Results 1 to 10 of 11
Thread: Finding Credit and Debit Data and Creating Pivot
    Aug 2011
    Hi Friends,
    I have attached receivable statement. From that sheet I need to create two sheets once as Credit and debits.
    Sheet "Credit" contains negate transaction (In Column "H") and sheet "Debit" contains positive transactions.
    Vendor wise I need to create Pivot table for both sheet(Credit and Debit) as per the sheet attached.
    Kindly help to create VBA code for the same.
    Regards,
    Prabhu
    Member littleiitin's Avatar
    Aug 2011
    Hi Prabhu,
    I have named this Data sheet name as "Raw Data", Created Two sheets "Credit" and "Debit"
    Now do the Same:
    Create a Module and Paste Below Code and Run First Code "CreatingPositiveNegativeSheet":
    Sub CreatingPositiveNegativeSheet()
        ThisWorkbook.Worksheets("Credit").UsedRange.ClearContents
        ThisWorkbook.Worksheets("Debit").UsedRange.ClearContents
        With ThisWorkbook.Worksheets("Raw Data")
            If .AutoFilterMode = True Then .AutoFilterMode = False
            .Range("A1").CurrentRegion.Offset(1).AutoFilter Field:=8, Criteria1:="<0", _
            Operator:=xlAnd
            .UsedRange.SpecialCells(xlCellTypeVisible).Copy
            ThisWorkbook.Worksheets("Credit").Range("A1").PasteSpecial xlPasteValuesAndNumberFormats
            .Range("A1").CurrentRegion.Offset(1).AutoFilter Field:=8, Criteria1:=">=0", _
            Operator:=xlAnd
            ThisWorkbook.Worksheets("Debit").Range("A1").PasteSpecial xlPasteValuesAndNumberFormats
            Application.CutCopyMode = False
            Call CreditSheetPivote
            Call DebitSheetPivote
    Sub CreditSheetPivote()
        Dim rngPivote   As Range
        Dim rngDest     As Range
       With ThisWorkbook.Worksheets("Credit")
            Set rngPivote = .Range("A2").CurrentRegion.Offset(1)
            Set rngDest = .Range("T3")
            ThisWorkbook.PivotCaches.Create(SourceType:=xlDatabase, SourceData:= _
            rngPivote, Version:=xlPivotTableVersion10).CreatePivotTable _
            TableDestination:=rngDest, TableName:="PivotTable2", DefaultVersion _
            With .PivotTables("PivotTable2").PivotFields("VENDOR")
                .Orientation = xlRowField
                .Position = 1
            .PivotTables("PivotTable2").AddDataField .PivotTables( _
                "PivotTable2").PivotFields("BOOKED"), "Sum of BOOKED", xlSum
        ThisWorkbook.ShowPivotTableFieldList = False
    Sub DebitSheetPivote()
       With ThisWorkbook.Worksheets("Debit")
                .Position = 1
    Aug 2011
    Finding Credit and Debit Data and Creating Pivote
    PFA
    Aug 2011
    Hi Friend,
    Thanks, But am getting error message as "Run-time error '9'
    "Subscript out of range"
    Debug highlight the below line.
    Plz help to resolve the same.
    Regards,
    Prabhu
    " ThisWorkbook.Worksheets("Credit").UsedRange.ClearC ontents"
    Aug 2011
    Prabhu,
    I am seeing a space " ClearC ontents". Please remove it.
    I have tried in my workbook.. It is running fine at my end.
    Rahul Singh
    Aug 2011
    Hi Rahul,
    I Am using the same workbook which you have uploaded.
    I have inserted New date sheet and deleted the existing 3 sheets and run the macro.
    But the same error is repeating. I have attached the workbook for your reference.
    Regards,
    Prabhu
    Aug 2011
    Hi Rahul,
    Can you help to solve the Query?
    Regards,
    Prabhu
    Apr 2011
    Make sure to rename sheet1 to "Raw data" - also add code shown below - it will create the debit & credit sheets (if they dont already exists) - then the code runs fine - I have no idea if the data is right - but the code executes.
        Dim NewSheetX As Worksheet
        Astr = "NotExists"
        For ii = 1 To Worksheets.Count
            If Worksheets(ii).Name = "Credit" Then Astr = "Exists"
        Next ii
        If Astr = "NotExists" Then
            Set NewSheetX = Worksheets.Add    'This makes it active sheet
            ActiveSheet.Name = "Credit" ' Name of new
        Astr = "NotExists"
            If Worksheets(ii).Name = "Debit" Then Astr = "Exists"
        Next ii
            ActiveSheet.Name = "Debit" ' Name of new sheet
        ThisWorkbook.Worksheets("Raw Data").Activate 'This not need - but will make the Raw Data sheet the active sheet
    xl2007 - Windows 7
    xl hates the 255 number
  1. finding the number of occurrence
    By zzzqinzzz in forum Excel Help
    Last Post: 12-13-2012, 10:24 AM
  2. Group Pivot Data Based On Row Values In One Column
    Last Post: 10-09-2012, 11:46 PM
  3. Replies: 3
    Last Post: 05-14-2012, 11:30 AM
  4. Finding highest value in array
    Last Post: 06-24-2011, 03:59 AM
  5. Finding Last Used Row or Column In Excel Sheet
    Last Post: 04-14-2011, 03:17 AM
