="_x0000_i1026"
     style='width:115.5pt;height:126.75pt;visibility:visible;mso-wrap-style:square'>
     <v:imagedata src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image009.png"
    </v:shape><![endif]--><![if !vml]><img width=154 height=169
    src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image010.jpg"
    alt="Keep Duplicates Using Power Query or Get &amp; Transform" v:shapes="Picture_x0020_43"><![endif]></span><span
    mso-fareast-font-family:"Times New Roman"'>You now have your new table with the
    duplicate rows kept!<o:p></o:p></span></p>
    yes'><!--[if gte vml 1]><v:shape id="Picture_x0020_44" o:spid="_x0000_i1025"
     style='width:89.25pt;height:70.5pt;visibility:visible;mso-wrap-style:square'>
     <v:imagedata src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image011.png"
    </v:shape><![endif]--><![if !vml]><img width=119 height=94
    src="2.%20KEEP%20DUPLICATE%20RECORDS-Dateien/image012.jpg"
    alt="Keep Duplicates Using Power Query or Get &amp; Transform" v:shapes="Picture_x0020_44"><![endif]></span><span
    <p class=MsoNormal><span lang=EN-US><o:p>&nbsp;</o:p></span></p>
    </div>
    </body>
    </html>
    These are the files and folders produced Files and Folders from OPs file saved as htm.jpg
    Here is the actual file as seen in word
    And it might be interesting to see the OPs file seen in the text format, if I delete all that stuff seen , making a new file, 2. KEEP DUPLICATE RECORDS All stuff removed.htm
    This is what that file looks like in the text format view:
     	mso-ansi-language:EN-US;
    </style>
     <o:shapedefaults v:ext="edit" spidmax="5122"/>
    </head>
    <p class=MsoNormal><span style='mso-ansi-language:DE'><o:p>&nbsp;</o:p></span></p>
    </div>
    </body>
    </html>
    2. KEEP DUPLICATE RECORDS All stuff removed.txt: https://app.box.com/s/f00nejo3edwygrz6jq3u8zvny7ceakp7
    The HTML text of the content – our stuff as seen in HTML coiding.
    The last few postings seem to tell us that the content we are interested in, that is to say what we put in the document seems to lie in between the HTML text of
    And something of the form
    </div>
    Or
    </div>
    The end point might not be too clear, but if we take all the text from <div class=WordSection1> to </div> then it looks like we will catch all of “our stuff”
    Comparing that with the typical files produced .._
    _.. , and considering that the document has clearly 6 images.._
    ( By the way, We can see some info from Microsoft on this …. To extract embedded images from a Word document …… Save As ….. Web Page (*.htm; *.html)
    Images will be extracted from the document and placed in the folder named <DocumentName>_files in the same location as the saved web page .
    https://support.microsoft.com/en-us/...c-3eeb284af36b
    http://web.archive.org/web/202103021...c-3eeb284af36b
    Macro to get this image info.
    It’s not too difficult to write a macro to list those files
    Example
    VBA seems to recognise in the following macro type both .htm and .txt files as just long strings of text.
    So I can do a macro to import that text string, then do some simple string manipulation to get the text bits looking like .jpg or .png file names
    I will do that in the next post
    Example, Sub ListThe_jpgs_pngs()
    VBA seems to recognise in the following macro type both .htm and .txt files as just long strings of text, so I can equally use my .htm or .txt file version of a file like the OPs 2. KEEP DUPLICATE RECORDS
    The macro below imports that text string, then does some simple string manipulation to get the text bits looking like .jpg or .png file names
    Rem 1 get the entire documant as a long text string in variable,  TotalDoc
    Dim FileNum As Long: Let FileNum = FreeFile(1)    ' https://msdn.microsoft.com/en-us/vba/language-reference-vba/articles/freefile-function    http://web.archive.org/web/20210914055920/https://docs.microsoft.com/en-us/office/vba/Language/Reference/User-Interface-Help/freefile-function
    Dim PathAndFileName As String, TotalDoc As String
     Let PathAndFileName = ThisWorkbook.Path & "\" & "2. KEEP DUPLICATE RECORDS.htm" '
        TotalDoc = Space(LOF(FileNum)) '....and wot recives it hs to be a string of exactly the right length
        Get #FileNum, , TotalDoc
      Close #FileNum
    Rem 2 Our text stuff content
    Dim OurStuffTxt As String, Strt As Long, Stp As Long
     Let Strt = InStr(1, TotalDoc, "
    ", vbBinaryCompare) + 25 ' +25 takes us to the end of "
    " Let Stp = InStr(Strt, TotalDoc, "
    ", vbBinaryCompare) Let OurStuffTxt = Mid(TotalDoc, Strt, Stp - Strt) Rem 3 getting at the .jpgs Dim Pos_jpg As Long '3a The first position, if there is one. If there isn't one then the next code line will return 0 Let Pos_jpg = InStr(1, OurStuffTxt, ".jpg", vbBinaryCompare) ' from the start of out stuff text string , 1 , we look for a .jpg Do While Pos_jpg <> 0 ' I will keep picking out the file names as long as I find another '3b if I have a .jpg , I will keep adding the name to a long string. Each file name will be seperated by a new line , ( which in VBA caan be represented in the text string by the two "invisible" characters carriage return, vbCr and line feed, vbLf - these two thinbgs are a throw back to old days when in the text string you had something to tell the printer to go back to the left ( carriage return ) and click the spindle up a line/ feed up a new line of paper, line feed Let Strt = InStrRev(OurStuffTxt, "/", Pos_jpg, vbBinaryCompare) ' looking backwards from position Pos_jpg to get at like in stuff like ............%20RECORDS-Dateien/image004.jpg" Dim Jpgs As String Let Jpgs = Jpgs & Mid(OurStuffTxt, Strt + 1, (Pos_jpg + (4 - 1)) - Strt) & vbCr & vbLf ' A bit of string manipulatzion to get the jpg file name text then add a bit to give the next line for adding the next one Let Pos_jpg = InStr(Pos_jpg + 4, OurStuffTxt, ".jpg", vbBinaryCompare) ' i trx again to find the next .jpg if there is one. This is similar to the code line looking for the first .jpg The difference is that I start looking at the position of the last one so as not to find one that I already considered Loop ' While Pos_jpg <> 0 MsgBox prompt:=".jpg names in string" & vbCr & vbLf & vbCr & vbLf & Jpgs Debug.Print ".jpg names in string" & vbCr & vbLf & vbCr & vbLf & Jpgs & vbCr & vbLf & vbCr & vbLf ' same output again in Immediate window ( Ctrl+g to get it up when looking in VB editor ) add a couple of lines to seperate it from the next png section Rem 4 getting at the .pngs Dim Pos_png As Long '4a Let Pos_png = InStr(1, OurStuffTxt, ".png", vbBinaryCompare) ' Do While Pos_png <> 0 ' '4b Let Strt = InStrRev(OurStuffTxt, "/", Pos_png, vbBinaryCompare) Dim Pngs As String Let Pngs = Pngs & Mid(OurStuffTxt, Strt + 1, (Pos_png + (4 - 1)) - Strt) & vbCr & vbLf ' Let Pos_png = InStr(Pos_png + 4, OurStuffTxt, ".png", vbBinaryCompare) ' i trx again to find the next .jpg if there is one. This is similar to the code line looking for the first .jpg The difference is that I start looking at the position of the last one so as not to find one that I already considered Loop ' While Pos_png <> 0 MsgBox prompt:=".png names in string" & vbCr & vbLf & vbCr & vbLf & Pngs Debug.Print ".png names in string" & vbCr & vbLf & vbCr & vbLf & Pngs End Sub
    Here is the typical output
    TypicalOutputFrom Sub ListThe_jpgs_pngs()
    https://www.youtube.com/watch?v=f7xZivqLZxc&lc=UgwhVTFaD469mW9wO194AaABAg.9gJzxwFcnPU9gORqKw5t W_
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgxUbeYSvsBH2Gianox4AaABAg.9VYH-07VTyW9gJV5fDAZNe
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgyhQ73u0C3V4bEPhYB4AaABAg
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgzIElpI5OFExnUyrk14AaABAg.9fsvd9zwZii9gMUka-NbIZ
    Saving Word doc containing images, as .htm produces a folder with images in it
    So we have established that saving Word doc containing images, as .htm produces a folder with images in it , and we can even find a bit of Microsoft documentation about it
    As Microsoft have “wired it” to do this, we might find some useful information in the arguments Iin the Save As code line
    This is the OPs original
    ActiveDocument.SaveAs strPath & "" & strDocumentName, wdFormatHTML, , , , , True
    In detail:
    wdFormatHTML,
    True
    Here for comparison what the macro recorder typically gave me:
    ActiveDocument.SaveAs FileName:="docHTML2.htm", FileFormat:=wdFormatHTML, LockComments:=False, Password:="", AddToRecentFiles:=True, WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    In detail:
    LockComments:= False,
    Password:="",
    AddToRecentFiles:= True,
    WritePassword:="",
    ReadOnlyRecommended:= False,
    EmbedTrueTypeFonts:= False,
    SaveNativePictureFormat:= False,
    SaveFormsData:= False,
    Unnamed arguments, as used by the OP, must go in correct order. Named argumenzts, as I am using, do not have to go in order, but as far as I am aware the macro recorder does
    _ give them in order, and
    _ usually gives a lot of the arguments in their default values.
    So we can re write the equivalent named argument version of the OPs code line thus:
    FileName:= strPath & "" & strDocumentName,
    FileFormat:= wdFormatHTML,
    Password:="",
    WritePassword:="",
    ReadOnlyRecommended:= True
    Conclusion here is that we are more or less doiung the same thing, - a recommendation for read only likely just causes some extra warnings when the file is opened. That is of little concern to our issues
  1. Class Stuff: VBA Custom Classes & Objects, Class Modules
    By DocAElstein in forum Excel and VBA Tips and Tricks
    Last Post: 06-02-2024, 01:49 PM
  2. Gif Image Video stuff testies
    Last Post: 09-06-2021, 01:07 PM
  3. Test my rights , to do stuff
    By TestAccount in forum Test Area
    Last Post: 10-07-2020, 11:49 AM
  4. Replies: 25
    Last Post: 03-10-2020, 01:28 PM
    Last Post: 04-02-2019, 03:04 PM
