Page 14 of 57 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 570
  1. #131
    Sub BubblesIndexIdeaWay As Sub Bubble , just replacing name in three places
    https://www.youtube.com/watch?v=7VwD9KuyMk4&lc=UgyZCnNfnZRfgwzDlQF4AaABAg.ADd4m2zp_xDADd6Nnotj 1C
    https://stackoverflow.com/questions/33868233/shell-namespace-not-accepting-string-variable-but-accepting-string-itself/77888851#77888851
    http://www.eileenslounge.com/viewtopic.php?p=322084#p322084
    http://www.eileenslounge.com/viewtopic.php?p=321822#p321822
    http://www.eileenslounge.com/viewtopic.php?p=322424#p322424
  2. #132
    This is Thread post 23 , forum post #post17885
    https://www.excelfox.com/forum/showt...ll=1#post17885
    https://www.excelfox.com/forum/showt...age2#post17885
    ……. the API, which knows nothing of BSTRs, assumes it is a pointer to an LPSTR (or LPWSTR) ……..
    ……In the case of passing strings, a pointer is passed, which has the effect of working similar to ByRef in a normal VBA function…..
    VB Strings and win32API
    This post is based on research and some initial investigations. It will be followed by more development to support and further the knowledge.
    For the sake of brevity we will use the convention of historical reference misnomers:
    _ ANSI for the 1 Byte, 8 Binary Bit character encoding for the first 256 characters as defined in the Windows code page, and
    _ Unicode for the 16 bit 2 Byte Little Endian encoding used by Microsoft to implement Unicode for the first 65536
    Unicode or (Microsoft) ANSI?
    API ANSI considerations
    Let’s get one thing clear: deep in the innards, VB and VBA strings are Unicode. But some aspects of the innards workings of the API Functions ( the API functionAs that most people are familiar with) , do most all things in ANSI, as perhaps do a few other Microsoft things. Perhaps this makes sense, in a broader sense. API controls window things, in one way or another, and a lot of things involving strings goes on, messaging etc. All this can easily be done with things like Askjuszff982jw33i()%, etc.
    Historically all API functions exclusively in their string workings used ANSI.
    This plays a part in the issue/ problem sparking off these rhetoric musings. So things ANSI will also be considered, since their consideration helps with the final solution
    (VBA) Runtime Unicode to ANSI Transfer
    In simple terms, VB, albeit having Unicode 16 behind the scenes, only understands ANSI characters
    There seems to be no official documentation to the following anomaly. ** However, this sounds reasonable: VB strings are stored in UNICODE, but all API calls are made with ANSI strings. This is accomplished by converting any string passed to an API call to ANSI before the call and back to UNICODE afterwards. While this conversion is transparent to the user most of the time, it makes it impossible to pass a UNICODE string from VB to a DLL via an argument typed As String in a Declare statement. Similarly, any structure which contains strings will go through the double conversion process during an API call. https://i.postimg.cc/28bPrbNj/Runtim...API-string.jpg
    We note here, just briefly for now, that for most all the original the API functionAs a later functionW. This goes some way, unclear how much, to make the API function work more with Unicode. Possibly this is just some data, such as that likely to be passed / carried in it.
    VB Strings Object
    Thinking about a VB Strings as an object, comes partly from hindsight, as I think it helps get to grips with some of the other goings on further down in these rhetoric musings
    A string variable itself is usually a "pointer", something like an address ( usually made with 32 bits ), of ( or usually part of, the left hand side start of ) the memory used to hold the actual string.
    This variable is often referred to as a data type called BSTR, which is short for Basic String. A BSTR is, in fact, a 32 Bit pointer to a null-terminated Unicode character array (that is preceded by a 4-byte length field).
    The thing pointed to and often "got", in a manner of speaking, the "object", will be something like a 1 dimensional array, where the elements are:
    For ANSI: a bit close to an array of the characters we might be as layman familiar with, in
    their character form,
    their decimal encoding.
    What we see or get, may depend on how we ask…… Example https://eileenslounge.com/viewtopic....297329#p297329 : StrConv("ZAC", vbFromUnicode) - coerced a string into a byte array
    For Unicode: something similar….. maybe.
    ….The Unicode character array that is pointed to by a BSTR must be preceded by a 4-byte length field and terminated by a single null 2-byte character (ANSI = 0).
    There may be additional null characters anywhere within the Unicode character array, so we cannot rely on a null character to signal the end of the character array. This is why the length field is vital.
    Again, the pointer points to the beginning of the character array, not to the 4-byte length field that precedes the array.
    https://postimg.cc/Xpgwq1Ny
    Attachment 6147
    LPSTR LPWSTR LPTSTR data types
    There is a pseudo data type, LongPtr which has, or will adjust itself appropriately, to the format required for the pointer of a string variable. This can be used to store the pointers as shown in the above Penis Pointer diagram. This is likely to be useful based on the tip above…. ….. the API, which knows nothing of BSTRs, assumes it is a pointer to an LPSTR (or LPWSTR…..) …..
    In documentation we distinguish three pointer types that can be stored in the LongPtr : An LPSTR string is defined as a pointer to a null-terminated ANSI character array. However, because the only way that we can tell when an LPSTR string ends is by the location of the terminating null, LPSTRs are not allowed to contain embedded null characters. Similarly, an LPWSTR is a pointer to a null-terminated Unicode character set with no embedded nulls. (The W in LPWSTR stands for Wide, which is Microsoft's way of saying Unicode.) )
    Pointers in general seem to be flexible things, and we have a LPTSTR which will effectively view the final character string as appropriate: LPTSTR, designates a general type that can be compiled for either Windows code pages or Unicode.
    VarPtr( ) strPtr( )
    We can get the pointer from a string (the address of the real UNICODE string buffer), using the strPtr function. It seems to be one of those important historical facts, not so well publicised, that this was introduced to help overcome problems when Unicode was introduced around the 95/97 VB 4/5. All VB strings are stored in UNICODE, but all API calls are made with ANSI strings. This is accomplished by converting any string passed to an API call to ANSI before the call and back to UNICODE afterwards. While this conversion is transparent to the user most of the time, it makes it impossible to pass a UNICODE string from VB to a DLL via an argument typed As String in a Declare statement.
    Unicode strings are converted to ANSI strings when using the declare statement as Win 95 didn't do Unicode.
    Sub VBptr() '    https://stackoverflow.com/questions/47499525/why-is-the-result-of-varptrbyval-str-the-same-as-strptrstr-vb6/47500197#47500197
    Dim BSTR As String ' BSTR is a 32 Bit pointer to a null-terminated Unicode character array (that is preceded by a 4-byte length field).
    '  VarPtr( ) returns the starting address of the memory area in which a variable is stored
    '                        VarPtr(ByVal ) - Strings passed ByVal pass the address of the first character of the containing string in the BStr.
    '                                             StrPtr( ) does the same, but makes sure it eturns the address of the real UNICODE string buffer
    Debug.Print VarPtr(BSTR); VarPtr(ByVal BSTR); StrPtr(BSTR); StrPtr(ByVal BSTR)
    '              1307644          0                    0              0
     Let BSTR = "Alan"
    '              1307644       141549884          141549884      141549884
    ' So VarPtr(BSTR) is the address of the Pointer. In that is the address of the first character, which VarPtr(ByVal ) should get, and might, and StrPtr most likely will. There isnt one if the variable is not filled
    Dim Poynter As Long, Trget As String, Rslt As Variant
     Let Poynter = VarPtr(BSTR)
     VBGetTarget Trget, Poynter, LenB(BSTR)
    Dim ByteArr() As Byte
    'Call WtchaGot_Unic_NotMuchIfYaChoppedItOff(Trget) ' "A" & Chr(0) & "l" & Chr(0) & "a" & Chr(0) & "n" & Chr(0)
     Let ByteArr() = Trget
    Call DBugPrntArr(ByteArr())  '  {65, 0, 0, 0, 108, 0, 0, 0, 97, 0, 0, 0, 110, 0, 0, 0}
    Debug.Print BSTR, Trget      '     ?? - Trget might be anything            A l a n
    _._________________
    It looks like we may be getting at some tools to assist us in the issues…. Let's see if we can find some more
    _.______________________________
    Some Tools for my research
    _1 StrPtr(), and LongPtr – see last bits above
    _2 Byte() Type Arrays and strConv()
    A Unicode string, the final array object, is just a memory buffer so we can hack it. Which is what The StrConv Hacker Function
    does…. This, and the Byte() Type Arrays in general , give both interesting and useful results, as well as a being great tools for researching the issues under consideration,…….
    …… next post
    https://web.archive.org/web/20201201...t/tips/varptr/ https://stackoverflow.com/questions/...-strptrstr-vb6
    https://web.archive.org/web/20201113...rconv-function
    ** Page 35, Steven Roman's book, Win32 API Programming: when we pass a string to an external function, VB translates the string from Unicode to ANSI
  3. #133
    Original test data range , ( B11:E16 )
    a
    b
    13
    c
    14
    d
    15
    e
    16
    f
    Worksheet: Sorting
    Added initial row and column indicees
    a
    b
    13
    c
    14
    d
    15
    e
    16
    f
    Worksheet: Sorting
  4. #134
    Sub Call_Sub_BubblesIndexIdeaWay()
    Calling routine required for previous Post and following Post
    Sub Call_Sub_BubblesIndexIdeaWay() ' Partially hard coded for ease of explanation
    ' data range info
    Dim WsS As Worksheet: Set WsS = ThisWorkbook.Worksheets("Sorting")
    Dim RngToSort As Range: Set RngToSort = WsS.Range("B11:E16")
        ' Set RngToSort = Selection '                          ' Selection.JPG : https://imgur.com/HnCdBt8
    Dim arrTS() As Variant ' This is somewhat redundant for this version and could be replaced by arrOrig()
     Let arrTS() = RngToSort.Value
    ' Index idea variables
     Let arrOrig() = arrTS()
     Let arrIndx() = arrTS()
     Let Cms() = Evaluate("=Column(A:D)") ' Convenient way to get
     Let Rs() = Evaluate("=Row(1:6)") ' Initial row indicies
    ' Add initial indicies
     Let RngToSort.Offset(-1, 0).Resize(1, 4).Value = Cms(): RngToSort.Offset(-1, 0).Resize(1, 4).Font.Color = vbRed
     Let RngToSort.Offset(0, -1).Resize(6, 1).Value = Rs(): RngToSort.Offset(0, -1).Resize(6, 1).Font.Color = vbRed
    ' Initial row indicies from full original range´of rows
    Dim strRows As String, Cnt As Long: Let strRows = " "
        For Cnt = 1 To 6
         Let strRows = strRows & Rs(Cnt, 1) & " "
    ' we should have now strRows = " 1 2 3 4 5 6 "
     Call BubblesIndexIdeaWay(1, arrIndx(), strRows, " 1 Asc 3 Asc 2 Asc ")
    ' Call BubblesIndexIdeaWay(1, arrIndx(), strRows, " 1 Asc ")
    ' Call BubblesIndexIdeaWay(1, arrIndx(), strRows, " 1 Asc 3 Asc ")
    ' Demo output
    Dim RngDemoOutput As Range: Set RngDemoOutput = WsS.Range("B31").Resize(RngToSort.Rows.Count, RngToSort.Columns.Count)
    ' Let WsS.Range("B31").Resize(RngToSort.Rows.Count, RngToSort.Columns.Count).Value = arrIndx()
     Let RngDemoOutput = arrIndx()
     Let RngDemoOutput.Offset(-1, 0).Resize(1, 4).Value = Cms(): RngToSort.Offset(-1, 0).Resize(1, 4).Font.Color = vbRed
     Let RngDemoOutput.Offset(0, -1).Resize(6, 1).Value = Rs(): RngToSort.Offset(0, -1).Resize(6, 1).Font.Color = vbRed
    Recursion routine for this post:
    http://www.excelfox.com/forum/showth...ll=1#post11078
    Sub BubblesIndexIdeaWay(ByVal CpyNo As Long, ByRef arsRef() As Variant, ByVal strRws As String, ByVal strKeys As String)
    Dim CopyNo As Long: Let CopyNo = CpyNo ' On every recurssion run this will be increased by the Rec Call. This will be a local variable indicating the level down in recursion - I increase it by 1 at every Rec Call, that is to say each Rec Call gets given CopyNo+1  -  during a long tunnel down, the number at this pint will keep increasing to reflect how far down we are.  This ensures we then have the correct value place at the start of any newly starting copy of the recursion routine, since the first copy of the recursion routine pauses and starts the second copy of the recursion routine, the second copy of the recursion routine pauses and starts the third copy of the recursion routine ….. etc…
        If CopyNo = 1 Then Debug.Print "First procedure Call"
    Rem -1 from the supplied  arguments, get all data needed in current bubble sort
    Dim Keys() As String: Let Keys() = Split(Replace(Trim(strKeys), "  ", " ", 1, -1, vbBinaryCompare), " ", -1, vbBinaryCompare) ''      The extra replace allows for me seperating with one or two spaces  - the following would do if I only used one space always    Split(Trim(strKeys), " ", -1, vbBinaryCompare) ' this will be an array twice as big as the number of keys that we have ...... ' Column for this level sort , and Ascending or Descending - both determined from the supplied forth arguments and the column/ copy number
        If (2 * CopyNo) > UBound(Keys()) + 1 Then Debug.Print "You need more than " & (UBound(Keys()) + 1) / 2 & " keys to complete sort": Exit Sub ' case we have less keys then we need to sort, are array has twice as many elements as we have supplied keys since we have a key and whether it needs to get bigger or smaller , and array is from  0   so must add 1 to ubound then half it get the key number we gave.  We come here if the last column we gave as a Key had duplicates in it
        'Dim GlLl As Long: If Keys((CopyNo * 2) - 1) = "Desc" Then Let GlLl = 1 ' (CopyNo * 2) - 1)  gives as we go down levels   1  3  5  7 etc  We're seeing if we had  Desc  for this column
    Dim Clm As Long: Let Clm = CLng(Keys((CopyNo * 2) - 2)) '              ' (CopyNo * 2) - 2)  gives as we go down levels   0  2  4  6 etc  We  are  picking  out  the  supplied   column to sort by for each level
    Rem 1 Bubble sort
    Dim rOuter As Long ' ========"Left Hand"=====================Outer Loop=====================================
        ' For rOuter = Rs(LBound(Rs(), 1), 1) To Rs(UBound(Rs(), 1), 1) - 1 ' THIS WOULD ONLY WORK FOR Copy No 1      For first row indicie to last but one row indicie - I could do this for copy 1
        For rOuter = Left(Trim(strRws), InStr(1, Trim(strRws), " ", vbBinaryCompare) - 1) To Right(Trim(strRws), Len(Trim(strRws)) - InStrRev(Trim(strRws), " ", -1, vbBinaryCompare)) - 1 '   ImmediteWindowToHelpGetAtStuff.JPG : https://imgur.com/yGqmYSu : http://www.eileenslounge.com/viewtopic.php?f=27&t=16407&p=247121#p247121
        'For rOuter = 1 To 5 ' For first run
        Dim rInner As Long ' -------Inner Loop-------------"Right Hand"--------------------------
            For rInner = rOuter + 1 To Rs(UBound(Rs(), 1), 1) ' from just above left hand through all the rest
                If CDbl(arsRef(rOuter, Clm)) > CDbl(arsRef(rInner, Clm)) Then
                Dim Temp As Variant ' I want to Swap those 2 above - I cant easilly in any coding change two values simulataneosly. So one of them Element values will put in this temporary place. This Element Values will then be given the other. Finally the other Element will be given this temporary value
                 Let Temp = arrIndx(rOuter, Clm): Let arrIndx(rOuter, Clm) = arrIndx(rInner, Clm): Let arrIndx(rInner, Clm) = Temp
                Dim TempRs As Long
                 Let TempRs = Rs(rOuter, 1): Let Rs(rOuter, 1) = Rs(rInner, 1): Let Rs(rInner, 1) = TempRs
            Next rInner ' -----------------------------------------------------------------------
        Next rOuter ' ==================End=Rem 1===============================================================
     Let arrIndx() = Application.Index(arrOrig(), Rs(), Cms())
    Rem 3 Preparation for possible recursion Call
    ' Catpains Blog
     Debug.Print " Running Copy No. " & CopyNo & " of routine." & vbCr & vbLf & "  Sorted rows " & strRws & " based on values in column " & Clm & vbCr & vbLf & "   Checking now for Dups in that last sorted list" & vbCr & vbLf
    Dim tempStr As String: Let tempStr = strRws ' Need this bodge because I set strRws="" below
     Let strRws = ""
        'For rOuter = Rs(LBound(Rs(), 1), 1) To Rs(UBound(Rs(), 1), 1) - 1  ' Only valis for first Copy No 1
        For rOuter = Left(Trim(tempStr), InStr(1, Trim(tempStr), " ", vbBinaryCompare) - 1) To Right(Trim(tempStr), Len(Trim(tempStr)) - InStrRev(Trim(tempStr), " ", -1, vbBinaryCompare)) - 1                                   '   ImmediteWindowToHelpGetAtStuff.JPG : https://imgur.com/yGqmYSu : http://www.eileenslounge.com/viewtopic.php?f=27&t=16407&p=247121#p247121
            If strRws = "" Or InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then Let strRws = " " & rOuter & " " ' case starting again to get duplicates
            'If strRws = "" Or Trim(strRws) = rOuter - 1 Then Let strRws = " " & rOuter & " " ' alternative
            If Trim(UCase(CStr(arrIndx(rOuter, Clm)))) = Trim(UCase(CStr(arrIndx(rOuter + 1, Clm)))) Then ' case in duplicate rows
             Let strRws = strRws & rOuter + 1 & " " ' we building a list like   " 4 5 6 "  based on if the next is a duplicate value, which is determined by the last line
            Else '  without the last condition met, we might have the end of a group duplicate rows, in which case it would be time to organise a recursion run so ..... we check for this situation needing a recursion run
                If Not InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then ' case we have at least 2 duplicates but have hit end of that list ( we have at least one space between indices, like " 3 4 " , " 6 7 8" etc..  ---- this , " 2 " , on the other hand, would would not have a space after trimming off the end spaces )
                 ' Now its time to organise a recursion run
                 Debug.Print "Found dups in last list column " & Clm & ",  " & strRws & " ,  so now main Rec Call " '     This is done for every duplicated
                 Call BubblesIndexIdeaWay(CopyNo + 1, arrIndx(), strRws, strKeys) ' Rec Call 1  I need to sort the last duplicates
                 Let strRws = "" ' ready to try for another set of duplicates
                End If ' we did not have more than one indicie in strRws so usually that's it for this loop
            '+++*** this would be end of loop for most cases ... but Oh Fuck
    'Oh Fuck' ...below section catches rows at the end that might need to be sorted. ......|
            If rOuter = UBound(arrIndx(), 1) - 1 And Not InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then ' case of duplicates in last row
             Debug.Print "Found dups in last rows of last list, so now Rec Call at end of loop (Dups at list end case)"  ' loop end rec call - only done for duplicates at end of list
            End If  '...   ................................................................|
        Next rOuter   '   **************************************************************************
     Debug.Print "Ending a copy, Copy level " & CopyNo & ""
    Some Killing File tests / What order does Dir(with wild cards) find stuff
    Some notes , tests in support of this
    https://www.excelforum.com/excel-pro...-the-file.html
    These are just some notes and tests into what order the Dir( with wild cards ) thing does stuff.
    Introduction
    VBA Dir Function thing ( https://docs.microsoft.com/en-us/off...p/dir-function )
    In the simplest form, ….._
    _____ Dir(Fullpath&FileName, __ )
    _............
    Dim IsFileName As String
      IsFileName = Dir("C:\MyFolder\myFileName.xls", __ )
    this basically gives you the file name back if it exists, based on you giving it the full path and File name string, Fullpath&FileName.
    In the above example, if you had the file "myFileName.xls" in the foilder, "MyFolder", then the text "myFileName.xls" would be Placed in variable , IsFileName
    If that file does not exist, then it gives you back nothing, or rather an empty string of sorts “” ( I believe Dir is a throw back to older early computer days, when you typed something like Dir C:_____, and the result was that you got to go to that place which Dir C:_____ represented )
    It seem that in VBA the Dir is mostly used to loop through all files in a single folder*. ( *It does not suit too well for use in coding looking at all files in folders and sub folders ). The suitability of the Dir function for this is based on a couple of things.
    _(i) In Microsoft Windows, Dir supports the use of multiple character (*) and single character (?) wildcards to specify multiple files. ......
    You can use wild cards in the full path and file name string that you give it, so it will look for a file matching your given string. ( So typically you might give a string like “C:\myFolder\*.xl*”, which would look for any excel file: In this bit *.xl* , the first * allows for any file name, and the second * will allow for extensions such as .xls , .xlsm, .xlsx, .. etc… )
    __Dir _____ without arguments
      IsFileName = Dir
    _(ii) After you use like Dir(Fullpath&FileName, __ ) once, then any use after of just _ Dir __ without any arguments, will give the next file it finds based on the criteria given by the wild carded full path and file name string you gave in the first use with arguments, or it returns "" if there are no further files meeting the criteria given by the wild carded full path and file name string you gave in the first use with arguments
    What this post is about:
    My interest was sparked by the reference thread ( https://www.excelforum.com/excel-pro...-the-file.html )
    I am interested in finding out which of the files Dir or Dir(Fullpath&FileName, __ )will choose if there are more than 1 file meeting the criteria of a string , Fullpath&FileName , containing wild cards
    Experiments so far
    I made a test folder , named "Folder"
    Folder.JPG : https://imgur.com/l9OwlQi
    Attachment 2213
    I created my files in this order
    _1 “wbCodes.xlsm” --- the main file with all the codes in it. This is in the same Folder as the folder which I named "Folder" ( The main Folder is called “Kill Stuff” : Kill Stuff Folder.JPG : https://imgur.com/hN26AoW )
    After making the main File, I created the folder, "Folder" , and created the following files in it. I created the following three files in the following order,
    _2 “SecondFirstAfterwb.xlsx” --- made first after making “wbCodes.xlsm”
    _3 “ThirdSecondAfterwb.xlsx” --- made second after making “wbCodes.xlsm”
    _4 “AForthThirdAfterwb.xlsx” --- made third after making “wbCodes.xlsm”
    I modified the codes from Alf and sintek from the referenced Thread, thus, ( I am mainly interested in the first part of the routines, as this deals with what the Dir chooses )
    Sub zed369() ' sintek
    Dim Path As String, File As String, Cnt As Long
    Dim wb1 As Workbook, wb2 As Workbook
    Dim ws1 As Worksheet, ws2 As Worksheet
    ' sintek's Dir Stuff
    'Application.ScreenUpdating = False
    Set wb1 = ThisWorkbook: Set ws1 = wb1.Sheets("Sheet1")
    Path = ThisWorkbook.Path & "\Folder\": File = Dir(Path & "*.xl*") ' For this example, specific file is in a folder called Folder...same path as macro file...
    Debug.Print "First got by  Dir  is " & File
        For Cnt = 1 To 3 - 1 ' -1 because we have three files, but typically the first is got from the first use of Dir , which is typically outside the loop
         File = Dir: Debug.Print " use " & Cnt & " in loop of  Dir   gives " & File
    ' sintek's way to do stuff
    'Stop ' _____________________________________________________________________________
    'Set wb2 = Workbooks.Open(Path & File): Set ws2 = wb2.Sheets("Tabelle1")
    'With ws2
    '    .UsedRange.Copy ws1.Range("A1")
    'End With
    'wb2.Close
    'Kill Path & File
    'Application.ScreenUpdating = True
    Sub CopyAndKill() ' Alf
    Dim aString As String, Cnt As Long, aStringToOpen As String
    ' Alf's Dir stuff
    'aString = Dir("N:\a_test\")
    aString = Dir("F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder\")
    Debug.Print "First got by  Dir  is " & aString
    aStringToOpen = "F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder\" & Dir("F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder\")
    Debug.Print "First file will be opened using this string  " & vbCrLf & aStringToOpen
         aString = Dir: Debug.Print " use " & Cnt & " in loop of  Dir   gives " & aString
    ' Alf's way to do the stuff
    'Workbooks.Open ("N:\a_test\" & Dir("N:\a_test\"))
    'Sheets("Sheet1").Activate
    'ActiveSheet.UsedRange.Copy
    'ThisWorkbook.ActiveSheet.Range("A1").PasteSpecial Paste:=xlAll
    'Application.CutCopyMode = False
    'Windows(aString).Close
    'Kill ("N:\a_test\" & Dir("N:\a_test\"))
    I get this sort of output ( in the immediate window )
     First got by  Dir  is AForthThirdAfterwb.xlsx
     use 1 in loop of  Dir   gives SecondFirstAfterwb.xlsx
     use 2 in loop of  Dir   gives ThirdSecondAfterwb.xlsx
    F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder\AForthThirdAfterwb.xlsx
    Initially it appears that I get alphabetic order.
    But possibly there could be more to it than that.
    I will look again at this in a few days , possibly on some other computers and systems, and experiment with various settings , etc….
    In the next posts I will use this simplified routine which is only interested in looking at the order in which Dir chooses files.
    Rem 1 gives a few ways to get the string up to and including the Folder in which files are to be searched for, ( in the form below , ‘1b ) , is used to get the folder named “Folder” in the same folder as the workbook in which the routine is placed )
    Rem 2 : As before, an initial use of Dir(C:\somewhers\kjhfkhs.*sdfjkah,___) is made to set the search criteria, followed by the un argumented Dir in a loop which then looks for the next files
    Sub DirOrder()
    Dim strWB As String
    Rem 1 get the full string, strWB, for a Folder to use in the  Dir(Fullpath&FileName, __ )        ( strWB=Fullpath&FileName - FileName )
    '1a) use the asking pop up thing, File dialogue folder picker
    '   With Application.FileDialog(msoFileDialogFolderPicker)
    '    .Title = "Folder Select"
    '    .AllowMultiSelect = False
    '        If .Show <> -1 Then
    '         Exit Sub
    '        Else
    '        End If
    '    Let strWB = .SelectedItems(1)  '  & "\"
    '   End With
    '1b) Using a test Folder, named  Folder  in the same Folder as the workbook in which this code is
     Let strWB = ThisWorkbook.Path & "\Folder"
    '1c) Hard code instead
    'Let strWB = "F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder"
     Debug.Print "Folder used is" & vbCrLf & strWB & vbCrLf & "" & Right(strWB, (Len(strWB) - InStrRev(strWB, "\", -1, vbTextCompare)))
     Let strWB = strWB & "\"
    Rem 2 add last file bit for use in the  Dir(Fullpath&FileName, __ ) , but include wild cards...    http://www.excelfox.com/forum/showthread.php/2056-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11089&viewfull=1#post11089 :  _(i) You can use wild cards in the full path and file name string that you give it, so it will look for a file matching your given string. ( So typically you might give a string like “C:\myFolder\*.xl*”, which would look for any excel file: In this bit *.xl* , the first * allows for any file name, and the second * will allow for extensions such as .xls , .xlsm, .xlsx, .. etc… )      _(ii) After you use like Dir(Fullpath&FileName, __ ) once, then any use after of just _ Dir __ without any arguments, will give the next file it finds based on the string you gave in the first use with arguments
    '2a)  Excel files
     Let strWB = strWB & "*.xls*"
    Dim file As String: Let file = Dir(strWB)
     Debug.Print "First got by  Dir(" & strWB & ")" & vbCrLf & "is             " & file
         file = Dir: Debug.Print "Use " & Cnt & " in loop of unargumented   Dir   gives   " & file
    This would be comparible output ( in the Immedite Window ( http://www.eileenslounge.com/viewtop...247121#p247121 ) ) to the test files anf folder used so far
    HTML Code:
    Folder used is
    Folder
    First got by  Dir(F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder\*.xls*)
    Use 1 in loop of unargumented   Dir   gives   SecondFirstAfterwb.xlsx
    Use 2 in loop of unargumented   Dir   gives   ThirdSecondAfterwb.xlsx
    And here is what it looks like in the explorer window:
    ExpOrder1.JPG : https://imgur.com/OfQfHeH
    Attachment 2224
  7. #137
    Dir Order
    Here is where we left off in the last post
    HTML Code:
    Folder used is
    Folder
    I can move the order pysically in the explorer window, by selecting and dragging the file position virtically, ( and I hit the refresh thing , just in case that should influence anything )
    ExpOrder2.JPG : https://imgur.com/AlV1MdB
    The routine, Sub DirOrder() , then seems to give the same results
    HTML Code:
    Folder used is
    Folder
    I can do this:
    ExpOrder3a.JPG : https://imgur.com/RBSa9Ou
    ExpOrder3a.JPG : https://imgur.com/2OVsguZ
    Once again I get the same alphabetical ordering in the Dir found order output
    i can play around with this:
    ExpOrder4.JPG : https://imgur.com/6FbYQgp
    or this
    Stack by change date.jpg : https://imgur.com/YIrTxpp , https://imgur.com/ht887FU , https://imgur.com/lHMcUjA
    Attachment 2226
    I made this d_xlsm_file.xlsm , and this ,c_xls_file.xls , and pit it in the foilder, Folder
    A xlsm and xls.JPG : https://imgur.com/w9gyRxj
    Attachment 2225
    here is part of my Immediate window output
    HTML Code:
    Use 1 in loop of unargumented   Dir   gives   c_xls_file.xls
    Use 2 in loop of unargumented   Dir   gives   d_xlsm_file.xlsm
    I need to increase my loop count, Cnt , to 4 to getting total all 5 files. But doing this is likely to get a bit tedious as I comtinue experiments with a different number of files in various folders. So I will change my coding, at the loop section, to a more typical type of loop used iin such a Dir __ file finding code: Usually something like this is done, so that the loop keeps going as long as Dir __ finds files
    ‘ First use of Dir  with full path and file name argument
    ‘  strWB = "F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder\*.xls*" ‘ Wild card to get all Excel Files
    ‘  File = Dir(strWB)‘ Loop for all files meeting search string criteria,  ( all Excel files in this example )
        Do '                  '_- I want to keep going in a Loop while I still get a file name returned by  Dir
        Dim Cnt As  Long: Let Cnt = Cnt + 1
         File = Dir: Debug.Print "Use " & Cnt & " in loop of unargumented   Dir   gives   """ & File & """"
        Loop While File <> "" '_- I want to keep going in a Loop while I still get a file name returned by  Dir
    Here is the full coding, http://www.excelfox.com/forum/showth...ll=1#post11108 , which gives for the last example:
    HTML Code:
    Folder
    Use 1 in loop of unargumented   Dir   gives   "c_xls_file.xls"
    Use 2 in loop of unargumented   Dir   gives   "d_xlsm_file.xlsm"
    Use 3 in loop of unargumented   Dir   gives   "SecondFirstAfterwb.xlsx"
    Use 4 in loop of unargumented   Dir   gives   "ThirdSecondAfterwb.xlsx"
    Use 5 in loop of unargumented   Dir   gives   ""
    I can change the serach criteria from strWB & "*.xls*" to strWB & "*" and it has no effect
    i added a .jpg pic, ( Add a jpg.JPG : https://imgur.com/XkXskiL ) , and the listing had it in the aplhabetical order :
    First got by  Dir(F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\Kill Stuff\Folder\*)
    Use 4 in loop of unargumented   Dir   gives   "Stack by change date  .JPG"
    Use 5 in loop of unargumented   Dir   gives   "ThirdSecondAfterwb.xlsx"
    Use 6 in loop of unargumented   Dir   gives   ""
    I use the last routine in the form to allow user selection of the folder to search for files
    http://www.excelfox.com/forum/showth...ll=1#post11108. I looked at some arbritrary folders, - once again alphabetical order seems to come out:
    Folder used is
    First got by  Dir(F:\Excel0202015Jan2016\ExcelForum\wbSheetMakerClsdWbADOMsQueery\*)
    is             83DB8900
    Use 1 in loop of unargumented   Dir   gives   "aaa.xlsm"
    Use 2 in loop of unargumented   Dir   gives   "Amar321.xls.xlsx"
    Use 3 in loop of unargumented   Dir   gives   "ApparantlyApparantIs_Change.JPG"
    Use 4 in loop of unargumented   Dir   gives   "Aufzeichnen.JPG"
    Use 5 in loop of unargumented   Dir   gives   "Book1.xls"
    Use 6 in loop of unargumented   Dir   gives   "Book1.xlsm.zip"
    Use 7 in loop of unargumented   Dir   gives   "CA930CD8.tmp"
    Use 8 in loop of unargumented   Dir   gives   "ClosedWorkbook.xlsm"
    Use 9 in loop of unargumented   Dir   gives   "CopyASheet.JPG"
    Use 10 in loop of unargumented   Dir   gives   "CresssieFiles.JPG"
    Use 11 in loop of unargumented   Dir   gives   "DB2IssJfürELProAbDec2014.xlsm"
    Use 12 in loop of unargumented   Dir   gives   "EFFldr.xlsm"
    Use 13 in loop of unargumented   Dir   gives   "EFldr1_1 Download.JPG"
    Use 14 in loop of unargumented   Dir   gives   "Eileens Fldr.zip"
    Use 15 in loop of unargumented   Dir   gives   "EileensFldr Contents Copy.JPG"
    Use 16 in loop of unargumented   Dir   gives   "EileensFldr Contents Paste.JPG"
    Use 17 in loop of unargumented   Dir   gives   "EileensFldr Make Empty Folder.JPG"
    Use 18 in loop of unargumented   Dir   gives   "EileensFldr zip  Download.JPG"
    Use 19 in loop of unargumented   Dir   gives   "EileensFldr.zip"
    Use 20 in loop of unargumented   Dir   gives   "EileensFolderExplainedOutput.JPG"
    Use 21 in loop of unargumented   Dir   gives   "Example Folder and Macro File in same Folder.JPG"
    Use 22 in loop of unargumented   Dir   gives   "FBandData.xlsm"
    Use 23 in loop of unargumented   Dir   gives   "FBandDataNorie.xlsm"
    Use 24 in loop of unargumented   Dir   gives   "FBandDataNorie.xlsx"
    Use 25 in loop of unargumented   Dir   gives   "FormulaBarClosedWB.JPG"
    Use 26 in loop of unargumented   Dir   gives   "GetData_ClosedBook+LINKS.xlsx"
    Use 27 in loop of unargumented   Dir   gives   "GetData_ClosedBook.xls"
    Use 28 in loop of unargumented   Dir   gives   "HimanshuktwCode.JPG"
    Use 29 in loop of unargumented   Dir   gives   "KissMyClosedWB.JPG"
    Use 30 in loop of unargumented   Dir   gives   "Mappe2.xlsm"
    Use 31 in loop of unargumented   Dir   gives   "MazanDikCollectionWonk.xlsm"
    Use 32 in loop of unargumented   Dir   gives   "mellowtangSummarySheets.xlsm"
    Use 33 in loop of unargumented   Dir   gives   "MsQueerOptions.JPG"
    Use 34 in loop of unargumented   Dir   gives   "myFileToClose.xlsm"
    Use 35 in loop of unargumented   Dir   gives   "MyNewWorkbook.xlsx"
    Use 36 in loop of unargumented   Dir   gives   "MySameFolder.JPG"
    Use 37 in loop of unargumented   Dir   gives   "NeuProAktuelleMakros.xlsm"
    Use 38 in loop of unargumented   Dir   gives   "NormalThisWorkbookCodeModule.JPG"
    Use 39 in loop of unargumented   Dir   gives   "NutritionalValues2016.xlsx"
    Use 40 in loop of unargumented   Dir   gives   "OnlyGets8810RowsInAQuerrListObjectTableThingyAnyways.JPG"
    Use 41 in loop of unargumented   Dir   gives   "Plop.xlsm"
    Use 42 in loop of unargumented   Dir   gives   "poo.xlsm"
    Use 43 in loop of unargumented   Dir   gives   "RudyMSRAllSubFldrsFndRep.xlsm"
    Use 44 in loop of unargumented   Dir   gives   "Sample.zip"
    Use 45 in loop of unargumented   Dir   gives   "SchemaIniErrorPipe.JPG"
    Use 46 in loop of unargumented   Dir   gives   "SrangeThisWorkbookCodeModule.JPG"
    Use 47 in loop of unargumented   Dir   gives   "StopClosing.xlsm"
    Use 48 in loop of unargumented   Dir   gives   "Summary sheet.xlsm"
    Use 49 in loop of unargumented   Dir   gives   "template test.xlsm"
    Use 50 in loop of unargumented   Dir   gives   "Top100MsQuery.JPG"
    Use 51 in loop of unargumented   Dir   gives   "ViskasVerticalsMaster dataMjoza.xlsm"
    Use 52 in loop of unargumented   Dir   gives   "wb2.csv"
    Use 53 in loop of unargumented   Dir   gives   "wb2.xlsm"
    Use 54 in loop of unargumented   Dir   gives   "wb2.xlsx"
    Use 55 in loop of unargumented   Dir   gives   "WBAccessTimeTestData.xlsx"
    Use 56 in loop of unargumented   Dir   gives   "WBAccestTimeTest.xlsm"
    Use 57 in loop of unargumented   Dir   gives   "wbCodes.xlsb"
    Use 58 in loop of unargumented   Dir   gives   "wbCodes.xlsm"
    Use 59 in loop of unargumented   Dir   gives   "WBOpenRenameKlaredog.xls"
    Use 60 in loop of unargumented   Dir   gives   "WBOpenRenameKlaredog.xlsm"
    Use 61 in loop of unargumented   Dir   gives   "Wb_with_5Sheets_4Worksheets.xlsm"
    Use 62 in loop of unargumented   Dir   gives   "WillyWonks.JPG"
    Use 63 in loop of unargumented   Dir   gives   "workbook2.xlsm"
    Use 64 in loop of unargumented   Dir   gives   "WorkbookOpenMsgBox.JPG"
    Use 65 in loop of unargumented   Dir   gives   "WorksheetNames.JPG"
    Use 66 in loop of unargumented   Dir   gives   "Worksheet_Change.JPG"
    Use 67 in loop of unargumented   Dir   gives   ""
    Note that a file named as a number comes first in the list, as is consitant with Excel regarding text as "larger" than a number in sorting things http://www.eileenslounge.com/viewtop...=32154#p249178
    Up until now, all tests were done on an old Lap top using Vista operating system. I rechecked on a newer machine uisng Windows 7. I get the same results
    "wbCodes.xlsm" : https://app.box.com/s/gfuintgifu1hgw5nap3jriz2x8mp911x ( Sub DirOrder() is here )
    folder, "Folder" : https://app.box.com/s/vmmzeboetkt07ocggbx6p8lkurmp5wca
    "wbCodes.xls" : https://app.box.com/s/gmdne53vehhuc6lvz3vfgyxqmwy07xlz ( Sub DirOrder() is here )
  8. #138
    There is a second argument to Dir. It is not used much. https://docs.microsoft.com/en-us/off...ction#settings
    One option will make it return folder names as well. For our example we can change Dir(strWB) to any if these: Dir(strWB, vbDirectory) ; Dir(PathName:=strWB, Attributes:=vbDirectory) ; Dir(PathName:=strWB, Attributes:=16) ; Dir(strWB, 16)
    Running the routine with the previous example, seems to slip the folder names in the appropriate place to once again have everything in alphabetical order
    Folder used is
    is             .
    Use 1 in loop of unargumented   Dir   gives   ".."
    Use 2 in loop of unargumented   Dir   gives   "83DB8900"
    Use 3 in loop of unargumented   Dir   gives   "aaa.xlsm"
    Use 4 in loop of unargumented   Dir   gives   "ACDC"
    Use 5 in loop of unargumented   Dir   gives   "Amar321.xls.xlsx"
    Use 6 in loop of unargumented   Dir   gives   "ApparantlyApparantIs_Change.JPG"
    Use 7 in loop of unargumented   Dir   gives   "Aufzeichnen.JPG"
    Use 8 in loop of unargumented   Dir   gives   "Bad Files"
    Use 9 in loop of unargumented   Dir   gives   "Book1.xls"
    Use 10 in loop of unargumented   Dir   gives   "Book1.xlsm.zip"
    Use 11 in loop of unargumented   Dir   gives   "CA930CD8.tmp"
    Use 12 in loop of unargumented   Dir   gives   "ClosedWorkbook.xlsm"
    Use 13 in loop of unargumented   Dir   gives   "ClsdWbs"
    Use 14 in loop of unargumented   Dir   gives   "CopyASheet.JPG"
    Use 15 in loop of unargumented   Dir   gives   "CressieFolder"
    Use 16 in loop of unargumented   Dir   gives   "CresssieFiles.JPG"
    Use 17 in loop of unargumented   Dir   gives   "DB2IssJfürELProAbDec2014.xlsm"
    Use 18 in loop of unargumented   Dir   gives   "EFFldr.xlsm"
    Use 19 in loop of unargumented   Dir   gives   "EFldr1_1"
    Use 20 in loop of unargumented   Dir   gives   "EFldr1_1 Download.JPG"
    Use 21 in loop of unargumented   Dir   gives   "Eileens Fldr.zip"
    Use 22 in loop of unargumented   Dir   gives   "EileensFldr"
    Use 23 in loop of unargumented   Dir   gives   "EileensFldr Contents Copy.JPG"
    Use 24 in loop of unargumented   Dir   gives   "EileensFldr Contents Paste.JPG"
    Use 25 in loop of unargumented   Dir   gives   "EileensFldr Make Empty Folder.JPG"
    Use 26 in loop of unargumented   Dir   gives   "EileensFldr zip  Download.JPG"
    Use 27 in loop of unargumented   Dir   gives   "EileensFldr.zip"
    Use 28 in loop of unargumented   Dir   gives   "EileensFolderExplainedOutput.JPG"
    Use 29 in loop of unargumented   Dir   gives   "Example Folder and Macro File in same Folder.JPG"
    Use 30 in loop of unargumented   Dir   gives   "FBandData.xlsm"
    Use 31 in loop of unargumented   Dir   gives   "FBandDataNorie.xlsm"
    Use 32 in loop of unargumented   Dir   gives   "FBandDataNorie.xlsx"
    Use 33 in loop of unargumented   Dir   gives   "FormulaBarClosedWB.JPG"
    Use 34 in loop of unargumented   Dir   gives   "GetData_ClosedBook+LINKS.xlsx"
    Use 35 in loop of unargumented   Dir   gives   "GetData_ClosedBook.xls"
    Use 36 in loop of unargumented   Dir   gives   "HimanshuktwCode.JPG"
    Use 37 in loop of unargumented   Dir   gives   "Kill Stuff"
    Use 38 in loop of unargumented   Dir   gives   "KissMyClosedWB.JPG"
    Use 39 in loop of unargumented   Dir   gives   "MacroRecording"
    Use 40 in loop of unargumented   Dir   gives   "Mappe2.xlsm"
    Use 41 in loop of unargumented   Dir   gives   "MazanDikCollectionWonk.xlsm"
    Use 42 in loop of unargumented   Dir   gives   "mellowtangSummarySheets.xlsm"
    Use 43 in loop of unargumented   Dir   gives   "MsQueerOptions.JPG"
    Use 44 in loop of unargumented   Dir   gives   "MsQueeryADO"
    Use 45 in loop of unargumented   Dir   gives   "myFileToClose.xlsm"
    Use 46 in loop of unargumented   Dir   gives   "MyNewWorkbook.xlsx"
    Use 47 in loop of unargumented   Dir   gives   "MySameFolder.JPG"
    Use 48 in loop of unargumented   Dir   gives   "Neuer Ordner"
    Use 49 in loop of unargumented   Dir   gives   "NeuProAktuelleMakros.xlsm"
    Use 50 in loop of unargumented   Dir   gives   "NormalThisWorkbookCodeModule.JPG"
    Use 51 in loop of unargumented   Dir   gives   "NutritionalValues2016.xlsx"
    Use 52 in loop of unargumented   Dir   gives   "OnlyGets8810RowsInAQuerrListObjectTableThingyAnyways.JPG"
    Use 53 in loop of unargumented   Dir   gives   "Plop.xlsm"
    Use 54 in loop of unargumented   Dir   gives   "poo.xlsm"
    Use 55 in loop of unargumented   Dir   gives   "RudyMSRAllSubFldrsFndRep.xlsm"
    Use 56 in loop of unargumented   Dir   gives   "Sample.zip"
    Use 57 in loop of unargumented   Dir   gives   "SchemaIniErrorPipe.JPG"
    Use 58 in loop of unargumented   Dir   gives   "SrangeThisWorkbookCodeModule.JPG"
    Use 59 in loop of unargumented   Dir   gives   "StopClosing.xlsm"
    Use 60 in loop of unargumented   Dir   gives   "Summary sheet.xlsm"
    Use 61 in loop of unargumented   Dir   gives   "template test.xlsm"
    Use 62 in loop of unargumented   Dir   gives   "Top100MsQuery.JPG"
    Use 63 in loop of unargumented   Dir   gives   "ViskasVerticalsMaster dataMjoza.xlsm"
    Use 64 in loop of unargumented   Dir   gives   "wb2.csv"
    Use 65 in loop of unargumented   Dir   gives   "wb2.xlsm"
    Use 66 in loop of unargumented   Dir   gives   "wb2.xlsx"
    Use 67 in loop of unargumented   Dir   gives   "WBAccessTimeTestData.xlsx"
    Use 68 in loop of unargumented   Dir   gives   "WBAccestTimeTest.xlsm"
    Use 69 in loop of unargumented   Dir   gives   "wbCodes.xls"
    Use 70 in loop of unargumented   Dir   gives   "wbCodes.xlsb"
    Use 71 in loop of unargumented   Dir   gives   "wbCodes.xlsm"
    Use 72 in loop of unargumented   Dir   gives   "WBOpenRenameKlaredog.xls"
    Use 73 in loop of unargumented   Dir   gives   "WBOpenRenameKlaredog.xlsm"
    Use 74 in loop of unargumented   Dir   gives   "Wb_with_5Sheets_4Worksheets.xlsm"
    Use 75 in loop of unargumented   Dir   gives   "WillyWonks.JPG"
    Use 76 in loop of unargumented   Dir   gives   "WonkBook"
    Use 77 in loop of unargumented   Dir   gives   "workbook2.xlsm"
    Use 78 in loop of unargumented   Dir   gives   "WorkbookOpenMsgBox.JPG"
    Use 79 in loop of unargumented   Dir   gives   "WorksheetNames.JPG"
    Use 80 in loop of unargumented   Dir   gives   "Worksheet_Change.JPG"
    Use 81 in loop of unargumented   Dir   gives   "XYT"
    Use 82 in loop of unargumented   Dir   gives   ""
    Here is the folder used for the last two tests: wbFolder.JPG : https://imgur.com/MMydq7n
    Deafault item to use if empty column
    In support of answer to this excelfox Thread:
    http://www.excelfox.com/forum/showth...ll=1#post11090
    Sub DefaultItem()
    Rem 1 data range info
    Dim rngIn As Range, Lr As Long, ClmCnt As Long
     Let ClmCnt = 3 '        : Let ClmCnt = Worksheets("Sheet2").Range("A1").CurrentRegion.Columns.Count
     Let Lr = Worksheets("Sheet2").Range("A1").CurrentRegion.Rows.Count
     Set rngIn = Worksheets("Sheet2").Range("A1:C" & Lr & "")
    Rem 2 Data to array
    Dim arrDtaIn() As Variant '  I need Variant type as the  .Value  in the next line returns a field of Variant type elements
     Let arrDtaIn() = rngIn.Value
    Rem 3 Determine default values
    ' 3a) Number of groups
    Dim arrGp() As Variant: Let arrGp() = Application.Index(rngIn, 0, 1).Value ' http://www.excelfox.com/forum/showthread.php/1111-VBA-Trick-of-the-Week-Slicing-an-Array-Without-Loop-%E2%80%93-Application-Index         Highlight arrGp and Hit F9.JPG : https://imgur.com/PZF0oXE
    Dim strGps As String: Let strGps = " " ' For a string like " 1 2 3 "
    Dim cnt As Long
        For cnt = 2 To Lr ' looking at all rows from the second in our input data
            If InStr(1, strGps, " " & arrGp(cnt, 1) & " ") = 0 Then ' This looks for the positiopn along ( starting from character 1  ,  in  strGps  ,  of  each row element arrGp(cnt, 1)  )    if it is not found then Instr retourns  0   as a n indication that it was not there
             Let strGps = strGps & arrGp(cnt, 1) & " "              ' Because it is not there, we now put it in
        Next cnt
    ' At this point we should have like  strGps = " 1 2 3 "
    ' 3b) Array of unique groups
     Let strGps = Trim(strGps) ' This takes off the first and last trailing spaces
    Dim arrGps() As String     ' The string split function below returns a fiels of String elements : Highlight arrGps  Hit F9.JPG : https://imgur.com/LT9dgHk
     Let arrGps() = Split(strGps, " ", -1, vbBinaryCompare)      ' this splits the (  strgps  ,  using  " " as denominator  ,  and returns all elemants in an array,  using exact binary computer match on the " "  )
    ' 3c) Array for output
    Dim arrOut() As String ' A dynamic array is needed as I can only use variables in the  ReDim  method - I cannot use varable in the declaration (Dim) statement
     ReDim arrOut(1 To UBound(arrGps()) + 2, 1 To 2) ' I  want +1 rows for the header   I also need +1 because split retouns a 1 dimensional array stating at indicie 0 - so the Ubound of arrGps() will give a numbe 1 less than I might expect - in our example we have 3 elements with  indicies of 0 1 2, ( and values in our example of 1 2 3 - for example  arrGps(0)=1  )  so the Ubound returns 2 - but we want 3 elements
    ' 3d) fill my arrOut()
    Dim Stear As Variant ' I want to use a  For ´Each  loop below   VBA must have an object varaible or a variable of variant type to hold each  item  in a collection of something. Our arrGps() can be considered a collection of numbers  1 2 3
    Dim ArrOutRw As Long: Let ArrOutRw = 1 ' Our row number in the outout array  : I use 1 initially, for the header
     Let arrOut(ArrOutRw, 1) = arrDtaIn(1, 1): Let arrOut(ArrOutRw, 2) = "Deafault item"
        For Each Stear In arrGps() ' This outer loop goes throug each unique group number =============== - For each number in  { 1, 2, 3 }
            For cnt = 2 To Lr ' An Inner loop to go through all data rows ' -----------------------------
                If CStr(arrDtaIn(cnt, 1)) = CStr(Stear) Then ' This will catch the first use of our group number, Stear is our group number taken from the array  1 2 3
                 Let ArrOutRw = ArrOutRw + 1                 ' Our next row to fill in arrOut()
                 Let arrOut(ArrOutRw, 1) = Stear             ' First column in our output array
                 Let arrOut(ArrOutRw, 2) = arrDtaIn(cnt, 2)  ' Second column in our output array will be given the first item in column B of our data for this group number, Stear
                 Exit For                                    ' I only want to get the first item for a group number
            Next cnt ' ----------------------------------------------------------------------------------
        Next Stear ' ====================================================================================
    ' at this point we have an array for output of default : Select ArrOut   then Hit F9.JPG : https://imgur.com/CNMeYV9
    Rem 4 Demo Output
    Let rngIn.Offset(0, ClmCnt).Resize(UBound(arrOut(), 1), 2).Value = arrOut() ' In the range which offset to the right of the input, of the dimension size of the output array, I paste my values out
    Coding in suport of these excelfox Threads and posts:
    Sub DirOrder()  '  http://www.excelfox.com/forum/showthread.php/2056-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11092&viewfull=1#post11092
    Dim strWB As String
    '         Exit Sub
    '        Else
    '        End If
    '   End With
    '2a)  Excel files
    Dim File As String: Let File = Dir(strWB)
     Debug.Print "First got by  Dir(" & strWB & ")" & vbCrLf & "is             " & File
         Let File = Dir: Debug.Print "Use " & Cnt & " in loop of unargumented   Dir   gives   """ & File & """"
    Here last routine in form to allow user selection of folder to search for files
    Sub DirOrder()  '   http://www.excelfox.com/forum/showthread.php/2056-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11093&viewfull=1#post11093
    Dim strWB As String
            If .Show <> -1 Then
    'Let strWB = ThisWorkbook.Path & "\Folder"
    '2a)  Excel files
     Let strWB = strWB & "*"
  2. Replies: 116
  3. Replies: 21
  4. Replies: 42
  5. Replies: 11
