Page 28 of 57 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 570
  1. #271
    Quote Originally Posted by sandy666 View Post
    do ya have : Attention deficit hyperactivity disorder (ADHD) ???
    Probably
    it is fixer's fault - he is driving me mad!
    Sir Moderator sandy666's Avatar
    May 2018
    easy, easy, this is a patience test
    sandy
    I know you know but I forgot my Crystal Ball and don't know what you know also I may not remember what I did weeks, months or years ago so answer asap. Thinking doesn't hurt
  3. #273
    It is character building.
    Actually, you are good at geussing what he wants...
    I will post just once more now in the main Thread , and then go and break some more rocks for relaxation for the rest of the day..
    C ya tomorrrow
    Another attempt to geuss what fixer is askig for from here:
    https://excelfox.com/forum/showthrea...ll=1#post13256
    Sub OpenTxtFiles_ValuesToBeSeperatedIntoExcelCells()
    ' Comma seperated values text files
    Call OpenA____SeperatedValuesTextFile("CommaSeperatedValues.csv", ",")
    Call OpenA____SeperatedValuesTextFile("CommaSeperatedValues.txt", ",")
    Sub OpenA____SeperatedValuesTextFile(ByVal Filname As String, ByVal Seprator As String)
    Rem 1 Get text file as long string.
    Dim FileNum As Long: Let FileNum = FreeFile(1) ' https://msdn.microsoft.com/en-us/vba/language-reference-vba/articles/freefile-function
     Let PathAndFileName = ThisWorkbook.Path & "\" & Filname '
    Open PathAndFileName For Binary As #FileNum 'Open Route to data. Binary is a fundemental type data input...
    TotalFile = Space(LOF(FileNum)) '....and wot recives it hs to be a string of exactly the right length
    Get #FileNum, , TotalFile
    Close #FileNum
    Rem 2 Put values in Excel
    Dim Ws1 As Worksheet
     Set Ws1 = ThisWorkbook.Worksheets.Item(1)
     Ws1.Cells.ClearContents
    '2b) Split Total File text into  a 1 Dimensional array into rows
    Dim RwTxt() As String: Let RwTxt() = Split(TotalFile, vbCr & vbLf, -1, vbBinaryCompare)
    Dim Clms() As String
     Let Clms() = Split(RwTxt(0), Seprator, -1, vbBinaryCompare) '  This will be the first row of data. Here we are doing it just to gat the column count. In the loop below, we will use it for every row, including initially this first row. We need it below to allow us to access each value seperately seperated via the seprator, seprator
    Dim HedClmsCnt As Long: Let HedClmsCnt = UBound(Clms) + 1    '  +1 is required , as , by default , a 1Dimensional array from split has first element indicie of 0 , so Ubound will be 1 less than the number of elements
    Dim arrOut() As String                                       '  I must make this dynamic, since i must use the TReDim method to size it. This is because the Dim statement will not accept variables or non static values: It omly accepts actual integer hard coded numbers
    ReDim arrOut(1 To UBound(RwTxt) + 1, 1 To HedClmsCnt)        '  +1 is required , as , by default , a 1Dimensional array from split has first element indicie of 0 , so Ubound will be 1 less than the number of elements
    Dim RwCnt As Long
        For RwCnt = 0 To UBound(RwTxt)
        '2c) Split each row into seperated values
         Let Clms() = Split(RwTxt(RwCnt), Seprator, -1, vbBinaryCompare)
        Dim ClmCnt As Long
            If Not UBound(Clms()) = -1 Then '   This might be the case fo extra rows in the text file with no  seperators in s
                For ClmCnt = 1 To HedClmsCnt
                 Let arrOut(RwCnt + 1, ClmCnt) = Clms(ClmCnt - 1)
                Next ClmCnt
        Next RwCnt
    Rem 2d) Put values from text file into first worksheet
    Ws1.Range("A1").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)) = arrOut()
    Try number 12976436. Education in Text files
    In support of this Thread: http://www.eileenslounge.com/viewtopic.php?f=30&t=34629
    DF.txt
    Text file, DF.txt https://app.box.com/s/gw941dh9v8sqhvzin3lo9rfc67fjsbic
    Original uploaded DF.txt looked like this as seen for example using a Text Editor. ( Notepad is just one of many available text editors )
    10,18052020,9.23,0015378
    20,1018GS2026,GS,IN0020010081,0.00,0.00,10.00,0.00 ,0.00,10.00
    20,1025GS2021,GS,IN0020010040,0.00,0.00
    ……..etc.
    You are using a comma in DF.txt to separate the values. Because you are using a comma to separate your values , we sometimes call such a file a comma separated values file., and we often give a comma separated values text file the extension .csv. But you don’t have to. It’s is your choice. Both DF.txt or DF.csv is OK. You can use either for your text file.
    You have used DF.txt for your comma separated values text file. That is a bit unusual, but it is OK. Its your choice.
    This macro will allow us to examine that text file, ( for simplicity I am using a test file example of just 3 rows )
    Sub WotsInDF_Text()  '  '  http://www.eileenslounge.com/viewtopic.php?p=268809#p268809   What is in   DF.txt :  https://app.box.com/s/gw941dh9v8sqhvzin3lo9rfc67fjsbic           https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=13273&viewfull=1#post13273
     Let PathAndFileName = ThisWorkbook.Path & "\csv Text file Chaos\" & "DF_first 3 rows.txt" ' From vixer zyxw1234  : http://www.eileenslounge.com/viewtopic.php?f=30&t=34629     DF.txt https://app.box.com/s/gw941dh9v8sqhvzin3lo9rfc67fjsbic
    TotalFile = Space(LOF(FileNum)) '....and wot recives it has to be a string of exactly the right length
    Close #FileNum
    ' What the fuck is in this string?
    Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(TotalFile) '    https://excelfox.com/forum/showthread.php/2302-quot-What%e2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string?p=11016&viewfull=1#post11016     https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11818&viewfull=1#post11818
    here is the full single string of the text file, shown in two forms:
    _ as seen in a text editor
    _ in a VBA code line form
    10,18052020,9.23,001537820,1018GS2026,GS,IN0020010081,0.00,0.00,10.00,0.00,0.00,10.0020,1025GS2021,GS,IN0020010040,0.00,0.00,10.00,0.00,0.00,10.00
    "10" & Chr(44) & "18052020" & Chr(44) & "9" & "." & "23" & Chr(44) & "0015378" & vbCr & vbLf & "20" & Chr(44) & "1018GS2026" & Chr(44) & "GS" & Chr(44) & "IN0020010081" & Chr(44) & "0" & "." & "00" & Chr(44) & "0" & "." & "00" & Chr(44) & "10" & "." & "00" & Chr(44) & "0" & "." & "00" & Chr(44) & "0" & "." & "00" & Chr(44) & "10" & "." & "00" & vbCr & vbLf & "20" & Chr(44) & "1025GS2021" & Chr(44) & "GS" & Chr(44) & "IN0020010040" & Chr(44) & "0" & "." & "00" & Chr(44) & "0" & "." & "00" & Chr(44) & "10" & "." & "00" & Chr(44) & "0" & "." & "00" & Chr(44) & "0" & "." & "00" & Chr(44) & "10" & "." & "00"
    here the same again, just shown slightly differently for easy of explanation
    we see the value seperator comma , ( character 44 ) and the line seperator, vbCr & vbLf
    In support of this Thread: https://excelfox.com/forum/showthrea...3427#post13427
    Alert 24 Mai..csv Alert 24 MaiDotDotcsv.jpg : https://imgur.com/0HsAOLj
    We analyse using the same macro as above, with this changed code line
     Let PathAndFileName = ThisWorkbook.Path & "\csv Text file Chaos\" & "Alert 24 Mai..csv" '  https://excelfox.com/forum/showthread.php/2500-Conditionally-delete-entire-row-with-calculation-within-files     Share ‘Alert 24 Mai..csv’  :  https://app.box.com/s/599q2it3uck3hfwm5kscmmgtn0be66wt
    Here is the results
    NSE,236,6,>,431555,A,,,,,GTTNSE,25,6,>,431555,A,,,,,GTTNSE,15083,6,>,431555,A,,,,,GTTNSE,17388,6,>,431555,A,,,,,GTTNSE,100,6,>,431555,A,,,,,GTTNSE,22,6,>,431555,A,,,,,GTT,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,Entire row of row 3 & row 4 both will be deleted after runing the macro,,,,,,
    "NSE" & Chr(44) & "236" & Chr(44) & "6" & Chr(44) & Chr(62) & Chr(44) & "431555" & Chr(44) & "A" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "GTT" & vbCr & vbLf & "NSE" & Chr(44) & "25" & Chr(44) & "6" & Chr(44) & Chr(62) & Chr(44) & "431555" & Chr(44) & "A" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "GTT" & vbCr & vbLf & "NSE" & Chr(44) & "15083" & Chr(44) & "6" & Chr(44) & Chr(62) & Chr(44) & "431555" & Chr(44) & "A" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "GTT" & vbCr & vbLf & "NSE" & Chr(44) & "17388" & Chr(44) & "6" & Chr(44) & Chr(62) & Chr(44) & "431555" & Chr(44) & "A" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "GTT" & vbCr & vbLf & "NSE" & Chr(44) & "100" & Chr(44) & "6" & Chr(44) & Chr(62) & Chr(44) & "431555" & Chr(44) & "A" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "GTT" & vbCr & vbLf & "NSE" & Chr(44) & "22" & Chr(44) & "6" & Chr(44) & Chr(62) & Chr(44) & "431555" & Chr(44) & "A" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "GTT" & vbCr & vb
    Lf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "Entire" & " " & "row" & " " & "of" & " " & "row" & " " & "3" & " " & "&" & " " & "row" & " " & "4" & " " & "both" & " " & "will" & " " & "be" & " " & "deleted" & " " & "
    after" & " " & "runing" & " " & "the" & " " & "macro" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf
    Here again adjusted for clarity
    "NSE" & Chr(44) & "22" & Chr(44) & "6" & Chr(44) & Chr(62) & Chr(44) & "431555" & Chr(44) & "A" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "GTT" & vbCr & vbLf &
    Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & "Entire" & " " & "row" & " " & "of" & " " & "row" & " " & "3" & " " & "&" & " " & "row" & " " & "4" & " " & "both" & " " & "will" & " " & "be" & " " & "deleted" & " " & "after" & " " & "runing" & " " & "the" & " " & "macro" & Chr(44) & Chr(44) & Chr(44) & Chr(44) & Chr(44) & vbCr & vbLf
    .csv text file is using commas , for the value separator, and for the line separate it has the typical convention of vbCr & vbLf
    In Support of this forum question
    https://eileenslounge.com/viewtopic....268481#p268481
    _____ Workbook: Converting formulas to valuesC.xlsm ( Using Excel 2007 32 bit )
    J
    K
    L
    M
    N
    O
    P
    Q
    #VALUE!
    Got missing number in column E CSE equivalent CSE equivalent
    Title 5
    Title 6
    Title 7
    Title 8
    Title 9
    Title 10
    eileenslounge
    1000.00
    1000
    Got one or more missing numbers
    eileenslounge1
    4.00
    eileenslounge2
    9.00
    Others
    16.00
    16
    eileenslounge
    1000.00
    1000
    13
    eileenslounge1
    36.00
    36
    14
    eileenslounge2
    49.00
    49
    15
    Others
    64.00
    64
    16
    Worksheet: data
    J
    K
    L
    M
    N
    O
    P
    Q
    =IF(G6="eileenslounge",1000,F7*E8)
    =IF(F7="","Got one or more missing numbers",IF(E8="","Got missing number in column E","")) CSE equivalent CSE equivalent
    Title 5
    Title 6
    Title 7
    Title 8
    Title 9
    Title 10
    eileenslounge
    =IF(G8="eileenslounge",1000,F9*E10)
    =IF(G8:G15="eileenslounge",1000,F9:F16*E10:E17)
    =IF(F8:F16="","Got one or more missing numbers",IF(E8:E15="","Got missing number in column E",""))
    eileenslounge1
    =IF(G9="eileenslounge",1000,F10*E11)
    eileenslounge2
    =IF(G10="eileenslounge",1000,F11*E12)
    Others
    =IF(G11="eileenslounge",1000,F12*E13)
    eileenslounge
    =IF(G12="eileenslounge",1000,F13*E14)
    13
    eileenslounge1
    =IF(G13="eileenslounge",1000,F14*E15)
    14
    eileenslounge2
    =IF(G14="eileenslounge",1000,F15*E16)
    15
    Others
    =IF(G15="eileenslounge",1000,F16*E17)
    16
    Worksheet: data
    J
    K
    L
    M
    N
    O
    =IF(E7="","Got one or more missing numbers",IF(F8="","Got missing number in column F",""))
    Title 5
    Title 6
    Title 7
    Title 8
    Title 9
    Title 10
    eileenslounge
    =IF(E8:E16="","Got one or more missing numbers",IF(F8:F15="","Got missing number in column E",""))
    eileenslounge1
    eileenslounge2
    Others
    eileenslounge
    13
    eileenslounge1
    14
    eileenslounge2
    15
    Others
    16
    Worksheet: data
    J
    K
    L
    M
    N
    O
    #VALUE!
    Title 5
    Title 6
    Title 7
    Title 8
    Title 9
    Title 10
    eileenslounge
    1000
    eileenslounge1
    eileenslounge2
    Others
    16
    eileenslounge
    1000
    13
    eileenslounge1
    36
    14
    eileenslounge2
    49
    15
    Others
    64
    16
    Worksheet: data
    Macro accomnpanying last post
    Sub EvaluateRangeFormulasC() '     https://eileenslounge.com/viewtopic.php?p=268537#p268537
    Dim Ws As Worksheet, Rng As Range, Clm As Range, lRow As Long
    Const fRow As Long = 6: Const sRow As Long = 8
     Set Ws = ThisWorkbook.Worksheets("data")
    ' Let lRow = Ws.Cells.Find(What:="*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row
     Let lRow = Ws.Range("G" & Ws.Rows.Count & "").End(xlUp).Row    '   '   http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11466&viewfull=1#post11466      Making Lr dynamic ( using rng.End(XlUp) for a single column. )
     Set Rng = Ws.Rows(fRow).SpecialCells(xlCellTypeFormulas)
        If Rng Is Nothing Then MsgBox "No formulas!": Exit Sub
      Let Application.ScreenUpdating = False
        For Each Clm In Rng
        Dim strEval As String '        '   Formula in column H                                    Formula in column J
         Let strEval = Clm.Formula: Debug.Print strEval                                             '  =IF(G6="eileenslounge",1000,F7*E8)                     =IF(E7="","Got one or more missing numbers",IF(F8="","Got missing number in column F",""))
         ' modifications to make first formula work in  CSE / Range Evaluate  sort of a way
         Let strEval = Replace(strEval, "G6", "G8:G" & lRow & ""): Debug.Print strEval              '  =IF(G8:G15="eileenslounge",1000,F7*E8)                 =IF(E7="","Got one or more missing numbers",IF(F8="","Got missing number in column F",""))
         Let strEval = Replace(strEval, "F7*E8", "F9:F16*E10:E17" & lRow & ""): Debug.Print strEval '  =IF(G8:G15="eileenslounge",1000,F9:F16*E10:E1715)      =IF(E7="","Got one or more missing numbers",IF(F8="","Got missing number in column F",""))
         Debug.Print ' just to make an emty line in the Immediate window
         ' modifications required for second  formula work in  CSE / Range Evaluate  sort of a way
         Let strEval = Replace(strEval, "E7", "E8:E15" & lRow & ""): Debug.Print strEval            '  =IF(G8:G15="eileenslounge",1000,F9:F16*E10:E1715)      =IF(E8:E1515="","Got one or more missing numbers",IF(F8="","Got missing number in column F",""))
         Let strEval = Replace(strEval, "F8", "F8:F15" & lRow & ""): Debug.Print strEval            '  =IF(G8:G15="eileenslounge",1000,F9:F16*E10:E1715)      =IF(E8:E1515="","Got one or more missing numbers",IF(F8:F1515="","Got missing number in column F",""))
        Let Clm.Offset(sRow - fRow).Resize(lRow - sRow + 1).Value = Evaluate(strEval)
        Next Clm
     Let Application.ScreenUpdating = True
    Running the above macro on the test data in uploade file will give these results:
    J
    K
    L
    M
    N
    O
    #VALUE!
    Title 5
    Title 6
    Title 7
    Title 8
    Title 9
    Title 10
    eileenslounge
    1000.00
    1000
    eileenslounge1
    4.00
    eileenslounge2
    9.00
    Others
    16.00
    16
    eileenslounge
    1000.00
    1000
    13
    eileenslounge1
    36.00
    36
    14
    eileenslounge2
    49.00
    49
    15
    Others
    64.00
    64
    16
    Worksheet: data
    When in the VB Editor, after running the macro, you can hit keys Ctrl+g to see the following in the Immediate window. It shows the build up of the formulas in a full run
    Some notes related to these posts
    https://excelfox.com/forum/showthrea...ll=1#post13318
    http://www.eileenslounge.com/viewtopic.php?f=30&t=34610
    http://www.eileenslounge.com/viewtop...267706#p267706
    .csv file before
    http://www.eileenslounge.com/viewtopic.php?f=30&t=34497
    After downloading the
    ALERT.xlsx
    file at that post , I navigsted to it using Windows file explorer and physically changed it in the explorer window without opening it to
    Alert29Apr..csv
    Double clicking that gives this
    _____ Workbook: Alert29Apr..csv ( Using Excel 2007 32 bit )
    17388
    Worksheet: ALERT
    The string of thet file has 9096 Characters!! : https://pastebin.com/Ptk0f7S8
    Share ‘9096Characters29Apr.xls’ : https://app.box.com/s/8g72lokzoil9fe6j645xcg8hej82gcn7
    This is how it opens in Notepads
    9096Characters29AprTextNotepads.JPG : https://imgur.com/USuCebF
    Attachment 2928
    One of the few things I can see of any sense is towards the start is a "[Content_Types].xml" : -
    "Content" & "_" & "Types" & Chr(93) & "." & "xml"
    [Content_Types].xml
    _____ Workbook: 9096Characters29Apr.xls ( Using Excel 2007 32 bit )
    30 2
    31 [ 91
    32 C 67
    33 o 111
    34 n 110
    35 t 116
    36 e 101
    37 n 110
    38 t 116
    39 _ 95
    40 T 84
    41 y 121
    42 p 112
    43 e 101
    44 s 115
    45 ] 93
    46 . 46
    47 x 120
    48 m 109
    49 l 108
    50 32
    This sort of macro gets the long file string.
    Sub WhatStringIsInAlertDotCSV() ' http://www.eileenslounge.com/viewtopic.php?f=30&t=34497
     Let PathAndFileName = ThisWorkbook.Path & "\At Eileen\" & "Alert29Apr..csv" ' This  would be made  if not existing and we would have a zero lenf string
    Dim Lenf As Long: Let Lenf = LOF(FileNum)
    TotalFile = Space(Lenf) '....and wot recives it hs to be a string of exactly the right length
    Close #FileNum
    Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(TotalFile)  '   ' https://excelfox.com/forum/showthread.php/2302-quot-What%E2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string?p=11015&viewfull=1#post11015
    There are no issues with the file format changing or in not getting the required format if this file is opened saved closed etc.. manually or using the below macro.
    Further we see that we can change things, and even add worksheets, save and reopen... All changes and any added worksheets are still there!!
    We are beginig to see the problem, or rather another twist in the confusion that is Avinash
    Sub OpenEileensAlertDotCSV() ' https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=13343&viewfull=1#post13343
    Dim PathAndFileName As String
    ' The  following file was uploaded as  ALERT.xlsx   I dowloaded it and I navigsted to it using Windows file explorer and physically changed it in the explorer window without opening it to    Alert29Apr..csv
    Dim Wb As Workbook, WbSaveSimp As Workbook, WbSaveComp As Workbook '  Ws1 As Worksheet
     Set Wb = Workbooks.Open(PathAndFileName)
     Set WbSaveSimp = Wb: Set WbSaveComp = Wb
    Wb.Close: Set Wb = Workbooks.Open(PathAndFileName)
     Call WhatStringIsInAlertDotCSV
    Wb.Save: Wb.Close
    ' ' No issues so far
    We are beginig to see the problem, or rather another twist in the confusion that is Avinash. We do not always have a .csv file!!!!! - I can see this for example if I manually try to open the file that typically "works" for Avinash Trying to open Alert when it is not a csv.JPG : https://imgur.com/sS2vnw0Attachment 2927
    ( Note: This warning does not appear when opening the file by a macro, such as in the macro above! )
    If I try to do a simple Save on such a file either manually or with coding as in the above macro , then ir is done OK. If I attempt a SaveAs then it will want to save it as an Excel File: Wants to SaveAs xlsx file.JPG : https://imgur.com/RAH3E9T Attachment 2929
    Furthermore , there is not an issue if I SaveAs manually with a Filename of "Alert29Apr..csv" ,
    But , it will end up as a new file "Alert29Apr..csv.xlsx
    There are not issues with SaveAs saving it with coding: These will give us our Excel file masquerading as a .csv file
    Wb.SaveAs Filename:=ThisWorkbook.Path & "\At Eileen" & "Alert29Apr..csv"
    Wb.SaveAs Filename:=ThisWorkbook.Path & "\At Eileen" & "Alert29AprRemove a dot.csv"
    There are no issues in reopening these files in coding, and also manually if the warning, ( about the file not being the type of the extension ) is ignored
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
