Page 27 of 57 FirstFirst ... 17252627282937 ... LastLast
Results 261 to 270 of 570
  1. #261
    Notes for this Post
    https://excelfox.com/forum/showthrea...COPY-AND-PASTE
    In 1.xls count the total number of rows that has data and copy the 3.xlsx sheet3 first row(first complete row copy) and paste that much time of 3.xlsx first row of sheet3 to 2.csv ........_
    J
    K
    L
    M
    NSE ACC EQ
    1182
    1193
    1151.7
    1190.45
    1156.6
    22
    11.566
    116815
    1168.166
    NSE ADANIENT EQ
    137.15
    140.55
    134.1
    140.5
    134.65
    25
    1.3465
    13595
    135.9965
    NSE ADANIPORTS EQ
    273.95
    276.95
    269.55
    277.6
    270.65
    15083
    2.7065
    27335
    273.3565
    NSE ADANIPOWER EQ
    32.3
    32.35
    30.45
    32.45
    30.65
    17388
    0.3065
    3095
    30.9565
    NSE AMARRAJA EQ
    555
    555
    529.25
    557.85
    532.1
    100
    5.321
    5374
    537.21
    Worksheet: 1-Sheet1 3Mai
    _____ Workbook: 3.xlsx ( Using Excel 2007 32 bit )
    J
    K
    L
    NSE
    A GTT
    Worksheet: Sheet1
    _..........
    suppose 1.xls has data in 5 rows then copy 3.xlsx first row of sheet3 and paste it to 2.csv 5 times
    _____ Workbook: 2.csv ( Using Excel 2007 32 bit )
    J
    K
    L
    NSE
    A GTT
    NSE
    A GTT
    NSE
    A GTT
    NSE
    A GTT
    NSE
    A GTT
    Worksheet: 2
    macro solution for last post and solution for
    https://excelfox.com/forum/showthrea...ll=1#post13185
    In the macro I have done for you , there are two possibilities.
    You only need one
    You can choose
    ' 2b)(i) Relative formula references ...
    ' 2b)(i)  Relative formula references  ... https://teylyn.com/2017/03/21/dollarsigns/#comment-191
     Ws2.Cells.NumberFormat = "General"                          ' May be needed to prevent formulas coming out as test     =[3.xlsx]Sheet1!$A$1
     Let rngOut.Value = "='[3.xlsx]" & Ws3.Name & "'!A$1"
     Let rngOut.Value = rngOut.Value  '  Change Formulas to values
     Let rngOut.Value = Evaluate("If({1},SUBSTITUTE(" & rngOut.Address & ", ""0"", """"))")      '                              https://excelribbon.tips.net/T010741_Removing_Spaces
    ' Or
    '' 2b)(ii) Copy paste
    'Dim rngIn As Range
    ' Set rngIn = Ws3.Range("A1:" & Lc3Ltr & "1")
    ' rngIn.Copy
    ' rngOut.PasteSpecial Paste:=xlPasteValues  '   understanding  Paste  across ranges of different size to  Copy  range : https://excelfox.com/forum/showthread.php/2221-VBA-Range-Insert-Method-Code-line-makes-a-space-to-put-new-range-in?p=10441&viewfull=1#post10441
    OR
    ' 2b)(ii) Copy Paste
    ' 2b)(i)  Relative formula referrences  ... https://teylyn.com/2017/03/21/dollarsigns/#comment-191
    ' Ws2.Cells.NumberFormat = "General"                          ' May be needed to prevent formulas coming out as test     =[3.xlsx]Sheet1!$A$1
    ' Let rngOut.Value = "='[3.xlsx]" & Ws3.Name & "'!A$1"
    ' Let rngOut.Value = rngOut.Value  '  Change Formulas to values
    ' Let rngOut.Value = Evaluate("If({1},SUBSTITUTE(" & rngOut.Address & ", ""0"", """"))")      '                              https://excelribbon.tips.net/T010741_Removing_Spaces
    ' Or
    Dim rngIn As Range
     rngIn.Copy
    Sub Step14()    '    http://www.eileenslounge.com/viewtopic.php?f=30&t=34508 (zyxw123)     https://excelfox.com/forum/showthread.php/2467-COPY-AND-PASTE?p=13182#post13182
    Rem 1 Worksheets info
    Dim w1 As Workbook, w2 As Workbook, w3 As Workbook
     Set w1 = Workbooks("1.xls")                         ' Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xlsx")
     Set w2 = Workbooks("2.csv")                         ' Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\document\2.csv")
     Set w3 = Workbooks("3.xlsx")                        ' Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\files\3.xlsx")
    Dim Ws1 As Worksheet, Ws2 As Worksheet, Ws3 As Worksheet
     Set Ws1 = w1.Worksheets.Item(1)
     Set Ws2 = w2.Worksheets.Item(1)
     Set Ws3 = w3.Worksheets.Item(1)
    Dim Lc3 As Long, Lenf1 As Long, Lr1 As Long
     Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row       '   http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11466&viewfull=1#post11466      Making Lr dynamic ( using rng.End(XlUp) for a single column. )
     Let Lc3 = Ws3.Cells.Item(1, Ws3.Columns.Count).End(xlToLeft).Column
    Dim Lc3Ltr As String
     Let Lc3Ltr = CL(Lc3)
    Rem 2  ' In 1.xls count the total number of rows that has data and copy the 3.xlsx sheet3 first row(first complete row copy) and paste that much time of 3.xlsx first row of sheet3 to 2.csv
     Let Lenf1 = Lr1 - 1                                                ' 1.xls first row has headers so dont count that
    ' 2a)
    Dim rngOut As Range: Set rngOut = Ws2.Range("A1:" & Lc3Ltr & Lenf1 & "")
    ' Or
    Dim rngIn As Range
     rngIn.Copy
    Rem 3
    ' w1.Close
    ' w2.Save
    ' Let Application.DisplayAlerts = False
    ' w2.Close
    ' Let Application.DisplayAlerts = True
    ' w3.Close
    '     http://www.excelfox.com/forum/showthread.php/1546-TESTING-Column-Letter-test-Sort
    In support to answer to this Thread
    from about here:
    https://excelfox.com/forum/showthrea...ll=1#post13193
    Before csv file link https://drive.google.com/open?id=1MF...s6EWCLjkblGxfo
    Before csv.jpg : https://imgur.com/NLryZml
    Attachment 2900
    After runing macro csv link https://drive.google.com/open?id=1V_...S63idSd5zlDcVX
    After csv.JPG : : https://imgur.com/IzaxRrh
    Attachment 2901
    Analysing what we have before and after
    To get the single string of what is in the file, from here , https://www.homeandlearn.org/open_a_...le_in_vba.html https://www.homeandlearn.org/write_to_a_text_file.html ,
    I use the below macro to analyse the supplied from vixer google drive share file for Before, ( Sub WtchaGot_Unic_NotMuchIfYaChoppedItOff(ByVal strIn As String) is in next post )
    '    https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=13208&viewfull=1#post13208
    Sub TestieCSVstringBefore()
    Dim FileNum As Long: Let FileNum = FreeFile(1) ' https://msdn.microsoft.com/en-us/vba/language-reference-vba/articles/freefile-function
      Let PathAndFileName = ThisWorkbook.Path & "\" & "2 Before.csv" ' From vixer :  https://excelfox.com/forum/showthread.php/2467-COPY-AND-PASTE?p=13193&viewfull=1#post13193     Before csv file link https://drive.google.com/file/d/1MFIgUUiH0QPO1oWpDms6EWCLjkblGxfo/view       Before csv.jpg : https://imgur.com/NLryZml
    Open PathAndFileName For Binary As #FileNum 'Open Route to data. Binary is a fundemental type data input...
    TotalFile = Space(LOF(FileNum)) '....and wot recives it hs to be a string of exactly the right length
    Get #FileNum, , TotalFile
    Close #FileNum
    ' What the fuck is in this string?
    Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(TotalFile)
    After running the above macro I get this analysis:
    vbCr & vbLf
    _._________________________________________
    I repeat the same for the supplied After file.
    ' Sub WtchaGot_Unic_NotMuchIfYaChoppedItOff(ByVal strIn As String) '  ' https://excelfox.com/forum/showthread.php/2302-quot-What%E2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string     ' https://excelfox.com/forum/showthread.php/2302-quot-What%E2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string?p=11015&viewfull=1#post11015
    Sub TestieCSVstringAfter()
     Let PathAndFileName = ThisWorkbook.Path & "\" & "2.csv" ' From vixer :  https://excelfox.com/forum/showthread.php/2467-COPY-AND-PASTE?p=13193&viewfull=1#post13193     After runing macro csv link  https://drive.google.com/file/d/1V_85p1O4lV4RvqHw1dS63idSd5zlDcVX/view      After csv.JPG : : https://imgur.com/IzaxRrh
    Close #FileNum
    Here is the result
     "NSE" & vbTab & vbTab & "6" & vbTab & vbTab & vbTab & "A" & vbTab & vbTab & vbTab & vbTab & vbTab & "GTT" & vbCr & vbLf & "NSE" & vbTab & vbTab & "6" & vbTab & vbTab & vbTab & "A" & vbTab & vbTab & vbTab & vbTab & vbTab & "GTT" & vbCr & vbLf & "NSE" & vbTab & vbTab & "6" & vbTab & vbTab & vbTab & "A" & vbTab & vbTab & vbTab & vbTab & vbTab & "GTT" & vbCr & vbLf & "NSE" & vbTab & vbTab & "6" & vbTab & vbTab & vbTab & "A" & vbTab & vbTab & vbTab & vbTab & vbTab & "GTT" & vbCr & vbLf & "NSE" & vbTab & vbTab & "6" & vbTab & vbTab & vbTab & "A" & vbTab & vbTab & vbTab & vbTab & vbTab & "GTT" & vbCr & vbLf
    vbCr & vbLf
    It is a single long string
    Here the same again , differently shown, just for clarity. But remember, it is actually a single long string.
    Or like
    "NSE" vbTab vbTab "6" vbTab vbTab vbTab "A" vbTab vbTab vbTab vbTab vbTab "GTT" vbCr vbLf
    Function required for last post
    Rem 1  ' Output "sheet hardcopies"
    '1a) Worksheets     'Make Temporary Sheets, if not already there, in Current Active Workbook, for a simple list of all characters, and for pasting the string into worksheet cells
    '1a)(i) Full list of characters worksheet
        If Not Evaluate("=ISREF(" & "'" & "WotchaGotInString" & "'!Z78)") Then '   ( the '  are not important here, but iin general allow for a space in the worksheet name like  "Wotcha Got In String"
        Dim Wb As Workbook '                                   ' ' Dim:  ' Preparing a "Pointer" to an Initial "Blue Print" in Memory of the Object ( Pigeon Hole with a bit of paper or code lines on that can be filled in to refer to a specific Objec of this type ) . This also us to get easily at the Methods and Properties throught the applying of a period ( .Dot) ( intellisense )                     '
         Set Wb = ActiveWorkbook '  '                            Set now (to Active Workbook - one being "looked at"), so that we carefull allways referrence this so as not to go astray through Excel Guessing inplicitly not the one we want...         Set: Values are filled at the memory locations and the directions there are specified in the variable "Blue Print "Pointer". In this case a Filled in Blue Print is passed.      http://www.excelforum.com/excel-programming-vba-macros/1138804-help-understanding-class-instancing-cant-set-ws-new-worksheet-intellisense-offers-it-4.html#post4387191                                '
         Wb.Worksheets.Add After:=Wb.Worksheets.Item(Worksheets.Count) 'A sheeet is added and will be Active
        Dim ws As Worksheet '
         Set ws = ActiveSheet 'Rather than rely on always going to the active sheet, we referr to it Explicitly so that we carefull allways referrence this so as not to go astray through Excel Guessing implicitly not the one we want...    Set: Values are filled at the memory locations and the directions there are specified in the variable "Blue Print "Pointer". In this case a Filled in Blue Print is passed.      http://www.excelforum.com/excel-programming-vba-macros/1138804-help-understanding-class-instancing-cant-set-ws-new-worksheet-intellisense-offers-it-4.html#post4387191            ' Values are filled at the memory locations and the directions there are specified in the variable "Blue Print "Pointer". In this case a Filled in Blue Print is passed.      http://www.excelforum.com/excel-programming-vba-macros/1138804-help-understanding-class-instancing-cant-set-ws-new-worksheet-intellisense-offers-it-4.html#post4387191
         ws.Activate: ws.Cells(1, 1).Activate ' ws.Activate and activating a cell sometimes seemed to overcome a strange error
         Let ws.Name = "WotchaGotInString"
        Else ' The worksheet is already there , so I just need to set my variable to point to it
         Set ws = ThisWorkbook.Worksheets("WotchaGotInString")
    '1a(ii) Worksheet to paste out string into worksheet cells
        If Not Evaluate("=ISREF(" & "'" & "StrIn|WtchaGot" & "'!Z78)") Then
         Wb.Worksheets.Add Before:=Wb.Worksheets.Item(1)
         Set Ws1 = ActiveSheet
         Ws1.Activate: Ws1.Cells(1, 1).Activate
         Let Ws1.Name = "StrIn|WtchaGot"
         Set Ws1 = ThisWorkbook.Worksheets("StrIn|WtchaGot")
    '1b) Array
    Dim myLenf As Long: Let myLenf = Len(strIn)  '            ' Long is very simple to handle, - final memory "size" type is known (123.456 and 000.001 have same "size" computer memory ) , and so a Address suggestion can be given for the next line when the variable is filled in.  '( Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647) If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.--upon/after 32-bit, Integers (Short) need converted internally anyways, so a Long is actually faster. )       https://www.mrexcel.com/forum/excel-questions/803662-byte-backward-loop-4.html
    Dim arrWotchaGot() As String: ReDim arrWotchaGot(1 To myLenf + 1, 1 To 2) ' +1 for header  Array for the output 2 column list.  The type is known and the size,  but I must use this ReDim  method simply because the dim statement  Dim( , )  is complie time thing and will only take actual numbers
     Let arrWotchaGot(1, 1) = Format(Now, "DD MMM YYYY") & vbLf & "Lenf is   " & myLenf: Let arrWotchaGot(1, 2) = Left(strIn, 40)
    Rem 2  String anylaysis
    'Dim myLenf As Long: Let myLenf = Len(strIn)
        For Cnt = 1 To myLenf ' ===Main Loop========================================================================
        ' Character analysis: Get at each character
        Dim Caracter As Variant ' String is probably OK.
        Let Caracter = Mid(strIn, Cnt, 1) ' '    the character in strIn at position from the left of length 1
        '2a) The character added to a single  WotchaGot  long character string to look at and possibly use in coding
        Dim WotchaGot As String ' This will be used to make a string that I can easilly see and also is in a form that I can copy and paste in a code line  required to build the full string of the complete character string
            '2a)(i) Most common characters and numbers to be displayed as "seen normally" ' -------2a)(i)--
            If Caracter Like "[A-Z]" Or Caracter Like "[0-9]" Or Caracter Like "[a-z]" Then ' Check for normal characters
                'SirNirios
                If Not Cnt = 1 Then ' I am only intersted in next line comparing the character before, and if i did not do this the next line would error if first character was a  "normal"  character
                    If Not Cnt = myLenf And (Mid(strIn, Cnt - 1, 1) Like "[A-Z]" Or Mid(strIn, Cnt - 1, 1) Like "[0-9]" Or Mid(strIn, Cnt - 1, 1) Like "[a-z]") Then  ' And (Mid(strIn, Cnt + 1, 1) Like "[A-Z]" Or Mid(strIn, Cnt + 1, 1) Like "[0-9]" Or Mid(strIn, Cnt + 1, 1) Like "[a-z]") Then
                     Let WotchaGot = WotchaGot & "|LinkTwoNormals|"
            Let WotchaGot = WotchaGot & """" & Caracter & """" & " & " ' This will give the sort of output that I need to write in a code line, so for example if I have a123 , this code line will be used 4 times and give like a final string for me to copy of   "a" & "1" & "2" & "3" &      I would phsically need to write in code  like  strVar = "a" & "1" & "2" & "3"   -  i could of course also write  = "a123"   but the point of this routine is to help me pick out each individual element
            Else ' Some other things that I would like to "see" normally - not "normal simple character" - or by a VBA constant, like vbCr vbLf  vbTab
             Select Case Caracter ' 2a)(ii)_1
              Case " "
               Let WotchaGot = WotchaGot & """" & " " & """" & " & "
              Case "!"
               Let WotchaGot = WotchaGot & """" & "!" & """" & " & "
              Case "$"
               Let WotchaGot = WotchaGot & """" & "$" & """" & " & "
              Case "%"
               Let WotchaGot = WotchaGot & """" & "%" & """" & " & "
              Case "~"
               Let WotchaGot = WotchaGot & """" & "~" & """" & " & "
              Case "&"
               Let WotchaGot = WotchaGot & """" & "&" & """" & " & "
              Case "("
               Let WotchaGot = WotchaGot & """" & "(" & """" & " & "
              Case ")"
               Let WotchaGot = WotchaGot & """" & ")" & """" & " & "
              Case "/"
               Let WotchaGot = WotchaGot & """" & "/" & """" & " & "
              Case "\"
               Let WotchaGot = WotchaGot & """" & "\" & """" & " & "
              Case "="
               Let WotchaGot = WotchaGot & """" & "=" & """" & " & "
              Case "?"
               Let WotchaGot = WotchaGot & """" & "?" & """" & " & "
              Case "'"
               Let WotchaGot = WotchaGot & """" & "'" & """" & " & "
              Case "+"
               Let WotchaGot = WotchaGot & """" & "+" & """" & " & "
              Case "-"
               Let WotchaGot = WotchaGot & """" & "-" & """" & " & "
              Case "_"
               Let WotchaGot = WotchaGot & """" & "_" & """" & " & "
              Case "."
               Let WotchaGot = WotchaGot & """" & "." & """" & " & "
    '          Case " "
    '           Let WotchaGot = WotchaGot & """" & " " & """" & " & "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '          Case " "
    '                   ' 2a)(ii)_2
    '          Case " "
    '          Case " "
              Case vbCr
               Let WotchaGot = WotchaGot & "vbCr & "  ' I actuall would write manually in this case like     vbCr &
              Case vbLf
               Let WotchaGot = WotchaGot & "vbLf & "
              Case vbCrLf
               Let WotchaGot = WotchaGot & "vbCrLf & "
              Case vbNewLine
               Let WotchaGot = WotchaGot & "vbNewLine & "
              Case """"   ' This is how to get a single   "    No one is quite sure how this works.  My theory that,  is as good as any other,  is that  syntaxly   """"    or  "  """  or    """    "   are accepted.   But  in that the  """  bit is somewhat strange for VBA.   It seems to match  the first and Third " together as a  valid pair   but  the other  " in the middle of the  3 "s is also syntax OK, and does not error as    """     would  because  of the final 4th " which it syntaxly sees as a valid pair matched simultaneously as it does some similar check on the  first  and Third    as a concluding  string pair.  All is well except that  the second  "  is captured   within a   accepted  enclosing pair made up of the first and third  "   At the same time the 4th  "  is accepted as a final concluding   "   paired with the   second which it is  using but at the same time now isolated from.
               Let WotchaGot = WotchaGot & """" & """" & """" & """" & " & "                                ' The reason why  ""  ""   would not work is that    at the end of the  "" the next empty  character signalises the end of a  string pair, and only if  it saw a " would it keep checking the syntax rules which  then lead in the previous case to  the situation described above.
              Case vbTab
               Let WotchaGot = WotchaGot & "vbTab & "
              ' 2a)(iii)
                Case Else
                    If AscW(Caracter) < 256 Then
                     Let WotchaGot = WotchaGot & "Chr(" & AscW(Caracter) & ")" & " & "
                     Let WotchaGot = WotchaGot & "ChrW(" & AscW(Caracter) & ")" & " & "
                'Let CaseElse = Caracter
            End If ' End of the "normal simple character" or not ' -------2a)------Ended-----------
        '2b)  A 2 column Array for convenience of a list
         Let arrWotchaGot(Cnt + 1, 1) = Cnt & "           " & Caracter: Let arrWotchaGot(Cnt + 1, 2) = AscW(Caracter) ' +1 for header
        Next Cnt ' ========Main Loop=================================================================================
        '2c) Some tidying up
        If WotchaGot <> "" Then
         Let WotchaGot = Left(WotchaGot, Len(WotchaGot) - 3) ' take off last " & "    ( 2 spaces one either side of a  & )
         Let WotchaGot = Replace(WotchaGot, """ & |LinkTwoNormals|""", "", 1, -1, vbBinaryCompare)
         ' The next bit changes like this  "Lapto" & "p"  to  "Laptop"   You might want to leave it out ti speed things up a bit
            If Len(WotchaGot) > 5 And (Mid(WotchaGot, Len(WotchaGot) - 1, 1) Like "[A-Z]" Or Mid(WotchaGot, Len(WotchaGot) - 1, 1) Like "[0-9]" Or Mid(WotchaGot, Len(WotchaGot) - 1, 1) Like "[a-z]") And (Mid(WotchaGot, Len(WotchaGot) - 7, 1) Like "[A-Z]" Or Mid(WotchaGot, Len(WotchaGot) - 7, 1) Like "[0-9]" Or Mid(WotchaGot, Len(WotchaGot) - 7, 1) Like "[a-z]") And Mid(WotchaGot, Len(WotchaGot) - 6, 5) = """" & " & " & """" Then
             Let WotchaGot = Left$(WotchaGot, Len(WotchaGot) - 7) & Mid(WotchaGot, Len(WotchaGot) - 1, 2) '  Changes like this  "Lapto" & "p"  to  "Laptop"
    Rem 3 Output
    '3a) String
    '3a)(i)
    MsgBox Prompt:=WotchaGot: Debug.Print WotchaGot ' Hit Ctrl+g from the VB Editor to get a copyable version of the entire string
    '3a)(ii)
    Ws1.Activate: Ws1.Cells.Item(1, 1).Activate
     Let Ws1.Range("A1").Value = strIn
     Let Ws1.Range("B1").Value = WotchaGot
    '3b) List
    Dim NxtClm As Long: Let NxtClm = 1 ' In conjunction with next  If  this prevents the first column beine taken as 0 for an empty worksheet
     ws.Activate: ws.Cells.Item(1, 1).Activate
     If Not ws.Range("A1").Value = "" Then Let NxtClm = ws.Cells.Item(1, Columns.Count).End(xlToLeft).Column + 1
     Let ws.Cells.Item(1, NxtClm).Resize(UBound(arrWotchaGot(), 1), UBound(arrWotchaGot(), 2)).Value = arrWotchaGot()
     ws.Cells.Columns.AutoFit
    Next solution attempt for this:
    https://excelfox.com/forum/showthrea...ll=1#post13219
    Do not put a code line in the macro to open 2.csv!
    Sub Step14_DogShit()    '     https://excelfox.com/forum/showthread.php/2467-COPY-AND-PASTE?p=13219&viewfull=1#post13219
    ' Do Not open 2.csv ' Set w2 = Workbooks("2.csv")                         ' Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\document\2.csv")
    ' Set Ws2 = w2.Worksheets.Item(1)
    '  Let Lc3 = Ws3.Cells.Item(1, Ws3.Columns.Count).End(xlToLeft).Column
    ' Dim Lc3Ltr As String
    '  Let Lc3Ltr = CL(Lc3)
    ' 2a) get range to be put into dog shit files
    Dim arrIn() As Variant: Let arrIn() = Ws3.Range("A1:K1").Value
    ' 2b) make a string fow a row, including a dog shit Tab seperator
    Dim cnt
        For cnt = 1 To UBound(arrIn(), 2) ' Column count in worksheet 3 row 1
        Dim strLine As String
         Let strLine = strLine & arrIn(1, cnt) & vbTab
        Next cnt
     Let strLine = Left(strLine, (Len(strLine) - 1)) ' Take off last  Tab
    ' Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(strLine) '   "NSE" & vbTab & vbTab & "6" & vbTab & vbTab & vbTab & "A" & vbTab & vbTab & vbTab & vbTab & vbTab & "GTT"
    ' 2c) repeat string to include (and include line breaks) to make complete string for do shit text files
        For cnt = 1 To Lenf1 ' row count of our dog shit text files
        Dim strTotalFile As String
         Let strTotalFile = strTotalFile & strLine & vbCr & vbLf
        Next cnt
    ' Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(strTotalFile) '  https://excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=13218&viewfull=1#post13218
    Rem 4 make dogshit files
    ' 4a) Dog Shit text
    Dim Highway1 As Long: Let Highway1 = FreeFile(0) 'range 1 – 255, inclusive - next free
     Open ThisWorkbook.Path & "\" & "DogShit.txt" For Append As #Highway1 ' Will be made if not there
     Print #Highway1, strTotalFile
     Close #Highway1
    ' 4b) 2.csv
    Dim Highway2 As Long: Let Highway2 = FreeFile(0) 'range 1 – 255, inclusive - next free
     Open ThisWorkbook.Path & "\" & "2.csv" For Append As #Highway2 ' Will be made if not there
     Print #Highway2, strTotalFile
     Close #Highway2
    Rem ....
    ' w1.Close
    ' w2.Save
    '' Let Application.DisplayAlerts = False
    '' w2.Close
    '' Let Application.DisplayAlerts = True
    ' w3.Close
    Some Development results from running macro from last post
    Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(strTotalFile )
    & vbCr & vbLf
    In support of these Post
    https://excelfox.com/forum/showthrea...ll=1#post13246
    http://www.eileenslounge.com/viewtop...268627#p268627
    These are all text Files. The macro in the next post ( https://excelfox.com/forum/showthrea...ll=1#post13248 ) will make them
    XXXXSeperatedValuesTextFiles.JPG : https://imgur.com/A2IebLK
    Comma Seperated values
    (Sometimes called English Comma Seperated Values )
    zyxw123 , jhas , , rider , roger , anjus , sumanjjj
    Leonardo , umpsbug , kinjals , , tinamishra , kinjal124 , WigWam
    Share ‘CommaSeperatedValues.txt’ : https://app.box.com/s/qcjpeu0vt875513gqawmtoufeba3xb28
    Share ‘CommaSeperatedValues.csv’ : https://app.box.com/s/w2barpwasveltam4lutjwijks0zft0vq
    Tab Seperated Values
    zyxw123 jhas rider roger anjus sumanjjj
    Leonardo umpsbug kinjals tinamishra kinjal124 WigWam
    Share ‘TabSeperatedValues.csv’ : https://app.box.com/s/ukgxcmxj8xhmy0gzvw5269zyjdmun28g
    Share ‘TabSeperatedValues.txt’ : https://app.box.com/s/d24blwuejfixh9ofhrg387nbadxjvu15
    NMOD Seperated Values
    zyxw123 NMOD jhas NMOD NMOD rider NMOD roger NMOD anjus NMOD sumanjjj
    Leonardo NMOD umpsbug NMOD kinjals NMOD NMOD tinamishra NMOD kinjal124 NMOD WigWam
    Share ‘NMODSeperatedValues.csv’ : https://app.box.com/s/ohxqrao160vapx5jozhx7ejc4t70v1wl
    Share ‘NMODSeperatedValues.txt’ : https://app.box.com/s/46p14u9rfwvve0s4yv01zyy34f6qhmmz
    Semi Colon Seperated Values
    (Sometimes called German Comma Seperated values)
    zyxw123 ; jhas ; ; rider ; roger ; anjus ; sumanjjj
    Leonardo ; umpsbug ; kinjals ; ; tinamishra ; kinjal124 ; WigWam
    Share ‘SemiColonSeperatedValues.csv’ : https://app.box.com/s/kvqqfsjaebzj684rw8n0u1v4hqfi3hea
    Share ‘SemiColonSeperatedValues.txt’ : https://app.box.com/s/qojzd9ogwgg2d2unh2k8dkvwzdpgh84e
    GollyWobbles Seperated Values
    zyxw123 GollyWobbles jhas GollyWobbles GollyWobbles rider GollyWobbles roger GollyWobbles anjus GollyWobbles sumanjjj
    Leonardo GollyWobbles umpsbug GollyWobbles kinjals GollyWobbles GollyWobbles tinamishra GollyWobbles kinjal124 GollyWobbles WigWam
    Share ‘GollyWobblesSeperatedValues.txt’ : https://app.box.com/s/d0pktg8fadbkl8nfwnodfyle5766lghx
    Share ‘GollyWobblesSeperatedValues.csv’ : https://app.box.com/s/5xbiy0wrc05txaofr7qknpot7cb3qdo3
    Excel File With Wrong Extension
    _____ Workbook: ExcelFileWithWrongExtension.csv ( Using Excel 2007 32 bit )
    Leonardo umpsbug kinjals tinamishra kinjal124 fxe632
    Worksheet: Tabelle1
    Share ‘ExcelFileWithWrongExtension.csv’ : https://app.box.com/s/esxlg0ovoux4gk29zxgklwog6zz6b7s1
    http://www.eileenslounge.com/viewtopic.php?f=30&t=34629
    These are all text Files. The macro in this post ( https://excelfox.com/forum/showthrea...ll=1#post13248 ) will make them
    PipeSeperatedValuesTextFiles.JPG : https://imgur.com/Y9676cg
    Pipe Seperated Text Files
    zyxw123 | jhas | | rider | roger | anjus | sumanjjj
    Leonardo | umpsbug | kinjals | | tinamishra | kinjal124 | WigWam
    Share ‘PipeSeperatedValues.txt’ : https://app.box.com/s/47eo2pmeqlmnjj5h9hlxog8ts47nlgj7
    Share ‘PipeSeperatedValues.csv’ : https://app.box.com/s/o7zculmorhyys3r9b6hwwuc3wry1mr6p
    In support of this Post
    Run the macro below, Sub XXXXXSeperatedValuesTextFiles() ,
    It will make text files in the same folder as the folder in which the macro is run in.
    ( The macro is also in the shared File, XXXXXSeperatedValues.xlsm )
    The text files are shown in the last post https://excelfox.com/forum/showthrea...ll=1#post13247
    Sub XXXXXSeperatedValuesTextFiles()     '                      https://excelfox.com/forum/showthread.php/2467-COPY-AND-PASTE?p=13246#post13246
     Call Make____SeperatedValuesTextFiles("CommaSeperatedValues", ",")                        ' make  CSV files ( Comma Seperated Values Files )
     Call Make____SeperatedValuesTextFiles("TabSeperatedValues", vbTab)                        ' make  Tab Seperated Values Files
     Call Make____SeperatedValuesTextFiles("NMODSeperatedValues", "NMOD")                      ' make  NMOD Seperated Values Files
     Call Make____SeperatedValuesTextFiles("SemiColonSeperatedValues", ";")                    ' make  ; Seperated Values Files ( sometimes called german Comma seperated files )
     Call Make____SeperatedValuesTextFiles("GollyWobblesSeperatedValues", "GollyWobbles")      ' make  GollyWobbles Seperated Values Files
     Call Make____SeperatedValuesTextFiles("PipeSeperatedValues", "|")                     ' make  Pipe Seperated Values Files
    Sub Make____SeperatedValuesTextFiles(ByVal Filname As String, Seprator As String)
    ' Make long string for text file
     Let strTotalFile = MakeA____SeperatedValuesTextFile(Seprator)
    ' .txt  Text File
     Open ThisWorkbook.Path & "\" & Filname & ".txt" For Append As #Highway1 ' Will be made if not there
     Close #Highway1
    ' .csv  Text File
     Open ThisWorkbook.Path & "\" & Filname & ".csv" For Append As #Highway2 ' Will be made if not there
     Close #Highway2
    Function MakeA____SeperatedValuesTextFile(ByVal Seprator As String) As String
    Rem 1 Rows
    Dim AvinashNamesRow1() As Variant, AvinashNamesRow2() As Variant
     Let AvinashNamesRow1() = Array("zyxw123", "jhas", "", "rider", "roger", "anjus", "sumanjjj")
     Let AvinashNamesRow2() = Array("Leonardo", "umpsbug", "kinjals", "", "tinamishra", "kinjal124", "fxe632")
    Rem 2 make single string for text files
    Dim strOut As String
     Let strOut = Join(AvinashNamesRow1(), Seprator) & vbCr & vbLf & Join(AvinashNamesRow2(), Seprator) & vbCr & vbLf
     Let MakeA____SeperatedValuesTextFile = strOut
    https://excelfox.com/forum/showthrea...-a-range/page3
    XXXXXSeperatedValues.xlsm : https://app.box.com/s/jvlu048tkg0rjw7xi4c4r838abw1z7bi
    Sir Moderator sandy666's Avatar
    May 2018
    ADHahdhdh
    do ya have : Attention deficit hyperactivity disorder (ADHD) ???
    sandy
    I know you know but I forgot my Crystal Ball and don't know what you know also I may not remember what I did weeks, months or years ago so answer asap. Thinking doesn't hurt
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
