Thread: VBA: keep only one searched string.
    Apr 2022
    The list of search stings is given in sheet 2.
    In sheet1, with VBA check if a given string is found more than once in a paragraph/line. If found more than once then keep only one.
    I want to do this both in an excel sheet with multiple column data in multiple rows as well as in a CSV or text file.
    @ susan santa 12345 et al
    You continue to post short badly explained questions, and either ignore or don’t understand the various things I have said to you.
    My best guess is that you are either
    _ a Bot,
    _ a total idiot,
    _ just trying your luck at getting Homework questions answered quickly
    _ just trying your luck at answering someone else’s questions and have no idea or interest in them yourself
    _ deliberately trying to be a pain in the arse.
    I will probably delete, close , ban you, or some combination in a few days to tidy the place up a bit, unless you improve somehow
    Apr 2022
    Attached in Post #1 a reduced size sample with a Before ( Input) and an After (Output).
    Hello again.
    This will be a very similar idea to the last solution I just did for you:
    https://excelfox.com/forum/showthrea...6728#post16728
    The difference is that we check for duplicate strings and remove those.
    As an example I will show you how to remove duplicates of " searched string" from cell A2, ( and put result in cell A3 )
    Before (cell A2)
     #VBA: keep only one searched string searched string searched string searched string.
    #VBA: keep only searched string one searched string.
    The list of search stings searchedCSV string searched string is given in sheet 2.
    In sheet1, with #VBA check if a given string is CSV searched string found more than once in a paragraph/line. If found more than once then keep only one.
    I want to do this both in an excel sheet with CSV searched string multiple column data in multiple rows as well as in a CSV or text file.
    After running macro below (cell A3)
     "#VBA: keep only one searched string.
    I want to do this both in an excel sheet with CSV searched string multiple column data in multiple rows as well as in a CSV or text file."
    Sub CleanUpCellA2() '    https://excelfox.com/forum/showthread.php/2819-VBA-keep-only-one-searched-string?p=16719&viewfull=1#post16719      https://excelfox.com/forum/showthread.php/2818-in-VBA-if-the-given-string-is-found-then-delete-everything-between-two-newlines-where-the-string-appears?p=16718&viewfull=1#post16718
    Rem 0 worksheet data info
    Dim Ws1 As Worksheet: Set Ws1 = ThisWorkbook.Worksheets.Item(1)
    Rem 1 We Split that text in a cell by the line separator, to give us an array where each element contains the text of a paragraph/ line.
    Dim Celtxt As String: Let Celtxt = Ws1.Range("A2").Value2
    Dim SptTxt() As String: Let SptTxt() = Split(Celtxt, vbLf, -1, vbBinaryCompare)
    Rem 2  Check each element content for duplicated strings, and remove them
    Dim Cnt As Long, NewStr As String
        For Cnt = 0 To UBound(SptTxt())
        Dim Pos1 As String: Let Pos1 = InStr(1, SptTxt(Cnt), " searched string", vbBinaryCompare)
            If Pos1 > 0 Then
            'If InStr(1, SptTxt(Cnt), "paragraph/line", vbBinaryCompare) = 0 And InStr(1, SptTxt(Cnt), "searched*string", vbBinaryCompare) = 0 And InStr(1, SptTxt(Cnt), "#VBA", vbBinaryCompare) = 0 Then
                Do While InStr(Pos1 + 1, SptTxt(Cnt), " searched string", vbBinaryCompare) > 0 ' I will keep doing this  Do While Loop  whilst I find another  " serched string"
                 Let SptTxt(Cnt) = Replace(SptTxt(Cnt), " searched string", "", 1, 1, vbBinaryCompare)
                 Let Pos1 = InStr(Pos1 + 1, SptTxt(Cnt), " searched string", vbBinaryCompare)
                Loop ' While InStr(Pos1 + 1, SptTxt(Cnt), "searched string", vbBinaryCompare) > 0
             Let NewStr = NewStr & SptTxt(Cnt) & vbLf
     Let NewStr = Left(NewStr, Len(NewStr) - 1)
    Rem 3 Output
     Let Ws1.Range("A3").Value2 = NewStr
    Quote Originally Posted by santa1234 View Post
    You will need to do the basic coding For each cell with data in it, using something like a For Each cell _ Next loop
    I want to do this ..... as well as in a CSV or text file.
    One way to do this would be to import the text file into
    an Excel worksheet
    , or
    a VBA array of data
    , do the necessary on that excel worksheet
    , then export the modified data to a text file.
    Something similar to what I showed you here
    https://excelfox.com/forum/showthrea...-a-space-found
    https://excelfox.com/forum/showthrea...ll=1#post16696
    VBA keep only one searched string.xls https://app.box.com/s/hjytoyz22uv0v1072cv855bgnem9n6fx
  1. "What’s in a String"- VBA break down Loop through character contents of a string
    By DocAElstein in forum Excel and VBA Tips and Tricks
    Last Post: 07-09-2023, 04:57 PM
  2. Replies: 4
    Last Post: 10-02-2022, 09:18 PM
  3. Replies: 0
    Last Post: 07-08-2020, 04:29 PM
  4. Looping Through String Using Excel VBA!
    By Jdean in forum Excel Help
    Last Post: 09-12-2014, 09:24 AM
  5. VBA Using MID Function To Replace Portion Of A String
    Last Post: 05-30-2013, 08:22 PM
