Page 24 of 57 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 570
  1. #231
    In support of these threads.
    http://www.excelfox.com/forum/showth...ge30#post12493
    http://www.excelfox.com/forum/showth...ge33#post12597
    Sub CompareDriverFilesDeviceManagerInDoubleDriverAllList2()
        If ActiveSheet.Name <> "DeviceManagerProperties" Then
         MsgBox prompt:="Oops": Exit Sub
    Rem 1 Worksheets info
    Dim WsDMP As Worksheet, WsDDA As Worksheet
     Set WsDMP = Worksheets("DeviceManagerProperties"): Set WsDDA = Worksheets("DDAllBefore")
    Rem 2 Looking at each cell in the selection
    ' Random number between 3 and 56 to get color index for any matching file names (1 is black, 2 is white , up to 56 is other colors:  3 to 56   is like  (0 to 53)+3  Rnd gives like  0-.99999  so (Int(Rnd*54))+3  is what we want
    Dim ClrIdx As Long
     Randomize: Let ClrIdx = (Int(Rnd * 54)) + 3
    Dim SrchForCel As Range
        For Each SrchForCel In Selection ' Take each cell in selected range
        Dim CelVl As String: Let CelVl = SrchForCel.Value
            If CelVl <> "" And Left(CelVl, 3) = "C:\" And InStr(4, CelVl, ".", vbBinaryCompare) > 1 Then ' use some criteria to check we have a file path
            Dim FileNmeSrchFor As String
             Let FileNmeSrchFor = Right(CelVl, (Len(CelVl)) - (InStrRev(CelVl, "\", -1, vbBinaryCompare))) ' Determine the file name as that looking from the right as many characters as (the total character number) - (the position looking from the right of a "\")
            Rem 3 We now should have a file name, so we look for it in worksheet  DDAllBefore
            Dim SrchRng As Range: Set SrchRng = Application.Range("=DDAllBefore!F5:DDAllBefore!G670")    ' WsDDA.Range("=F5:G670")
            Dim FndCel As Range
             Set FndCel = SrchRng.Find(what:=FileNmeSrchFor, After:=Application.Range("=DDAllBefore!F5"), LookAt:=xlPart, searchorder:=xlNext, MatchCase:=False) '
                If Not FndCel Is Nothing Then ' the range is set, so the file string has been found in a cell in  DDAllBefore
                Rem 4 we have two matching cells
                 'Debug.Print FndCel.Value
                '4b) color matching file names in each worksheet, we do the unecerssary activating and selecting so we can see what is going in
                 WsDMP.Activate: SrchForCel.Select
                 Application.Wait (Now + TimeValue("00:00:01"))
                 'Let SrchForCel.Characters(((InStrRev(CelVl, "\", -1, vbBinaryCompare)) + 1), (Len(CelVl)) - (InStrRev(CelVl, "\", -1, vbBinaryCompare))).Font.ColorIndex = ClrIdx
                 Let SrchForCel.Font.ColorIndex = ClrIdx
                 WsDDA.Activate: FndCel.Select
                 Let FndCel.Font.ColorIndex = ClrIdx
                Else ' No match was found - the thing in the cell in
            Else ' case no file path string in cell
        Next SrchForCel
    For
    http://www.excelfox.com/forum/showth...ge30#post12492
    In support of this post:
    http://www.excelfox.com/forum/showth...ge36#post12628
    Note a new modification... for the case of when a cell in Device Manger is coloured ( indicating a match to drivers ) but the case when no match is found in DriverStore. We then need to make the underline which we are using as an indication for a match to drivers
                Else ' No match was found - the thing in the cell in this worksheet is not in the other worksheet
                    If SrchForCel.Font.Color <> 0 Then Let SrchForCel.Font.Underline = True 'we need an extra check for if the cell is already coluoured indicating a match in drivers
    Sub CompareDriverFilesDeviceManagerInDriverStore2() '
    Dim WsDMP As Worksheet, WsDrSt As Worksheet
     Set WsDMP = Worksheets("DeviceManagerProperties"): Set WsDrSt = Worksheets("DriverStore")
    Dim ClrIdx As Long
        For Each SrchForCel In Selection ' Take each cell in selected range. Each should be a cell in DeviceManagerProperties
             Let FileNmeSrchFor = Right(CelVl, (Len(CelVl)) - (InStrRev(CelVl, "\", -1, vbBinaryCompare))) ' Determine the file name as that looking from the right as many characters as (the total character number) - (the position looking from the right of a "\")  ---   the characters count left over after the subtraction is equal to the character length of the file name
            Dim SrchRng As Range: Set SrchRng = Application.Range("=DriverStore!D5:DriverStore!F4437")    '
            Dim FndCel As Range: Set FndCel = SrchRng.Find(what:=FileNmeSrchFor, After:=Application.Range("=DriverStore!D5"), LookAt:=xlPart, searchorder:=xlNext, MatchCase:=False) '
                '4a) but we might already have a match,
                    If SrchForCel.Font.Color <> 0 Then ' Extra things to do if we already found the cell value in drivers
                     Let ClrIdx = SrchForCel.Font.ColorIndex ' this will make the line below to colorthe text of this cell redundant but will ensure that we use the same color in the DriverStore worksheet rather than the randomly generated one
                  Do While Not FndCel Is Nothing ' Start Find next loop ======
                    WsDMP.Activate: SrchForCel.Select ' This worksheet will be colured
                    Let SrchForCel.Font.Italic = True
                    WsDrSt.Activate: FndCel.Select ' the other workseet
                    Application.Wait (Now + TimeValue("00:00:02"))
                  Set FndCel = Application.Range("=DriverStore!D" & FndCel.Row + 1 & ":DriverStore!F4437").Find(what:=FileNmeSrchFor, After:=Application.Range("=DriverStore!F4437"), LookIn:=xlValues, LookAt:=xlPart, searchorder:=xlByRows, SearchDirection:=xlNext, MatchCase:=False)  '
                  Loop  '  End Find next loop =================================
        Next SrchForCel
    In support of this Post
    http://www.excelfox.com/forum/showth...ge39#post12659
    Sub FileTypesHereInDeviceManagerPropertiesUndDriverStoreUnddrivers2() '   http://www.excelfox.com/forum/showthread.php/2408-Windows-10-and-Office-Excel/page39#post12659                                http://www.excelfox.com/forum/showthread.php/2408-Windows-10-and-Office-Excel/page18#post12360
    Dim Ws As Worksheet: Set Ws = Me
    Dim Rng As Range: Set Rng = Ws.Range("D2:F264")
    'Dim arrFiles() As Variant: Let arrFiles() = Rng.Value2
    Rem 2 File extension types
    Dim Ddl As Long, Sys As Long, Bin As Long, Cpa As Long, Vp As Long, Els As Long
    Dim Ddl2 As Long, Sys2 As Long, Bin2 As Long, Cpa2 As Long, Vp2 As Long, Els2 As Long
    Dim Ddl3 As Long, Sys3 As Long, Bin3 As Long, Cpa3 As Long, Vp3 As Long, Els3 As Long
    Rem 3 Looping
    'Dim ClCnt As Long, RwCnt As Long
    Dim rngStr As Range ' a single cell to use as a stear element in the For Next loop
        For Each rngStr In Rng
    '    For RwCnt = 1 To UBound(arrFiles(), 1)
    '        For ClCnt = 1 To UBound(arrFiles(), 2)
                'If arrFiles(RwCnt, ClCnt) = "" Then
                If rngStr.Value = "" Then
                ' Empty cell, so do nothing
                Else ' Time to look at cell value
                    'If Left(arrFiles(RwCnt, ClCnt), 3) = "C:\" And InStr(4, arrFiles(RwCnt, ClCnt), ".", vbBinaryCompare) > 1 Then ' use some criteria to check we have a file path
                    If Left(rngStr.Value, 3) = "C:\" And InStr(4, rngStr.Value, ".", vbBinaryCompare) > 1 Then ' use some criteria to check we have a file path
                    ' Get the extension
                    Dim Xtn As String
                    'Let Xtn = Mid(arrFiles(RwCnt, ClCnt), (InStr(4, arrFiles(RwCnt, ClCnt), ".", vbBinaryCompare) + 1))
                     Let Xtn = Mid(rngStr.Value, (InStr(4, rngStr.Value, ".", vbBinaryCompare) + 1))
                        Select Case UCase(Xtn)
                         Case "SYS"
                          Let Sys = Sys + 1
                          If rngStr.Font.Italic = True Then Let Sys2 = Sys2 + 1
                          If rngStr.Font.Underline = xlUnderlineStyleSingle Then Let Sys3 = Sys3 + 1
                         Case "DLL"
                          Let Ddl = Ddl + 1
                          If rngStr.Font.Italic = True Then Let Ddl2 = Ddl2 + 1
                          If rngStr.Font.Underline = xlUnderlineStyleSingle Then Let Ddl3 = Ddl3 + 1
                         Case "BIN"
                          Let Bin = Bin + 1
                          If rngStr.Font.Italic = True Then Let Bin2 = Bin2 + 1
                          If rngStr.Font.Underline = xlUnderlineStyleSingle Then Let Bin3 = Bin3 + 1
                         Case "CPA"
                          Let Cpa = Cpa + 1
                          If rngStr.Font.Italic = True Then Let Cpa2 = Cpa2 + 1
                          If rngStr.Font.Underline = xlUnderlineStyleSingle Then Let Cpa3 = Cpa3 + 1
                         Case "VP"
                          Let Vp = Vp + 1
                          If rngStr.Font.Italic = True Then Let Vp2 = Vp2 + 1
                          If rngStr.Font.Underline = xlUnderlineStyleSingle Then Let Vp3 = Vp3 + 1
                         Case Else
                          Debug.Print "Case Else   " & rngStr.Value
                          Let Els = Els + 1
                          If rngStr.Font.Italic = True Then Let Els2 = Els2 + 1
                          If rngStr.Font.Underline = xlUnderlineStyleSingle Then Let Els3 = Els3 + 1
                    Else ' not a file path
    '        Next ClCnt
    '    Next RwCnt
        Next rngStr
    Rem 4 output
    Debug.Print "sys     " & Sys & " (" & Sys2 & ")   [" & Sys3 & "]"
    Debug.Print "dll     " & Ddl & " (" & Ddl2 & ")   [" & Ddl3 & "]"
    Debug.Print "bin     " & Bin & " (" & Bin2 & ")   [" & Bin3 & "]"
    Debug.Print "cpa     " & Cpa & " (" & Cpa2 & ")   [" & Cpa3 & "]"
    Debug.Print "vp      " & Vp & " (" & Vp2 & ")    [" & Vp3 & "]"
    Debug.Print "els     " & Els & " (" & Els2 & ")   [" & Els3 & "]"
    Debug.Print "Totals " & Sys + Ddl + Bin + Cpa + Vp + Els & " (" & Sys2 + Ddl2 + Bin2 + Cpa2 + Vp2 + Els2 & ") [" & Sys3 + Ddl3 + Bin3 + Cpa3 + Vp3 + Els3 & "]"
    In support of this Thread answer
    http://www.eileenslounge.com/viewtop...=34247#p265646
    Sub DDAllEarlier_Marz172020()  '    http://www.eileenslounge.com/viewtopic.php?f=55&t=34247#p265646
    Dim WsDDD As Worksheet: Set WsDDD = Worksheets("DDAllEarlier_Marz17")
    Dim RngDD As Range, rngDB As Range  '     =ANZAHL2(B2:B550) 255         =ANZAHL2(D2:D550)    366
     Set RngDD = WsDDD.Range("B2:B550"): Set rngDB = WsDDD.Range("D2:D550")
    ' take each cell in column B range and find it in column D, but find next if the text is already coloured
    Dim Rng As Range
        For Each Rng In RngDD '----------------------|
            If Rng <> "" Then
            Dim ClrIdx As Long: Randomize: Let ClrIdx = (Int(Rnd * 54)) + 3
            Dim FndRng As Range
             Set FndRng = rngDB.Find(what:=Rng.Value, After:=rngDB.Cells.Item(1), LookAt:=xlPart, searchorder:=xlNext, MatchCase:=False) '
                If Not FndRng Is Nothing Then ' we have a match that may or may not have already been found.
                    Do While Not FndRng Is Nothing ' ===
                        If FndRng.Font.Color = 0 Then ' case "virgin black" text
                         FndRng.Select
                         Let FndRng.Font.ColorIndex = ClrIdx
                         Rng.Select
                         Let Rng.Font.ColorIndex = ClrIdx
                         Set FndRng = Nothing ' This will force the Loop to end after a succesful match
                        Else ' The cell text is already colored, so try again
                         Set FndRng = WsDDD.Range("D" & FndRng.Row + 1 & ":D550").Find(what:=Rng.Value, After:=WsDDD.Range("D550"), LookIn:=xlValues, LookAt:=xlPart, searchorder:=xlByRows, SearchDirection:=xlNext, MatchCase:=False)  '   https://stackoverflow.com/questions/49094391/excel-vba-range-findnext-v-range-find-what-have-i-missed/49181464#49181464
                    Loop ' looping for next match ======
                Else ' no cell value match
            Else ' case rng has not text in it
        Next Rng  ' Each Rng In RngDD ---------------|
    In support of these posts
    http://www.excelfox.com/forum/showth...ge40#post12669
    ' _   Marz 2020
    Sub DeviceManagerPropertiesMarz172020()  '    http://www.eileenslounge.com/viewtopic.php?f=55&t=34247#p265646
    Dim WsDMP As Worksheet: Set WsDMP = Worksheets("DeviceManagerProperties")
    Dim rngDMP1 As Range, rngDMP2 As Range  '           B1:F550          G1:J550
     Set rngDMP1 = WsDMP.Range("B5:F550"): Set rngDMP2 = WsDMP.Range("G5:J550")
    ' take each cell in range for original DMP and find it in range for new DMP but find next if the interior is already coloured
    Dim Rng As Range
        For Each Rng In rngDMP1 '----------------------|
            If Rng <> "" Then
            Dim FndRng As Range
             Set FndRng = rngDMP2.Find(what:=Rng.Value, After:=rngDMP2.Cells.Item(1), LookAt:=xlPart, searchorder:=xlNext, MatchCase:=False) '
                        If FndRng.Interior.ColorIndex = -4142 Then  ' case "virgin "white"" text
                         FndRng.Select
                         Let FndRng.Interior.ColorIndex = ClrIdx
                         Rng.Select
                         Let Rng.Interior.ColorIndex = ClrIdx
                        Else ' The cell already has background color, so try again from next row
                         Set FndRng = WsDMP.Range("G" & FndRng.Row + 1 & ":J550").Find(what:=Rng.Value, After:=WsDMP.Range("J550"), LookIn:=xlValues, LookAt:=xlPart, searchorder:=xlByRows, SearchDirection:=xlNext, MatchCase:=False)  '   https://stackoverflow.com/questions/49094391/excel-vba-range-findnext-v-range-find-what-have-i-missed/49181464#49181464
        Next Rng '------------------------------------|
    ExplorerBefore DeviceManager Earlier and Marz17 2020.xlsm : https://app.box.com/s/gsgwwbqggel397ufnruegjyfst51p3g6
    http://www.excelfox.com/forum/showth...ge40#post12670
    ' Marz 2020
    Private Sub FileTypesHere_And_MaybeAlsoInDeviceManager()
    Dim Rng As Range: Set Rng = Ws.Range("D4:E300") 'Set Rng = Ws.Range("F4:G300") ' Set Rng = Ws.Range("D4:E75")
    Dim Bag As Long, Xml As Long, Js As Long, Gdl As Long, Cab As Long, Ini As Long
    Dim Cat As Long, Inf As Long, Pnf As Long, Gpd As Long, Exe As Long
    Dim Bag2 As Long, Xml2 As Long, Js2 As Long, Gdl2 As Long, Cab2 As Long, Ini2 As Long
    Dim Cat2 As Long, Inf2 As Long, Pnf2 As Long, Gpd2 As Long, Exe2 As Long
    Dim Dpb As Long, Ppd As Long
    Dim Dpb2 As Long, Ppd2 As Long
    Rem 3 Looping
    Dim rngStr As Range
    '                If Left(arrFiles(RwCnt, ClCnt), 3) = "C:\" And InStr(4, arrFiles(RwCnt, ClCnt), ".", vbBinaryCompare) > 1 Then ' use some criteria to check we have a file path
                    'If InStr(2, arrFiles(RwCnt, ClCnt), ".", vbBinaryCompare) > 1 Then ' use some criteria to check we have a file path
                    If InStr(2, rngStr.Value, ".", vbBinaryCompare) > 1 Then ' use some criteria to check we have a file path
                    ' Get the extension
                    Dim Xtn As String
                     'Let Xtn = Mid(arrFiles(RwCnt, ClCnt), (InStr(2, arrFiles(RwCnt, ClCnt), ".", vbBinaryCompare) + 1))
                     Let Xtn = Mid(rngStr.Value, (InStr(2, rngStr.Value, ".", vbBinaryCompare) + 1))
                         Case "SYS"
                          Let Sys = Sys + 1: If rngStr.Font.Color <> 0 Then Let Sys2 = Sys2 + 1
                         Case "DLL"
                          Let Ddl = Ddl + 1: If rngStr.Font.Color <> 0 Then Let Ddl2 = Ddl2 + 1
                         Case "BIN"
                          Let Bin = Bin + 1: If rngStr.Font.Color <> 0 Then Let Bin2 = Bin2 + 1
                         Case "CPA"
                          Let Cpa = Cpa + 1: If rngStr.Font.Color <> 0 Then Let Cpa2 = Cpa2 + 1
                         Case "VP"
                          Let Vp = Vp + 1: If rngStr.Font.Color <> 0 Then Let Vp2 = Vp2 + 1
                         'Dim Bag As Long, Xml As Long, Js As Long, Gdl As Long, Cab As Long, Ini As Long, Cat As Long
                         Case "BAG"
                          Let Bag = Bag + 1: If rngStr.Font.Color <> 0 Then Let Bag2 = Bag2 + 1
                         Case "XML"
                          Let Xml = Xml + 1: If rngStr.Font.Color <> 0 Then Let Xml2 = Xml2 + 1
                         Case "JS"
                          Let Js = Js + 1: If rngStr.Font.Color <> 0 Then Let Js2 = Js2 + 1
                         Case "GDL"
                          Let Gdl = Gdl + 1: If rngStr.Font.Color <> 0 Then Let Gdl2 = Gdl2 + 1
                         Case "CAB"
                          Let Cab = Cab + 1: If rngStr.Font.Color <> 0 Then Let Cab2 = Cab2 + 1
                         Case "INI"
                          Let Ini = Ini + 1: If rngStr.Font.Color <> 0 Then Let Ini2 = Ini2 + 1
                         Case "CAT"
                          Let Cat = Cat + 1: If rngStr.Font.Color <> 0 Then Let Cat2 = Cat2 + 1
                         ' Inf As Long, Pnf As Long, Gpd As Long, Exe as long
                         Case "INF"
                          Let Inf = Inf + 1: If rngStr.Font.Color <> 0 Then Let Inf2 = Inf2 + 1
                         Case "PNF"
                          Let Pnf = Pnf + 1: If rngStr.Font.Color <> 0 Then Let Pnf2 = Pnf2 + 1
                         Case "GPD"
                          Let Gpd = Gpd + 1: If rngStr.Font.Color <> 0 Then Let Gpd2 = Gpd2 + 1
                         Case "EXE"
                          Let Exe = Exe + 1: If rngStr.Font.Color <> 0 Then Let Exe2 = Exe2 + 1
                         ' Dim Dpb As Long, Ppd As Long
                         Case "DPB"
                          Let Dpb = Dpb + 1: If rngStr.Font.Color <> 0 Then Let Dpb2 = Dpb2 + 1
                         Case "PPD"
                          Let Ppd = Ppd + 1: If rngStr.Font.Color <> 0 Then Let Ppd2 = Ppd2 + 1
                         Case Else
                          Debug.Print "Case Else   " & rngStr.Value ' arrFiles(RwCnt, ClCnt)
                          Let Els = Els + 1
                    Else ' not a file path, or rather not a  .  in
                    Dim Fldr As Long: Let Fldr = Fldr + 1
    '        Next ClCnt
    '    Next RwCnt
        Next rngStr
    Rem 4 output
    Debug.Print "sys   " & Sys & " (" & Sys2 & ")"
    Debug.Print "dll   " & Ddl & " (" & Ddl2 & ")"
    Debug.Print "bin   " & Bin & " (" & Bin2 & ")"
    Debug.Print "cpa   " & Cpa & " (" & Cpa2 & ")"
    Debug.Print "vp   " & Vp & " (" & Vp2 & ")"
    Debug.Print "bag   " & Bag & " (" & Bag2 & ")"
    Debug.Print "xml   " & Xml & " (" & Xml2 & ")"
    Debug.Print "js   " & Js & " (" & Js2 & ")"
    Debug.Print "gdl   " & Gdl & " (" & Gdl2 & ")"
    Debug.Print "cab   " & Cab & " (" & Cab2 & ")"
    Debug.Print "ini   " & Ini & " (" & Ini2 & ")"
    Debug.Print "cat   " & Cat & " (" & Cat2 & ")"
    Debug.Print "inf   " & Inf & " (" & Inf2 & ")"
    Debug.Print "pnf   " & Pnf & " (" & Pnf2 & ")"
    Debug.Print "gpd   " & Gpd & " (" & Gpd2 & ")"
    Debug.Print "exe   " & Exe & " (" & Exe2 & ")"
    Debug.Print "dpb   " & Dpb & " (" & Dpb2 & ")"
    Debug.Print "ppd   " & Ppd & " (" & Ppd2 & ")"
    Debug.Print "Total files is  " & Sys + Ddl + Bin + Cpa + Vp + Bag + Xml + Js + Gdl + Cab + Ini + Cat + Inf + Pnf + Gpd + Exe + Dpb + Ppd
    Debug.Print "Things with no  .  are  " & Fldr
    http://www.excelfox.com/forum/showth...ge40#post12671
    Option Explicit  '  http://www.excelfox.com/forum/showthread.php/2408-Windows-10-and-Office-Excel/page40#post12671
    Dim WsDDD As Worksheet: Set WsDDD = Worksheets("DDAllComparison")
    Dim RngDD1 As Range, RngDD2 As Range  '
     Set RngDD1 = WsDDD.Range("D4:E680"): Set RngDD2 = WsDDD.Range("F4:H680")
    Dim Rng As Range
        For Each Rng In RngDD1 '----------------------| looking at each cell in the newest range, trying to find it in the original range
            If Rng <> "" Then
            Dim FndRng As Range ' FndRng, if found, is in RngDD2 , looking for value in each cell in RngDD1
             Set FndRng = RngDD2.Find(what:=Rng.Value, After:=RngDD2.Cells.Item(1), LookAt:=xlPart, searchorder:=xlNext, MatchCase:=False) '
                         FndRng.Select
                         Rng.Select
                         Set FndRng = WsDDD.Range("F" & FndRng.Row + 1 & ":H680").Find(what:=Rng.Value, After:=WsDDD.Range("H680"), LookIn:=xlValues, LookAt:=xlPart, searchorder:=xlByRows, SearchDirection:=xlNext, MatchCase:=False)  '   https://stackoverflow.com/questions/49094391/excel-vba-range-findnext-v-range-find-what-have-i-missed/49181464#49181464
        Next Rng  ' Each Rng In RngDD1 ---------------|
    http://www.excelfox.com/forum/showth...ge40#post12672
    '   http://www.excelfox.com/forum/showthread.php/2408-Windows-10-and-Office-Excel/page40#post12672
    '   Set Rngdr1 = Wsdrs.Range("F2:H180"): Set Rngdr2 = Wsdrs.Range("C2:E180") ' A bit back to front 1 is right columns original , 2 is left columns new from Marz 2020
    Private Sub FileTypesHereIndrivers_()
    Dim Ws As Worksheet: Set Ws = Worksheets("drivers marz 2020")
    Dim Rng As Range: Set Rng = Ws.Range("C2:E180") ' Ws.Range("F2:H180") ' Ws.Range("C2:E180")
    Dim Sam As Long
    Dim Sam2 As Long
    Rem 3 Looping
     Dim rngStr As Range
    '                If InStr(2, arrFiles(RwCnt, ClCnt), ".", vbBinaryCompare) > 1 Then ' use some criteria to check we have a file path
    '                    Dim Xtn As String: Let Xtn = Mid(arrFiles(RwCnt, ClCnt), (InStr(2, arrFiles(RwCnt, ClCnt), ".", vbBinaryCompare) + 1)) ' this will give the text starting from after the first  dot  .
                        Dim Xtn As String: Let Xtn = Mid(rngStr.Value, (InStr(2, rngStr.Value, ".", vbBinaryCompare) + 1)) ' this will give the text starting from after the first  dot  .
                        ' this next section catches single  .  things
    '                    If Len(arrFiles(RwCnt, ClCnt)) - Len(Replace(arrFiles(RwCnt, ClCnt), ".", "")) = 1 Then ' case a single  .
                        If Len(rngStr.Value) - Len(Replace(rngStr.Value, ".", "")) = 1 Then ' case a single  .
                             Case "SYS"
                             Case "DLL"
                             Case "BIN"
                             Case "CPA"
                             Case "VP"
                             Case "BAG"
                              Let Bag = Bag + 1: If rngStr.Font.Color <> 0 Then Let Bag2 = Bag + 1
                             Case "XML"
                             Case "JS"
                             Case "GDL"
                             Case "CAB"
                             Case "INI"
                             Case "CAT"
                             Case "INF"
                             Case "PNF"
                             Case "GPD"
                             Case "EXE"
                             ' sam
                             Case "SAM"
                              Let Sam = Sam + 1: If rngStr.Font.Color <> 0 Then Let Sam2 = Sam2 + 1
                             Case Else
                              Debug.Print "Case Else for single ""  .   ""    " & rngStr.Value
                              Let Els = Els + 1
                        ElseIf Len(rngStr.Value) - Len(Replace(rngStr.Value, ".", "")) = 2 Then ' a thing like  hidscanner.dll.mui  or  sdstor.sys.mui
                        ' this next section catches double  .  .  things
                        Dim DllMui As Long, SysMui As Long, Els2 As Long
                        Dim DllMui2 As Long, SysMui2 As Long
                             Case "DLL.MUI"
                              Let DllMui = DllMui + 1: If rngStr.Font.Color <> 0 Then Let DllMui2 = DllMui + 1
                             Case "SYS.MUI"
                              Let SysMui = SysMui + 1: If rngStr.Font.Color <> 0 Then Let SysMui2 = SysMui + 1
                             Case Else
                              Debug.Print "Case Else for double ""  .    .  ""    " & rngStr.Value
                              Let Els2 = Els2 + 1
                        ElseIf Len(rngStr.Value) - Len(Replace(rngStr.Value, ".", "")) > 2 Then
                        ' this section catches strings with dots more than 2
                        Dim LtsDts As Long
                         Debug.Print "More than 2 dots   --  " & rngStr.Value
                         Let LtsDts = LtsDts + 1
                    Else ' not a file, ( well no  .   in it anyway )
                    Dim Fldr As Long
                     Debug.Print "Folder?    " & rngStr.Value
                     Let Fldr = Fldr + 1
           Next rngStr
    '        Next ClCnt
    '    Next RwCnt
    Rem 4 output
    Debug.Print "Else1     " & Els
    ' sam
    Debug.Print "sam       " & Sam & " (" & Sam2 & ")"
    ' Dim DllMui As Long, SysMui As Long, Els2 As Long
    Debug.Print "dll.mui   " & DllMui & " (" & DllMui2 & ")"
    Debug.Print "sys.mui   " & SysMui & " (" & SysMui2 & ")"
    Debug.Print "Else2     " & Els2
    Debug.Print "Total files is  " & Els + Sys + Ddl + Bin + Cpa + Vp + Bag + Xml + Js + Gdl + Cab + Ini + Cat + Inf + Pnf + Gpd + Exe + Els2 + DllMui + SysMui + Sam & " (" & Sys2 + Ddl2 + Bin2 + Cpa2 + Vp2 + Bag2 + Xml2 + Js2 + Gdl2 + Cab2 + Ini2 + Cat2 + Inf2 + Pnf2 + Gpd2 + Exe2 + DllMui2 + SysMui2 + Sam2 & ")"
    Debug.Print "Total Folders is    " & Fldr
    Debug.Print "Total things with more than 2 dots is  " & LtsDts
    In support of this post.
    Dim Wsdrs As Worksheet: Set Wsdrs = Worksheets("drivers marz 2020") ' C2:E180     F2:H180
    Dim Rngdr1 As Range, Rngdr2 As Range  '
    Dim Rng As Range
        For Each Rng In Rngdr2 '----------------------| looking at each cell in the newest range, trying to find it in the original range
            If Rng <> "" Then
             Set FndRng = Rngdr1.Find(what:=Rng.Value, After:=Rngdr1.Cells.Item(1), LookAt:=xlPart, searchorder:=xlNext, MatchCase:=False) '
                         FndRng.Select
                         Rng.Select
                         Set FndRng = Wsdrs.Range("F" & FndRng.Row + 1 & ":H180").Find(what:=Rng.Value, After:=Wsdrs.Range("H180"), LookIn:=xlValues, LookAt:=xlPart, searchorder:=xlByRows, SearchDirection:=xlNext, MatchCase:=False)  '   https://stackoverflow.com/questions/49094391/excel-vba-range-findnext-v-range-find-what-have-i-missed/49181464#49181464
        Next Rng  ' Each Rng In Rngdr2 ---------------|
    In support of this post…
    http://www.excelfox.com/forum/showth...ge40#post12673
    '  =ANZAHL2(H3:J4396)     =ANZAHL2(D3:F4396)   G3:J4396     C3:F4396
    Private Sub FileTypesHereArraysNew()
    Dim Rng As Range: Set Rng = Ws.Range("A1:F4397")
    Dim Sam As Long
    Dim Inf_loc As Long, Hlp As Long, Ntf As Long, Ppd As Long, Tbl As Long, Icc As Long, Dat As Long
    Dim Dpb As Long, Cty As Long, Msc As Long, Xst As Long
    Rem 3 Looping
                If ClCnt = 2 And arrFiles(RwCnt, ClCnt) <> "" Then   ' case of folder path
                    Dim Fldr As Long '  Debug.Print "Folder?    " & arrFiles(RwCnt, ClCnt)
                     Let Fldr = Fldr + 1
                     Let RwCnt = RwCnt + 1 ' this is naughty, but will stop us hitting the folder name as the columns increase
                Else ' not a folder and if empty then not in column 2
                                 Case "SYS"
                                  Let Sys = Sys + 1
                                 Case "DLL"
                                  Let Ddl = Ddl + 1
                                 Case "BIN"
                                  Let Bin = Bin + 1
                                 Case "CPA"
                                  Let Cpa = Cpa + 1
                                 Case "VP"
                                  Let Vp = Vp + 1
                                 Case "BAG"
                                  Let Bag = Bag + 1
                                 Case "XML"
                                  Let Xml = Xml + 1
                                 Case "JS"
                                  Let Js = Js + 1
                                 Case "GDL"
                                  Let Gdl = Gdl + 1
                                 Case "CAB"
                                  Let Cab = Cab + 1
                                 Case "INI"
                                  Let Ini = Ini + 1
                                 Case "CAT"
                                  Let Cat = Cat + 1
                                 Case "INF"
                                  Let Inf = Inf + 1
                                 Case "PNF"
                                  Let Pnf = Pnf + 1
                                 Case "GPD"
                                  Let Gpd = Gpd + 1
                                 Case "EXE"
                                  Let Exe = Exe + 1
                                 ' sam
                                 Case "SAM"
                                  Let Sam = Sam + 1
                                 'inf_loc Pnf HLP NTF Ppd TBL ICC DAT
                                 Case "INF_LOC"
                                  Let Inf_loc = Inf_loc + 1
                                 Case "HLP"
                                  Let Hlp = Hlp + 1
                                 Case "NTF"
                                  Let Ntf = Ntf + 1
                                 Case "PPD"
                                  Let Ppd = Ppd + 1
                                 Case "TBL"
                                  Let Tbl = Tbl + 1
                                 Case "ICC"
                                  Let Icc = Icc + 1
                                 Case "DAT"
                                  Let Dat = Dat + 1
                                 'Dim Dpb As Long, Cty As Long, Msc As Long, Xst As Long
                                 Case "DPB"
                                  Let Dpb = Dpb + 1
                                 Case "CTY"
                                  Let Cty = Cty + 1
                                 Case "MSC"
                                  Let Msc = Msc + 1
                                 Case "XST"
                                  Let Xst = Xst + 1
                                 Case Else
                                  Debug.Print "Case Else for single ""  .   ""    " & arrFiles(RwCnt, ClCnt)
                                  Let Els = Els + 1
                            ElseIf Len(arrFiles(RwCnt, ClCnt)) - Len(Replace(arrFiles(RwCnt, ClCnt), ".", "")) = 2 Then ' a thing like  hidscanner.dll.mui  or  sdstor.sys.mui
                                 Case "DLL.MUI"
                                 Case "SYS.MUI"
                                 Case Else
                                  Debug.Print "Case Else for double ""  .    .  ""    " & arrFiles(RwCnt, ClCnt)
                                  Let Els2 = Els2 + 1
                            ElseIf Len(arrFiles(RwCnt, ClCnt)) - Len(Replace(arrFiles(RwCnt, ClCnt), ".", "")) > 2 Then
                            Dim LtsDts As Long
                             Debug.Print "More than 2 dots   --  " & arrFiles(RwCnt, ClCnt)
    '                    Dim Fldr As Long
    '                     Let Fldr = Fldr + 1
                    End If ' end of case empty cell
                End If ' end of folder is counted based on "G:\" in column B
            Next ClCnt
        Next RwCnt
    Rem 4 output
    ' sam
    ' inf_loc Pnf HLP NTF Ppd TBL ICC DAT
    Debug.Print "inf_loc   " & Inf_loc
    Debug.Print "hlp       " & Hlp
    Debug.Print "ntf       " & Ntf
    Debug.Print "tbl       " & Tbl
    Debug.Print "icc       " & Tbl
    Debug.Print "dat       " & Dat
    ' Dim Dpb As Long, Cty As Long, Msc As Long, Xst As Long
    Debug.Print "cty       " & Cty
    Debug.Print "msc       " & Msc
    Debug.Print "xst       " & Xst
    Debug.Print "Total files is  " & Els + Sys + Ddl + Bin + Cpa + Vp + Bag + Xml + Js + Gdl + Cab + Ini + Cat + Inf + Pnf + Gpd + Exe + Els2 + DllMui + SysMui + Sam + Inf_loc + Hlp + Ntf + Ppd + Tbl + Icc + Dat + Dpb + Cty + Msc + Xst
    ExplorerBefore DriverStore Comparison Marz 2020.xlsm : https://app.box.com/s/oy8pnuizk6xng1msqlsxho7l8e0bi0t8
    Explorer Before DriverStore Comparison Marz 2020.xlsm : https://app.box.com/s/4zx7b8d2gwjix7u68zit6o22x7q0kwm2
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
