Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 110
Thread: Notes tests, string, manipulation of text files and string manipulations
  1. #41
    Clipboard Spam Link Wonks
    In Excel columns I have the URLs, and I copy them
    Then I look at what is in the clipboard with the aim of adding enough BB Code URL tags
    This is what two links look like
     "https" & ":" & "/" & "/" & "www" & "." & "youtube" & "." & "com" & "/" & "watch" & "?" & "v" & "=" & "pGcerfVqYyU" & "&" & "lc" & "=" & "UgwYnetS3HRljX9vOLx4AaABAg" & "." & "94UVSldHOOy9VDJUb" & "_" & "mRBH" & vbCr & vbLf & "https" & ":" & "/" & "/" & "www" & "." & "youtube" & "." & "com" & "/" & "watch" & "?" & "v" & "=" & "pGcerfVqYyU" & "&" & "lc" & "=" & "UgzCtsi4abaxZnZJjZR4AaABAg" & vbCr & vbLf
    Fortunately, no surprises, so we just need to add the BB Code URL tags in some convenient way. First thought is to replace the vbCr & vbLf with [/url] & vbCr & vbLf and replace the http with [url] & http
    The we put the modified string back in the clipboard
    'https://excelfox.com/forum/showthread.php/2559-Notes-tests-text-files-manipulation-of-text-files-in-Excel-and-with-Excel-VBA/page5
    'https://excelfox.com/forum/showthread.php/2559-Notes-tests-text-files-manipulation-of-text-files-in-Excel-and-with-Excel-VBA?p=16480&viewfull=1#post16480
    'https://excelfox.com/forum/showthread.php/2559-Notes-tests-text-files-manipulation-of-text-files-in-Excel-and-with-Excel-VBA/page5#post16480
    Sub CopyExcelColumnSpamURL()
    Selection.Copy ' This will put it in the clipboard
    'Dim objCliCodeCopied As DataObject   '**Early Binding.   This is for an Object from the class MS Forms. This will be a Data Object of what we "send" to the Clipboard. So I name it CLIpboardSend. But it is a DataObject. It has the Methods I need to send text to the Clipboard
    ' Set objCliCodeCopied = New DataObject '**Must enable Forms Library: In VB Editor do this:  Tools -- References - scroll down to Microsoft Forms 2.0 Object Library -- put checkmark in.  Note if you cannot find it try   OR IF NOT THERE..you can add that manually: VBA Editor -- Tools -- References -- Browse -- and find FM20.DLL file under C:\WINDOWS\system32 and select it --> Open --> OK.     https://web.archive.org/web/20140610055224/http://excelmatters.com/2013/10/04/late-bound-msforms-dataobject/
    ' ( or instead of those two lines  Dim obj As New DataObject ).    or  next two lines are.....Late Binding equivalent'
    Dim objCli As Object '  Late Binding equivalent'   If you declare a variable as Object, you are late binding it.  https://web.archive.org/web/20141119223828/http://excelmatters.com/2013/09/23/vba-references-and-early-binding-vs-late-binding/
     Set objCli = GetObject("New:{1C3B4210-F441-11CE-B9EA-00AA006B1A69}") ' https://web.archive.org/web/20140610055224/http://excelmatters.com/2013/10/04/late-bound-msforms-dataobject/
     objCli.GetFromClipboard 'All that is in the Clipboard goes in this Data Object initial instance of the Class
    Dim SpamURLs As String ' String varable to take the moodified code. This can be very long,        like my cock
     Let SpamURLs = objCli.GetText() 'retrieve the text in the initial instance of the Class. ( In this case the original code modifies to have code lines )
    ' Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(SpamURLs)
    Let SpamURLs = Replace(SpamURLs, vbCr & vbLf, "[/uRl]" & vbCr & vbLf, 1, -1, vbBinaryCompare)
    Let SpamURLs = Replace(SpamURLs, "http", "[uRl]http", 1, -1, vbBinaryCompare)
     ' Make a data Object to put back in clipboard. This a Another Object from class just to demo, could have used the first
    'Dim objDatCliBackIn As DataObject
    ' Set objDatCliBackIn = New DataObject 'Set to a new Instance ( Blue Print ) of dataobject
    Dim objDatCliBackIn As Object
     Set objDatCliBackIn = GetObject("New:{1C3B4210-F441-11CE-B9EA-00AA006B1A69}")
     objDatCliBackIn.SetText "Alan Spam Tests" & vbCr & vbLf & SpamURLs  'Make Data object's text equal to the long string of the modified code
     objDatCliBackIn.PutInClipboard 'Place current Data object into the Clipboard, effectivelly putting its text, which is oue final code in the Clipcoard
    https://www.youtube.com/watch?v=f7xZivqLZxc&lc=UgwhVTFaD469mW9wO194AaABAg. 9gJzxwFcnPU9gORqKw5tW_
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgxUbeYSvsBH2Gianox4AaABAg. 9VYH-07VTyW9gJV5fDAZNe
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgyhQ73u0C3V4bEPhYB4AaABAg
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgzIElpI5OFExnUyrk14AaABAg. 9fsvd9zwZii9gMUka-NbIZ
  2. #42
    Post #36 15604 ( copied originally from post 35, then edited as a way of getting a post here )
    continued from last post
    This is how the text file from the last 2 post opens in my Excel
    _____ Workbook: apvtrn.csv ( Using Excel 2007 32 bit )
    Row\Col DI DJ DK DL DM DN DO DP DQ
    1 PY00000000000000004918 PY
    04-01-2021
    749-3
    -240.74
    4.00E+11
    IN JAN 16-MAR 17-2021
    04-08-2021
    05-08-2021
    1100-23
    2,371.66
    3 PY00000000000000005064 PY
    05-06-2021
    769-1
    -2,371.66
    4.00E+11
    IN APRIL 01-12-2021
    05-10-2021
    06-09-2021
    1135-7
    262.8
    5 PY00000000000000005149 PY
    05-27-2021
    784-7
    -262.8
    4.00E+11
    IN APR 01 - MAY 18- 2021
    06-08-2021
    07-08-2021
    1168-2
    1,864.35
    7 PY00000000000000005260 PY
    06-24-2021
    801-3
    -1,864.35
    4.00E+11
    IN APR 13-JUN 10-2021
    07-08-2021
    08-07-2021
    1187-25
    196.23
    9 PY00000000000000005453 PY
    08-05-2021
    834-1
    -196.23
    Worksheet: apvtrn
    _.. The OP appears unable to explain what he wants, and he probably doesn't know or can hardly speak a word of English.. never mind ... it isn't the fucking first time, and i doubt it will be the last, onward! based on seeing this a lot form the OP , Set rngDst = wkbDst.Worksheets("STATEMENT").Range("A17:C17, E17") , as well as a screenshots he gave,
    https://i.imgur.com/VtfbGD2.jpg https://i.imgur.com/W0qJZCN.png Attachment 3603 Attachment 3604
    I am taking a guess that somehow, some of the data above needs to find its way somewhere in the general area shown below
    _____ Workbook: VENDOR STATEMENT.xlsm ( Using Excel 2007 32 bit )
    Row\Col A B C D E
    15 Invoice Date Invoice # Invoice Due
    Date
    A/C Invoice $
    16 Balance brought forward
    17
    18
    19
    Worksheet: STATEMENT
    -.. and from seeing this... For Each Col In Array("DM", "DI", "DN", "DQ") , I will take a guess we can make these relations
    DM – A ( date )
    DI – B ( big number )
    DN – C ( date )
    DQ – E ( a number that might be something to do with money )
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgxesLhWNr_zNP0GUdh4AaABAg.9hI1CQJMLLo9hWn2pGBe SS
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgzkRujoMw9PblmXDQ14AaABAg.9hJRnEjxQrd9hJoCjomN I2
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgzPZbG7OvUkh35nXDd4AaABAg.9hJOZEEZa6p9hJqLC7El-w
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgwUcEpm8u6ZW3uOHXx4AaABAg.9hIlxxGY7t49hJsB2PWx C4
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgyvDj6NWT1Gxyy2JyR4AaABAg.9hIKlNPeqDn9hJskm92n p6
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=Ugwy7qx_kG9iUmMVO_F4AaABAg.9hI2IGUdmTW9hJuyaQaw qx
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgxesLhWNr_zNP0GUdh4AaABAg.9hI1CQJMLLo9hJwTB9Jl ob
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9iHOYYpaA bC
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgxuL6YCUckeUIh9hoh4AaABAg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwGTEyefOX7msIh1wZ4AaABAg.9h4sd6Vs4qE9h7G-bVm8_-
  3. #43
    ( this is post 35 15601 , it was used to copy to get post 36 below )
    https://excelfox.com/forum/showthrea...ll=1#post15597 https://excelfox.com/forum/showthread.php/2757-Run-time-error-1004-when-trying-to-resize-a-multi-area-range-object?p=15597&viewfull=1#post15597
    apvtrn.csv - last 2 of 9 lines
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,4.00003E+11,IN,,APR 13-JUN 10-2021,2021-07-08,2021-08-07,1187-25,0,196.23,0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,PY00000000000000005453,PY,,,2021-08-05,,834-1,,-196.23,0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
    continued in next post
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgxUbeYSvsBH2Gianox4AaABAg.9VYH-07VTyW9gJV5fDAZNe
    https://www.youtube.com/watch?v=v_1iqtOnUMg&lc=UgzIElpI5OFExnUyrk14AaABAg.9fsvd9zwZii9gMUka-NbIZ
  4. #44
    04-01-2021
    749-3
    -240.74
    4.00E+11
    04-08-2021
    05-08-2021
    1100-23
    2,371.66
    05-06-2021
    769-1
    -2,371.66
    4.00E+11
    IN APRIL 01-12-2021
    05-10-2021
    06-09-2021
    1135-7
    262.8
    05-27-2021
    784-7
    -262.8
    4.00E+11
    06-08-2021
    07-08-2021
    1168-2
    1,864.35
    06-24-2021
    801-3
    -1,864.35
    4.00E+11
    07-08-2021
    08-07-2021
    1187-25
    196.23
    08-05-2021
    834-1
    -196.23
    Worksheet: apvtrn
    Row\Col A B C D E
    Date
    A/C Invoice $
    17
    18
    19
    DM – A ( date )
    DN – C ( date )
  5. #45
    ( Post #37 15602 )
    formatting-number-in-csv-file-import-Number-being-rounded-decimnal-places-truncated
    https://excelfox.com/forum/showthrea...aces-truncated https://excelfox.com/forum/showthread.php/2758-formatting-number-in-csv-file-import-Number-being-rounded-decimnal-places-truncated [/size]
    apvtrn.csv - first 6 lines of 9 lines in Text File supplied here https://excelfox.com/forum/showthrea...ll=1#post15598
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,PY00000000000000004918,PY,,,2021-04-01,,749-3,,-240.74,0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,4.00003E+11,IN,,JAN 16-MAR 17-2021,2021-04-08,2021-05-08,1100-23,0,"2,371.66",0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,PY00000000000000005064,PY,,,2021-05-06,,769-1,,"-2,371.66",0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,4.00003E+11,IN,,APRIL 01-12-2021,2021-05-10,2021-06-09,1135-7,0,262.8,0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,PY00000000000000005149,PY,,,2021-05-27,,784-7,,-262.8,0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,4.00003E+11,IN,,APR 01 - MAY 18- 2021,2021-06-08,2021-07-08,1168-2,0,"1,864.35",0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
  6. #46
    ( Post #37 15602 )
  7. #47
    ( Post #37 15602 )
  8. #48
    ( Post #38 15603 )
    contunued from last post
    last 5 of nine lines in apvtrn.csv as supplied for formatting number in csv file import. Number being rounded / decimal places truncated
    https://excelfox.com/forum/showthread.php/2758-formatting-number-in-csv-file-import-Number-being-rounded-decimnal-places-truncated?p=15598&viewfull=1#post15598
    2021-08-17  10:56:40AM,Navigata Communications Limited,Page 1,A/P Vendor Transactions  (APVTRN01),From Vendor Number,[100045]  To  [100045],From Vendor Group,[VCAD]  To  [VEFT],,,,,Sort Vendors By,[Vendor Name],,,,,,,From Document Date,[2021-04-01]  To  [2021-08-17],Session Date,[2021-08-17],Report Format,[Vendor Transactions by Document Date],Transaction Types,"[Invoice, Credit Note, Prepayment, Payment]",Include Contact/Phone/Credit Limit,[No],Include Space For Comments,[No],Include Zero-Balance Vendors,[Yes],Include Transaction Type Totals,[No],Show Applied Details,[No],Show Fully Paid Transactions,[Yes],Sort Transactions by Transaction Type,[No],Print Amounts In,[Vendor Currency],,,,,,,,,,,,,,,,,,Vendor Number/Name/,,Batch-,Days,Transaction,Document Number/Type,Order Number,PO Number,Doc. Date,Due Date or Check Number,Entry,Over,Amount,Balance,,,,,,,,,100045,BC Hydro (1500 0415 081) consolidated account,,,,,,,,,,,,,,,,,,,,,,,,,,,,PY00000000000000005260,PY,,,2021-06-24,,801-3,,"-1,864.35",0,Vendor Total: ,CAD,-240.74,0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,CR: Credit Note                            DB: Debit Note                           IN: Invoice                            IT: Interest Charge                       PI: Prepayment                      MC: Miscellaneous Payment,AD: Adjustment                            CF: Applied Credit (from)           CT: Applied Credit (to)         DF: Applied Debit (from)              DT: Applied Debit (to)   ,ED: Earned Discount Taken         GL: Gain or Loss (multicurrency ledgers)                                PY: Payment                                RD: Rounding,,1 vendor printed,1 vendor name record printed
  9. #49
    ( Post #38 15603 )
  10. #50
    ( Post #38 15603 )
  1. Replies: 116
  2. Replies: 4
    Last Post: 10-02-2022, 09:18 PM
  3. Replies: 4
    Last Post: 01-30-2022, 04:05 PM
  4. Replies: 0
    Last Post: 07-08-2020, 04:29 PM
  5. string manipulation
    By kylefoley76 in forum Excel Help
    Last Post: 02-20-2014, 12:10 AM
