Page 45 of 57 FirstFirst ... 35434445464755 ... LastLast
Results 441 to 450 of 570
  1. #441
    Post for later use
    Some notes from this question:
    http://www.eileenslounge.com/viewtop...281312#p281312
    Question …
    http://www.eileenslounge.com/viewtopic.php?f=30&t=36224
    _____ Workbook: Extract missing dates for each person.xlsm ( Using Excel 2007 32 bit )
    Row\Col A B C D E F G H I T U V
    1 Name Dates Helper Check Dates Result aa Yasser Given
    2 aa 2021-02-19 2021-02-19 2021-01-26 2021-01-26 2021-01-29 2021-01-29
    3 aa 2021-01-26 2021-01-26 2021-01-27 2021-01-27 2021-01-30 2021-01-30
    4 aa 2021-01-27 2021-01-27 2021-01-28 2021-01-28 2021-02-05 2021-02-05
    5 aa 2021-01-28 2021-01-28 2021-01-29 Missing 2021-02-12 2021-02-12
    6 aa 2021-01-31 2021-01-31 2021-01-30 Missing
    7 aa 2021-02-01 2021-02-01 2021-01-31 2021-01-31
    8 aa 2021-02-02 2021-02-02 2021-02-01 2021-02-01
    9 aa 2021-02-03 2021-02-03 2021-02-02 2021-02-02
    10 aa 2021-02-04 2021-02-04 2021-02-03 2021-02-03
    11 aa 2021-02-06 2021-02-06 2021-02-04 2021-02-04
    12 aa 2021-02-07 2021-02-07 2021-02-05 Missing
    13 aa 2021-02-08 2021-02-08 2021-02-06 2021-02-06
    14 aa 2021-02-09 2021-02-09 2021-02-07 2021-02-07
    15 aa 2021-02-10 2021-02-10 2021-02-08 2021-02-08
    16 aa 2021-02-11 2021-02-11 2021-02-09 2021-02-09
    17 aa 2021-02-13 2021-02-13 2021-02-10 2021-02-10
    18 aa 2021-02-14 2021-02-14 2021-02-11 2021-02-11
    19 aa 2021-02-15 2021-02-15 2021-02-12 Missing
    20 aa 2021-02-16 2021-02-16 2021-02-13 2021-02-13
    21 aa 2021-02-17 2021-02-17 2021-02-14 2021-02-14
    22 aa 2021-02-18 2021-02-18 2021-02-15 2021-02-15
    23 aa 2021-02-20 2021-02-20 2021-02-16 2021-02-16
    24 aa 2021-02-21 2021-02-21 2021-02-17 2021-02-17
    25 aa 2021-02-22 2021-02-22 2021-02-18 2021-02-18
    26 aa 2021-02-23 2021-02-23 2021-02-19 2021-02-19
    27 aa 2021-02-24 2021-02-24 2021-02-20 2021-02-20
    28 aa 2021-02-25 2021-02-25 2021-02-21 2021-02-21
    29 bb 2021-01-27 2021-01-27 2021-02-22 2021-02-22
    30 bb 2021-01-28 2021-01-28 2021-02-23 2021-02-23
    31 bb 2021-01-31 2021-01-31 2021-02-24 2021-02-24
    32 bb 2021-02-01 2021-02-01 2021-02-25 2021-02-25
    33 bb 2021-02-03 2021-02-03
    Worksheet: Sheet1
    Continued from last post: Some notes from this question:
    Yasser Question.JPG https://excelfox.com/forum/showthrea...ll=1#post15418
    Hans Solution. What’s he doing:
    Rem 1 Make dictionary of Dictionaries2
    There are two dictionary variables.
    The first one contains all the unique name values from column A . So this is the unique names dictionary
    We loop down to build that dictionary, and the solution is relying on a un unbroken sequential list of names, in other words no mixed up , but an order list like
    Name1
    Name1
    Name1
    Name2
    Name2
    ..etc.
    In that main loop , all the values, from column B are put in the Item ( which is itself a dictionary ) of each unique name in the unique names dictionary.
    This is the clever line that does that. The line is done for each row in the data to be looked in ( column B )
    Let dct1(rng1(r1, 1))(Int(rng1(r1, 2))) = 1
    The 1 is arbitrary. What we are doing is like referring to ( trying to put 1 into ) the key of an item in the second dictionary that does not exist. When this is done, rather than error, the Scripting.Dictionary is programmed to make an item with that key.
    The end result of all this is that we end up with a main dictionary that has a key for each unique name. The item for each name / Key has a second dictionary in it of all the Integer parts of the Date & time in column B. ( The dictionary will be seeing the basic Excel .Vaue2 of the date & time, so the Integer part will be just the date.
    Here is a pseudo couple of code lines to demo that last bit
    Dick1(Name1) ( 2021-02-19 ) = 1
    Dick1(Name1) ( 2021-01-26 ) = 1
    You see what’s going on is the following:
    Dick1(Name1) will always return the same thing which is the Item in Dick1 with the Key of Name1
    So Effectively those lines are pseudo
    Dick2 ( 2021-02-19 ) = 1
    Dick2 ( 2021-01-26 ) = 1
    What those code lines try to do is put a 1 in the items of a Dick2 element that does not exist. As noted, the Scripting.Dictionary is programmed to make an item with that key rather than error if such an action is attempted.
    So that is just a convenient way to make the second dictionaries – Note I said dictionaries
    We end up with this:
    Dick1 keys
    These lines give me that from doing a Shift F9 on any variable
    Shift F9 on vTemps for Watch Window.JPG http://i.imgur.com/Ms7HmG6.jpg
    We have an Outer loop and an inner loop in it.
    __The outer loop is done once for each unique name, so for each key of the main dictionary
    ____The inner loop goes down the entire F column Check dates and does a write out any missing dates, that is to say dates not in the dictionary that is the item for that unique name, key of the main dictionary
    Hans macro
    Sub ListMissing()  '  ' Hans    http://www.eileenslounge.com/viewtopic.php?p=281312#p281312
    Dim vTemp1, vTemp2 ' For development and debug
    Dim wsh1 As Worksheet
    Dim wsh2 As Worksheet
    Dim rng1 As Variant
    Dim rng2 As Variant
    Dim m1 As Long
    Dim m2 As Long
    Dim r1 As Long
    Dim r2 As Long
    Dim r3 As Long
    Dim dct1 As Object
    Dim dcTemp2 As Object
    Dim n As Variant
     Set dct1 = CreateObject("Scripting.Dictionary")
     Set wsh1 = Worksheets("Sheet1")
     Let m1 = wsh1.Range("A" & wsh1.Rows.Count).End(xlUp).Row
     Let rng1 = wsh1.Range("A2:B" & m1).Value
        For r1 = 1 To UBound(rng1)
            If Not dct1.Exists(rng1(r1, 1)) Then ' this gives us  3 elements in  the  dct1  that have like key  aa  and  the item is an empty dictionary object
             Set dcTemp2 = CreateObject("Scripting.Dictionary") ' This effectively clears the variable used temporarily
             dct1.Add Key:=rng1(r1, 1), Item:=dcTemp2
         Let dct1(rng1(r1, 1))(Int(rng1(r1, 2))) = 1 ' the  1  is arbritrary, we effectively create a Key looking like  aa 2021-02-19 in the  second dictionary that is the item of the unique
        Next r1
     vTemp1 = dct1.keys()  '  Dick1.JPG                                http://i.imgur.com/zTWYpuy.jpg
     vTemp2 = dct1.items() '  Dick2KeysWichAreDicksInDick1Items.jpg    http://i.imgur.com/Jsd2kXS.jpg
     Let m2 = wsh1.Range("F" & wsh1.Rows.Count).End(xlUp).Row
     Let rng2 = wsh1.Range("F2:F" & m2).Value
     Set wsh2 = Worksheets("Sheet2Hans")
     wsh2.Range("A2:B" & wsh2.Rows.Count).Clear
     Rem 2  Go through checking for existance of an Item. For no existance , then that is missing data
      Let r3 = 1
        ' The outer loop is done once for each unique name, so for each key of the main dictionary ===========
        For Each n In dct1.keys '  this and next line make it  For Each  of .._
         Set dcTemp2 = dct1(n)  ' _.. the dictionries within each item of  Dick1  In other words  For Each  Name
            ' The inner loop goes down the entire  F column Check dates and does a write out any  missing dates, that is to say dates not in the dictionary that is the item for that  unique name,  key of the main dictionary
            For r2 = 1 To UBound(rng2) ' Going down the entire   F  range
                If Not dcTemp2.Exists(rng2(r2, 1)) Then
                 Let r3 = r3 + 1
                 Let wsh2.Range("A" & r3).Value = n           '  n is the key, the unique name, in the main large dictionary
                 Let wsh2.Range("B" & r3).Value = rng2(r2, 1) ' This will be the missing entry
            Next r2 ' ________________________________________
        Next n ' ==============================================================================================
    Some notes for this question:
    http://www.eileenslounge.com/viewtop...281291#p281291
    For example, this bit …. using formulas like that
    =IFERROR(INDEX($A$2:$C$1000,MATCH(1,($A$2:$A$1000= $I$1)*($C$2:$C$1000=F2),0),3),"Missing")
    Then I manually filter by Missing and copied the results
    That can be done in a single code line, …. _
    Sub BasicOneLine() '  '....  http://www.eileenslounge.com/viewtopic.php?p=281291#p281291
     Let Range("T2").Resize(UBound(Application.Index(Worksheets("Sheet1").Columns(6), Application.Index(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1), Evaluate("=row(1:" & UBound(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1)) + 1 & ")/row(1:" & UBound(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), _
     Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1)) + 1 & ")"), Evaluate("=row(1:" & UBound(Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", ""), "#", -1)) + 1 & ")")), 1), 1), 1).Value = _
    Before
    Row\Col I T U V
    1 aa Yasser Given
    2 2021-01-29
    3 2021-01-30
    4 2021-02-05
    5 2021-02-12
    Worksheet: Sheet1
    After
    Row\Col I T U V
    1 aa Yasser Given
    2 2021-01-29 2021-01-29
    3 2021-01-30 2021-01-30
    4 2021-02-05 2021-02-05
    5 2021-02-12 2021-02-12
    Worksheet: Sheet1
    Run Sub BasicOneLine() on the uploaded file to demo those results
    extended coding notes for last post
    https://excelfox.com/forum/showthrea...ll=1#post15420
    Sub Pretty2()  '
    Dim arrTemp() As Variant
    Rem  To get the results in  column  T  ( same as
     ' Ths first forumula give me all the matches for F in the C ( helper column )  or error for no match
     Let arrTemp() = Evaluate("=If({1},MATCH(F2:F463,C2:C463,0))")   '   If({1},____)    may not be needed for Excel 2016 and higher   The first formula does the main work
     ' The multiplication by $A$2:$A$1000=$I$1 limits the range used by effectively making 0 check dates outside or range of interest
     Let arrTemp() = Evaluate("=IF({1},MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0))")   '  $A$2:$A$1000=$I$1 gives us an array full of  Falses and Trues , which Excel will interpret mathematically as 0 or 1   This has the effect of giving us a 0 multiplyer on numbers outside our range of interst, so in total a 0 for outside our range of interest.   Our range of interest gets a 1 multiplier so has therefore no change and we can find those numbers whereas we wont find a 0, well actually we will find a zero if the range to search for has a zero as it does further down, so we take care of that in the next line
     ' The above formula has one problem with the supplied data in that empty cells are seen in this formula as 0 which gives a match
     Let arrTemp() = Evaluate("=IF(F2:F463=0,0,MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0))")   '   In looking in the range to find a match in ( the range to be searched we have all 0s outside the range caused by the previous $A$2:$A$1000=$I$1  So the first of these 0s will be seen as the match cell for all cells in  F  that are empty.  So i take care here of the situation where an empty cell in  F  is by  giving a  0  output   So far two things retrn me a zero.   You often find in formula building that the coercing  If({1},___) suddenly is not needed. Her we find that the newly used here  IF(F2:F463=0,0,___)  is doing the required co oecing
     ' we will now do a simple  If(ISERROR( ) , Row( ) , 0 ) on the above . This will give us a row indicie for the missing data,  and  a  0  for the found data
     Let arrTemp() = Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)")
     ' At this point we have wanted data or zeros. I want to conveniently use some VB string fuction whuch annoyingly onl work on 1 D arrays, so we convert it by a transpose in the next code line
     Let arrTemp() = Application.Index(arrTemp(), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)"))
     ' The next few lines get rid of the  0s
    Dim StrTemp As String: Let StrTemp = Join(arrTemp(), "#") ' Convert the array to a string with a  #  in between each data
     Let StrTemp = Replace(StrTemp, "#0", "", 1, -1, vbBinaryCompare): StrTemp = Replace(StrTemp, "0#", "", 1, -1, vbBinaryCompare) ' This effectiveely removes the  0s   data ( and its seperator )
    Dim arrStrTemp() As String: Let arrStrTemp() = Split(StrTemp, "#", -1, vbBinaryCompare) ' remake the array
     ' We need a "vertical" array for output, so we  transpose
     Let arrTemp() = Application.Index(arrStrTemp(), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")/row(1:" & UBound(arrStrTemp()) + 1 & ")"), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")"))
     Let arrTemp() = Application.Index(Worksheets("Sheet1").Columns(6), arrTemp(), 1) ' finally we want the  dates  ( so far we have the row indicies obtained from  Match   Note. this formula has the problem that we get the results  a row out of step... Its actually very convenient because if i use  Cells typically, here a column  then I have a nice solution
     Let Range("T2").Resize(UBound(arrTemp(), 1), 1).Value = arrTemp()
     Let Range("T2").Resize(UBound(arrTemp(), 1), 1).NumberFormat = "yyyy/mm/dd" '  from macro recorder .NumberFormat = "[$-1010000]yyyy/mm/dd,@"
    Stop
     Range("T2").Resize(UBound(arrTemp(), 1), 1).ClearContents
     ' Or
    Stop
     '  Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), "0#", "")
    Rem  To get to  Column N  in   Extract missing dates for each person.xlsm
     ' The next step is to replace the errors with  0s
     Let arrTemp() = Evaluate("=IFERROR(IF(F2:F463=0,0,MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)),0)")   '   In looking in the range to find a match in ( the range to be searched we have all 0s outside the range caused by the previous $A$2:$A$1000=$I$1  So the first of these 0s will be seen as the match cell for all cells in  F  that are empty.  So i take care here of the situation where an empty cell in  F  is by  giving a  0  output   So far two things retrn me a zero.   You often find in formula building that the coercing  If({1},___) suddenly is not needed. Her we find that the newly used here  IF(F2:F463=0,0,___)  is doing the required co oecing
    'Dim StrTemp As String
     Let StrTemp = Replace(StrTemp, "#0", "", 1, -1, vbBinaryCompare) ' This effectiveely removes the  0s   data ( and its seperator )
    'Dim arrStrTemp() As String
     Let arrTemp() = Application.Index(Range("C2:C463"), arrTemp(), 1) ' finally we want the  dates  ( so far we have the row indicies obtained from  Match
     Let Range("N2").Resize(UBound(arrTemp(), 1), 1).Value = arrTemp()
     Let Range("N2").Resize(UBound(arrTemp(), 1), 1).NumberFormat = "yyyy/mm/dd" '  from macro recorder .NumberFormat = "[$-1010000]yyyy/mm/dd,@"
     ' Or
    '  Let arrTemp() = Evaluate("=If({1},IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0))")
     'let worksheets("Sheet2").range
    'v = Join(v, "#")                                             '  https://www.vbarchiv.net/commands/cmd_filter.html
    'v = Application.Index(Range("C2:C463"), Evaluate("=If({1},MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1))"), 1)
    'v = Application.Index(v, Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)"))
    'v = Evaluate("=IFERROR(INDEX($A$2:$C$1000,MATCH(1,($A$2:$A$1000=$I$1)*($C$2:$C$1000=" & r.Address & "),0),3),""Missing"")")
    This is a slightly more sane version of the single line macro idea from here
    https://excelfox.com/forum/showthrea...ll=1#post15421
    Sub SlightlySanerVersion()
    Dim arrStrTemp() As String: Let arrStrTemp() = Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "0#", ""), "#0", ""), "#")
    Dim arrTemp() As Variant:  Let arrTemp() = Application.Index(Worksheets("Sheet1").Columns(6), Application.Index(arrStrTemp(), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")/row(1:" & UBound(arrStrTemp()) + 1 & ")"), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")")), 1)
    Stop
    ' Or
    Dim UnicNm As String: Let UnicNm = "aa"
     Let arrStrTemp() = Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=" & """" & UnicNm & """" & "),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "0#", ""), "#0", ""), "#")
    We can use the basic idea above to make a function idea to do the same
    Sub UseNotSoInsaneFunction()
     Let arrTemp() = NotSoInsane("aa")
    Function NotSoInsane(ByVal Nme As String) As Variant
    Dim arrStrTemp() As String: Let arrStrTemp() = Split(Replace(Replace(Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=" & """" & Nme & """" & "),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "0#", ""), "#0", ""), "#")
     Let NotSoInsane = arrTemp()
    In support of these Threads and posts
    A problem arose with testing with bb
    _____ Workbook: Extract missing dates for each person bb.xlsm ( Using Excel 2007 32 bit )
    Row\Col T U V W X Y Z
    1 Yasser Given Hans Results Indicies
    2 2021-01-26 2021-01-29 2021-01-29 2
    3 2021-01-30 2021-01-30 0
    4 2021-02-05 2021-02-05 0
    5 2021-01-29 2021-02-12 2021-02-12 5
    6 2021-01-30 2021-01-26 2021-01-26 6
    7 2021-01-29 2021-01-29 0
    8 2021-01-30 2021-01-30 0
    9 2021-02-02 2021-02-02 2021-02-02 9
    10 2021-02-05 0
    11 2021-02-12 0
    12 2021-02-05 2021-02-05 12
    13 2021-02-16 0
    14 2021-02-19 0
    15 2021-02-25 0
    16 0
    17 0
    18 0
    19 2021-02-12 2021-02-12 19
    20 2021-02-13 20
    21 0
    22 2021-02-15 22
    23 2021-02-16 2021-02-16 23
    24 0
    25 0
    26 2021-02-19 2021-02-19 26
    27 0
    28 0
    29 0
    30 0
    31 0
    32 2021-02-25 2021-02-25 32
    33 2021-01-29 0
    Worksheet: Sheet1
    If you examine above my ( wrong) results in column T against Hans results in column V and
    then look at the Debug / Immediate window info below for
    before ( http://i.imgur.com/M3laahV.jpg )
    after ( http://i.imgur.com/RUPIWIg.jpg ), where I take out the unwanted data from a text string , .._
     ? strtemp
    2#0#0#5#6#0#0#9#0#0#12#0#0#0#0#0#0#19#20#0#22#23#0#0#26#0#0#0#0#0#32#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0#0
    ? strtemp
    2#5#6#9#12#19#222#23#26#32
    _...then I can see the problem and where its coming from:
    The problem is that I chose to remove the unwanted data
    _ first by removing all #0 - that works fine, no problem with that as I am not expecting any real data starting with a 0
    _ second I allow for the case of unwanted data at the start by removing all 0# - this can cause problems as it has in this example – It has resulted for example in this
    #20#0#22
    becoming this
    #20#22
    And then when after , (or previously) the 0# is removed/ was removed, the final result is
    #222
    So I loose the valid data of 20 and 22 and get a wrong data of 222 ( and in the test data, indicial 222 matches to an empty cell )
    The final outcome is I loose two final date values and gain an extra unwanted empty ( nonsense date zero value ) date
    There are thousands of easy ways to solve this problem , with various If Then ways. But these will “interrupt the flow” as it were, leading to inefficiency and prevent me building my final one line code way.
    This first element problem is one I often refer to as an awkward bollock
    Variations of this come up a lot. Often an efficient cure to this awkward bollock is to include an extra separator at the start. This wont quite for us in the case of this data, but almost.
    The following variation seems OK
    Consider these two lines, where the awkward bollock is dealt with second
     Let StrTemp = Replace(StrTemp, "#0", "", 2, -1, vbBinaryCompare): StrTemp = Replace(StrTemp, "0#", "", 1, -1, vbBinaryCompare) ' This effectively removes the  0s   data ( and its seperator )
    Solution:
    I add some arbitrary character at the start
    StrTemp = "_" & Join(arrTemp(), "#")
    That wont add much extra overhead
    Now deal with the awkward bollock first
    StrTemp = Replace(StrTemp, "_0#", "_" ………..
    That has done no extra work, just done an existing step a bit differently
    So far nothing so clever. The next part allows us to do no, or little, extra work by taking advantage of a little known extra argument of the Replace
    The forth (optional) argument of Replace lets us say at which character point in the original we start our returned string. That may confuse, so let me say that again with an example..
    I have this xy-z-2 and I want this yz2
    Most people would think they need
    either
    _ two Replaces , one to take out – and the other to take out x
    _ a Replace to take out – and then some other process or function to take out the first character.
    But if we choose 2 in our forth argument of the Replace that takes out the - , then our returned string will effectively have the first character removed.
    Dim StrTemp As String: Let StrTemp = "_" & Join(arrTemp(), "#") ' Convert the array to a string with a  #  in between each data
     Let StrTemp = Replace(StrTemp, "_0#", "_", 1, 1, vbBinaryCompare): StrTemp = Replace(StrTemp, "#0", "", 2, -1, vbBinaryCompare) ' This effectiveely removes the  0s   data ( and its seperator )
    That seems to solve the problem
    Full macro in next post
    Full macro for last post
    Sub Pretty3bbProbSolved()  '  https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=15426&viewfull=1#post15426
     ' Or
     Let arrTemp() = Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)"))
    ' Or
    Let arrStrTemp() = Split(Replace(Replace("_" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "_0#", "_"), "#0", "", 2), "#")
    ' Or
     Let arrTemp() = Application.Index(Worksheets("Sheet1").Columns(6), Application.Index(arrStrTemp(), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")/row(1:" & UBound(arrStrTemp()) + 1 & ")"), Evaluate("=row(1:" & UBound(arrStrTemp()) + 1 & ")")), 1) ' finally we want the  dates  ( so far we have the row indicies obtained from  Match   Note. this formula has the problem that we get the results  a row out of step... Its actually very convenient because if i use  Cells typically, here a column  then I have a nice solution
    Stop
    ' Or
     ' Or
     Let Range("T2").Resize(UBound(Application.Index(Worksheets("Sheet1").Columns(6), Application.Index(Split(Replace(Replace("_" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "_0#", "_"), "#0", "", 2), "#", -1), Evaluate("=row(1:" & UBound(Split(Replace(Replace("_" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "_0#", "_"), "#0", "", 2), "#", -1)) + 1 & ")/row(1:" & UBound(Split(Replace(Replace("_" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), _
     Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "_0#", "_"), "#0", "", 2), "#", -1)) + 1 & ")"), Evaluate("=row(1:" & UBound(Split(Replace(Replace("_" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "_0#", "_"), "#0", "", 2), "#", -1)) + 1 & ")")), 1), 1), 1).Value = _
    I am not quite sure what got in my brain in the last post. With hind site most of what I said and done is crap. But maybe later I will twig to what was going on.
    I will start again…. Or rather pick it up where I went off course…._ I have …_
    _.... an awkward bollock
    The general solution is fine. After adding a separator, #, at the start, I remove all #0
    All is well and then I only need to get rid finally of a single # I don’t need at the start.
    For that last thing, Mid(StrTemp,2) would do. So would a second Replace in this form Replace(StrTemp, "#", "", 1, 1…. Or Replace(StrTemp, "#", "", , 1….
    In the Replace.. we are using the 5th (optional ) argument to restrict us to removing a single # and the convention is to start from the left so that will hit on the first.
    In this complete version I use the Mid(StrTemp,2) way
    Sub Pretty3bbaa()  '
    Rem  To get the results in  column  T  ( same as Yassers or Hans Results
     ' Ths first forumula gives me all the matches for F in the C ( helper column )  or error for no match
     ' Or
     ' The next few lines get rid of the  0s   ( 2 lines commented out to prevent the shortened line messing up )
    Dim StrTemp As String: Let StrTemp = "#" & Join(arrTemp(), "#") ' Convert the array to a string with a  #  in between each data.  The extra # allows us to remove all  0  entries via removing all  #0  Without this we might get one left at the start
    ' Let StrTemp = Replace(StrTemp, "#0", "", 1, -1, vbBinaryCompare) ' This effectiveely removes the  0s   data ( and its seperator )
    ' Let StrTemp = Mid(StrTemp, 2) '  Because I omit the third optional ( length ) argument I get all the remaing string after the first one. This effectively takes off the extra  #  which I don't need
    ' Or ,
    Let arrStrTemp() = Split(Mid(Replace("#" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), 2), "#")
    ' Or
    Stop
    Dim arrStrTemp() As String: Let arrStrTemp() = Split(Mid(Replace("#" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=$I$1),0)*($A$2:$A$1000=$I$1)),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), 2), "#")
    Stop
    ' Or
    Dim UnicNm As String: Let UnicNm = "aa" ' "aa"
     Let arrStrTemp() = Split(Mid(Replace("#" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=" & """" & UnicNm & """" & "),0)*($A$2:$A$1000=" & """" & UnicNm & """" & ")),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), 2), "#")
    I can sanitise the last version a bit and come up with a simple function to get you an array of your missings, where the function takes the unique name, ( the unique name in the test data is the things like aa bb cc etc. )
    Stop
    ' Or
     Let arrTemp() = NotSoInsane("bb")
     ' Columns("T:T").ClearContents  ' Range("T2").Resize(UBound(arrTemp(), 1), 1).ClearContents
    Dim arrStrTemp() As String: Let arrStrTemp() = Split(Mid(Replace("#" & Join(Application.Index(Evaluate("=IF(ISERROR(MATCH(F2:F463,C2:C463*($A$2:$A$1000=" & """" & Nme & """" & "),0)*($A$2:$A$1000=" & """" & Nme & """" & ")),ROW(F2:F463),0)"), Evaluate("=column(A:QT)"), Evaluate("=column(A:QT)/column(A:QT)")), "#"), "#0", ""), 2), "#")
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
