Thread: Excel VBA Highlight Duplicates and Duplicate between Range
    Hello
    Quote Originally Posted by ayazgreat View Post
    ....but it seems to be just like a challenge work I just want to know that can it be possible through macro ....
    This is very bad English and does not really make any sense.
    One answer to this could be
    Yes, it most likely can be done with a macro, what ever it is you want. But god only knows what it is you actually want.
    What is column B about?
    Does column B have anything to do with the problem?
    This is what you have given
    Row\Col A B C D
    1 Numbers Remarks Duplication
    2 12345 1 Duplication
    3 23456 This number is duplicated between C6 Cell 2 Duplication
    4 32456
    5 12345 1 Duplication
    6 23455-23458 Total Duplicated in this range 3
    7 23457 This number is duplicated between C6 Cell 3 Duplication
    8 34567
    9 23455 This number is duplicated between C6 Cell 3 Duplication
    The only thing that makes any sense at all there is row 2 and row 5.
    Nothing else makes any sense there, and your attempts to explain anything are useless.
    I assume the results you want are column C ?
    And I assume you start with just column A?
    If that is the case you need to explain exactly how you get the results, etc. etc.
    You need to explain it a lot more
    Perhaps the best I can do is try to help you with some English language.
    Dog
    Cat
    Dog
    There are duplicates there because Dog and Dog are the same. There are 2 Dogs.
    Dog
    Cat
    Dog
    ---- this is a duplicate
    _.____________________________
    Dog
    123
    Cat
    123
    There are duplicates there because 123 and 123 are the same. There are 2 numbers the same (123)
    Dog
    123
    Cat
    123
    Dog
    123
    Cat
    124
    There are no duplicates here
    ( There are two sequential numbers here. 123 and 124 are sequential numbers.
    We may also describe these as sequential numbers out of sequence.
    Here I have 4 sequential numbers in sequence.
    The sequential numbers 11 12 13 14 are in ordered sequence.
    They are in order
    13
    14
    Dog
    _._____
    Here I have the same 4 sequential numbers but they are out of sequence.
    They are not in ordered sequence.
    They are not in order.
    They are out of order
    They are jumbled up.
    The order of the sequential numbers, 11 12 13 14, is all fucked up in a bloody jumbled up mess
    Dog
    14
    13
    _.__________________________________
    Here I have identified a set of sequential numbers that are out of order in a list of things. I have identified the sequential numbers by highlighting the cells containing them
    Row\Col A B
    21
    22 12
    23 Dog
    24 14
    25 7
    26 13
    27 11
    28
    23455-23458 ______ - This is representing 4 sequential numbers.
    Using a dash, -, in between 2 numbers is a typical way to represent a list of numbers
    In that example, the 4 numbers that are being represented are
    23455
    23456
    23457
    23458
    With ayazgreat forum postings there are two main problems
    Problem 1
    This is usually a macro requirement, - a coding is wanted. This problem is usually not too difficult to solve, requiring just basic VBA skills
    Problem 2
    This problem is trying to understand what ayazgreat wants. This is usually a very big problem, and sometimes impossible to solve
  1. Replies: 6
    Last Post: 09-24-2013, 04:13 PM
  2. Highlight Current Row in Excel (VBA)
    Last Post: 07-31-2013, 06:46 AM
  3. Replies: 10
  4. Replies: 6
    Last Post: 05-16-2013, 09:56 AM
  5. Replies: 7
    Last Post: 04-22-2013, 01:41 PM
