Page 44 of 55 FirstFirst ... 34424344454654 ... LastLast
Results 431 to 440 of 542
Thread: Appendix Thread. App Index Rws() Clms() Majic code line Codings for other Threads, Tables etc.)
  1. #431
    macro for last two posts
    Sub Transfer_marasAlan_3()  '   https://www.excelforum.com/excel-programming-vba-macros/1338596-transferring-data.html#post5460624
    Dim a(), cls_v() As String, Rws(), aSum(), arrOut__(), JagdDikIt()
    Dim Rng As Range, Rng_v As Range, cel As Range
    Dim Wrbk As Workbook, Rw As Long
    Dim Pth As String
     Let Pth = ThisWorkbook.Path & Application.PathSeparator  '       Const pth = "C:\Users\L026936\Desktop\Excel\"      '<---- use own path
    Const Wnm = "Workbook2_3.xlsx"                             'your workbook name
    '    Application.ScreenUpdating = False
    Rem 1 the main data range from source
        With ThisWorkbook.Sheets("Sheet1")
         Set Rng = .Range("a1:ai" & 36 & "")    '   main data range    hard coded to 36  for testing and  demonstration         .UsedRange.Rows.Count)
         Let a() = Rng.Value                    '   all data values in the source.  This will end up in the tyopical    arrOut()=AppIndex( a(), Rws(),  Clms() )
         Set Rng_v = Rng.Columns(2).SpecialCells(xlCellTypeVisible)  '  this gives us the range we see , (it is likely as a collection of areas) in the ID column
            If Rng_v.Count > 1 Then
       Rem 2 Make the sums column array, aSum() , and while we are looping we will collect the seen row indicies, Rws()
    '       ' ddddddddddddddddddddddd Dictionaray bit ------
            '  Dictionaray    -   The only reason to use this is that its a convenient way to get a unique list thing, or a unique set of things.
            Dim Dik As Object: Set Dik = CreateObject("Scripting.Dictionary")   '      https://excelmacromastery.com/vba-dictionary/
            'Dim d As Scripting.Dictionary: Set d = New Scripting.Dictionary
            Dim aTp() As Variant: ReDim aTp(1 To 3) ' This is a temporary array used to fill the dictionary  Items   it must be dynamic and variant type  - see note +++ below
                For Each cel In Rng_v  '   we effectivelly are going down all the seen rows
                    If cel.Row > 1 And cel.Value <> "" Then
                     Let Rw = cel.Row
                        If Not Dik.exists(a(Rw, 2)) Then ' -Case we don't yet have any dictionaray item with this ID  key
                         Let aTp(1) = Rw                                          '  row number
                         Let aTp(2) = a(Rw, 35)                                   '  grangtotal for this row
                         Let aTp(3) = .Evaluate("=Sum(o" & Rw & ": z" & Rw & ")") ' Our  column Sums
                         Dik.Add Key:=a(Rw, 2), Item:=aTp() '   The key becomes the ID  ,      The Item is a three element array of      the row number     the columns sum for this row    the gradtotal for this row                              shothand way to do this line is  d(a(r, 2)) = atp
                        Else '                           ' -Case we already have a dictionary item with this key
                         Let aTp() = Dik.Item(a(Rw, 2)) ' we are returning an item that is an array, so the recieving array variable must be dynamic.  the returned element type3s are  Variant   +++
                            If a(Rw, 35) > aTp(2) Then  '  If the grand total for this row and  ID  is  greater than a previous, then ....
                                Let aTp(1) = Rw                                        '   we are replacing ..
                                Let aTp(2) = a(Rw, 35)                                 '    .. the item with the relavent  ..
                                Let aTp(3) = .Evaluate("=Sum(o" & Rw & ": z" & Rw & ")") '    .. info from this row
                                Dik(a(Rw, 2)) = aTp()  '  shorthand version for   Dik.Add  Key:=a(Rw, 2), Item:=aTp()
                        End If ' end of making or replacing  a dictiuonary item
            ' at this point we have a dictionary that has one  Item  for each  ID
            ' in this last  Dik  bit we use the first and third part  of the 3 element items  in  a pseudo   arrOut()=AppIndex( arrUnjaggedJaged(), Rws() , Clms() )    '    https://www.ozgrid.com/forum/index.php?thread/1227920-slicing-a-2d-array/&postID=1239241#post1239241
                If Dik.Count Then
                    'Let JagdDikIt() = Application.Transpose(Dik.items()) '    we can treat an unjagged jagged array  that is a 1 D array of 1 D arrays as if it was a  2 D array  ...   https://eileenslounge.com/viewtopic.php?p=266691#p266691
                    Let JagdDikIt() = Dik.items()
                    'Let Rws() = Application.Index(JagdDikIt(), 1, Evaluate("row(1:" & UBound(JagdDikIt(), 2) & ")"))                                          '   Application.Transpose(Application.Transpose(Application.Index(v, 1, Evaluate("row(1:" & UBound(v, 2) & ")"))))
                    Let Rws() = Application.Index(JagdDikIt(), Evaluate("row(1:" & UBound(JagdDikIt()) + 1 & ")"), 1)                                        '   Application.Transpose(Application.Transpose(Application.Index(v, 1, Evaluate("row(1:" & UBound(v, 2) & ")"))))
                    'Let aSum() = Application.Index(JagdDikIt(), 3, Evaluate("row(1:" & UBound(JagdDikIt(), 2) & ")"))                         'Application.Transpose(Application.Transpose(Application.Index(v, 3, Evaluate("row(1:" & UBound(v, 2) & ")"))))
                    Let aSum() = Application.Index(JagdDikIt(), Evaluate("row(1:" & UBound(JagdDikIt()) + 1 & ")"), 3)                       'Application.Transpose(Application.Transpose(Application.Index(v, 3, Evaluate("row(1:" & UBound(v, 2) & ")"))))
    '       ' ddddddddddddddddddddddddd -----------------------------
            Else ' case only a header row to be seen
        If Rng_v.Count = 1 Or Dik.Count = 0 Then
            MsgBox "No rows to transfer."
        On Error Resume Next   '   https://eileenslounge.com/viewtopic.php?f=30&t=35861&start=20
         Set Wrbk = Workbooks(Wnm)
            If Wrbk Is Nothing Then
             Workbooks.Open Filename:=Pth & Wnm
             Workbooks(Wnm).Activate
        With ActiveWorkbook
            With .Sheets("Sheet1")
            Dim vTemp As Variant ' just for demo purposes
             Let vTemp = .UsedRange.Rows(1)
             ' { empty ,  Unique ID  , Gap ,Name  ,  Title ,  Platform  ,  Salary , Gap, Total ,  copy1  , copy2 ,  copy3 ,  copy4  , copy5 ,  copy6 ,  copy7 ,  copy2 ,  copy3 ,  copy4 ,  copy5  , copy6 ,  copy7 ,  Formula7   , Formula8 ,   Formula9  }
             Let vTemp = Rng.Rows(1)
             ' { Number , ID , Name ,   Title ,  Platform ,   Filter  ,  ,  ,   ,    ,Salary ,   ,    ,   ,Add1  ,  Add2 ,   Add3  ,  Add4  ,  Add5 ,   Add6 ,   Add7  ,  Add8 ,   Add9 ,   Add10 ,  Add11 ,  Add12 ,  copy1 ,  copy2 ,  copy3 ,  copy4 ,  copy5  , copy6 ,  copy7  , Total ,  grandtotal  }
             Let vTemp = Application.Match(.UsedRange.Rows(1), Rng.Rows(1), 0) '  This gives a 1 D array and each element has either the position of the header in the destination workbook, or an error if it did not find it
             '  { 2 ,  error  , 3  , 4 ,  5 ,  11  , error  , 34 ,  27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33 , 28 , error ,error ,error ,error ,error ,error ,error ,error ,error ,   }
             ' So the above line tells us where there is an error in a match with the header names
             Let vTemp = Application.IfError(vTemp, "x") ' Instead of the vbError , a text of  "x"  is put into the array
             '  { 2 ,  x   , 3  , 4 ,  5 ,  11  , x , 34  ,  27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33 , x ,x ,x ,x ,x ,x ,x ,x ,x ,  }
             Let vTemp = Filter(vTemp, "x", False, 0) ' take out the  "x"s
             '  { 2    , 3  , 4 ,  5 ,  11   , 34,  27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33  }
             Let cls_v() = Filter(Application.IfError(Application.Match(.UsedRange.Rows(1), Rng.Rows(1), 0), "x"), "x", False, 0)
             '  { 2   , 3  , 4 ,  5 ,  11  ,   27 ,  28 ,  29  , 30 ,  31 ,  32 ,  33  }
                With .Range("B2")  '   .UsedRange.Offset(1)
                 ' .Resize(, 15).ClearContents
                 Let arrOut__() = Application.Index(a(), Rws(), cls_v())
                 .Resize(UBound(Rws()), 1) = arrOut__()
                 Let Rws() = Evaluate("row(1:" & UBound(Rws()) & ")") '  Using the variable  Rws()  for a sequential indicie list  1; 2; 3 ... etc for all rows in the  arrOut__()
                 .Offset(, 2).Cells(1).Resize(UBound(Rws()), 4).Value = Application.Index(arrOut__(), Rws(), Array(2, 3, 4, 5))  '  columns   D - G
                 .Offset(, 7).Cells(1).Resize(UBound(Rws())) = aSum()  '  columm I
                 .Offset(, 8).Cells(1).Resize(UBound(Rws()), 7).Value = Application.Index(arrOut__(), Rws(), Array(6, 7, 8, 9, 10, 11, 12))  ' Column J to P
    '        .Save
    '    Set Rng = Nothing
    '    Set Rng_v = Nothing
    '    Set cel = Nothing
        Set Dik = Nothing
    In suppot of this thread
    https://excelfox.com/forum/showthrea...5292#post15292
    Input data
    _____ Workbook: VBA3.xls ( Using Excel 2007 32 bit )
    Find word 1Abc 2wer# 3smar 4chris
    AP1k AP1k, 6-9| AP1k, 10-13
    ForCome ForCome, 13-19
    Double Double, 14-16 | Double, 14-16| Double, 14-16 Double, 14-16| Double, 14-16 Double, 14-16| Double, 14-16
    Worksheet: inputA
    Wanted Output
    Output
    1Abc
    2wer# AP1k, 6-9
    2wer# AP1k, 10-13
    2wer# Double, 14-16
    2wer# Double, 14-16
    2wer# Double, 14-16
    3smar ForCome, 13-19
    3smar Double, 14-16
    3smar Double, 14-16
    4chris Double, 14-16
    Worksheet: OutputB
    Results after running macro in next post
    1Abc
    2wer# AP1k, 6-9
    2wer# AP1k, 10-13
    2wer# Double, 14-16
    2wer# Double, 14-16
    2wer# Double, 14-16
    3smar Double, 14-16
    3smar Double, 14-16
    Worksheet: Output
    Macro for last post
    Sub StartOffvbadumbarse()
    Rem 1 Worksheets info
    Dim WsIn As Worksheet, WsOut As Worksheet
     Set WsIn = ThisWorkbook.Worksheets.Item(1): Set WsOut = ThisWorkbook.Worksheets.Item(2)
    Dim arrIn() As Variant: Let arrIn() = WsIn.Range("B1:F5").Value2
    '2b
    Dim Clm As Long
        For Clm = 1 To 5 Step 1
            If arrIn(1, Clm) = "" Then
            ' Nothing to do for no header
            Dim Itms As String: Let Itms = arrIn(1, Clm)
            Dim RwDta As Long
                For RwDta = 2 To 5 Step 1
                Dim strFndWd As String
                    If arrIn(RwDta, Clm) = "" Then
                    ' no data
                        If InStr(1, arrIn(RwDta, Clm), "|", vbBinaryCompare) > 0 Then ' we must have two or more datas seperatied by a  |
                        Dim CelDts As Long
                            For CelDts = 0 To UBound(Split(arrIn(RwDta, Clm), "|", -1, vbBinaryCompare))
                             Let strFndWd = strFndWd & Split(arrIn(RwDta, Clm), "|", -1, vbBinaryCompare)(CelDts) & vbCr & vbLf
                            Next CelDts
                        Else ' case single data
                         Let strFndWd = strFndWd & arrIn(RwDta, Clm) & vbCr & vbLf  ' effectively a single row is added for this data
                Next RwDta
            '2e we have been through the data, so time to see what we got and fill our two strings appropriately
            Dim strOutA As String, strOutB As String
                If strFndWd = "" Then ' case we had no data
                 Let strFndWd = strFndWd & vbCr & vbLf ' effectively adds an empty row
                 Let strOutA = strOutA & Itms & vbCr & vbLf ' a single row with header
                Else ' we have data, so need do add some rows to strOutA ( strOutB effecively has all the rows determined by the number of  vbCr & vbLf   added
                Dim RwCnt As Long: Let RwCnt = UBound(Split(strFndWd, vbCr & vbLf, -1, vbBinaryCompare)) + 1 - 1 ' The number of  vbCr & vbLf  gives us the number rows
                    For CelDts = 1 To RwCnt
                    Next CelDts
         Let strOutB = strOutB & strFndWd
         Let strFndWd = ""
        Next Clm
    ' I can view my data in a message box or in the immediate window
     MsgBox Prompt:=strOutA: Debug.Print strOutA
     MsgBox Prompt:=strOutB: Debug.Print strOutB
    Rem 3 outout
    Dim arrOutA() As String: Let arrOutA() = Split(strOutA, vbCr & vbLf, -1, vbBinaryCompare) '  Excel has the convention of taking a  1D  array as being "horizontal" for spreadsheet purposes, so will consider it as a row of data values if applied to a worksheet range
    Dim arrOutB() As String: Let arrOutB() = Split(strOutB, vbCr & vbLf, -1, vbBinaryCompare)
    ' Let WsOut.Range("A2").Resize(UBound(arrOutA()), 1).Value = Application.Transpose(arrOutA())
     Let WsOut.Range("A2").Resize(UBound(arrOutA()), 1).Value = Application.Index(arrOutA(), Evaluate("=row(1:" & UBound(arrOutA()) & ")/row(1:" & UBound(arrOutA()) & ")"), Evaluate("=row(1:" & UBound(arrOutA()) & ")"))
    ' Let WsOut.Range("B2").Resize(UBound(arrOutB()), 1).Value = Application.Transpose(arrOutB())
     Let WsOut.Range("B2").Resize(UBound(arrOutB()), 1).Value = Application.Index(arrOutB(), Evaluate("=row(1:" & UBound(arrOutB()) & ")/row(1:" & UBound(arrOutB()) & ")"), Evaluate("=row(1:" & UBound(arrOutB()) & ")"))
    for later use
    In support of this post
    http://www.eileenslounge.com/viewtop...281164#p281164
    Sub On___Then____()  '    http://www.eileenslounge.com/viewtopic.php?p=281164#p281164
    ' Going nowhere    the first   ____ evaluates to a number in range 0  or 2 , 3, 4 ..... 255 so I don't  GoTo
    On 0.2 GoTo NeverBeHere
    On Err GoTo NeverBeHere
    On TwitTwo GoTo NeverBeHere
    On Nmber(255) GoTo NeverBeHere
    On -0.5 GoTo NeverBeHere
    On 255.49999 GoTo NeverBeHere
    ' Going somewhere  the first   ____  evaluates to 1  so I  GoTo
    On 1 GoTo 10
     MsgBox prompt:="I am never here. You will never see this"
    10 On 1.49999 GoTo 20
    20 On Nmber(0.5001) GoTo 30
    30  Exit Sub
    NeverBeHere:
    ' I will never be here
    Function TwitTwo() As Double
     Let TwitTwo = 2.1
    Function Nmber(ByVal No As Double) As  Double
     Let Nmber = No
    Post for later use
    Some notes from this question:
    http://www.eileenslounge.com/viewtop...281312#p281312
    Question …
    http://www.eileenslounge.com/viewtopic.php?f=30&t=36224
    _____ Workbook: Extract missing dates for each person.xlsm ( Using Excel 2007 32 bit )
    Row\Col A B C D E F G H I T U V
    1 Name Dates Helper Check Dates Result aa Yasser Given
    2 aa 2021-02-19 2021-02-19 2021-01-26 2021-01-26 2021-01-29 2021-01-29
    3 aa 2021-01-26 2021-01-26 2021-01-27 2021-01-27 2021-01-30 2021-01-30
    4 aa 2021-01-27 2021-01-27 2021-01-28 2021-01-28 2021-02-05 2021-02-05
    5 aa 2021-01-28 2021-01-28 2021-01-29 Missing 2021-02-12 2021-02-12
    6 aa 2021-01-31 2021-01-31 2021-01-30 Missing
    7 aa 2021-02-01 2021-02-01 2021-01-31 2021-01-31
    8 aa 2021-02-02 2021-02-02 2021-02-01 2021-02-01
    9 aa 2021-02-03 2021-02-03 2021-02-02 2021-02-02
    10 aa 2021-02-04 2021-02-04 2021-02-03 2021-02-03
    11 aa 2021-02-06 2021-02-06 2021-02-04 2021-02-04
    12 aa 2021-02-07 2021-02-07 2021-02-05 Missing
    13 aa 2021-02-08 2021-02-08 2021-02-06 2021-02-06
    14 aa 2021-02-09 2021-02-09 2021-02-07 2021-02-07
    15 aa 2021-02-10 2021-02-10 2021-02-08 2021-02-08
    16 aa 2021-02-11 2021-02-11 2021-02-09 2021-02-09
    17 aa 2021-02-13 2021-02-13 2021-02-10 2021-02-10
    18 aa 2021-02-14 2021-02-14 2021-02-11 2021-02-11
    19 aa 2021-02-15 2021-02-15 2021-02-12 Missing
    20 aa 2021-02-16 2021-02-16 2021-02-13 2021-02-13
    21 aa 2021-02-17 2021-02-17 2021-02-14 2021-02-14
    22 aa 2021-02-18 2021-02-18 2021-02-15 2021-02-15
    23 aa 2021-02-20 2021-02-20 2021-02-16 2021-02-16
    24 aa 2021-02-21 2021-02-21 2021-02-17 2021-02-17
    25 aa 2021-02-22 2021-02-22 2021-02-18 2021-02-18
    26 aa 2021-02-23 2021-02-23 2021-02-19 2021-02-19
    27 aa 2021-02-24 2021-02-24 2021-02-20 2021-02-20
    28 aa 2021-02-25 2021-02-25 2021-02-21 2021-02-21
    29 bb 2021-01-27 2021-01-27 2021-02-22 2021-02-22
    30 bb 2021-01-28 2021-01-28 2021-02-23 2021-02-23
    31 bb 2021-01-31 2021-01-31 2021-02-24 2021-02-24
    32 bb 2021-02-01 2021-02-01 2021-02-25 2021-02-25
    33 bb 2021-02-03 2021-02-03
    Worksheet: Sheet1
    Continued from last post: Some notes from this question:
    Yasser Question.JPG https://excelfox.com/forum/showthrea...ll=1#post15418
    Hans Solution. What’s he doing:
    Rem 1 Make dictionary of Dictionaries2
    There are two dictionary variables.
    The first one contains all the unique name values from column A . So this is the unique names dictionary
    We loop down to build that dictionary, and the solution is relying on a un unbroken sequential list of names, in other words no mixed up , but an order list like
    Name1
    Name1
    Name1
    Name2
    Name2
    ..etc.
    In that main loop , all the values, from column B are put in the Item ( which is itself a dictionary ) of each unique name in the unique names dictionary.
    This is the clever line that does that. The line is done for each row in the data to be looked in ( column B )
    Let dct1(rng1(r1, 1))(Int(rng1(r1, 2))) = 1
    The 1 is arbitrary. What we are doing is like referring to ( trying to put 1 into ) the key of an item in the second dictionary that does not exist. When this is done, rather than error, the Scripting.Dictionary is programmed to make an item with that key.
    The end result of all this is that we end up with a main dictionary that has a key for each unique name. The item for each name / Key has a second dictionary in it of all the Integer parts of the Date & time in column B. ( The dictionary will be seeing the basic Excel .Vaue2 of the date & time, so the Integer part will be just the date.
    Here is a pseudo couple of code lines to demo that last bit
    Dick1(Name1) ( 2021-02-19 ) = 1
    Dick1(Name1) ( 2021-01-26 ) = 1
    You see what’s going on is the following:
    Dick1(Name1) will always return the same thing which is the Item in Dick1 with the Key of Name1
    So Effectively those lines are pseudo
    Dick2 ( 2021-02-19 ) = 1
    Dick2 ( 2021-01-26 ) = 1
    What those code lines try to do is put a 1 in the items of a Dick2 element that does not exist. As noted, the Scripting.Dictionary is programmed to make an item with that key rather than error if such an action is attempted.
    So that is just a convenient way to make the second dictionaries – Note I said dictionaries
    We end up with this:
    Dick1 keys
    These lines give me that from doing a Shift F9 on any variable
    Shift F9 on vTemps for Watch Window.JPG http://i.imgur.com/Ms7HmG6.jpg
    We have an Outer loop and an inner loop in it.
    __The outer loop is done once for each unique name, so for each key of the main dictionary
    ____The inner loop goes down the entire F column Check dates and does a write out any missing dates, that is to say dates not in the dictionary that is the item for that unique name, key of the main dictionary
    Hans macro
    Sub ListMissing()  '  ' Hans    http://www.eileenslounge.com/viewtopic.php?p=281312#p281312
    Dim vTemp1, vTemp2 ' For development and debug
    Dim wsh1 As Worksheet
    Dim wsh2 As Worksheet
    Dim rng1 As Variant
    Dim rng2 As Variant
    Dim m1 As Long
    Dim m2 As Long
    Dim r1 As Long
    Dim r2 As Long
    Dim r3 As Long
    Dim dct1 As Object
    Dim dcTemp2 As Object
    Dim n As Variant
     Set dct1 = CreateObject("Scripting.Dictionary")
     Set wsh1 = Worksheets("Sheet1")
     Let m1 = wsh1.Range("A" & wsh1.Rows.Count).End(xlUp).Row
     Let rng1 = wsh1.Range("A2:B" & m1).Value
        For r1 = 1 To UBound(rng1)
            If Not dct1.Exists(rng1(r1, 1)) Then ' this gives us  3 elements in  the  dct1  that have like key  aa  and  the item is an empty dictionary object
             Set dcTemp2 = CreateObject("Scripting.Dictionary") ' This effectively clears the variable used temporarily
             dct1.Add Key:=rng1(r1, 1), Item:=dcTemp2
         Let dct1(rng1(r1, 1))(Int(rng1(r1, 2))) = 1 ' the  1  is arbritrary, we effectively create a Key looking like  aa 2021-02-19 in the  second dictionary that is the item of the unique
        Next r1
     vTemp1 = dct1.keys()  '  Dick1.JPG                                http://i.imgur.com/zTWYpuy.jpg
     vTemp2 = dct1.items() '  Dick2KeysWichAreDicksInDick1Items.jpg    http://i.imgur.com/Jsd2kXS.jpg
     Let m2 = wsh1.Range("F" & wsh1.Rows.Count).End(xlUp).Row
     Let rng2 = wsh1.Range("F2:F" & m2).Value
     Set wsh2 = Worksheets("Sheet2Hans")
     wsh2.Range("A2:B" & wsh2.Rows.Count).Clear
     Rem 2  Go through checking for existance of an Item. For no existance , then that is missing data
      Let r3 = 1
        ' The outer loop is done once for each unique name, so for each key of the main dictionary ===========
        For Each n In dct1.keys '  this and next line make it  For Each  of .._
         Set dcTemp2 = dct1(n)  ' _.. the dictionries within each item of  Dick1  In other words  For Each  Name
            ' The inner loop goes down the entire  F column Check dates and does a write out any  missing dates, that is to say dates not in the dictionary that is the item for that  unique name,  key of the main dictionary
            For r2 = 1 To UBound(rng2) ' Going down the entire   F  range
                If Not dcTemp2.Exists(rng2(r2, 1)) Then
                 Let r3 = r3 + 1
                 Let wsh2.Range("A" & r3).Value = n           '  n is the key, the unique name, in the main large dictionary
                 Let wsh2.Range("B" & r3).Value = rng2(r2, 1) ' This will be the missing entry
            Next r2 ' ________________________________________
        Next n ' ==============================================================================================
    Some notes for this question:
    http://www.eileenslounge.com/viewtop...281291#p281291
    For example, this bit …. using formulas like that
    =IFERROR(INDEX($A$2:$C$1000,MATCH(1,($A$2:$A$1000= $I$1)*($C$2:$C$1000=F2),0),3),"Missing")
    Then I manually filter by Missing and copied the results
    That can be done in a single code line, …. _
    Sub BasicOneLine() '  '....  http://www.eileenslounge.com/viewtopic.php?p=281291#p281291
     Let Range("T2").Resize(UBound(Application.Index(Worksheets("Sheet1").Columns(6), Application.Index(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1), Evaluate("=row(1:" & UBound(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1)) + 1 & ")/row(1:" & UBound(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), _
     Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1)) + 1 & ")"), Evaluate("=row(1:" & UBound(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1)) + 1 & ")")), 1), 1), 1).Value = _
    Before
    Row\Col I T U V
    1 aa Yasser Given
    2 2021-01-29
    3 2021-01-30
    4 2021-02-05
    5 2021-02-12
    Worksheet: Sheet1
    After
    Row\Col I T U V
    1 aa Yasser Given
    2 2021-01-29 2021-01-29
    3 2021-01-30 2021-01-30
    4 2021-02-05 2021-02-05
    5 2021-02-12 2021-02-12
    Worksheet: Sheet1
    Run Sub BasicOneLine() on the uploaded file to demo those results
    extended coding notes for last post
    https://excelfox.com/forum/showthrea...ll=1#post15420
    Sub Pretty2()  '
    Dim arrTemp() As Variant
    Rem  To get the results in  column  T  ( same as
     ' Ths first forumula give me all the matches for F in the C ( helper column )  or error for no match
     Let arrTemp() = Evaluate("=If({1},MATCH(F2:F463,C2:C463,0))")   '   If({1},____)    may not be needed for Excel 2016 and higher   The first formula does the main work
     ' The multiplication by $A$2:$A$1000=$I$1 limits the range used by effectively making 0 check dates outside or range of interest
     Let arrTemp() = Evaluate("=IF({1},MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0))")   '  $A$2:$A$1000=$I$1 gives us an array full of  Falses and Trues , which Excel will interpret mathematically as 0 or 1   This has the effect of giving us a 0 multiplyer on numbers outside our range of interst, so in total a 0 for outside our range of interest.   Our range of interest gets a 1 multiplier so has therefore no change and we can find those numbers whereas we wont find a 0, well actually we will find a zero if the range to search for has a zero as it does further down, so we take care of that in the next line
     ' The above formula has one problem with the supplied data in that empty cells are seen in this formula as 0 which gives a match
     Let arrTemp() = Evaluate("=IF(F2:F463=0,0,MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0))")   '   In looking in the range to find a match in ( the range to be searched we have all 0s outside the range caused by the previous $A$2:$A$1000=$I$1  So the first of these 0s will be seen as the match cell for all cells in  F  that are empty.  So i take care here of the situation where an empty cell in  F  is by  giving a  0  output   So far two things retrn me a zero.   You often find in formula building that the coercing  If({1},___) suddenly is not needed. Her we find that the newly used here  IF(F2:F463=0,0,___)  is doing the required co oecing
     ' we will now do a simple  If(ISERROR( ) , Row( ) , 0 ) on the above . This will give us a row indicie for the missing data,  and  a  0  for the found data
     Let arrTemp() = Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)")
     ' At this point we have wanted data or zeros. I want to conveniently use some VB string fuction whuch annoyingly onl work on 1 D arrays, so we convert it by a transpose in the next code line
     Let arrTemp() = Application.Index(arrTemp(), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)"))
     ' The next few lines get rid of the  0s
    Dim StrTemp As String: Let StrTemp = Join(arrTemp(), "#") ' Convert the array to a string with a  #  in between each data
     Let StrTemp = Replace(StrTemp, "#0", "", 1, -1, vbBinaryCompare): StrTemp = Replace(StrTemp, "0#", "", 1, -1, vbBinaryCompare) ' This effectiveely removes the  0s   data ( and its seperator )
    Dim arrStrTemp() As String: Let arrStrTemp() = Split(StrTemp, "#", -1, vbBinaryCompare) ' remake the array
     ' We need a "vertical" array for output, so we  transpose
     Let arrTemp() = Application.Index(arrStrTemp(), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")/row(1:" & UBound(arrStrTemp()) + 1 & ")"), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")"))
     Let arrTemp() = Application.Index(Worksheets("Sheet1").Columns(6), arrTemp(), 1) ' finally we want the  dates  ( so far we have the row indicies obtained from  Match   Note. this formula has the problem that we get the results  a row out of step... Its actually very convenient because if i use  Cells typically, here a column  then I have a nice solution
     Let Range("T2").Resize(UBound(arrTemp(), 1), 1).Value = arrTemp()
     Let Range("T2").Resize(UBound(arrTemp(), 1), 1).NumberFormat = "yyyy/mm/dd" '  from macro recorder .NumberFormat = "[$-1010000]yyyy/mm/dd,@"
    Stop
     Range("T2").Resize(UBound(arrTemp(), 1), 1).ClearContents
     ' Or
    Stop
     '  Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", "")
    Rem  To get to  Column N  in   Extract missing dates for each person.xlsm
     ' The next step is to replace the errors with  0s
     Let arrTemp() = Evaluate("=IFERROR(IF(F2:F463=0,0,MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)),0)")   '   In looking in the range to find a match in ( the range to be searched we have all 0s outside the range caused by the previous $A$2:$A$1000=$I$1  So the first of these 0s will be seen as the match cell for all cells in  F  that are empty.  So i take care here of the situation where an empty cell in  F  is by  giving a  0  output   So far two things retrn me a zero.   You often find in formula building that the coercing  If({1},___) suddenly is not needed. Her we find that the newly used here  IF(F2:F463=0,0,___)  is doing the required co oecing
    'Dim StrTemp As String
     Let StrTemp = Replace(StrTemp, "#0", "", 1, -1, vbBinaryCompare) ' This effectiveely removes the  0s   data ( and its seperator )
    'Dim arrStrTemp() As String
     Let arrTemp() = Application.Index(Range("C2:C463"), arrTemp(), 1) ' finally we want the  dates  ( so far we have the row indicies obtained from  Match
     Let Range("N2").Resize(UBound(arrTemp(), 1), 1).Value = arrTemp()
     Let Range("N2").Resize(UBound(arrTemp(), 1), 1).NumberFormat = "yyyy/mm/dd" '  from macro recorder .NumberFormat = "[$-1010000]yyyy/mm/dd,@"
     ' Or
    '  Let arrTemp() = Evaluate("=If({1},IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0))")
     'let worksheets("Sheet2").range
    'v = Join(v, "#")                                             '  https://www.vbarchiv.net/commands/cmd_filter.html
    'v = Application.Index(Range("C2:C463"), Evaluate("=If({1},MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1))"), 1)
    'v = Application.Index(v, Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)"))
    'v = Evaluate("=IFERROR(INDEX($A$2:$C$1000,MATCH(1,($A$2:$A$1000=$I$1)*($C$2:$C$1000=" & r.Address & "),0),3),""Missing"")")
  1. Replies: 192
  2. Replies: 3
    Last Post: 03-07-2022, 05:12 AM
  3. HTML (Again!) arrOut()=Index(arrIn(),Rws(),Clms()
    Last Post: 08-23-2014, 02:27 AM
