Some notes related to these posts
https://excelfox.com/forum/showthrea...ll=1#post13318
http://www.eileenslounge.com/viewtopic.php?f=30&t=34610
http://www.eileenslounge.com/viewtop...267706#p267706
Later
Later
In support of this post:
https://excelfox.com/forum/showthrea...pplied-over-it
_____ Workbook: address sheet.xlsm ( Using Excel 2007 32 bit )
Worksheet: Sheet1
Row\Col A B C D E F G 1Address Door# Direction street name roadtype street name + roadtype City Name 2 204 6 AVE NW 204 6AVE NW 3 2510 5 AVE N 2510 5AVE N 4 1 CICADA RD 1CICADA RD 5 100 annacis Pkwy 100annacis Pkwy 6 100 MAIN ST 100MAIN ST 7 10008 107 ST 10008 107ST 8 1001 110 AVE 1001 110AVE 9 10010 102A AVE NW 10010102A AVE NW 10 10115 110 AVE 10115 110AVE 11 102 11 AVE S 102S 11AVE 12 10205 134 AVE NW 10205134 AVE NW 13 10235 101 ST NW 10235101 ST NW 14 10365 97 ST NW 1036597 ST NW 15 105 MARTIN ST 105MARTIN ST 16 10504 100 AVE 10504 100AVE 17 10600 100 ST 10600 100ST
Some notes in support in answering this question: https://excelfox.com/forum/showthrea...ata-if-matches
If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx and if it matches then copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to sheet 1 of 2.xlsx in the row of the matched value in column A of sheet 1 of 2.xlsx
i have pasted the result in sheet3 of 2.xlsx but the result should be in sheet1(I have pasted the result in sheet3 only for understanding purpose)
Before:
_____ Workbook: Actual File.xlsx ( Using Excel 2007 32 bit )
Worksheet: Sheet1
Row\Col A B C D E F G H I J K 1Exchange Symbol Series/Expiry Open High Low Prev Close LTP 2NSE ASHOKLEY EQ 65 65.35 60.55 63.3 63.3 1 3NSE BANKBARODA EQ 62.1 62.95 56.15 56.65 56.65 1 4NSE BEL EQ 66.15 66.75 62.4 65.65 65.65 1 5NSE EQUITAS EQ 82 82.05 71 73.05 73.05 1 6NSE FEDERALBNK EQ 68 68.45 62.45 63.1 63.1 1 7NSE GAIL EQ 85 88.8 79.1 79.95 79.95 1 8NSE IDFCFIRSTB EQ 32.1 32.35 27.2 27.55 27.55
_.................If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx
_____ Workbook: 2 18May.xlsx ( Using Excel 2007 32 bit )
Worksheet: Sheet1
Row\Col A 1Stock Name 2ACC 3ADANIENT 4ADANIPORTS 5ASHOKLEY 6EQUITAS 7L&TFH 8
Worksheet: Sheet2
Row\Col A B C D E F G H I J K L 1 1 2 3 4 5 6 7 8 9 10
_.......copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to sheet 1 of 2.xlsx
After:
Worksheet: Sheet3
Row\Col A B C D E F G H I J K L M 1Stock Name data data data data data data data data data data data data 2ACC 100 108 120 128 134 151 6534 30 90 97 103 3ADANIENT 101 109 121 127 135 122 782 40 92 98 4ADANIPORTS 102 110 122 16 137 177 10 50 93 99 104 5ASHOKLEY 1 2 3 4 5 6 7 8 9 10 6EQUITAS 1 2 3 4 5 6 7 8 9 10 7AMBUJACEM 105 117 125 133 140 746 23 80 96 102 109 8
macro for solution to this Thread:
( Remember to include Public Function CL() )
Code:Sub CopyPaste20() ' https://excelfox.com/forum/showthread.php/2494-Copy-and-paste-of-data-if-matches Rem 1 Worksheets info ' 2.xlsx Dim Wb2 As Workbook Set Wb2 = Workbooks("2.xlsx") Dim Ws1 As Worksheet: Set Ws1 = Wb2.Worksheets.Item(1) Dim Lr1 As Long Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row Dim arrA() As Variant: Let arrA() = Ws1.Range("A1:A" & Lr1 & "").Value2 ' 2.xlsx sheet1 column A Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2) Dim Rng22 As Range: Set Rng22 = Ws2.Range("A1").CurrentRegion ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx ' Actual File.xlsx Dim Wb As Workbook, Ws As Worksheet Set Wb = Workbooks("Actual File.xlsx") Set Ws = Wb.Worksheets.Item(1) Dim Jmax As Long: Let Jmax = Ws.Range("J" & Ws.Rows.Count & "").End(xlUp).Row Dim arrB() As Variant: Let arrB() = Ws.Range("B1:B" & Jmax & "").Value2 ' Actual File.xlsx sheet1 column B Rem 2 do it Dim Cnt ' this is for - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B For Cnt = 2 To Jmax Dim MtchRes As Variant Let MtchRes = Application.Match(arrA(Cnt, 1), arrB(), 0) ' - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B If IsError(MtchRes) Then ' no match do nothing Else ' Cnt is now at the row number of where 2.xlsx sheet1 column A was found in Actual File.xlsx sheet1 column B Dim Lc1Cnt As Long: Let Lc1Cnt = Ws1.Cells.Item(Cnt, Ws1.Columns.Count).End(xlToLeft).Column Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").ClearContents ' clear row Cnt of all data before pasting Rng22.Copy Destination:=Ws1.Range("B" & Cnt & "") ' copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to the row in sheet 1 of 2.xlsx at the row number of the matched value of 2.xlsx sheet1 End If Next Cnt End Sub ' http://www.excelfox.com/forum/showthread.php/1546-TESTING-Column-Letter-test-Sort Public Function CL(ByVal lclm As Long) As String ' http://www.excelforum.com/development-testing-forum/1101544-thread-post-appendix-no-reply-needed-please-do-not-delete-thanks-4.html#post4213980 Do: Let CL = Chr(65 + (((lclm - 1) Mod 26))) & CL: Let lclm = (lclm - (1)) \ 26: Loop While lclm > 0 End Function
Notes for question 2 here
https://excelfox.com/forum/showthrea...ll=1#post13379
https://excelfox.com/forum/showthrea...ll=1#post13387
Before is as here ,
https://excelfox.com/forum/showthrea...ll=1#post13382
, but ignore Sheet2 - no row is to be copied
Worksheet: Sheet1 (2)
Row\Col A B C D E F G H I J K 1Exchange Symbol Series/Expiry Open High Low Prev Close LTP 2NSE ASHOKLEY EQ 65 65.35 60.55 63.3 63.3 1 3NSE BANKBARODA EQ 62.1 62.95 56.15 56.65 56.65 1 4NSE BEL EQ 66.15 66.75 62.4 65.65 65.65 1 5NSE EQUITAS EQ 82 82.05 71 73.05 73.05 1 6NSE FEDERALBNK EQ 68 68.45 62.45 63.1 63.1 1 7NSE GAIL EQ 85 88.8 79.1 79.95 79.95 1 8NSE IDFCFIRSTB EQ 32.1 32.35 27.2 27.55 27.55 9NSE IOC EQ 93 93.65 87.25 87.9 87.9 10NSE L&TFH EQ 90 91.55 80.5 81.65 81.65 11
_____ Workbook: 2 (2).xlsx ( Using Excel 2007 32 bit )
Worksheet: Sheet1
Row\Col A B C D E F G H I J K L M N O 1Stock Name data data data data data data data data data data data data data data 2ACC 100 108 120 128 134 151 6534 30 90 97 103 3ADANIENT 101 109 121 127 135 122 782 40 92 98 4ADANIPORTS 102 110 122 16 137 177 10 50 93 99 104 5ASHOKLEY 1 2 3 4 5 16 137 177 10 50 93 99 104 6EQUITAS 10 50 93 99 5 102 110 122 9 10 11 7L&TFH 11 12 13 14 15 16 17 18 19 20 21 22 23 8
If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx and if it matches then double the value of that row of 2.xlsx
After
Worksheet: Sheet2
Row\Col A B C D E F G H I J K L M N O 1Stock Name data data data data data data data data data data data data data data 2ACC 100 108 120 128 134 151 6534 30 90 97 103 3ADANIENT 101 109 121 127 135 122 782 40 92 98 4ADANIPORTS 102 110 122 16 137 177 10 50 93 99 104 5ASHOKLEY 2 4 6 8 10 32 274 354 20 100 186 198 208 6EQUITAS 20 100 186 198 10 204 220 244 18 20 22 7L&TFH 22 24 26 28 30 32 34 36 38 40 42 44 46 8
Note: I think your supplied After is wrong! - L&TFH should not be considered from Actual File.xlsx, because J of that row is not 1
Macro for last post
Code:Sub CopyPaste20Q2() ' Question 2 https://excelfox.com/forum/showthread.php/2494-Copy-and-paste-of-data-if-matches ' https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=13388&viewfull=1#post13388 Rem 1 Worksheets info ' 2.xlsx Dim Wb2 As Workbook Set Wb2 = Workbooks("2.xlsx") Dim Ws1 As Worksheet: Set Ws1 = Wb2.Worksheets.Item(1) Dim Lr1 As Long Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row Dim arrA() As Variant: Let arrA() = Ws1.Range("A1:A" & Lr1 & "").Value2 ' 2.xlsx sheet1 column A ' Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2) ' Dim Rng22 As Range: Set Rng22 = Ws2.Range("A1").CurrentRegion ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx ' Actual File.xlsx Dim Wb As Workbook, Ws As Worksheet Set Wb = Workbooks("Actual File.xlsx") Set Ws = Wb.Worksheets.Item(1) Dim Jmax As Long: Let Jmax = Ws.Range("J" & Ws.Rows.Count & "").End(xlUp).Row Dim arrB() As Variant: Let arrB() = Ws.Range("B1:B" & Jmax & "").Value2 ' Actual File.xlsx sheet1 column B Rem 2 do it Dim Cnt ' this is for - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B For Cnt = 2 To Jmax Dim MtchRes As Variant Let MtchRes = Application.Match(arrA(Cnt, 1), arrB(), 0) ' - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B If IsError(MtchRes) Then ' no match do nothing Else ' Cnt is now at the row number of where 2.xlsx sheet1 column A was found in Actual File.xlsx sheet1 column B Dim Lc1Cnt As Long: Let Lc1Cnt = Ws1.Cells.Item(Cnt, Ws1.Columns.Count).End(xlToLeft).Column ' Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").ClearContents ' clear row Cnt of all data before pasting ' Rng22.Copy Destination:=Ws1.Range("B" & Cnt & "") ' copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to the row in sheet 1 of 2.xlsx at the row number of the matched value of 2.xlsx sheet1 Let Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Value = Ws1.Evaluate("=2*" & Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Address & "") ' then double the value of that row of 2.xlsx End If Next Cnt End Sub
Macro for this post:
https://excelfox.com/forum/showthrea...ll=1#post13397
Code:Sub ConditionalCalcPaste() ' https://excelfox.com/forum/showthread.php/2495-Conditional-calculation-and-pasting-of-the-data Rem 1 Worksheets info '1a) 2.xlsx Dim Wb2 As Workbook Set Wb2 = Workbooks("2.xlsx") Dim Ws1 As Worksheet: Set Ws1 = Wb2.Worksheets.Item(1) Dim Lr1 As Long Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row Dim arrA() As Variant: Let arrA() = Ws1.Range("A1:A" & Lr1 & "").Value2 ' 2.xlsx sheet1 column A 'Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2) 'Dim Rng22 As Range: Set Rng22 = Ws2.Range("A1").CurrentRegion ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx '1b) Actual File.xlsx Dim Wb As Workbook, Ws As Worksheet Set Wb = Workbooks("Actual File.xlsx") Set Ws = Wb.Worksheets.Item(1) Dim Lr As Long: Let Lr = Ws.Range("A" & Ws.Rows.Count & "").End(xlUp).Row ' Dim Jmax As Long: Let Jmax = Ws.Range("J" & Ws.Rows.Count & "").End(xlUp).Row Dim rngIn As Range: Set rngIn = Ws.Range("A1:S" & Lr & "") Dim arrIn() As Variant, arrOut() As Variant: Let arrIn() = rngIn.Value2 Dim arrB() As Variant: Let arrB() = Ws.Range("B1:B" & Lr & "").Value2 ' Ws.Range("B1:B" & Jmax & "").Value2 ' Actual File.xlsx sheet1 column B '1c ' calculate the total value of column Q of ActualFile.xlsx and if it is Greater than S10 of ActualFile.xlsx then Dim SomeQ As Double: Let SomeQ = Ws.Evaluate("=SUM(Q2:Q" & Lr & ")") ' total value of column Q of ActualFile.xlsx Let SomeQ = Application.WorksheetFunction.Round(SomeQ, 2) Dim S10Val As Double: Let S10Val = arrIn(10, 19) ' S10 of ActualFile.xlsx If SomeQ > S10Val Then ' total value of column Q of ActualFile.xlsx and if it is Greater than S10 of ActualFile.xlsx then do nothing ' do nothing ElseIf SomeQ < S10Val Then ' if it is lower than S10 of ActualFile.xlsx then divide S10 of ActualFile.xlsx with the total value of Column Q of ActualFile.xlsx Dim S10dQ As Double: Let S10dQ = S10Val / SomeQ ' Divide S10 of ActualFile.xlsx with the total value of Column Q of ActualFile.xlsx Let S10dQ = Int(S10dQ) ' Application.WorksheetFunction.Round(S10dQ, 4) Dim Cnt ' this is for - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B For Cnt = 2 To Lr1 ' Jmax Dim MtchRes As Variant Let MtchRes = Application.Match(arrA(Cnt, 1), arrB(), 0) ' - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B If IsError(MtchRes) Then ' no match do nothing Else ' Cnt is now at the row number of where 2.xlsx sheet1 column A was found in Actual File.xlsx sheet1 column B Dim Lc1Cnt As Long: Let Lc1Cnt = Ws1.Cells.Item(Cnt, Ws1.Columns.Count).End(xlToLeft).Column ' Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").ClearContents ' clear row Cnt of all data before pasting ' Rng22.Copy Destination:=Ws1.Range("B" & Cnt & "") ' copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to the row in sheet 1 of 2.xlsx at the row number of the matched value of 2.xlsx sheet1 Let Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Value = Ws1.Evaluate("=" & S10dQ & "*" & Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Address & "") ' Ws1.Evaluate("=2*" & Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Address & "") ' then double the value of that row of 2.xlsx End If Next Cnt Else ' Sum = S10 End If ' SumQ>S10 End Sub
Share 'Actual File.xlsx' : https://app.box.com/s/9dfaq1997whyyj0jq7ew30sixcmq9zpm
Share '2.xlsx' : https://app.box.com/s/ij24a4nmnnvi0h4qr13h49ro05aouatk
Share 'macro.xlsm' : https://app.box.com/s/599q2it3uck3hfwm5kscmmgtn0be66wt
Test ranges used to answer this post:
https://excelfox.com/forum/showthrea...ll=1#post13401
Before:
Row\Col A B C D E F G H I J K L M N O P Q 1Exchange Symbol Series/Expiry Open High Low Prev Close LTP 2NSE ASHOKLEY EQ 65 65.35 60.55 63.3 63.3 1 1 60 1.055 1.055 54 56.97 3NSE BANKBARODA EQ 62.1 62.95 56.15 56.65 56.65 1 6 60 0.944167 5.665 54 50.985 4NSE BEL EQ 66.15 66.75 62.4 65.65 65.65 1 6 60 1.094167 6.565 54 59.085 5NSE EQUITAS EQ 82 82.05 71 73.05 73.05 1 1 60 1.2175 1.2175 54 65.745 6NSE FEDERALBNK EQ 68 68.45 62.45 63.1 63.1 1 6 60 1.051667 6.31 54 56.79 7NSE GAIL EQ 85 88.8 79.1 79.95 79.95 1 6 60 1.3325 7.995 54 71.955 8NSE IDFCFIRSTB EQ 32.1 32.35 27.2 27.55 27.55 1 60 0.459167 0.459167 54 24.795 9NSE IOC EQ 93 93.65 87.25 87.9 87.9 1 60 1.465 1.465 54 79.11 10NSE L&TFH EQ 90 91.55 80.5 81.65 81.65 6 51 1.60098 9.605882 54 86.45294 11
_____ Workbook: 2.xlsx ( Using Excel 2007 32 bit )
Worksheet: Sheet1 (5)
Row\Col A B C D E F G H I J K L M N O 1Stock Name data data data data data data data data data data data data data data 2ACC 100 108 120 128 134 151 6534 30 90 97 103 3ADANIENT 101 109 121 127 135 122 782 40 92 98 4ADANIPORTS 102 110 122 16 137 177 10 50 93 99 104 5ASHOKLEY 1 2 3 4 5 16 137 177 6ANJALIPHARMA 10 50 93 99 5 102 110 122 9 10 11 7SUNTECK 11 12 13 14 15 16 17 18 19 20 21 22 23 8
Row\Col O P Q R S 6 6.31 54 56.79 7 7.995 54 71.955Total Fund Amount 8387.320769 8 0.459167 54 24.795Current Fund Amount 9000 9 1.465 54 79.11Fund Allocated 8000 10 9.605882 54 86.45294Profit Amount 1000 11Sum is 551.8879
Row\Col Q 2 56.97 3 50.985 4 59.085 5 65.745 6 56.79 7 71.955 8 24.795 9 79.11 10 86.45294 11 =SUM(Q2:Q10)
In this example sum of column Q is less than Range S10 value so nothing is done
Macro for last post, and to answer this post:
Code:Sub CopyPaste20Q2b() ' https://excelfox.com/forum/showthread.php/2494-Copy-and-paste-of-data-if-matches?p=13401&viewfull=1#post13401 Rem 1 Worksheets info ' 2.xlsx Dim Wb2 As Workbook Set Wb2 = Workbooks("2.xlsx") Dim Ws1 As Worksheet: Set Ws1 = Wb2.Worksheets.Item(1) Dim Lr1 As Long Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row Dim arrA() As Variant: Let arrA() = Ws1.Range("A1:A" & Lr1 & "").Value2 ' 2.xlsx sheet1 column A 'Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2) 'Dim Rng22 As Range: Set Rng22 = Ws2.Range("A1").CurrentRegion ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx ' Actual File.xlsx Dim Wb As Workbook, Ws As Worksheet Set Wb = Workbooks("Actual File.xlsx") Set Ws = Wb.Worksheets.Item(1) Dim Jmax As Long: Let Jmax = Ws.Range("J" & Ws.Rows.Count & "").End(xlUp).Row Dim arrB() As Variant: Let arrB() = Ws.Range("B1:B" & Jmax & "").Value2 ' Actual File.xlsx sheet1 column B '1c ' calculate the total value of column Q of ActualFile.xlsx and if it is Greater than S10 of ActualFile.xlsx then Dim Lr As Long: Let Lr = Ws.Range("A" & Ws.Rows.Count & "").End(xlUp).Row Dim SomeQ As Double: Let SomeQ = Ws.Evaluate("=SUM(Q2:Q" & Lr & ")") ' total value of column Q of ActualFile.xlsx Let SomeQ = Application.WorksheetFunction.Round(SomeQ, 2) Dim S10Val As Double: Let S10Val = Ws.Range("S10").Value ' S10 of ActualFile.xlsx If SomeQ > S10Val Then ' total value of column Q of ActualFile.xlsx and if it is Greater than S10 of ActualFile.xlsx then this macro should do the process Rem 2 do it Dim Cnt ' this is for - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B but only as far as JMax For Cnt = 2 To Lr1 ' Jmax Dim MtchRes As Variant Let MtchRes = Application.Match(arrA(Cnt, 1), arrB(), 0) ' - going down column A of 2.xlsx sheet1 looking for a match in Actual File.xlsx sheet1 column B If IsError(MtchRes) Then ' no match do nothing Else ' Cnt is now at the row number of where 2.xlsx sheet1 column A was found in Actual File.xlsx sheet1 column B Dim Lc1Cnt As Long: Let Lc1Cnt = Ws1.Cells.Item(Cnt, Ws1.Columns.Count).End(xlToLeft).Column ' Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").ClearContents ' clear row Cnt of all data before pasting ' Rng22.Copy Destination:=Ws1.Range("B" & Cnt & "") ' copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to the row in sheet 1 of 2.xlsx at the row number of the matched value of 2.xlsx sheet1 Let Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Value = Ws1.Evaluate("=2*" & Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").Address & "") ' then double the value of that row of 2.xlsx End If Next Cnt Else ' else do nothing End If End Sub
Just testing
ignore all this
C:\Users
ror Resume Next
Set WB1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls")
If Err <> 0 Then
