Page 54 of 57 FirstFirst ... 4445253545556 ... LastLast
Results 531 to 540 of 570
  1. #531
    Some more notes in support of this main Forum Thread
    https://www.eileenslounge.com/viewto...p?f=27&t=39784
    Sub ClipIt() ' https://www.eileenslounge.com/viewtopic.php?f=27&t=39784
     Selection.Copy  '  Or   Application.SendKeys "^c"
        With GetObject("New:{1C3B4210-F441-11CE-B9EA-00AA006B1A69}")  '    http://web.archive.org/web/20200124185244/http://excelmatters.com/2013/10/04/late-bound-msforms-dataobject/
        Dim StringBack As String ' This is for the entire text held for the range in the windows clipboard after a  .Copy
         .GetFromClipboard: Let StringBack = .GetText()
         Let StringBack = Replace(StringBack, vbCr & vbLf, ", ", 1, -1, vbBinaryCompare) '  Binary - derived from the internal binary representations of the characters    https://www.eileenslounge.com/viewtopic.php?p=308065#p308065
         Let StringBack = Left(StringBack, Len(StringBack) - 2) '  .Copy  adds an extra trailing vbCr & vbLf      https://www.eileenslounge.com/viewtopic.php?p=303007#p303007
         .Clear
         .SetText StringBack
         .PutInClipboard
     Let Selection(1).Offset(1, 1).NumberFormat = "@"
     ActiveSheet.Paste Destination:=Selection(1).Offset(1, 1)
    more later..
    https://www.youtube.com/watch?v=yVgLmj0aojI
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgwWg8x2WxLSxxGsUP14AaABAg.9k3ShckGnhv9k89Lsaig oO
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgxxxIaK1pY8nNvx6JF4AaABAg.9k-vfnj3ivI9k8B2r_uRa2
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgxKFXBNd6Pwvcp4Bsd4AaABAg
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=Ugw9X6QS09LuZdZpBHJ4AaABAg
  2. #532
    .c, cxn n
  3. #533
    This is post
    https://www.excelfox.com/forum/showt...ll=1#post24114
    https://www.excelfox.com/forum/showthread.php/2559-Notes-tests-text-files-manipulation-of-text-files-in-Excel-and-with-Excel-VBA-CSV-stuff?p=24114&viewfull=1#post24114
    https://www.excelfox.com/forum/showt...ge12#post24114
    https://www.excelfox.com/forum/showthread.php/2559-Notes-tests-text-files-manipulation-of-text-files-in-Excel-and-with-Excel-VBA-CSV-stuff/page12#post24114
    In support of these main forum posts
    https://www.excelfox.com/forum/showt...ge12#post24048
    https://eileenslounge.com/viewtopic....314920#p314920
    Similar to a post or two previously , just a bit more complicated, the full text in a cell may have these sort of forms, (4 cell examples are shown)
    Address.Country -- PKEY_Address_Country
    //  Type:     String -- VT_LPWSTR  (For variants: VT_BSTR)
    //  FormatID: {C07B4199-E1DF-4493-B1E1-DE5946FB58F8}, 100
    DEFINE_PROPERTYKEY(PKEY_Address_Country, 0xC07B4199, 0xE1DF, 0x4493, 0xB1, 0xE1, 0xDE, 0x59, 0x46, 0xFB, 0x58, 0xF8, 100);
    #define INIT_PKEY_Address_Country { { 0xC07B4199, 0xE1DF, 0x4493, 0xB1, 0xE1, 0xDE, 0x59, 0x46, 0xFB, 0x58, 0xF8 }, 100 }
    Audio.Compression -- PKEY_Audio_Compression
    //  FormatID: (FMTID_AudioSummaryInformation) {64440490-4C8B-11D1-8B70-080036B11A03}, 10 (PIDASI_COMPRESSION)
    DEFINE_PROPERTYKEY(PKEY_Audio_Compression, 0x64440490, 0x4C8B, 0x11D1, 0x8B, 0x70, 0x08, 0x00, 0x36, 0xB1, 0x1A, 0x03, 10);
    #define INIT_PKEY_Audio_Compression { { 0x64440490, 0x4C8B, 0x11D1, 0x8B, 0x70, 0x08, 0x00, 0x36, 0xB1, 0x1A, 0x03 }, 10 }
    IsSendToTarget -- PKEY_IsSendToTarget
    //  Type:     Boolean -- VT_BOOL
    //  FormatID: (FMTID_ShellDetails) {28636AA6-953D-11D2-B5D6-00C04FD918D0}, 33
    //  Provided by certain shell folders. Return TRUE if the folder is a valid Send To target.
    DEFINE_PROPERTYKEY(PKEY_IsSendToTarget, 0x28636AA6, 0x953D, 0x11D2, 0xB5, 0xD6, 0x00, 0xC0, 0x4F, 0xD9, 0x18, 0xD0, 33);
    #define INIT_PKEY_IsSendToTarget { { 0x28636AA6, 0x953D, 0x11D2, 0xB5, 0xD6, 0x00, 0xC0, 0x4F, 0xD9, 0x18, 0xD0 }, 33 }
    TitleSortOverride -- PKEY_TitleSortOverride
    //  Type:     String -- VT_LPWSTR  (For variants: VT_BSTR)  Legacy code may treat this as VT_LPSTR.
    //  FormatID: {F0F7984D-222E-4AD2-82AB-1DD8EA40E57E}, 300 (PIDSI_TITLE_SORT_OVERRIDE)
    //  This optional string value allows for overriding the standard sort order of System.Title.
    //  This is very important for proper sorting of music files in Japanese which cannot be
    //  correctly sorted phonetically (the user-expected ordering) without this field.
    //  It can also be used for customizing sorting in non-East Asian scenarios,
    //  such as allowing the user to remove articles for sorting purposes.
    DEFINE_PROPERTYKEY(PKEY_TitleSortOverride, 0xF0F7984D, 0x222E, 0x4AD2, 0x82, 0xAB, 0x1D, 0xD8, 0xEA, 0x40, 0xE5, 0x7E, 300);
    #define INIT_PKEY_TitleSortOverride { { 0xF0F7984D, 0x222E, 0x4AD2, 0x82, 0xAB, 0x1D, 0xD8, 0xEA, 0x40, 0xE5, 0x7E }, 300 }
    What I want is the SCIDS, aHoy, aHoy ( https://www.youtube.com/watch?v=DDg1hy6VhxY&t=110s
    https://eileenslounge.com/viewtopic....314905#p314905
    I took a more fuller look those,
     '   https://www.excelfox.com/forum/showthread.php/2909-Appendix-Thread-Evaluate-Range-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=24049&viewfull=1#post24049
    Sub CheckCharacters()  '  Cells  A2  A8  A288  A377
     Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(Range("A2").Value)
     Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(Range("A8").Value)
     Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(Range("A288").Value)
     Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(Range("A377").Value)
    End Sub  '  see worksheet  WotchaGotInString  4 Mrz Results
    For the results, see worksheet WotchaGotInString 4 Mrz Results in the uploaded workbook
    Here again parts around the 4 examples simple text forms
    Cell A2
    112           I	73
    113           D	68
    114           :	58
    115            	32
    116           {	123
    117           C	67
    118           0	48
    119           7	55
    120           B	66
    121           4	52
    122           1	49
    123           9	57
    124           9	57
    125           -	45
    126           E	69
    127           1	49
    128           D	68
    129           F	70
    130           -	45
    131           4	52
    132           4	52
    133           9	57
    134           3	51
    135           -	45
    136           B	66
    137           1	49
    138           E	69
    139           1	49
    140           -	45
    141           D	68
    142           E	69
    143           5	53
    144           9	57
    145           4	52
    146           6	54
    147           F	70
    148           B	66
    149           5	53
    150           8	56
    151           F	70
    152           8	56
    153           }	125
    154           ,	44
    155            	32
    156           1	49
    157           0	48
    158           0	48
    "159
    "	13
    "160
    "	10
    161           D	68
    162           E	69
    163           F	70
    Cell A8
    116           I	73
    117           D	68
    118           :	58
    119            	32
    120           (	40
    121           F	70
    122           M	77
    123           T	84
    124           I	73
    125           D	68
    126           _	95
    127           A	65
    128           u	117
    129           d	100
    130           i	105
    131           o	111
    132           S	83
    133           u	117
    134           m	109
    135           m	109
    136           a	97
    137           r	114
    138           y	121
    139           I	73
    140           n	110
    141           f	102
    142           o	111
    143           r	114
    144           m	109
    145           a	97
    146           t	116
    147           i	105
    148           o	111
    149           n	110
    150           )	41
    151            	32
    152           {	123
    153           6	54
    154           4	52
    155           4	52
    156           4	52
    157           0	48
    158           4	52
    159           9	57
    160           0	48
    161           -	45
    162           4	52
    163           C	67
    164           8	56
    165           B	66
    166           -	45
    167           1	49
    168           1	49
    169           D	68
    170           1	49
    171           -	45
    172           8	56
    173           B	66
    174           7	55
    175           0	48
    176           -	45
    177           0	48
    178           8	56
    179           0	48
    180           0	48
    181           3	51
    182           6	54
    183           B	66
    184           1	49
    185           1	49
    186           A	65
    187           0	48
    188           3	51
    189           }	125
    190           ,	44
    191            	32
    192           1	49
    193           0	48
    194            	32
    195           (	40
    196           P	80
    197           I	73
    198           D	68
    199           A	65
    200           S	83
    201           I	73
    202           _	95
    203           C	67
    204           O	79
    205           M	77
    206           P	80
    207           R	82
    208           E	69
    209           S	83
    210           S	83
    211           I	73
    212           O	79
    213           N	78
    214           )	41
    "215
    "	13
    "216
    "	10
    Cell A288
    84           I	73
    85           D	68
    86           :	58
    87            	32
    88           (	40
    89           F	70
    90           M	77
    91           T	84
    92           I	73
    93           D	68
    94           _	95
    95           S	83
    96           h	104
    97           e	101
    98           l	108
    99           l	108
    100           D	68
    101           e	101
    102           t	116
    103           a	97
    104           i	105
    105           l	108
    106           s	115
    107           )	41
    108            	32
    109           {	123
    110           2	50
    111           8	56
    112           6	54
    113           3	51
    114           6	54
    115           A	65
    116           A	65
    117           6	54
    118           -	45
    119           9	57
    120           5	53
    121           3	51
    122           D	68
    123           -	45
    124           1	49
    125           1	49
    126           D	68
    127           2	50
    128           -	45
    129           B	66
    130           5	53
    131           D	68
    132           6	54
    133           -	45
    134           0	48
    135           0	48
    136           C	67
    137           0	48
    138           4	52
    139           F	70
    140           D	68
    141           9	57
    142           1	49
    143           8	56
    144           D	68
    145           0	48
    146           }	125
    147           ,	44
    148            	32
    149           3	51
    150           3	51
    "151            "	13
    "152
    "	10
    Cell A377
    155           a	97
    156           t	116
    157           I	73
    158           D	68
    159           :	58
    160            	32
    161           {	123
    162           F	70
    163           0	48
    164           F	70
    165           7	55
    166           9	57
    167           8	56
    168           4	52
    169           D	68
    170           -	45
    171           2	50
    172           2	50
    173           2	50
    174           E	69
    175           -	45
    176           4	52
    177           A	65
    178           D	68
    179           2	50
    180           -	45
    181           8	56
    182           2	50
    183           A	65
    184           B	66
    185           -	45
    186           1	49
    187           D	68
    188           D	68
    189           8	56
    190           E	69
    191           A	65
    192           4	52
    193           0	48
    194           E	69
    195           5	53
    196           7	55
    197           E	69
    198           }	125
    199           ,	44
    200            	32
    201           3	51
    202           0	48
    203           0	48
    204            	32
    205           (	40
    206           P	80
    207           I	73
    208           D	68
    209           S	83
    210           I	73
    211           _	95
    212           T	84
    213           I	73
    214           T	84
    215           L	76
    216           E	69
    217           _	95
    218           S	83
    219           O	79
    220           R	82
    221           T	84
    222           _	95
    223           O	79
    224           V	86
    225           E	69
    226           R	82
    227           R	82
    228           I	73
    229           D	68
    230           E	69
    231           )	41
    "232            "	13
    "233
    "	10
    The conclusion from examination of those text parts, is that there are no surprises such as strange "invisible coding". The line separator is the typical pair, vbCr & vbLf
    So we can simply look at these 4 lines, when thinking of how to get at the SCIDS, (and the second one I show again the whole cell of it, just to remind of how the full strings containing the lines of interest look like)
    So we will check that out in the next post
  6. #536
    This is post
    https://www.excelfox.com/forum/showt...ll=1#post24124
    https://www.excelfox.com/forum/showthread.php/2559-Notes-tests-text-files-manipulation-of-text-files-in-Excel-and-with-Excel-VBA-CSV-stuff?p=24124&viewfull=1#post24124
    https://www.excelfox.com/forum/showt...ge12#post24124
    https://www.excelfox.com/forum/showthread.php/2559-Notes-tests-text-files-manipulation-of-text-files-in-Excel-and-with-Excel-VBA-CSV-stuff/page12#post24124
    Cell A2
    112           I	73
    113           D	68
    114           :	58
    115            	32
    116           {	123
    117           C	67
    118           0	48
    119           7	55
    120           B	66
    121           4	52
    122           1	49
    123           9	57
    124           9	57
    125           -	45
    126           E	69
    127           1	49
    128           D	68
    129           F	70
    130           -	45
    131           4	52
    132           4	52
    133           9	57
    134           3	51
    135           -	45
    136           B	66
    137           1	49
    138           E	69
    139           1	49
    140           -	45
    141           D	68
    142           E	69
    143           5	53
    144           9	57
    145           4	52
    146           6	54
    147           F	70
    148           B	66
    149           5	53
    150           8	56
    151           F	70
    152           8	56
    153           }	125
    154           ,	44
    155            	32
    156           1	49
    157           0	48
    158           0	48
    "159
    "	13
    "160
    "	10
    161           D	68
    162           E	69
    163           F	70
    Cell A8
    116           I	73
    117           D	68
    118           :	58
    119            	32
    120           (	40
    121           F	70
    122           M	77
    123           T	84
    124           I	73
    125           D	68
    126           _	95
    127           A	65
    128           u	117
    129           d	100
    130           i	105
    131           o	111
    132           S	83
    133           u	117
    134           m	109
    135           m	109
    136           a	97
    137           r	114
    138           y	121
    139           I	73
    140           n	110
    141           f	102
    142           o	111
    143           r	114
    144           m	109
    145           a	97
    146           t	116
    147           i	105
    148           o	111
    149           n	110
    150           )	41
    151            	32
    152           {	123
    153           6	54
    154           4	52
    155           4	52
    156           4	52
    157           0	48
    158           4	52
    159           9	57
    160           0	48
    161           -	45
    162           4	52
    163           C	67
    164           8	56
    165           B	66
    166           -	45
    167           1	49
    168           1	49
    169           D	68
    170           1	49
    171           -	45
    172           8	56
    173           B	66
    174           7	55
    175           0	48
    176           -	45
    177           0	48
    178           8	56
    179           0	48
    180           0	48
    181           3	51
    182           6	54
    183           B	66
    184           1	49
    185           1	49
    186           A	65
    187           0	48
    188           3	51
    189           }	125
    190           ,	44
    191            	32
    192           1	49
    193           0	48
    194            	32
    195           (	40
    196           P	80
    197           I	73
    198           D	68
    199           A	65
    200           S	83
    201           I	73
    202           _	95
    203           C	67
    204           O	79
    205           M	77
    206           P	80
    207           R	82
    208           E	69
    209           S	83
    210           S	83
    211           I	73
    212           O	79
    213           N	78
    214           )	41
    "215
    "	13
    "216
    "	10
    Cell A288
    84           I	73
    85           D	68
    86           :	58
    87            	32
    88           (	40
    89           F	70
    90           M	77
    91           T	84
    92           I	73
    93           D	68
    94           _	95
    95           S	83
    96           h	104
    97           e	101
    98           l	108
    99           l	108
    100           D	68
    101           e	101
    102           t	116
    103           a	97
    104           i	105
    105           l	108
    106           s	115
    107           )	41
    108            	32
    109           {	123
    110           2	50
    111           8	56
    112           6	54
    113           3	51
    114           6	54
    115           A	65
    116           A	65
    117           6	54
    118           -	45
    119           9	57
    120           5	53
    121           3	51
    122           D	68
    123           -	45
    124           1	49
    125           1	49
    126           D	68
    127           2	50
    128           -	45
    129           B	66
    130           5	53
    131           D	68
    132           6	54
    133           -	45
    134           0	48
    135           0	48
    136           C	67
    137           0	48
    138           4	52
    139           F	70
    140           D	68
    141           9	57
    142           1	49
    143           8	56
    144           D	68
    145           0	48
    146           }	125
    147           ,	44
    148            	32
    149           3	51
    150           3	51
    "151            "	13
    "152
    "	10
    Cell A377
    155           a	97
    156           t	116
    157           I	73
    158           D	68
    159           :	58
    160            	32
    161           {	123
    162           F	70
    163           0	48
    164           F	70
    165           7	55
    166           9	57
    167           8	56
    168           4	52
    169           D	68
    170           -	45
    171           2	50
    172           2	50
    173           2	50
    174           E	69
    175           -	45
    176           4	52
    177           A	65
    178           D	68
    179           2	50
    180           -	45
    181           8	56
    182           2	50
    183           A	65
    184           B	66
    185           -	45
    186           1	49
    187           D	68
    188           D	68
    189           8	56
    190           E	69
    191           A	65
    192           4	52
    193           0	48
    194           E	69
    195           5	53
    196           7	55
    197           E	69
    198           }	125
    199           ,	44
    200            	32
    201           3	51
    202           0	48
    203           0	48
    204            	32
    205           (	40
    206           P	80
    207           I	73
    208           D	68
    209           S	83
    210           I	73
    211           _	95
    212           T	84
    213           I	73
    214           T	84
    215           L	76
    216           E	69
    217           _	95
    218           S	83
    219           O	79
    220           R	82
    221           T	84
    222           _	95
    223           O	79
    224           V	86
    225           E	69
    226           R	82
    227           R	82
    228           I	73
    229           D	68
    230           E	69
    231           )	41
    "232            "	13
    "233
    "	10
  7. #537
    Later
  8. #538
    Later
  9. #539
    Later
  10. #540
    Later
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
