Thread: SQL in Excel
    SQL in Excel
    Hi I am trying to run SQL in EXcel on data stored in Sheet2 of same workbook.
    I am tryting to fill a combo box using SQL queries ..The list populating is dependent
    on selection made in another drop down.eg
    A japan
    B india
    B UK
    A germany
    A italy
    B France
    so if A is selected I want the other combo box to be populated with japan,germany and Italy...
    please help wth the code for running the SQL
    Hi Nishant,
    It's recommend that not to query using ADO on an open excel workbook. More details can be found here;
    BUG: Memory leak occurs when you query an open Excel worksheet by using ActiveX Data Objects (ADO)
    You may also interested this link: http://www.excelfox.com/forum/f12/de...-formulas-111/
    Apr 2011
    I read the article about the memory leak - below is the code I use to read my Access table(s) - so I guess I am going to run into the memory problem. Can you suggest another method of connecting to Access or SQL for that matter.
    Is there a way I can monitor the amount of free memory - in the olden days the 'Free' command fullfilled that purpose - But I am not sure what replaces that command.
    Public Sub FindFirstLastDates(strDBPath As String, DB_PW As String)
        Dim adoConn     As Object
        Dim rstRec      As Object
        Set adoConn = CreateObject("ADODB.Connection")
        Set rstRec = CreateObject("ADODB.Recordset")
        strTable = "SampleHeader"
        With adoConn
            Err.Clear
            .provider = "Microsoft.Jet.Oledb.4.0"
            .Properties("Jet OLEDB:Database Password") = DB_PW
            .Open "Data Source=" & strDBPath
            If Err.Number <> 0 Then
        rstRec.Open "Select * from " & strTable & " ORDER BY SampleDateTime", adoConn, 3, 3
        rstRec.movefirst
        TxtStartDate.Text = Format(rstRec.fields("SampleDateTime"), "YYYY/MM/DD")
        rstRec.movelast
        TxtEndDate.Text = Format(rstRec.fields("SampleDateTime"), "YYYY/MM/DD")
        adoConn.Close
    xl2007 - Windows 7
    xl hates the 255 number
  1. SQL output from Excel VBA macro
    By goldenbutter in forum Excel Help
    Last Post: 05-07-2013, 08:07 PM
  2. Upload Excel Data to SQL Table
    By littleiitin in forum Excel and VBA Tips and Tricks
    Last Post: 08-22-2012, 11:02 AM
  3. Replies: 2
    Last Post: 11-17-2011, 07:49 PM
  4. Execute SQL From Excel (VBA)
    By Mechanic in forum Excel and VBA Tips and Tricks
    Last Post: 10-02-2011, 04:30 PM
  5. Execute SQL From Excel (VBA)
    By Mechanic in forum Excel Help
    Last Post: 05-13-2011, 10:27 AM
