Page 7 of 57 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 570
  1. #61
    Testing Hyperlinks in received EMail
    Page 4
    https://www.excelfox.com/forum/showt...PI-stuff/page4
    https://www.excelfox.com/forum/showt...ll=1#post17896
    https://www.excelfox.com/forum/showt...age3#post24934
    #post17896 , Thread2824 , Post 31
    Some notes related loosely to these forum posts
    https://eileenslounge.com/viewtopic....322955#p322955 https://eileenslounge.com/viewtopic....323065#p323065
    https://eileenslounge.com/viewtopic.php?f=30&t=41659
    https://www.excelfox.com/forum/showt...dows-API/page3
    https://www.excelfox.com/forum/showt...ll=1#post24934
    post24934, Thread2989
    Theory Ælstein
    This is not necessarily a final answer, ( an unlikely to be the final word on the issue ), but this is an attempt to get the thing out, and keep it simmering while I take a break to write my Xmas cards. I have only looked in depth at less than a third of the book chapter
    API App message box renewed experiments
    Because I am new and still very flaky with API stuff, and because whilst on Panzer Schokolade a few years back, I got to know this API MessageboxAA very well, almost as well probably as a computer professional, exceptionally for Layman me, and as part of my recent API revision I revisited there.
    So let me see if I can apply some of my initial findings and solution/ Theory suggestions to that.
    In my research and experiments I went off in a tangent into very basic Unicode and ANSI/Ascii associated with VB strings and windoew32 API. In the long run, that may not be such a bad thing. The detailed discussions will be continued in more detail in this page 2 ++
    Some (Vague for now) thoughts / Clues gleaned from a week of research
    In no particular order, yet….
    ( These thoughts are given in more detail and better ordered in this page 2 ++ But it’s not finished yet. I have only looked in depth at less than a third of that book chapter
    _ Things windows API certainly where and in many ways still are, or efficiently use, ANSI. This does cause issues with String things
    _ The issues have been known about for over 20 years and we have things like strPtr extra made to help us, along with things like LongPtr which compliment it in some ways
    _ a VBA string variable is a pointer to a VB pointer which final points to some form or part of the final string you actually want. Pointing to a pointer is possibly not so bad, whereas mixing up a pointer with a string is more deadly.
    _** At some point in that book chapter , the author is hinting that his attempts to explain what is going on with existing VB documentation are his ideas and that other smart people were thinking something extra might be going on,
    _ Somewhat less known as it perhaps should be, … for almost, if not all, API functions/ Sub routines, there is two versions, denoted by the last character in the name of A and W. Very briefly W can be thought of as meaning Unicode, A as ANSI/Ascii. The W things are not so new….
    _ I noticed some strange things with types and type documentation. When considering string arguments, they seem to be wording things sometimes as if they are not talking about the string, but the pointer. I got some strange feeling that talking pointers is more low level, or more fundamental
    _ I notice some things giving me the string problem issues were actually, (not always), sometimes in documentation or in working API stuff, declared As Any when String was either more intuitive or more often used.
    My brain went off in some lateral thinking that rarely produce anything other than time and resource loss, but when they do 1 in 10 times produce something, it is usually more than worth the "lost" investment.
    What did I decide to look at, and why
    _ (For one thing the computer Unicode ANSI/Ascii very basics and History thereof. But maybe I may not have needed that if I was not so doubly ignorant in this area….)
    _ I decided to look in strings, and string types, and string related pointer things.
    _ I went off in an absurd diverse direction, thinking to get a way to do something involving a string by avoiding the string.
    ** As I went on, I started thinking that this original throw away thought of mine was not so bad after all …
    …....... the simple answer is that ByVal and ByRef behaviour in windows API Declare lines is different, at least with As String.. ….
    .... no one could figure out a more ordered logical well organised interface so the nearest looking combination of Declare line, call line and associated coding is used as an enigma type coding that sets off some particular back end coding to do something….
    As I went on, I came to an idea, which with hindsight later searching, some people, al be it very few, but computer Profis never the less, also thought…. As soon as VBA sees a Declare line, it decides to do some Unicode to ANSI transformations, in particular when it sees a string argument. I am thinking I don’t want that.**
    For one thing, Excel spreadsheets and word documents, I have noticed seem very good with many exotic characters and languages. Even my preferred earlier Office versions.
    I think I, (and likely some others, possibly even some Microsoft people ) , may have been mislead sometimes in code development by apparent failings of passing characters due to failures in the VB Editor, and possibly then even overlooked that we have some (less commonly known and less commonly used) in most cases an API function version that it is regarded as a Unicode version.
    I want to see if I can get a more Unicode API thing, and perhaps try at the same time to stop VBA messing with things so much…..My brain started one of its lateral thinking that rarely produce anything other than time and resource loss, but when they do 1 in 10 times produce something, it is usually more than worth the "lost" investment. This time it may have got something interesting and useful. Maybe not
    This is just a provisional initial theory:
    _ Behold: I have seen a API World, where direct ANSI Strings stuff f is often avoided, and that World is good. In this regard, String is anything at a API Declare line or related main code lines. This will include anything in API related VBA code lines that include As String
    _In VBA, VB and possibly in other computer things, much involving string manipulations involves the handling not directly of the string itself, but of numbers: addresses of a Long type. This may be able to be exploited, when the string manipulation involves simple transferring: We can try to pass a pointer. This may effectively being something like a ByRef, when it is ByVal declared. This can help reduce certain conflicts associated with an actual explicit ByRef usage
    (We note possible parallels here to hacks to arguments in VBA Application.Run)
    Having done many empirical measurements, I may have found a way to do Unicode API things, and that may to soime extent explain issues which initiated this Thread https://eileenslounge.com/viewtopic.php?f=30&t=41659
    Here we go for now (and a lot to be added to and edited later
    MessageBoxÆ function https://www.excelfox.com/forum/showt...ge4#post417897
    The standard/ old Declareation looks like this
    Declare Function MessageBox Lib "user32" Alias "MessageBoxA" (ByVal hwnd As Long, ByVal lpText As String, ByVal lpCaption As String, ByVal wType As Long) As Long
    In this case disappointingly, the string arguments are given As String
    However, take a look at the moderner documentation. ( That is usually in C language , but translating them is usually straight forward. )
    int MessageBoxA(
    [in, optional] HWND hWnd,
    [in, optional] LPCSTR lpText,
    [in, optional] LPCSTR lpCaption,
    [in] UINT uType
    int MessageBoxW(
    [in, optional] LPCWSTR lpText,
    [in, optional] LPCWSTR lpCaption,
    [in] UINT uType
    Encouraging we see the pointer stuff is there on the two string arguments.
    So
    We is trying to get something that very likely does a Unicode thing, as much as possible. That is to say the provisional Ælstein Theory proclamates something like:
    _ Behold: I have seen a API World, where direct ANSI Strings stuff is often avoided, or at least cropped back / restrained a bit, and that World is good. In this regard, String is anything at a API Declare line or related main code lines. This will include anything in API related VBA code lines that include As String
    Worked example
    I got an interesting word, or rather interesting first character of a word, in the first cell of a worksheet
    Whilst Excel seems very good with displaying a massive amount of exotic high up the Unicode list characters, initially both the inbuilt VBA MsgBox and initially the API MessageBoxA don’t do at all well, not even if it's an ANSI that is probably not on my code page .
    later.....
    Code for Thai .
    Sub Sendfromexcellearninggmail()
    Rem 6 EMail send 'For info see:  http://www.excelfox.com/forum/showthread.php/2233-Urgent-support-needed-Multiple-emails-multiple-Excel-workbooks-at-once#post10519
    'Working at my end With my With End With Created LCDCW Library, (LCD 1.0 Library ) (Linking Configuration Data_Cods Wollups)
        '6a(i)
        With CreateObject("CDO.Message") ' -Linking Cods Wollups--------
        Dim LCD_CW As String: Let LCD_CW = "http://schemas.microsoft.com/cdo/configuration/"
         .Configuration(LCD_CW & "smtpusessl") = True '
         .Configuration(LCD_CW & "smtpauthenticate") = 1  '
        '  ' Sever info
         .Configuration(LCD_CW & "smtpserver") = "smtp.gmail.com" ' "smtp.office365.com" ' "smtp.live.com" ' "smtp-mail.outlook.com" ' "smtp.live.com" ' "smtp.gmail.com" ' "securesmtp.t-online.de" "smtp.mail.yahoo.com" "smtp.live.com" "pod51017.outlook.com"  "smtp-mail.outlook.com" "smtp.live.com"  "securesmtp.t-online.de"
        '  The mechanism to use to send messages.
         .Configuration(LCD_CW & "sendusing") = 2  '  Based on the LCD_OLE Data Base of type DBTYPE_I4
         .Configuration(LCD_CW & "smtpserverport") = 465 ' 465 or 25 for gmail '587 ' 25  ' 465 or 25 for t-online.de 'or 587 'or 25
         .Configuration(LCD_CW & "sendusername") = "excellearning12@gmail.com" '
         .Configuration(LCD_CW & "sendpassword") = "xxxxxxxxxxxxx"       '                                  '
    '     .Configuration(LCD_CW & "sendusername") = "YourEMailAddress"
    '     .Configuration(LCD_CW & "sendpassword") = "YourEMailPassword"
        ' Optional - How long to try
         .Configuration(LCD_CW & "smtpconnectiontimeout") = 30 '
        ' Intraction protocol is Set/ Updated
         .Configuration.Fields.Update '
        'End With 6a(i)' ----------------------        my Created  LCDCW Library
        '6a(ii) With   ' -- ' Data to be sent---       my Created  LCDCW Library
         Dim strHTML As String: Let strHTML = "<font size=""3"" face=""Calibri"">" & _
         "This is sent from EMail account:" & _
         "<br>Username: ""excellearning12@gmail.com""" & _
         "<br>Password: ""xxxxxxxxxxxxx""" & _
         "<br><br>" & _
         "<br>Please click on the 5 links below and tell me what happens, thanks!" & _
         "<br>1 <A HREF=""https://app.box.com/s/x01liz3ralbdrt152i52fpwb0wx40ff3"">link to box net cloud free file sharing</A>" & _
         "<br>2 <A HREF=""file://" & ThisWorkbook.Path & "\" & "Test file DOThtm to be stored on your computer to try to open with a Hyperlink in a received EMail.htm"""">htm file on your computer</A>" & _
         "<br>3 <A HREF=""file://" & ThisWorkbook.Path & "\" & "Test file DOThtm to be stored on your computer to try to open with a Hyperlink in a received EMail.htm"""">htm file on your computer</A>" & _
         "<br>4 <A HREF=""file://" & ThisWorkbook.Path & "\" & "Empty test file DOTxls stored on your computer to try to open from Hyperlink in arrived Email.xls"""">empty xls file on your computer</A>" & _
         "<br>5 <A HREF=""file:///" & ThisWorkbook.Path & "\" & "Empty test file DOTxls stored on your computer to try to open from Hyperlink in arrived Email.xls"""">empty xls file on your computer</A>"
        .To = "THai xxxxxxxxx"
        '.CC = "xxxxxxxxxxxxx"
        .BCC = ""
        .from = """excellearning12@gmail.com"" <excellearning12@gmail.com>"
        .Subject = "Sent from EMail address: excellearning12@gmail.com"
        .htmlbody = strHTML
        .Send ' Do it
        End With ' 6a(ii) CreateObject("CDO.Message") ---my Created  LCDCW Library
    Testing files( sent privately ) :
    I have also posted 3 files to you using our share g mail account , ExcelVBAExp@gmail.com
    Please can you also try out the test…
    Please do the following.
    _1) Download all three files , and important: All must be stored in the same Folder.
    ( the three files are:
    Test file DOThtm to be stored on your computer to try to open with a Hyperlink in a received Email.htm
    Test File Thai to send EMail containing Hyperlinks to Files.xlsm
    _2) Open only file Test File Thai to send EMail containing Hyperlinks to Files.xlsm
    Run code Sub Sendfromexcellearninggmail()
    You should receive an Email similar to these:
    Alan 5 Links in German Telekom.JPG : https://imgur.com/LeASbhf
    Attachment 2079
    Alan 5 Links in gmail.JPG : https://imgur.com/0sdyZEj
    Attachment 2080
    _3) Please click on the links.
    _4) Please reply and tell me what happens when you click each link
    Code for Thai .
        '6a(i)
        '  ' Sever info
         "<br><br>" & _
        .BCC = ""
        .htmlbody = strHTML
        .Send ' Do it
    Attachment 2079
    Attachment 2080
    First test code for solution to this thread:
    http://www.excelfox.com/forum/showth...le-or-two-tabs
    ( Run code Sub TestieCalls() )
    Sub TestieCalls()
     Call Testie(Worksheets("Sheet1"), Worksheets("Sheet2"))
    Sub Testie(Ws1 As Worksheet, Ws2 As Worksheet)
    Rem 1 Worksheet data info
    '1a capture data
    '1a(i) last data rows
    Dim lr1_1 As Long, Lr1_2 As Long, Lr2_1 As Long, Lr2_2 As Long, Lr1 As Long, lr2 As Long
     Let lr1_1 = Ws1.Cells(Rows.Count, 1).End(xlUp).row
     Let Lr1_2 = Ws1.Cells(Rows.Count, 2).End(xlUp).row: Lr2_1 = Ws2.Cells(Rows.Count, 1).End(xlUp).row: Lr2_2 = Ws2.Cells(Rows.Count, 2).End(xlUp).row
        If lr1_1 > Lr1_2 Then
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
     Let lr2 = Lr2_2: If Lr2_1 > Lr2_2 Then Let lr2 = Lr2_1
    '1a(ii) capture data into arrays in one go
    Dim arrSht1() As Variant, arrSht2() As Variant
     Let arrSht1() = Ws1.Range("A1:B" & Lr1 & "").Value
     Let arrSht2() = Ws2.Range("A1:B" & lr2 & "").Value
    Rem 2 arrays for check and output
    Dim arrSht1b() As String, arrOut() As String
    '2a size arrays to that of sheet 2 data
     ReDim arrSht1b(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
     ReDim arrOut(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
    '2b fill modified sheet 1 array, arrSht1b() , initially with sheet 1 data
        For Cnt = 1 To UBound(arrSht1(), 1) Step 1
         Let arrSht1b(Cnt, 1) = arrSht1(Cnt, 1): Let arrSht1b(Cnt, 2) = arrSht1(Cnt, 2)
    Rem 3 main loop   ' == Start main loop ==========
        For Cnt = 1 To UBound(arrSht2(), 1) - 1 Step 1 ' Counting at each row
        Dim DifCnt As Long 'Count of different cells
            ' Condition check
            If (arrSht2(Cnt, 1) <> arrSht1b(Cnt, 1) Or arrSht2(Cnt, 2) <> arrSht1b(Cnt, 2)) And (arrSht2(Cnt + 1, 1) = arrSht1b(Cnt + 1, 1) And arrSht2(Cnt + 1, 2) = arrSht1b(Cnt + 1, 2)) Then  ' condition for changed row but next row is as previous : row had data changed, but a row was not inserted
             Let arrSht1b(Cnt, 1) = arrSht2(Cnt, 1): arrSht1b(Cnt, 2) = arrSht2(Cnt, 2) 'change any changed cell
                If arrSht1b(Cnt, 1) <> arrSht1(Cnt, 1) Then
                 Let arrOut(Cnt, 1) = arrSht1b(Cnt, 1) & "  <>  " & arrSht1(Cnt, 1)
                 Let DifCnt = DifCnt + 1
                Else: End If
                If arrSht1b(Cnt, 2) <> arrSht1(Cnt, 2) Then
                 Let arrOut(Cnt, 2) = arrSht1b(Cnt, 2) & "  <>  " & arrSht1(Cnt, 2)
                Else: End If
            ' Condition check
            ElseIf ((arrSht2(Cnt, 1) <> arrSht1b(Cnt, 1) Or arrSht2(Cnt, 2) <> arrSht1b(Cnt, 2)) And (arrSht2(Cnt + 1, 1) <> arrSht1b(Cnt + 1, 1) Or arrSht2(Cnt + 1, 2) <> arrSht1b(Cnt + 1, 2))) Then   ' main condition suggesting added new row
            Dim AdedRows As Long: Let AdedRows = AdedRows + 1
            '3b we need to shift all data down to allow space for new row in arrSht2()
            Dim CntIn As Long
                For CntIn = (UBound(arrSht2(), 1) - 1) To Cnt Step -1 'loop for all but last from this row
                 Let arrSht1b(CntIn + 1, 1) = arrSht1b(CntIn, 1): arrSht1b(CntIn + 1, 2) = arrSht1b(CntIn, 2) ' This effectively pulls up each row by one
                Next CntIn
            '3c add the new data to the modified array, Let arrSht1b()
                If arrSht1b(Cnt, 1) = "" Then arrSht1b(Cnt, 1) = "           " ' Just to make final output more neat
                If arrSht1b(Cnt, 2) = "" Then arrSht1b(Cnt, 2) = "           "
            '3d add info to the output array
                If Cnt > UBound(arrSht1(), 1) Then ' case of new lines
                 Let arrOut(Cnt, 1) = "An new extra line contains  " & arrSht1b(Cnt, 1): arrOut(Cnt, 2) = "An new extra line contains  " & arrSht1b(Cnt, 2)
                   Else: End If
                   Else: End If
             Let Cnt = Cnt + 1 ' we need to skip the next row as that was just effectively added so we are done with it
            Else ' row has not been added here
        Next Cnt ' ========= End main loop ==========
    Rem 4 last row may be new
        If arrSht2(lr2, 1) <> arrSht1(Lr1, 1) Or arrSht2(lr2, 2) <> arrSht1(Lr1, 2) Then ' either cell in last row is different
            If arrSht2(lr2, 1) <> arrSht1(Lr1, 1) Then
             Let arrOut(lr2, 1) = arrSht2(lr2, 1) & "  on last row is new"
            Else: End If
            If arrSht2(lr2, 2) <> arrSht1(Lr1, 2) Then
             Let arrOut(lr2, 2) = arrSht2(lr2, 2) & "  on last row is new"
            Else: End If
        Else 'last row on sheet2 is as on sheet1
    Rem 5 Output in new file For testing purposes, I give the output in a third worksheet, Tabelle3
    Dim Ws3 As Worksheet: Set Ws3 = ThisWorkbook.Worksheets("Tabelle3")
     Ws3.Cells.ClearContents
     Let Ws3.Range("A1:B1").Value = "Sheet1": Ws3.Range("C1:D1").Value = "Test Output": Ws3.Range("E1:F1").Value = "Sheet2"
     Let Ws3.Range("A2").Resize(UBound(arrSht1(), 1), UBound(arrSht1(), 2)).Value = arrSht1()
     Let Ws3.Range("C2").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)).Value = arrOut()
     Let Ws3.Range("E2").Resize(UBound(arrSht2(), 1), UBound(arrSht2(), 2)).Value = arrSht2()
     Ws3.Columns.AutoFit
    Rem 6 MsgBoox output
     MsgBox Prompt:="inserted lines is   " & AdedRows & vbCrLf & "Changed cells is  " & DifCnt
    Sub TestieCalls()
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
            ' Condition check
                Else: End If
                Else: End If
            ' Condition check
            Dim CntIn As Long
                Next CntIn
                   Else: End If
                   Else: End If
            Else: End If
            Else: End If
     Ws3.Columns.AutoFit
    Test runs from code
    Sub TestyCalls() ' http://www.excelfox.com/forum/showthread.php/2277-Vba-button-Comparison-data-between-two-file-or-two-tabs?p=10741#post10741
    ' Call Testie(Worksheets("Sheet1"), Worksheets("Sheet2"))
     Call Testy(Worksheets("Sheet1"), Worksheets("Sheet2"))
    For support of this excelfox Thread:
    http://www.excelfox.com/forum/showth...0741#post10741
    Using Excel 2007 32 bit
    Sheet1 Sheet1 Test Output Test Output Sheet2 Sheet2
    Customer Assembly Customer Assembly
    Nu Torque
    13456
    Nu Torque
    13456
    Blu Origin Spaceship Blu Origin Spaceship
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Dup 2 of Toyota Dup 2 of Supra Toyota Supra
    Dup 2 of Emirate Dup 2 of ABC12345 Emirate ABC12345
    Spaceship 12 Spaceship
    Worksheet: Tabelle3
    Nu Torque
    13456
    Nu Torque
    13456
    Blu Origin Spaceship Alaska
    789
    Jet Blue21 ABC Excel123 HiThai Excel123 HiThai
    Alaska
    789
    Toyota Supra Emirate ABC12345
    Emirate ABC12345 Jet Blue21 ABC
    Toyota Supra
    Worksheet: Tabelle3
    Test runs from code
    Nu Torque
    13456
    Nu Torque
    13456
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Worksheet: Tabelle3
    Nu Torque
    13456
    Nu Torque
    13456
    789
    Alaska
    789
    Toyota Supra
    Worksheet: Tabelle3
    Code in support of this Post
    Sub Testy(Ws1 As Worksheet, Ws2 As Worksheet)
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
    Dim arrSht1b() As String, arrOut() As String, arrSht1Chk() As String, arrSht2Chk() As String
    ' ReDim arrSht1b(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
     ReDim arrSht1Chk(1 To UBound(arrSht1(), 1)): ReDim arrSht2Chk(1 To UBound(arrSht2(), 1)) ' Arrays for concatenated data
    '2b make check arrays        fill modified sheet 1 array, arrSht1b() , initially with sheet 1 data
    '     Let arrSht1b(Cnt, 1) = arrSht1(Cnt, 1): Let arrSht1b(Cnt, 2) = arrSht1(Cnt, 2)
         Let arrSht1Chk(Cnt) = arrSht1(Cnt, 1) & "|" & arrSht1(Cnt, 2)
        For Cnt = 1 To UBound(arrSht2(), 1) Step 1
         Let arrSht2Chk(Cnt) = arrSht2(Cnt, 1) & "|" & arrSht2(Cnt, 2)
    '2c make contents of array for output initially all dat from Sheet2
         Let arrOut(Cnt, 1) = CStr(arrSht2(Cnt, 1)): arrOut(Cnt, 2) = CStr(arrSht2(Cnt, 2))
    Rem 3 main loop   ' == Start Main loop ================
        For Cnt = 1 To UBound(arrSht1(), 1) Step 1 ' Counting at each row of Sheet2
        Dim MtchRes As Variant
         Let MtchRes = Application.Match(arrSht1Chk(Cnt), arrSht2Chk(), 0)
        '3a action whilst match is found --Inner Loop------
            Do While Not IsError(MtchRes) ' The 3a Loop
            Dim DupyCnt As Long: Let DupyCnt = DupyCnt + 1
                If DupyCnt > 1 Then
                 Let arrOut(MtchRes, 1) = "Dup " & DupyCnt & " of " & arrOut(MtchRes, 1): arrOut(MtchRes, 2) = "Dup " & DupyCnt & " of " & arrOut(MtchRes, 2)
                 Let arrOut(MtchRes, 1) = "": arrOut(MtchRes, 2) = "" ' remove the found data from array for output so that next line can look again for a possible duplicate
                 Let arrSht2Chk(MtchRes) = "" ' remove entry in check array so that next line can look for possible duplicate
            Loop ' ----------------------------------------
         Let DupyCnt = 0 ' reset the Duplicated data count for next row of data in Sheet1
        Next Cnt ' ========= End main loop ================= effectively we go to next row of data in Sheet1 with this line
     Ws3.Columns.AutoFit
    Rem 6 MsgBox output
    ' MsgBox Prompt:="Inserted lines is   " & AdedRows & vbCrLf & "Changed cells is  " & DifCnt
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
                If DupyCnt > 1 Then
     Ws3.Columns.AutoFit
    Rem 6 MsgBox output
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
