Page 52 of 57 FirstFirst ... 2425051525354 ... LastLast
Results 511 to 520 of 570
  1. #511
    docs.microsoft.com
    learn.microsoft.com
    https://web.archive.org/web/20230121...m-renderformat 12/12/2020
    https://web.archive.org/web/20191230...m-renderformat 05/31/2018
    WM_RENDERFORMAT message
    05/31/2018
    Sent to the clipboard owner if it has delayed rendering a specific clipboard format and if an application has requested data in that format. The clipboard owner must render data in the specified format and place it on the clipboard by calling the SetClipboardData function.
    https://web.archive.org/web/20191230...xchg/clipboard
    ps://web.archive.org/web/20100506094659/http://support.microsoft.com/default.aspx/kb/221190
    ps://web.archive.org/web/20080508194547/http://msdn.microsoft.com/en-us/library/ms649052(VS.85).aspx
    https://www.mrexcel.com/board/threads/vba-autofilter-specialcells-xlcelltypevisible-copy-only-values-not-formulas.828241/#post-4040646
    https://eileenslounge.com/viewtopic.php?p=246740#p246740
    https://eileenslounge.com/viewtopic.php?p=246884#p246884
    https://eileenslounge.com/viewtopic.php?p=246838#p246838
    https://eileenslounge.com/viewtopic.php?p=246770#p246770
    https://stackoverflow.com/questions/25091571/strange-behavior-from-vba-dataobject-gettext-returns-what-is-currently-on-the-c/54960767#54960767
    https://eileenslounge.com/viewtopic.php?p=247809#p247809
    ps://web.archive.org/web/20131003213600/http://msdn.microsoft.com/en-us/library/office/ff192913.aspx
    ps://web.archive.org/web/20130113075556/http://ms
    tps://www.spreadsheet1.com/how-to-copy-strings-to-clipboard-using-excel-vba.html#
    https://eileenslounge.com/viewtopic.php?p=249755#p249755
    https://eileenslounge.com/viewtopic.php?p=249795#p249795
    http://eileenslounge.com/viewtopic.php?p=262011#p262011
    http://eileenslounge.com/viewtopic.php?f=18&t=33834
    https://eileenslounge.com/viewtopic.php?p=279659#p279659
    https://www.eileenslounge.com/viewtopic.php?p=295816#p295816
    https://www.eileenslounge.com/viewtopic.php?f=30&t=35100&p=295780#p295780
    https://www.eileenslounge.com/viewtopic.php?p=294721#p294721
    https://www.eileenslounge.com/viewtopic.php?p=296145#p296145
    https://www.eileenslounge.com/viewtopic.php?p=296126#p296126
    https://www.eileenslounge.com/viewtopic.php?f=27&t=38910&p=301028#p301028
    https://www.eileenslounge.com/viewtopic.php?p=300947#p300947
    https://www.eileenslounge.com/viewtopic.php?p=300955#p300955
    https://www.eileenslounge.com/viewtopic.php?p=301028#p301028
    https://www.eileenslounge.com/viewtopic.php?p=301534#p301534
    https://www.eileenslounge.com/viewtopic.php?p=301761#p301761
    https://www.eileenslounge.com/viewtopic.php?p=304976#p304976
    https://www.eileenslounge.com/viewtopic.php?f=26&t=39715&p=307826#p307826
    https://www.eileenslounge.com/viewtopic.php?p=303007#p303007
    https://www.eileenslounge.com/viewtopic.php?p=303039#p303039
    https://eileenslounge.com/viewtopic.php?p=289020#p289020
    https://eileenslounge.com/viewtopic.php?p=286708#p286708
    https://chandoo.org/forum/threads/clipboard-copy-vba-code-not-working-in-windows-10.37126/#post-223256
  2. #512
    In support of these issues
    https://excelfox.com/forum/showthrea...ge51#post12784 https://www.youtube.com/watch?v=dKM8ZScbic8&t=75s
    Winget issues https://github.com/ChrisTitusTech/wi...770ae56d3b6e85
    https://github.com/ChrisTitusTech/wi...b236f3ecf290db
    06.07.2021 The Best Windows Utility ( second nice shade of grey GUI )
    Write-Host "Checking winget..."
    Try{
    	# Check if winget is already installed
    	$er = (invoke-expression "winget -v") 2>&1
    	if ($lastexitcode) {throw $er}
    	Write-Host "winget is already installed."
    Catch{
    	# winget is not installed. Install it from the Github release
    	Write-Host "winget is not found, installing it right now."
    	$download = "https://github.com/microsoft/winget-cli/releases/download/v1.0.11692/Microsoft.DesktopAppInstaller_8wekyb3d8bbwe.msixbundle"
    	$output = $PSScriptRoot + "\winget-latest.appxbundle"
    	Write-Host "Dowloading latest release"
    	Invoke-WebRequest -Uri $download -OutFile $output
    	Write-Host "Installing the package"
    	Add-AppxPackage -Path $output
    Finally {
    	# Start installing the packages with winget
    	#Get-Content .\winget.txt | ForEach-Object {
    	#	iex ("winget install -e " + $_)
    The Ultimate Windows Utility Upgrade 29 09 2021
    Try{
    Catch{
    	# winget is not installed. Install it from the Microsoft Store
    	Start-Process "ms-appinstaller:?source=https://aka.ms/getwinget"
    	$nid = (Get-Process AppInstaller).id
    	Wait-Process -Id $nid
    Finally {
    A commit a bit later by mrhaydendp to simplify a bit https://github.com/ChrisTitusTech/wi...0db?diff=split
    # Check if winget is installed
    if (Test-Path ~\AppData\Local\Microsoft\WindowsApps\winget.exe){
        'Winget Already Installed'
    else{
        # Installing winget from the Microsoft Store
    	Write-Host "Winget not found, installing it now."
    	$nid = (Get-Process AppInstaller).Id
    	Write-Host Winget Installed
  3. #513
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg.8xzeMdC8IOGABa6BSa17 3Z
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg.8xzeMdC8IOGABa6-64Xpgl
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg.8xzeMdC8IOGABa5ms39y jd
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg.8xzeMdC8IOGABa5ZXJwR CM
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg.8xzeMdC8IOGABa4Pr15N Ut
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg.8xzeMdC8IOGABa4I83Je lY
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg.8mjgPNoTt_HABa3tnAjh ZU
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg.8mjgPNoTt_HABa3KswxL 3c
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=UgyBXFxnVWT3pqtdqPx4AaABAg
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=Ugi53h84LUm5bHgCoAEC.7-H0Z7-COoGABZFQ8vjEvY
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg.8xzeMdC8IOGABZ8N9O-O8p
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgxREWxgx2z2Lza_0st4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgyikSWvlxbWS24NBeR4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgwNiH4hhyrd2UjDK8d4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg.8mjgPNoTt_HAAf952WoU ti
    https://www.youtube.com/watch?v=hz4vb48wzMM&lc=Ugy2N3gvXBNrvWpojqR4AaABAg
    In support of this Thread https://eileenslounge.com/viewtopic.php?f=30&t=38110
    https://eileenslounge.com/viewtopic....294721#p294721
    Vertical to Horizontal,
    This to this
    Part 1 The main data Vertical to Horizontal
    An idea I have is to build up the single string that we know can be put into the Windows Clipboard, and then pasted out into Excel. ( http://www.eileenslounge.com/viewtop...242941#p242941 )
    I basically build that up with some Do While Loopy stuff
    The Full Story
    The usual worksheets defining and data getting information stuff.
    ( We capture one extra empty row, because, past experience with these sort of Do While Loopy stuff has shown that it can help simplify some conditional comparison things and/ or help prevent arrays doing out of bounds by one row.
    The purpose of this is to get that maximum Amounts or Notes count, ( the biggest group ) ( which is 4 in the given example )
    But its worth looking at how that works since the basic Do While Loop is then used in the next main ( Rem 2 ) section.
    The #### Main Outer Loop keeps us going through all data rows
    Within that the ' ---- Inner Loop that takes us through a group
    This loop adds the things in the group, and after each loop is finished we check If the count was the biggest group so far.
    This is the main meat of the solution.
    First, exactly as before we have a #### Main Outer Loop keeps us going through all data rows
    Within that Main Outer Loop we now have 2 inner loops.
    '2a
    The '2a The first inner loop one does something similar to before. It loops for a group. This time within it we build up two strings that we need for a line in the output.
    As example, for the first group we are basically trying to build up these two strings, ( Just before we start that loop, we tack onto the string at the start the group name, which is A in the first group example.
    This is what we would see, for example in the immediate window, for querying the string content after, in this example, the the loops for that inner loop
     ?  strClipL
    A   vbTab  10 vbTab     20 vbTab     30
    ?    strClipR
      vbTab    N1  vbTab  N2  vbTab  N3
    ( For the sake of clarity I use a vbTab to indicate the “invisible” vbTab characters, which is actually on those strings )
    '2b
    The purpose of '2b the second inner loop is to ,( if necessary ), give us effectively extra empty cells, ( achieved by adding a vbTab of the strings.
    Using the same example, we would see that the loop is needed to be done once, and at the end of that single loop, our strings are modifies such:
     ?  strClipL
    A   vbTab  10 vbTab     20 vbTab     30   vbTab
    ?    strClipR
      vbTab    N1  vbTab  N2  vbTab  N3  vbTab
    '2c
    At this point we combine the two strings and add a line separator so that this row data can be added onto by the next row data
    So as to be sure what I have and demonstrate it more clearly, I added a line in testing which calls a function of mine , ( https://excelfox.com/forum/showthrea...ll=1#post15522 ) , which checks that line screen,
    Here is the result
    "A" & vbTab & "10" & vbTab & "20" & vbTab & "30" & vbTab & vbTab & "N1" & vbTab & "N2" & vbTab & "N3" & vbTab & vbTab & "GroupA" & vbCr & vbLf
    That looks about correct.
    Doing a few other tests, suggest to me that I have the final result that I need:
     ? strclip
    A   10  20  30      N1  N2  N3      GroupA
    B   40  50  60  70  N4  N5  N6  N7  GroupB
    C   80              N8              GroupC
    D   90  100         N9  N10         GroupD
    "A" & vbTab & "10" & vbTab & "20" & vbTab & "30" & vbTab & vbTab & "N1" & vbTab & "N2" & vbTab & "N3" & vbTab & vbTab & "GroupA" & vbCr & vbLf & "B" & vbTab & "40" & vbTab & "50" & vbTab & "60" & vbTab & "70" & vbTab & "N4" & vbTab & "N5" & vbTab & "N6" & vbTab & "N7" & vbTab & "GroupB" & vbCr & vbLf & "C" & vbTab & "80" & vbTab & vbTab & vbTab & vbTab & "N8" & vbTab & vbTab & vbTab & vbTab & "GroupC" & vbCr & vbLf & "D" & vbTab & "90" & vbTab & "100" & vbTab & vbTab & vbTab & "N9" & vbTab & "N10" & vbTab & vbTab & vbTab & "GroupD" & vbCr & vbLf
    ' Ref
    ' http://www.eileenslounge.com/viewtop...=31395#p242941
    ' http://www.eileenslounge.com/viewtop...=31489#p243731
    ' http://www.eileenslounge.com/viewtop...=31938#p247681
    ' http://www.eileenslounge.com/viewtop...art=20#p246887
    ' http://web.archive.org/web/202001241...ms-dataobject/
    ' https://stackoverflow.com/questions/...60767#54960767
    ' https://stackoverflow.com/questions/...12342#59812342
    https://www.myonlinetraininghub.com/excel-clipboard https://support.microsoft.com/en-us/...&fromar=1#bm2b
    https://www.thespreadsheetguru.com/b...nal-macro-file
    https://excelribbon.tips.net/T009810...Clipboard.html
    https://www.excelforum.com/excel-pro...t-working.html
    https://www.thespreadsheetguru.com/b...-the-clipboard
    https://excelribbon.tips.net/T010691...Clipboard.html
    https://excel.tips.net/T003111_Cant_...Workbooks.html
    ' VBA to clear the Office Clipboard http://www.eileenslounge.com/viewtop...634c64#p246838
  5. #515
    Coding so far , for last post, https://excelfox.com/forum/showthrea...ll=1#post16529
    '  https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=16529&viewfull=1#post16529
    '  http://www.eileenslounge.com/viewtopic.php?f=30&t=38110&p=294692#p294692
    Sub Stantial()
    Rem 0 data
    Dim Ws1 As Worksheet: Set Ws1 = ThisWorkbook.Worksheets("Sheet1")
    Dim RngPlus1 As Range
     Set RngPlus1 = Ws1.Cells.Item(1).CurrentRegion.Resize(Ws1.Cells.Item(1).CurrentRegion.Rows.Count + 1, Ws1.Cells.Item(1).CurrentRegion.Columns.Count)
    Dim vArr() As Variant: Let vArr() = RngPlus1.Value2
    Rem 1 determine the biggest group ( that maximum Amounts or Notes count )
    Dim Cnt As Long, Cnt2 As Long, Mx As Long: Let Mx = 1: Let Cnt = 1
        Do  '            ############################# Main Outer Loop keeps us going through all data rows
            Do  '                           -----------------  Inner Loop that takes us through a group
             Let Cnt = Cnt + 1 ' Cnt is the main data row number
             Let Cnt2 = Cnt2 + 1
            Loop While vArr(Cnt + 1, 1) = vArr(Cnt, 1) ' ----  Inner Loop that takes us through a group
            If Cnt2 > Mx Then Let Mx = Cnt2
         Let Cnt2 = 0
        Loop While Cnt < UBound(vArr(), 1) - 1 '  #### Main Outer Loop keeps us going through all data rows
    Rem 2 '            ############################# Main Outer Loop keeps us going through all data rows
     Let Cnt = 1
        Do
        Dim HrCnt As Long: Let HrCnt = 1
        Dim strClipR As String, strClipL As String: Let strClipL = strClipL & vArr(Cnt + 1, 1)
            Do                                         '2a The first inner loop
             Let Cnt = Cnt + 1
             Let HrCnt = HrCnt + 1
             Let strClipL = strClipL & vbTab & vArr(Cnt, 2)
             Let strClipR = strClipR & vbTab & vArr(Cnt, 3)
            Loop While vArr(Cnt + 1, 1) = vArr(Cnt, 1) '   The first inner loop
            Do While HrCnt < Mx + 1                    '2b the second inner loop
            Loop                                       '   the second inner loop
        '2c Finishing off the strings, and final string for an output line, after the inner loops
         Let strClipR = strClipR & vbTab & vArr(Cnt, 4) ' add the group name
        Dim strClip As String: Let strClip = strClip & strClipL & strClipR & vbCr & vbLf  ' join the strings and add a line seperator to the output row string
        'Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(strClip)
        Let strClipL = "": strClipR = ""
    '2d paste  strClip  out via the windows Clipboard
    Dim objDataObject As Object: Set objDataObject = GetObject("New:{1C3B4210-F441-11CE-B9EA-00AA006B1A69}")   '     http://web.archive.org/web/20200124185244/http://excelmatters.com/2013/10/04/late-bound-msforms-dataobject/
     objDataObject.SetText Text:=strClip
     objDataObject.PutInClipboard
     Ws1.Paste Destination:=Ws1.Range("G2")
    Spare post for later
    https://www.youtube.com/watch?v=bRd4mJglWiM&lc=UgxRmh2gFhpmHNnPemR4AaABAg.A0opm95t2XEA0q3Kshmu uY
    https://eileenslounge.com/viewtopic.php?p=317050&sid=d7e077e50e904a138c794e1f2115da95#p317050
  7. #517
    Following on from posts,
    https://excelfox.com/forum/showthrea...ll=1#post16530 https://excelfox.com/forum/showthrea...ll=1#post16529
    http://www.eileenslounge.com/viewtop...294692#p294692
    The header row,
    Group Amount1 Amount2 Amount3 Amount4 Notes1 Notes2 Notes3 Notes4 Name
    , we could make partially dynamic, as is needed, since we don’t know the maximum number of amounts ( = maximum number of Notes ) , before seeing the data.
    We do have the information needed, since Mx contains, in our current example, the required value of 4
    Evaluate Range techniques are a convenient way to get these sort of things.
    We start by considering spreadsheet formulas such as this,
    ={"Amount" & COLUMN(A1:D1)}
    , which returns us an array, which applied across a range , would give us like
    Taking that general idea and a few other steps we can finally get at our heading like in this demo coding
    ' https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=16532&viewfull=1#post16532
    Sub MakeHeadings()
    Dim Mx As Long: Let Mx = 4
    Dim Amounts() As Variant
     Let Amounts() = Evaluate("=""Amount"" & COLUMN(A1:D1)")
     Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:D)")
     Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:" & "D" & ")")
    ' We need to get   D  from what we know,  Mx
    Dim vTemp As Variant
     vTemp = Cells(1, 4).Address
     vTemp = Split(vTemp, "$", 3, vbBinaryCompare)
     vTemp = vTemp(1)
    ' Or
     vTemp = Split(Cells(1, 4).Address, "$", 3, vbBinaryCompare)(1)
    ' Or
     vTemp = Split(Cells(1, 4).Address, "$")(1)
     vTemp = Split(Cells(1, Mx).Address, "$")(1)
    Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:" & vTemp & ")")
    Let Amounts() = Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")")
    ' We want this array as a string with   vbTabs seperating the array elements
    Dim strAmounts As String
     Let strAmounts = Join(Amounts(), vbTab)
     Let strAmounts = Join(Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab)
    ' similarly for the  notes
    Dim strNotes As String
     Let strNotes = Join(Evaluate("=""Note"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab)
    ' To get our final heading string,
    Dim strHd As String
     Let strHd = "Group" & vbTab & Join(Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & Join(Evaluate("=""Note"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & "Notes"
     objDataObject.SetText Text:=strHd
     Ws1.Paste Destination:=Ws1.Range("G1")
    In the next post , https://excelfox.com/forum/showthrea...ll=1#post16533 , is that integrated into the main coding in Rem 3
  8. #518
    Coding for these posts
    https://excelfox.com/forum/showthrea...ll=1#post16532
    Sub Stantially()
    Rem 0 data
             Let Cnt2 = Cnt2 + 1
         Let Cnt2 = 0
     Let Cnt = 1
        Do
             Let Cnt = Cnt + 1
    Rem 3 headers
    Dim strHd As String
     Let strHd = "Group" & vbTab & Join(Evaluate("=""Amount"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & Join(Evaluate("=""Note"" & COLUMN(A:" & Split(Cells(1, Mx).Address, "$")(1) & ")"), vbTab) & vbTab & "Name"
    Some extra notes for this main forum post:
    http://www.eileenslounge.com/viewtopic.php?f=27&t=38331
    This is a sample input,
    _____ Workbook: Split- Copy.xlsm ( Using Excel 2007 32 bit )
    1,2,3,4 t,y,u,m
    Worksheet: Sheet2Original
    This is what I want out
    t
    y
    u
    m
    Worksheet: Sheet2
    I want to do this sort of thing,
    __ arrOut()= App.Index(arrIn(), Rws(), Clms())
    The arrIn() in this case will be all the input data. Conveniently, we can join the two cell values with a comma then split all that by comma to get a single array, {1 2 3 4 t y u m }
    Then we need the Rws() like this
    1 1
    1 1
    1 1
    1 1
    and the Clms() like this
    1 5
    2 6
    3 7
    4 8
    '  https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=16639&viewfull=1#post16639
    Sub SplitData4()
    Dim Ws2 As Worksheet: Set Ws2 = ThisWorkbook.Worksheets.Item("Sheet2")
    Dim strDta As String: Let strDta = Ws2.Range("A2").Value & "," & Ws2.Range("B2").Value
    Dim arrIn() As String
     Let arrIn() = Split(strDta, ",", -1, vbBinaryCompare)
    ' Or
     arrIn() = Split(Range("A2").Value & "," & Range("B2").Value, ",")
    Dim Rws() As Variant
     Let Rws() = Evaluate("=Row(1:4)/Row(1:4)*Column(A:B)/Column(A:B)")
     Let Rws() = Evaluate("=Row(1:" & (UBound(arrIn()) + 1) / 2 & ")/Row(1:" & (UBound(arrIn()) + 1) / 2 & ")*Column(A:B)/Column(A:B)")
    Dim Clms() As Variant
     Let Clms() = Evaluate("=Row(1:4)+((Column(A:B)-1)*" & (UBound(arrIn()) + 1) / 2 & ")")
     Let Clms() = Evaluate("=Row(1:" & (UBound(arrIn()) + 1) / 2 & ")+((Column(A:B)-1)*" & (UBound(arrIn()) + 1) / 2 & ")")
    Dim arrOut() As Variant
     Let arrOut() = Application.Index(arrIn(), Rws(), Clms())
     Let Ws2.Range("A2").Resize((UBound(arrIn()) + 1) / 2, 2).Value = arrOut()
    ' Or
    ' Range("A2").Resize((UBound(arrIn()) + 1) / 2, 2).Value = arrOut()
    ' Range("A2").Resize((UBound(arrIn()) + 1) / 2, 2).Value = Application.Index(arrIn(), Rws(), Clms())
    ' Range("A2").Resize((UBound(arrIn()) + 1) / 2, 2).Value = Application.Index(arrIn(), Evaluate("=Row(1:" & (UBound(arrIn()) + 1) / 2 & ")/Row(1:" & (UBound(arrIn()) + 1) / 2 & ")*Column(A:B)/Column(A:B)"), Evaluate("=Row(1:" & (UBound(arrIn()) + 1) / 2 & ")+((Column(A:B)-1)*" & (UBound(arrIn()) + 1) / 2 & ")"))
     Range("A2").Resize((UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2, 2).Value = Application.Index(Split(Range("A2").Value & "," & Range("B2").Value, ","), Evaluate("=Row(1:" & (UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2 & ")/Row(1:" & (UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2 & ")*Column(A:B)/Column(A:B)"), Evaluate("=Row(1:" & (UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2 & ")+((Column(A:B)-1)*" & (UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2 & ")"))
    Sub StantiallyBeautiful() '  http://www.eileenslounge.com/viewtopic.php?f=27&t=38331
    In actual fact, we can simplify things a bit , since Intersexual interception theory tells us that if Excel is looking for the indicies of this form
    A b
    C d
    E f
    G h
    , but we only give it
    , then it will see this instead
    1 1
    1 1
    1 1
    1 1
    So that means we can replace Rws() with just 1
    So that all simplifies it a bit…
    Sub SplitData4b()
    ' Or
    'Dim Rws() As Variant
    ' Let Rws() = Evaluate("=Row(1:4)/Row(1:4)*Column(A:B)/Column(A:B)")
    ' Let Rws() = Evaluate("=Row(1:" & (UBound(arrIn()) + 1) / 2 & ")/Row(1:" & (UBound(arrIn()) + 1) / 2 & ")*Column(A:B)/Column(A:B)")
    ' Let arrOut() = Application.Index(arrIn(), Rws(), Clms())
     Let arrOut() = Application.Index(arrIn(), 1, Clms())
    ' Or
    ' Range("A2").Resize((UBound(arrIn()) + 1) / 2, 2).Value = Application.Index(arrIn(), 1, Clms())
    ' Range("A2").Resize((UBound(arrIn()) + 1) / 2, 2).Value = Application.Index(arrIn(), 1, Evaluate("=Row(1:" & (UBound(arrIn()) + 1) / 2 & ")+((Column(A:B)-1)*" & (UBound(arrIn()) + 1) / 2 & ")"))
     Range("A2").Resize((UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2, 2).Value = Application.Index(Split(Range("A2").Value & "," & Range("B2").Value, ","), 1, Evaluate("=Row(1:" & (UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2 & ")+((Column(A:B)-1)*" & (UBound(Split(Range("A2").Value & "," & Range("B2").Value, ",")) + 1) / 2 & ")"))
    Sub StantiallyBeautifulb() '  http://www.eileenslounge.com/viewtopic.php?f=27&t=38331
    some more notes on it....
    later.....
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
