Page 26 of 57 FirstFirst ... 16242526272836 ... LastLast
Results 251 to 260 of 570
  1. #251
    test Evaluate range for this post
    http://www.excelfox.com/forum/showth...ecimals-by-vba
    We can find the position of the . using Instr function https://docs.microsoft.com/en-us/off...instr-function
    Then we can take the left of the number for a length equal to the position of the . + 3 using the Left function https://docs.microsoft.com/en-us/off.../left-function
    Then we can remove the . using the Replace function , https://docs.microsoft.com/en-us/off...place-function
    or formulas...
    K
    L
    M
    N
    264.4785
    30.2495
    1090.69 109069
    147.96 14796
    264.47 26447
    13
    1090.699
    14
    147.965
    15
    264.4785
    16
    30.2495
    Worksheet: 1-Sheet1
    K
    L
    M
    N
    264.4785
    30.2495
    =FIND(".",K2)
    =LEFT(K2,L8+2) =SUBSTITUTE(M8,".","")
    =FIND(".",K3)
    =LEFT(K3,L9+2) =SUBSTITUTE(M9,".","")
    =FIND(".",K4)
    =LEFT(K4,L10+2) =SUBSTITUTE(M10,".","")
    =FIND(".",K5)
    =LEFT(K5,L11+2) =SUBSTITUTE(M11,".","")
    13
    1090.699
    14
    147.965
    15
    264.4785
    16
    30.2495
    Worksheet: 1-Sheet1
    L
    M
    N
    O
    =FIND(".",K2)
    =LEFT(K2,L8+2) =SUBSTITUTE(M8,".","") =SUBSTITUTE(LEFT(K2,FIND(".",K2)+2),".","")
    =FIND(".",K3)
    =LEFT(K3,L9+2) =SUBSTITUTE(M9,".","") =SUBSTITUTE(LEFT(K3,FIND(".",K3)+2),".","")
    =FIND(".",K4)
    =LEFT(K4,L10+2) =SUBSTITUTE(M10,".","") =SUBSTITUTE(LEFT(K4,FIND(".",K4)+2),".","")
    =FIND(".",K5)
    =LEFT(K5,L11+2) =SUBSTITUTE(M11,".","") =SUBSTITUTE(LEFT(K5,FIND(".",K5)+2),".","")
    Worksheet: 1-Sheet1
    from Forulas, Evaluate Range
    Sub EvaluateRangeTrimRemoveDot() '  http://www.excelfox.com/forum/showthread.php/2456-Remove-decimals-by-vba?p=13068#post13068
    Dim Ws1 As Worksheet
     Set Ws1 = Workbooks("1.xls").Worksheets.Item(1) ' First worksheet in open workbooks 1.xls
     Dim LrK As Long: Let LrK = Ws1.Range("K" & Ws1.Rows.Count & "").End(xlUp).Row
    Dim RngK As Range: Set RngK = Ws1.Range("K2:K" & LrK & "")
     Let RngK.Value = Evaluate("=if({1},SUBSTITUTE(LEFT(" & RngK.Address & ",FIND("".""," & RngK.Address & ")+2),""."",""""))")
    in support of this forum post
    http://www.excelfox.com/forum/showth...ll=1#post13088
    Explanation 1
    In column K are numbers given to a maximum of 2 decimal places, for example
    Column K
    1090.69
    147.95
    264.47
    30
    The value in Column K must be adjusted so that it has the decimal format to 2 decimal places in steps of .05
    So in this form, of like
    …… 23.95 234 34.25 4.30 100.35 45.45 56.05 ……… etc….
    So for example, in the above Column K test data, no adjustment is needed for 147.95 or 30
    For 1090.69 and 264.47 some adjustment is needed. The adjustment could be to raise or lower the value. These are the possibilities:
    change 1090.69 to 1090.65 or 1090.7
    change 264.47 to 264.45 or 264.50
    Which of the two adjustments is necessary will depend on the following:
    If column H is greater than column D , then we adjust up .
    If column H is lower than column D, then we adjust down .
    Explanation 2
    For all data rows, we compare column H to column D. If column H is greater than column D , then we adjust the value in column K up to the nearest multiple of .05. If column H is less than column D , then we adjust the value in column K down to the nearest multiple of .05. ( If the value in column K is an exact multiple of .05, then no action is to be taken )
    For example
    Before:
    J
    K
    1088
    1077.25
    1067.25
    1079.9
    25
    10.799
    1090.69
    149.9
    146.5
    146
    146.5
    22
    1.465
    147.95
    265
    269.3
    265
    262.85
    267.15
    15083
    2.6715
    264.47
    30.4
    30.4
    29.8
    29.65
    29.95
    17388
    0.2995
    30
    After:
    J
    K
    L
    1088
    1077.25
    1067.25
    1079.9
    25
    10.799
    1090.65
    This nuber is adjusted down
    149.9
    146.5
    146
    146.5
    22
    1.465
    147.95
    This number is not changed
    265
    269.3
    265
    262.85
    267.15
    15083
    2.6715
    264.5
    This number is adjusted up
    30.4
    30.4
    29.8
    29.65
    29.95
    17388
    0.2995
    30
    Solution ( guess )
    The previous formula solution already always adjust number down,
    K
    L
    M
    N
    O
    P
    1079.9
    1090.69
    21813.8
    21813
    1090.65
    1090.65
    1090.65
    146.5
    147.95
    2959
    2959
    147.95
    147.95
    147.95
    265
    267.15
    264.47
    5289.4
    5289
    264.45
    264.45
    264.45
    30.4
    29.95
    30
    600
    600
    30
    30
    30
    K
    L
    M
    N
    O
    P
    1079.9
    1090.69
    =K2*100/5
    =INT(L2)
    =M2*5/100
    =INT(L2)*5/100
    =INT(K2*100/5)*5/100
    146.5
    147.95
    =K3*100/5
    =INT(L3)
    =M3*5/100
    =INT(L3)*5/100
    =INT(K3*100/5)*5/100
    265
    267.15
    264.47
    =K4*100/5
    =INT(L4)
    =M4*5/100
    =INT(L4)*5/100
    =INT(K4*100/5)*5/100
    30.4
    29.95
    30
    =K5*100/5
    =INT(L5)
    =M5*5/100
    =INT(L5)*5/100
    =INT(K5*100/5)*5/100
    So previous solution is correct if H < D
    If H > D , the previous solution is .05 too small , so previous solution must be adjusted by +.05
    =IF(H2<D2,INT(K2*100/5)*5/100,IF(H2>D2,(INT(K2*100/5)*5/100)+0.05,"H is equal to D"))
    =IF(H3<D3,INT(K3*100/5)*5/100,IF(H3>D3,(INT(K3*100/5)*5/100)+0.05,"H is equal to D"))
    =IF(H4<D4,INT(K4*100/5)*5/100,IF(H4>D4,(INT(K4*100/5)*5/100)+0.05,"H is equal to D"))
    =IF(H5<D5,INT(K5*100/5)*5/100,IF(H5>D5,(INT(K5*100/5)*5/100)+0.05,"H is equal to D"))
    But we must also check if number is already exact multiple of .05
    Like if ( integer (value/.05)) – value/.05) = 0
    ( Excel has errors and bugs, and may give a very small number when it should give us 0, so we must do a trick-
    if Round ( ( integer (value/.05)) – value/.05) ) = 0 )
    So:
    =IF(ROUND(INT(K2/0.05)-(K2/0.05),2)=0,K2,IF(H2<D2,INT(K2*100/5)*5/100,IF(H2>D2,(INT(K2*100/5)*5/100)+0.05,"H is equal to D")))
    =IF(ROUND(INT(K3/0.05)-(K3/0.05),2)=0,K3,IF(H3<D3,INT(K3*100/5)*5/100,IF(H3>D3,(INT(K3*100/5)*5/100)+0.05,"H is equal to D")))
    =IF(ROUND(INT(K4/0.05)-(K4/0.05),2)=0,K4,IF(H4<D4,INT(K4*100/5)*5/100,IF(H4>D4,(INT(K4*100/5)*5/100)+0.05,"H is equal to D")))
    =IF(ROUND(INT(K5/0.05)-(K5/0.05),2)=0,K5,IF(H5<D5,INT(K5*100/5)*5/100,IF(H5>D5,(INT(K5*100/5)*5/100)+0.05,"H is equal to D")))
    1090.65
    147.95
    264.5
    30
    VBA Solution to above, and answer to this Post
    http://www.excelfox.com/forum/showth...ll=1#post13102
    VBA answer
    Put columns in arrays
    Open
    265
    30.4
    arrD() =
    1087
    148.05
    265
    30.4
    LTP
    267.15
    29.95
    arrH() =
    1079.9
    146.5
    267.15
    29.95
    K
    264.47
    30
    arrK() ( initial ) =
    1090.69
    147.95
    264.47
    30
    The macro below manipulates the contents of arrK() as per the question requirement, then pastes the modified array over the initial values
    Sub ChangeSecondNumberAfterDecimalConditionally() ' http://www.excelfox.com/forum/showthread.php/2457-change-the-second-number-after-decimal-conditionally
    Rem 1 Worksheets info
    Dim Wb1 As Workbook
     Set Wb1 = Workbooks("SAMPLE1 18Apr2020.xlsx")  '  Workbooks("1.xls")        ' CHANGE TO SUIT
     Set Ws1 = Wb1.Worksheets.Item(1)
    Dim Lrow As Long
     Let Lrow = Ws1.Range("A" & Ws1.Rows.Count).End(xlUp).Row      '   http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11466&viewfull=1#post11466      Making Lr dynamic ( using rng.End(XlUp) for a single column. )
    Rem 2 ranges of interest, D H and K , are placed in 1 column arrays, rows from 2 to Lrow
     Dim arrD() As Variant, arrH() As Variant, ArrK() As Variant  '  The  .Value  property used below returns its values in a field of variant type elements, so to avoiud a type mismatch we must  Dim  here appropriately
     Let arrD() = Ws1.Range("D2:D" & Lrow & "").Value: Let arrH() = Ws1.Range("H2:H" & Lrow & "").Value: Let ArrK() = Ws1.Range("K2:K" & Lrow & "").Value
    Rem 3 Manipulate  arrK()  as per requiremnt   For all data rows, we compare column H to column D. If column H is greater than column D , then we adjust the value in column K up to the nearest multiple of .05. If column H is less than column D , then we adjust the value in column K down to the nearest multiple of .05. ( If the value in column K is an exact multiple of .05, then no action is to be taken )   http://www.excelfox.com/forum/showthread.php/2457-change-the-second-number-after-decimal-conditionally?p=13099&viewfull=1#post13099
    Dim Cnt
        For Cnt = 1 To Lrow - 1 ' range is row 2 to Lrow-1, array will be 1 to Lrow-1
            If Int(Round((ArrK(Cnt, 1) / 0.05), 2)) - Round((ArrK(Cnt, 1) / 0.05), 2) = 0 Then
            ' do nothing because we have exact mulktiple of .05
            Else ' case K is not an exact multiple of .05
                If arrH(Cnt, 1) < arrD(Cnt, 1) Then
                 Let ArrK(Cnt, 1) = Int(ArrK(Cnt, 1) * 100 / 5) * 5 / 100 '    =INT(K2*100/5)*5/100     =K2*100/5    =INT(L2)   =M2*5/100   =INT(L2)*5/100   =INT(K2*100/5)*5/100   http://www.excelfox.com/forum/showthread.php/2457-change-the-second-number-after-decimal-conditionally?p=13100&viewfull=1#post13100
                ElseIf arrH(Cnt, 1) > arrD(Cnt, 1) Then
                 Let ArrK(Cnt, 1) = (Int(ArrK(Cnt, 1) * 100 / 5) * 5 / 100) + 0.05
                Else ' case H = D
                 Let ArrK(Cnt, 1) = "H is equal to D"
    Rem 4 Paste out modified array over original values
     Let Ws1.Range("K2:K" & Lrow & "").Value = ArrK()
    After running that macro the arrK() contents change to
    1090.65
    147.95
    264.5
    30
    And that is then pasted out into the range
    K
    264.5
    30
    In support of this Thread
    http://www.excelfox.com/forum/showth...d-paste-by-vba
    1.xls
    A		B			C		D	E	F	G	H	I	J	K	L
    Exchange		Symbol			Series/Expiry		Open	High	Low 	Prev Close	LTP
    NSE		ACC			EQ		1182	1193	1151.7	1156.6	1156.6	22	11.566	116815	1168.166
    NSE		ADANIENT			EQ		137.15	140.55	134.1	134.65	134.65	25	1.3465	13595	135.9965
    NSE		ADANIPORTS			EQ		273.95	276.95	269.55	270.65	270.65	15083	2.7065	27335	273.3565
    NSE		ADANIPOWER			EQ		32.3	32.35	30.45	30.65	30.65	17388	0.3065	3095	30.9565
    NSE		AMARAJABAT			EQ		555	555	529.25	532.1	532.1	100	5.321	5374	537.421
    NSE		ASIANPAINT			EQ		1815.05	1842.8	1814	1827.55	1827.55	236	18.2755	18093	1809.2745
    NSE		AMBUJACEM			EQ		169.9	171.6	166.2	167.95	167.95	1270	1.6795	1696	169.6295
    NSE		APOLLOHOSP			EQ		1360	1377.5	1341.1	1359.5	1359.5	157	13.595	137305	1373.095
    NSE		APOLLOPIPE			EQ		277.55	284	277.4	280.15	280.15	14361	2.8015	27735	277.3485
    NSE		ASHOKLEY			EQ		46	46.3	44.6	44.95	44.95	212	0.4495	4535	45.3995
    NSE		AUROPHARMA			EQ		629.05	654.5	618.5	624.45	624.45	275	6.2445	63065	630.6945
    NSE		AXISBANK			EQ		416	419.65	401.25	403.95	403.95	5900	4.0395	40795	407.9895
    NSE		BAJAJ-AUTO			EQ		2410	2472	2381	2445.35	2445.35	16669	24.4535	24209	2420.8965
    NSE		BAJAJFINSV			EQ		4675	4675	4365	4389.8	4389.8	16675	43.898	443365	4433.698
    NSE		BAJFINANCE			EQ		2113.5	2113.5	1970.05	1976.25	1976.25	317	19.7625	199601.25	1996.0125
    NSE		BALKRISIND			EQ		879	887.5	856.7	867.75	867.75	335	8.6775	8764	876.4275
    NSE		BANKBARODA			EQ		47.65	48	46.1	46.35	46.35	4668	0.4635	468	46.8135
    NSE		BATAINDIA			EQ		1258	1313	1230	1239.55	1239.55	371	12.3955	12519	1251.9455
    NSE		BEL			EQ		75.1	77.7	73.35	74.55	74.55	383	0.7455	7525	75.2955
    NSE		BERGEPAINT			EQ		521	535	515	519.7	519.7	404	5.197	52485	524.897
    NSE		BHARATFORG			EQ		251.1	265	251.1	263.25	263.25	422	2.6325	26065	260.6175
    NSE		BHARTIARTL			EQ		494.9	499	484.45	494.25	494.25	10604	4.9425	49915	499.1925
    NSE		BHEL			EQ		21.1	21.4	20.6	20.65	20.65	438	0.2065	2085	20.8565
    NSE		BIOCON			EQ		346	360	339	357.4	357.4	11373	3.574	35385	353.826
    NSE		BOSCHLTD			EQ		10470	10500	10100	10212.45	10212.45	2181	102.1245	1031455	10314.5745
    NSE		BPCL			EQ		352	356.65	347	350.45	350.45	526	3.5045	35395	353.9545
    NSE		BRITANNIA			EQ		2980	3122.9	2956	3062.15	3062.15	547	30.6215	303155	3031.5285
    NSE		CADILAHC			EQ		333.25	344	330.9	336.95	336.95	7929	3.3695	3336	333.5805
    NSE		CANBK			EQ		82.55	84.7	81.05	81.35	81.35	10794	0.8135	8215	82.1635
    NSE		CASTROLIND			EQ		124.15	127	119.3	120.7	120.7	1250	1.207	1219	121.907
    NSE		CENTURYTEX			EQ		289.2	298.5	282	284.05	284.05	625	2.8405	28685	286.8905
    NSE		CESC			EQ		603	609.5	590.95	596.75	596.75	628	5.9675	6027	602.7175
    NSE		CHOLAFIN			EQ		145	145.8	132.05	132.9	132.9	685	1.329	1342	134.229
    NSE		CIPLA			EQ		586.4	606	583.6	599.3	599.3	694	5.993	59335	593.307
    NSE		COALINDIA			EQ		140.6	143.8	135.8	137	137	20374	1.37	13835	138.37
    NSE		COLPAL			EQ		1470	1497.95	1463.6	1483.65	1483.65	15141	14.8365	146885	1468.8135
    NSE		CONCOR			EQ		368	376.6	359.5	361.1	361.1	4749	3.611	3647	364.711
    NSE		CUMMINSIND			EQ		420.95	426.55	377.25	384.95	384.95	1901	3.8495	38875	388.7995
    NSE		DABUR			EQ		499	503.75	494.5	499.05	499.05	772	4.9905	4941	494.0595
    NSE		DISHTV			EQ		5.1	5.15	4.75	4.75	4.75		0.0475	475	4.7975
    NSE		DIVISLAB			EQ		2410	2460	2390.6	2425.4	2425.4	10940	24.254	240115	2401.146
    NSE		DLF			EQ		135	135	127.6	128.2	128.2	14732	1.282	12945	129.482
    NSE		DRREDDY			EQ		4010	4049.6	3970.1	4002.8	4002.8	881	40.028	40428	4042.828
    NSE		EICHERMOT			EQ		14068	14091	13505.1	13589.2	13589.2	910	135.892	1372505	13725.092
    NSE		EQUITAS			EQ		53.85	56.4	50.65	51.05	51.05	16852	0.5105	5155	51.5605
    NSE		ESCORTS			EQ		744	758.7	712.2	717	717	958	7.17	72415	724.17
    NSE		EXIDEIND			EQ		146.3	151.8	145.15	148.45	148.45	676	1.4845	14696.55	146.9655
    NSE		FEDERALBNK			EQ		44	44.2	42.9	43.1	43.1	1023	0.431	435	43.531
    NSE		GAIL			EQ		82.95	84.25	79	81.5	81.5	4717	0.815	823	82.315
    NSE		GLENMARK			EQ		342.7	360.95	342	344.85	344.85	7406	3.4485	34145	341.4015
    NSE		GMRINFRA			EQ		17.5	17.5	17	17.15	17.15	13528	0.1715	173	17.3215
    NSE		GODREJCP			EQ		536.95	547.1	530.05	534.4	534.4	10099	5.344	5397	539.744
    NSE		GRASIM			EQ		492	501.9	484.75	499.05	499.05	1232	4.9905	4941	494.0595
    NSE		HAVELLS			EQ		524	537	517.1	525.6	525.6	9819	5.256	52035	520.344
    NSE		HCLTECH			EQ		480	496.9	465.15	468.1	468.1	7229	4.681	47275	472.781
    NSE		HDFC			EQ		1603	1624.95	1569.1	1580.3	1580.3	1330	15.803	15961	1596.103
    NSE		HDFCBANK			EQ		933	958.4	926	938.05	938.05	1333	9.3805	9287	928.6695
    NSE		HEROMOTOCO			EQ		1842.5	1939.4	1840	1894.8	1894.8	1348	18.948	18759	1875.852
    NSE		HINDALCO			EQ		109.95	109.95	102.85	103.65	103.65	1363	1.0365	10465	104.6865
    NSE		HINDPETRO			EQ		208.75	208.75	200	201.4	201.4	1406	2.014	2034	203.414
    NSE		HINDUNILVR			EQ		2311	2338	2280	2283.1	2283.1	1394	22.831	23059	2305.931
    NSE		IBULHSGFIN			EQ		114	118.4	111	112.95	112.95	30125	1.1295	11405	114.0795
    NSE		ICICIBANK			EQ		337.9	343.25	331.5	334.85	334.85	4963	3.3485	33815	338.1985
    NSE		ICICIPRULI			EQ		348	356.8	329.4	336.55	336.55	18652	3.3655	3399	339.9155
    NSE		IDEA			EQ		4.25	4.25	3.95	4	4	14366	0.04	404	4.04
    NSE		IDFCFIRSTB			EQ		23.35	23.4	22.1	22.2	22.2	11184	0.222	224	22.422
    NSE		IGL			EQ		446	455.7	430	437.25	437.25	11262	4.3725	4416	441.6225
    NSE		INDIGO			EQ		930	938.55	878.75	891.75	891.75	11195	8.9175	90065	900.6675
    NSE		INDUSINDBK			EQ		392.25	399.9	380	382.9	382.9	5258	3.829	3867	386.729
    NSE		INFRATEL			EQ		169	172.9	149.5	152	152	29135	1.52	1535	153.52
    NSE		INFY			EQ		668.55	675	654.8	658	658	1594	6.58	66455	664.58
    NSE		IOC			EQ		82.25	84.4	81.1	81.5	81.5	1624	0.815	823	82.315
    NSE		ITC			EQ		181	182.8	179.3	180.05	180.05	1660	1.8005	18185	181.8505
    NSE		JINDALSTEL			EQ		85	87	78.25	79.15	79.15	6733	0.7915	799	79.9415
    NSE		JSWSTEEL			EQ		157.5	159.5	152.6	153.25	153.25	11723	1.5325	15475	154.7825
    NSE		JUBLFOOD			EQ		1484	1494.7	1444.45	1478.7	1478.7	18096	14.787	149345	1493.487
    NSE		JUSTDIAL			EQ		343	349.85	327	329.8	329.8	29962	3.298	33305	333.098
    NSE		KOTAKBANK			EQ		1219	1258	1213.35	1239.55	1239.55	1922	12.3955	12272	1227.1545
    NSE		L&TFH			EQ		58.5	60.2	58.05	58.95	58.95	24948	0.5895	584	58.3605
    NSE		LICHSGFIN			EQ		280	281	259.15	260.65	260.65	1997	2.6065	26325	263.2565
    NSE		LT			EQ		838	869	834.15	851.2	851.2	11483	8.512	8427	842.688
    NSE		LUPIN			EQ		824.7	891	820.7	877.35	877.35	10440	8.7735	8686	868.5765
    NSE		M&M			EQ		342	344.75	332	334.3	334.3	2031	3.343	3376	337.643
    NSE		M&MFIN			EQ		150	150	138.2	140.45	140.45	13285	1.4045	14185	141.8545
    NSE		MANAPPURAM			EQ		106	108.1	104.05	107.1	107.1	19061	1.071	10605	106.029
    NSE		MARICO			EQ		300.9	309.55	300	306.1	306.1	4067	3.061	30305	303.039
    NSE		MARUTI			EQ		5100	5140	5030	5045.65	5045.65	10999	50.4565	50961	5096.1065
    NSE		MCDOWELL-N			EQ		524.9	527.9	516.7	519.5	519.5	10447	5.195	52465	524.695
    NSE		MFSL			EQ		415	432.75	400.55	420.15	420.15	2142	4.2015	41595	415.9485
    NSE		MGL			EQ		912	936.95	890	913.05	913.05	17534	9.1305	90395	903.9195
    NSE		MINDTREE			EQ		770.75	785	755	780.35	780.35	14356	7.8035	77255	772.5465
    NSE		MOTHERSUMI			EQ		72.4	74.25	71.35	72	72	4204	0.72	727	72.72
    NSE		MRF			EQ		58225	59200	58000	58805.4	58805.4	2277	588.054	5821735	58217.346
    NSE		MUTHOOTFIN			EQ		809.4	834	798.05	813.95	813.95	23650	8.1395	80585	805.8105
    NSE		NATIONALUM			EQ		33.75	34.9	30.55	31.5	31.5	6364	0.315	318	31.815
    NSE		NBCC			EQ		20.5	20.6	18.9	19.25	19.25	31415	0.1925	194	19.4425
    NSE		NCC			EQ		25.45	25.8	24.4	24.6	24.6	2319	0.246	248	24.846
    NSE		NESTLEIND			EQ		17300	17800	17300	17406.05	17406.05	17963	174.0605	1723198.95	17231.9895
    NSE		NIITTECH			EQ		1181	1199	1085.25	1116.1	1116.1	11543	11.161	112725	1127.261
    NSE		NMDC			EQ		76.7	77.9	73.4	73.8	73.8	15332	0.738	745	74.538
    NSE		NTPC			EQ		94.75	96.35	91.95	93.4	93.4	11630	0.934	943	94.334
    NSE		OIL			EQ		86	88.6	83.5	83.85	83.85	17438	0.8385	8465	84.6885
    NSE		ONGC			EQ		67.15	69.5	66.6	67.6	67.6	2475	0.676	6695	66.924
    NSE		PAGEIND			EQ		17550	17970	17460	17854.35	17854.35	14413	178.5435	1767585	17675.8065
    NSE		PEL			EQ		815	877.45	808.1	864.45	864.45	2412	8.6445	85585	855.8055
    NSE		PETRONET			EQ		220	222.95	215.75	218.5	218.5	11351	2.185	22065	220.685
    NSE		PFC			EQ		90.7	94.35	89.6	91.05	91.05	14299	0.9105	9015	90.1395
    NSE		PIDILITIND			EQ		1532.1	1576.8	1500.15	1505.2	1505.2	2664	15.052	152025	1520.252
    NSE		PNB			EQ		30.7	31.1	30.15	30.2	30.2	10666	0.302	305	30.502
    NSE		POWERGRID			EQ		157	160.1	155.75	159.15	159.15	14977	1.5915	1576	157.5585
    NSE		PVR			EQ		973	989.4	950	954.6	954.6	13147	9.546	9641	964.146
    NSE		RAMCOCEM			EQ		569.5	584.4	534	538.05	538.05	2043	5.3805	5434	543.4305
    NSE		RBLBANK			EQ		104.5	110.7	101.7	107.15	107.15	18391	1.0715	1061	106.0785
    NSE		RECLTD			EQ		90.65	93.4	89.1	89.35	89.35	15355	0.8935	902	90.2435
    NSE		RELIANCE			EQ		1350.15	1494.95	1347.2	1417	1417	2885	14.17	140285	1402.83
    NSE		SAIL			EQ		26	27.35	25.8	26.9	26.9	2963	0.269	2665	26.631
    NSE		SBIN			EQ		184	184	179	179.75	179.75	3045	1.7975	1815	181.5475
    NSE		SHREECEM			EQ		18739	18927.3	18382.55	18587.45	18587.45	3103	185.8745	187733	18773.3245
    NSE		SIEMENS			EQ		1159	1203.7	1135	1145.9	1145.9	3150	11.459	115735	1157.359
    NSE		SRF			EQ		3602	3660.8	3470	3488.05	3488.05	3273	34.8805	35229	3522.9305
    NSE		SRTRANSFIN			EQ		610	699	579.25	668.2	668.2	4306	6.682	66155	661.518
    NSE		SUNPHARMA			EQ		476.95	497	473.55	485.55	485.55	3351	4.8555	4807	480.6945
    NSE		SUNTV			EQ		368.7	385.45	366.5	376.9	376.9	13404	3.769	37315	373.131
    NSE		TATACHEM			EQ		263.4	273	255.35	270.05	270.05	3405	2.7005	26735	267.3495
    NSE		TATAMOTORS			EQ		75	76.9	74	74.2	74.2	3456	0.742	749	74.942
    NSE		TATAMTRDVR			EQ		34.3	34.95	33.5	33.7	33.7	16965	0.337	3403.7	34.037
    NSE		TATAPOWER			EQ		32.6	32.6	30.8	31.05	31.05	3426	0.3105	3135	31.3605
    NSE		TATASTEEL			EQ		266.3	273.85	264.45	267.55	267.55	3499	2.6755	2649	264.8745
    NSE		TCS			EQ		1840.7	1851.95	1807.8	1818.55	1818.55	11536	18.1855	18367	1836.7355
    NSE		TECHM			EQ		522	532.6	502.1	503.45	503.45	13538	5.0345	50845	508.4845
    NSE		TITAN			EQ		910	926.9	893.1	906.05	906.05	3506	9.0605	9151	915.1105
    NSE		TORNTPHARM			EQ		2430	2488	2361.65	2430.5	2430.5	3518	24.305	24062	2406.195
    NSE		TORNTPOWER			EQ		297.5	307.9	296.65	303.8	303.8	13786	3.038	3008	300.762
    NSE		TVSMOTOR			EQ		298	302	289.05	297	297	8479	2.97	29995	299.97
    NSE		UBL			EQ		921	922.5	863.85	880.75	880.75	16713	8.8075	88955	889.5575
    NSE		UJJIVAN			EQ		170	173.5	161.6	164.1	164.1	17069	1.641	1657	165.741
    NSE		ULTRACEMCO			EQ		3410	3440	3292.8	3307.95	3307.95	11532	33.0795	334102.95	3341.0295
    NSE		UPL			EQ		345	347.6	334.2	335.85	335.85	11287	3.3585	3392	339.2085
    NSE		VEDL			EQ		76.8	80.25	75.7	77.95	77.95	3063	0.7795	772	77.1705
    NSE		VOLTAS			EQ		500	505	485	487.15	487.15	3718	4.8715	49202.15	492.0215
    NSE		WIPRO			EQ		179.95	180.8	177.15	177.75	177.75	3787	1.7775	1795	179.5275
    NSE		ZEEL			EQ		150.8	152.85	143	145.15	145.15	3812	1.4515	1466	146.6015
    Shortened
    http://www.excelfox.com/forum/showth...ll=1#post13126
    _____ Workbook: 1 26Apr.xls ( Using Excel 2007 32 bit )
    J
    K
    L
    NSE ACC EQ
    1182
    1193
    1151.7
    1156.6
    1156.6
    22
    11.566
    116815
    1168.166
    NSE ADANIENT EQ
    137.15
    140.55
    134.1
    134.65
    134.65
    25
    1.3465
    13595
    135.9965
    NSE ADANIPORTS EQ
    273.95
    276.95
    269.55
    270.65
    270.65
    15083
    2.7065
    27335
    273.3565
    NSE ADANIPOWER EQ
    32.3
    32.35
    30.45
    30.65
    30.65
    17388
    0.3065
    3095
    30.9565
    NSE AMARAJABAT EQ
    555
    575
    529.25
    532.1
    570.1
    100
    5.321
    5374
    537.421
    Worksheet: 1-Sheet1
    From last post
    Before
    _____ Workbook: Alert.txt ( Using Excel 2007 32 bit )
    NSE
    14361
    NSE
    25
    NSE
    15083
    NSE
    17388
    NSE
    100
    NSE
    22
    Worksheet: Alert
    check wheather column H of 1.xls is greater or lower than column D of 1.xls
    if column H of 1.xls is greater than column D of 1.xls then match column I of 1.xls with column B of 2.csv & if it matches then put this symbol "<" in column D of 2.csv & copy paste the data of column K of 1.xls in column E of 2.csv
    if column H of 1.xls is lower than column D of 1.xls then match column I of 1.xls with column B of 2.csv & if it matches then put this symbol ">" in column D of 2.csv & copy paste the data of column K of 1.xls in column E of 2.csv
    Run macro ( from here https://www.ozgrid.com/forum/index.p...54#post1233954 )
    Sub STEP8() '   http://www.excelfox.com/forum/showthread.php/2461-copy-and-paste-by-vba?p=13126&viewfull=1#post13126
    Dim Wb1 As Workbook, Wb2 As Workbook
    Dim Ws1 As Worksheet, Ws2 As Worksheet
    Dim rg1 As Range, i As Long, c As Range
    Set Wb1 = Workbooks("1.xls")       '  Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls")
    Set Wb2 = Workbooks("Alert.txt")   '  Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Alert..csv")
    Set Ws2 = Wb2.Worksheets.Item(1)
    Set rg1 = Ws1.Cells(1, 1).CurrentRegion
        With rg1
            For i = 2 To rg1.Rows.Count
                If .Cells(i, 8) > .Cells(i, 4) Then    ' if column H of 1.xls is greater than column D of 1.xls
                Set c = Ws2.Columns(2).Find(.Cells(i, 9)) ' match column I of 1.xls with column B of 2.csv
                    If Not c Is Nothing Then 'if match found
                    c.Offset(, 2).Value = "<"          '  put this symbol "<" in column D of 2
                    c.Offset(, 3).Value = .Cells(i, 11) '  copy paste the data of column K of 1.xls in column E of 2.csv
                Else   '    if column H of 1.xls is lower than column D of 1.xls
                    c.Offset(, 2).Value = ">"            '  then put this symbol ">" in column D of 2.csv
            Next i
    After - results after running macro above
    NSE
    14361
    NSE
    25
    13595
    NSE
    15083
    27335
    NSE
    17388
    3095
    NSE
    100
    5374
    NSE
    22
    116815
    Worksheet: Alert
    1.xls : https://app.box.com/s/38aoip5xi7018y9syt0xe4g04u95l6xk
    macro.xlsm : https://app.box.com/s/599q2it3uck3hfwm5kscmmgtn0be66wt
    Alert.csv : https://app.box.com/s/4ejptbaggn67nc91yz9jhgcefm2qae0r
    In support of this post
    http://www.excelfox.com/forum/showth...ll=1#post13131
    It is not necessary to have all data to demonstrate the problem!!
    ....It is difficult in a forum to work with many rows.
    Reduce the rows
    We need just enough data to test.
    Pick your test data carefully.
    Just use a few rows. But pick your test data carefully so that it test all scenarios....
    ....make a small file with also row data that errors.
    Explain again and show me what and where the errors are….
    J
    K
    L
    M
    NSE ACC EQ
    1182
    1193
    1151.7
    1190.45
    1156.6
    22
    11.566
    116815
    1168.166
    NSE DABUR EQ
    499
    503.75
    494.5
    499
    499.05
    772
    4.9905
    4941
    494.0595
    NSE DISHTV EQ
    5.1
    5.15
    4.75
    4.95
    4.75
    0.0475
    475
    4.7975
    NSE UBL EQ
    921
    922.5
    863.85
    920
    880.75
    16713
    8.8075
    88955
    889.5575
    NSE UJJIVAN EQ
    170
    173.5
    161.6
    179.55
    164.1
    17069
    1.641
    1657
    165.741
    NSE VEDL EQ
    76.8
    80.25
    75.7
    77.6
    77.95
    3063
    0.7795
    772
    77.1705
    NSE VOLTAS EQ
    500
    505
    485
    508.2
    487.15
    3718
    4.8715
    49202.15
    492.0215
    NSE ZEEL EQ
    150.8
    152.85
    143
    157.55
    145.15
    3812
    1.4515
    1466
    146.6015
    Worksheet: 1-Sheet1 27Apr_2
    Before
    _____ Workbook: Alert.csv ( Using Excel 2007 32 bit )
    NSE
    25
    NSE
    3812
    NSE
    15083
    NSE
    22
    Worksheet: Alert.
    Run macro, then we have After results:
    NSE
    25
    NSE
    3812
    1466
    NSE
    15083
    NSE
    22
    116815
    475
    Worksheet: Alert.
    J
    Low Prev Close LTP
    1190.45
    1156.6
    22
    11.566
    499
    499.05
    772
    4.9905
    4.75
    4.95
    4.75
    0.0475
    863.85
    920
    880.75
    16713
    8.8075
    161.6
    179.55
    164.1
    17069
    1.641
    NSE
    15083
    NSE
    22
    column I of 1.xls is Empty
    column B of 2.csv is Empty
    Empty = Empty = Match
    J
    Low Prev Close LTP
    1190.45
    1156.6
    22
    11.566
    499
    499.05
    772
    4.9905
    4.75
    4.95
    4.75
    Empty
    0.0475
    863.85
    920
    880.75
    16713
    8.8075
    161.6
    179.55
    164.1
    17069
    1.641
    NSE
    15083
    NSE
    22
    Empty
    http://www.excelfox.com/forum/showth...ll=1#post13140
    Explanation of the problem
    The error is caused by bad understanding of Range.Find Method ( https://docs.microsoft.com/de-de/off...cel.range.find )
    We only need small amount of test data to demonstrate the problem:
    Consider the results of this test data
    Before:
    J
    K
    L
    M
    NSE ACC EQ
    1182
    1193
    1151.7
    1190.45
    1156.6
    22
    11.566
    116815
    1168.166
    NSE ADANIENT EQ
    137.15
    140.55
    134.1
    140.5
    134.65
    25
    1.3465
    13595
    135.9965
    NSE ADANIPORTS EQ
    273.95
    276.95
    269.55
    277.6
    270.65
    15083
    2.7065
    27335
    273.3565
    Worksheet: 1-Sheet1 27Apr_2 (2)
    _____ Workbook: AlertTestData.xlsx ( Using Excel 2007 32 bit )
    NSE
    25
    NSE
    17388
    NSE
    404
    NSE
    422
    NSE
    10604
    NSE
    438
    NSE
    10794
    NSE
    1250
    NSE
    625
    NSE
    15083
    NSE
    22
    Worksheet: Alert.
    results After
    NSE
    25
    NSE
    17388
    NSE
    404
    NSE
    422
    116815
    NSE
    10604
    NSE
    438
    NSE
    10794
    NSE
    1250
    13595
    NSE
    625
    NSE
    15083
    27335
    NSE
    22
    Worksheet: Alert.
    Those results come from using this macro here: http://www.excelfox.com/forum/showth...ll=1#post13143
    Those results arise due to this problem code line
    That code line is only using one argument for Range.Find Method
    So VBA must guess the others. It has guessed not what we want. It has guessed similar to this
    Ws2.Columns(2).Find(What:=.Cells(i, 9), After:=B1, LookAt:xlpart)
    Because of After:=B1 , it starts to look from B2 in
    Because of LookAt:xlpart , we will look for what we want anywhere inside a cell, so if we are looking for the number 25 , then all these numbers or even text could be a match
    4567256
    2500
    25
    564rghsseeffzz25adksfhaejh
    VBA will choose the first match that it finds
    For example, for our 25 it started looking from B2 in Worksheet Alert, and the first it found was 1250
    For large data, there will be many errors caused by this problem. But the problem and the solution will be the same.
    It is easier to demonstrate the problem with small test data.
    It is easier to test a solution with small test data.
    It is the responsibility of the person finally responsible for the macros in real use to take the time to check for larger amounts of real data. For getting free help in a forum , this will be the responsibility of the persom getting help.
    Share ‘1.xls’ : https://app.box.com/s/38aoip5xi7018y9syt0xe4g04u95l6xk
    Share ‘AlertTestData.xlsx’ : https://app.box.com/s/nhdxcq0ulxldebanz1lz49wr1stf1pc4
    Share ‘macro.xlsm’ : https://app.box.com/s/599q2it3uck3hfwm5kscmmgtn0be66wt
    Macro used to get the results in the last post above
    Previous macro
    https://www.ozgrid.com/forum/index.p...38#post1234138
    '  Old macro (  https://www.ozgrid.com/forum/index.php?thread/1227284-copy-and-paste-by-macro/&postID=1234138#post1234138  )
    Set Wb2 = Workbooks("AlertTestData.xlsx")  '  Workbooks("Alert.csv") ' Workbooks("Alert.txt")   '  Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Alert..csv")
        With rg1
                    If .Cells(i, 9).Value = "" Then
                    ' do nothing
                    ' do nothing
            Next i
    New macro ( for http://www.excelfox.com/forum/showth...3144#post13144 )
    Sub STEP8_AE() '   http://www.excelfox.com/forum/showthread.php/2461-copy-and-paste-by-vba?p=13126&viewfull=1#post13126
    Rem 1 Worksheets data range info
    Dim Rg1 As Range, RngSrchIn As Range
     Set Rg1 = Ws1.Cells.Item(1, 1).CurrentRegion
    Dim Lr2 As Long: Let Lr2 = Ws2.Range("B" & Ws1.Rows.Count & "").End(xlUp).Row       '   http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11466&viewfull=1#post11466      Making Lr dynamic ( using rng.End(XlUp) for a single column. )
     Set RngSrchIn = Ws2.Range("B1:B" & Lr2 & "") ' Only us as much of Column B as we need to search in for a match
    Dim Cnt
        For Cnt = 2 To Rg1.Rows.Count             ' For all rows in  1.xls
        Dim cRng As Range '2a Check for match, BUT DO IT PROPERLY!!! -    http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=13142&viewfull=1#post13142
         Set cRng = RngSrchIn.Find(What:=Ws1.Cells.Item(Cnt, 9), LookIn:=xlValues, Lookat:=xlWhole, searchorder:=xlByRows, Searchdirection:=xlNext, MatchCase:=True)
            If Not cRng Is Nothing And Not cRng.Value = "" Then
                If Ws1.Cells(Cnt, 8) > Ws1.Cells(Cnt, 4) Then      ' if column H of 1.xls is greater than column D of 1.xls
                 Let cRng.Offset(, 2).Value = "<"                  '  put this symbol "<" in column D of 2
                 Let cRng.Offset(, 3).Value = Ws1.Cells(Cnt, 11)     '  copy paste the data of column K of 1.xls in column E of 2.csv
                ElseIf Ws1.Cells(Cnt, 8) < Ws1.Cells(Cnt, 4) Then  ' if column H of 1.xls is lower than column D of 1.xls
                 Let cRng.Offset(, 2).Value = ">"                  '  then put this symbol ">" in column D of 2.csv
                ' column H of 1.xls is equal to column D of 1.xls
            Else  ' cRng is nothing so no match was found, or cell was empty
            ' do nothing
    '        If .Cells(i, 8) > .Cells(i, 4) Then   ' if column H of 1.xls is greater than column D of 1.xls
    '            If .Cells(i, 9).Value = "" Then
    '            ' do nothing
    '            Else
    '            Set c = Ws2.Columns(2).Find(.Cells(i, 9)) ' match column I of 1.xls with column B of 2.csv
    '                If Not c Is Nothing Then 'if match found
    '                c.Offset(, 2).Value = "<"          '  put this symbol "<" in column D of 2
    '                c.Offset(, 3).Value = .Cells(i, 11) '  copy paste the data of column K of 1.xls in column E of 2.csv
    '                End If
    '            End If
    '        Else   '    if column H of 1.xls is lower than column D of 1.xls
    '            ' do nothing
    '            Else
    '                c.Offset(, 2).Value = ">"            '  then put this symbol ">" in column D of 2.csv
    '                End If
    '            End If
    '        End If
    Macro for this Post
    http://www.excelfox.com/forum/showth...ed-from-Sheet1
    Sub testIt() ' http://www.excelfox.com/forum/showthread.php/2463-VBA-to-create-formula-references-and-values-in-Sheet2-that-either-reference-or-are-derived-from-Sheet1
     Call Worksheet_SelectionChange(Me.Range("B10"))
    Private Sub Worksheet_SelectionChange(ByVal Target As Range)
    Rem 1 check fo column B single cell selection, if not exit sub
        If Target.Cells.Count > 1 Or Application.Intersect(Target, Columns("B")) Is Nothing Then Exit Sub
    Rem 2 second worksheets info
    Dim Ws2 As Worksheet: Set Ws2 = ThisWorkbook.Worksheets.Item(2)
    Dim Lr2 As Long: Let Lr2 = Ws2.Range("A" & Ws2.Rows.Count & "").End(xlUp).Row
    Rem 3 insert row -  create a new row on "Sheet2" one line above the last used row and fill in the cells as follows:
     Ws2.Rows("" & Lr2 & ":" & Lr2 & "").Insert shift:=xlDown
    Rem 4 Create formulas in columns "A" ("Description") & "B" ("Item #") in "Sheet2" that have formulas that references those values from "Sheet1".
    Dim Ws1 As Worksheet: Set Ws1 = ThisWorkbook.Worksheets.Item(1)
     Let Ws2.Range("A" & Lr2 & "").Value = "=" & Ws1.Name & "!" & Target.Address(Rowabsolute:=False, columnabsolute:=False)
     Let Ws2.Range("B" & Lr2 & "").Value = "=" & Ws1.Name & "!" & Target.Offset(0, 1).Address(Rowabsolute:=False, columnabsolute:=False)
    Rem 5 create a formula in column "E" ("Gross Income") in "Sheet2".
     Let Ws2.Range("E" & Lr2 & "").Value = "=" & Ws2.Range("C" & Lr2 & "").Address(Rowabsolute:=False, columnabsolute:=False) & "*" & Ws2.Range("D" & Lr2 & "").Address(Rowabsolute:=False, columnabsolute:=False)
    Rem 6 fill in a value in column "G" ("Sugg. Retail Price") in "Sheet2" from the value in column "F" ("Sugg. Retail Price") of "Sheet1"
     Let Ws2.Range("G" & Lr2 & "").Value = Ws1.Range("D" & Target.Row & "").Value
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
