Thread: Explain App.Index(Rng, Rws(), Clms()) (multicolumn Combobox with Index.application)
    Feb 2022
    Question Explain App.Index(Rng, Rws(), Clms()) (multicolumn Combobox with Index.application)
    Who can help me, I have the following code that I found somewhere that I don't remember:
       Dim rng As Range
       Set rng = Range("B4:D8")
       With ComboBox1
          .ColumnCount = 2
          .ColumnWidths = "50;50"
          ' load 1st, 2nd columns of range into combobox
          .List = Application.Index(rng, Evaluate("ROW(1:" & rng.Rows.Count & ")"), Array(1, 3))
    In "sheet1" I have three columns of data in the range from B4 to D8 (the headers in row 3). In a combobox the data of columns B and D appears.This is a multicolumn combobox with non-continuous columns (that are not next to each other). It works perfectly and is adapted to what I wanted. Unfortunately I don't understand how the line
    ".List = Application.Index(rng, Evaluate("ROW(1:" & rng.Rows.Count & ")"), Array(1, 3))"
    works and I can't stay So.
    I know that we are making an output list from an input list and I understand that evaluate with row is returning the index of the rows that have data in the range, from the first row to the fifth, and that with array we determine the columns which will take the combobox (or so I thought I understood).
    But why can't we use an array to determine the rows as well?
    I tried to do it and it didn't work for me.
    If someone is kind enough to tell me what data is returning evaluate (which is supposed to be used to occupy excel formulas in vba) with row, I would greatly appreciate it.
    I hope everything is understood. I'm using google translator.
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgwWg8x2WxLSxxGsUP14AaABAg. 9k3ShckGnhv9k89LsaigoO
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgxxxIaK1pY8nNvx6JF4AaABAg. 9k-vfnj3ivI9k8B2r_uRa2
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgxKFXBNd6Pwvcp4Bsd4AaABAg
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=Ugw9X6QS09LuZdZpBHJ4AaABAg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg. 9h5lFRmix1R9h78GftO_iE
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg. 9h740K6COOA9h77HSGDH4A
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg. 9h740K6COOA9h76fafzcEJ
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg. 9h740K6COOA9h759YIjlaG
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg. 9h740K6COOA9h74pjGcbEq
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgzJJUDVv2Mb6YGkPYh4AaABAg. 9h5uPRbWIZl9h7165DZdjg
    Hello Amelynn
    Welcome to ExcelFox , the thinking man’s Excel forum
    Quote Originally Posted by Amelynn View Post
    Who can help me, ....
    I think, therefore I am , and able to help you.
    ...... I don't understand how the line ".List
    " works and I can't stay So....
    To Explain
    Question: _(i) What is Array(1, 3) ?
    Answer_ It is like –
    ___1 _3
    ( Sometime we write in excel spreadsheet convention {1, 3} , but this usually means the same thing )
    Question: _(ii)a) Evaluate("ROW(1:" & rng.Rows.Count & ")")
    Answer:
    ..... evaluate (…….. used to occupy excel formulas in vba) with row,
    Correct! Good! - Because you understand this, it makes the explanation for me much easier.
    We are really only interested in understanding what is , =ROW(1:" & rng.Rows.Count & ")" , in excel spreadsheet formula
    Question: _(ii)b) What is =ROW(1:" & rng.Rows.Count & ") ? ( in excel spreadsheet )
    For your range, rng = B4:D8 , rng.Rows.Count = 5
    =ROW(1: " & rng.Rows.Count & " )
    =ROW(1: " & 5 & " )
    =ROW(1:5)
    ( Green is Excel Spreadsheet, Blue is VBA in string “ “ in Evaluate( “ “ ) )
    The excel spreadsheet Row( ) function is usually like for
    Row( A1) = 1
    but can also return a “vertical” array of values like
    Row( A1:A2) = 1
    Row( A1:A2) = 2
    Inside VBA Evaluate _ we find that we are decoupled from spreadsheet absolute values, and so in inside VBA Evaluate _
    Row(A1:A2) = Row( 1:2) = 1
    Row(A1:A2) = Row( 1:2) = 2
    ROW(1:5)
    It is like
    ( Sometimes we may write
    {1
    5}
    or sometimes we may write in excel spreadsheet convention , ={1;2;3;4;5} , but usually this means the same thing
    Note: For “vertical” array some excel use ; but some Excel use \ – So sometime you may need ={1\2\3\4\5}
    Sometimes if we are lucky, Excel will try to do array calculations and return you an array.
    Like
    	{	1	2		X	{	6	8		  =	{	1, 6	2, 8
    		3	4	}			7	9	}			3, 7	4, 9	}
    But if you ask it to do = Index ___ , ROW(1:5)_ ,_ Array{1 , 3} it tries to look at columns and rows not specified.
    This should not work
    =  {	1	?			   {	1	3
    	2	?				?	?
    	3	?		X		?	?
    	4	?				?	?
    	5	?	}			?	?	}
    ???? So we have a problem ?,
    But we can be lucky again, because then Excel will guess to see the following instead, ( actually its more complicated then that, more precisely it is due to Excel VBA Interception and Implicit Intersection , but we often say that Excel guesses things, as its often written to get things correct when you miss things out. ( In this particular case it is not clear if the phenomenum occurs by accident or design ) )
    =  {	1	1			   {	1	3
    	2	2				1	3
    	3	3		X		1	3
    	4	4				1	3
    	5	5	}			1	3	}
    ( What is actually happening there above in those last two sketches is: -
    If Excel is given a single row or a single column, but is being required to look at values of further adjoining rows and columns where no values are given, then the effect of the phenomena of Excel VBA Interception and Implicit Intersection is that in certain situation the missing values will effectively be taken as a duplication of the values in the given row or column
    So, Index will try to give us
    _______    Index(    (    ,	1, 1	1, 3
    				2, 1	2, 3
    				3, 1	3, 3
    				4, 1	4, 3
    				5, 1	5, 3	  )
    So if your range is, rng = B4:D8
    -__=
    	_B4	_C4	_D4
    	_B5	_C5	_D5
    	_B6	_C6	_D6
    	_B7	_C7	_D7
    	_B8	_C8	_D8
    then Application.Index(rng, Evaluate("=ROW(1:" & rng.Rows.Count & ")"), Array(1, 3))
    -__ =Application.Index(rng, Evaluate("=ROW(1:5)"), Array(1, 3))
    -__ =Application.Index(rng, Evaluate("={1;2;3;4;5}"), Array(1, 3))
    -__ =Application.Index(rng, Evaluate("={1;2;3;4;5}"), Evaluate("={1, 3}"))
    -__ =
        rng  ,            1,1  1,3
                          2,1  2,3
                          3,1  3,3
                          4,1  4,3
                          5,1  5,3
    -__=
        _B4 _C4 _D4       1,1  1,3
        _B5 _C5 _D5       2,1  2,3
        _B6 _C6 _D6       3,1  3,3
        _B7 _C7 _D7       4,1  4,3
        _B8 _C8 _D8       5,1  5,3
    	  =     _B4	_D4
    		_B5	_D5
    		_B6	_D6
    		_B7	_D7
    		_B8	_D8
    ........use an array to determine the rows as well......
    Sure, this is no problem:
    One way, for example, for just 1st 3rd and 5th row
    Change
    to
    Evaluate("={1;3;5}")
    -__ =Application.Index(rng, Evaluate("={1;3;5}"), Array(1, 3))
    -__ =Application.Index(rng, Evaluate("={1;3;5}"), Evaluate("={1, 3}"))
        _B4 _C4 _D4       1,1  1,3
        _B5 _C5 _D5       3,1  3,3
        _B6 _C6 _D6       5,1  5,3
        _B7 _C7 _D7
        _B8 _C8 _D8
    	  =     _B4	_D4
    		_B6	_D6
    		_B8	_D8
    Here a demo macro for you
    Put some arbitrary values in your range "B4:D8" , then run this macro:
    Sub Test()
    Dim Rng As Range
     Set Rng = Worksheets("Sheet1").Range("B4:D8")
    Dim RwsCnt As Long
     Let RwsCnt = Rng.Rows.Count '  is = 5
    Dim arr_List() As Variant
     Let arr_List() = Application.Index(Rng, Evaluate("=ROW(1:" & Rng.Rows.Count & ")"), Array(1, 3))
     Let arr_List() = Application.Index(Rng, Evaluate("=ROW(1:" & RwsCnt & ")"), Array(1, 3))
     Let arr_List() = Application.Index(Rng, Evaluate("=ROW(1:5)"), Array(1, 3))
     Let arr_List() = Application.Index(Rng, Evaluate("={1;2;3;4;5}"), Array(1, 3))
     Let arr_List() = Application.Index(Rng, Evaluate("={1;2;3;4;5}"), Evaluate("={1,3}"))
     Let Worksheets("Sheet1").Range("A40").Resize(UBound(arr_List(), 1), UBound(arr_List(), 2)).Value = arr_List()
    ' To only select 1st 3rd and 5th row
     Let arr_List() = Application.Index(Rng, Evaluate("={1;3;5}"), Evaluate("={1,3}"))
     Let Worksheets("Sheet1").Range("A47").Resize(UBound(arr_List(), 1), UBound(arr_List(), 2)).Value = arr_List()
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgykemWTw-fGoPwu8E14AaABAg.9iECYNx-n4U9iK75iCEaGN
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgykemWTw-fGoPwu8E14AaABAg.9iECYNx-n4U9iK7XF33njy
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=Ugy_1xkcndYdzUapw-J4AaABAg.9iGOq_leF_E9iKCSgpAqA1
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=Ugy_1xkcndYdzUapw-J4AaABAg.9iGOq_leF_E9iKCy--3x8E
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgwNaJiNATXshvJ0Zz94AaABAg. 9iEktVkTAHk9iF9_pdshr6
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgykemWTw-fGoPwu8E14AaABAg.9iECYNx-n4U9iFAZq-JEZ-
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgxV2r7KQnuAyZVLHH54AaABAg. 9iDVgy6wzct9iFBxma9zXI
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgwnYuSngiuYaUhEMWN4AaABAg. 9iDQN7TORHv9iFGQQ5z_3f
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgwJ3yzdk_EE98dndmt4AaABAg. 9iDLC2uEPRW9iFGvgk11nH
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgyDWAVqCa4yMot463x4AaABAg. 9iH3wvUZj3n9iHnpOxOeXa
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=UgwvLFdMEAba5rLHIz94AaABAg. 9iGReNGzP4v9iHoeaCpTG8
    https://www.youtube.com/watch?v=ITI1HaFeq_g&lc=Ugy_1xkcndYdzUapw-J4AaABAg.9iGOq_leF_E9iHpsWCdJ5I
    Feb 2022
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGADdPM65i9PG
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGADdPQHFk_zm
    https://www.youtube.com/watch?v=fEHKPhJxgBA&lc=Ugxx8_MjhC9FDaQgcHN4AaABAg
    https://www.youtube.com/watch?v=jpjYm4UvyWk&lc=Ugx_Qd4rfAN_ZYcJbo94AaABAg. ACGbG9c76OWACGbjKa7H8k
    https://www.youtube.com/watch?v=GyPHaydeng0&lc=UgzE4a4f_e_y9Rk5OR94AaABAg
    https://www.youtube.com/watch?v=I5FkNG94BcQ&lc=UgxXnkEHqulXSR5tXwh4AaABAg
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6BSa173Z
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6-64Xpgl
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ms39yjd
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ZXJwRCM
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4Pr15NUt
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4I83JelY
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGADdMo2n-hyF
    Feb 2022
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=UgwplzlpYpmRqjGZem14AaABAg. 9hrvbYRwXvg9ht4b7z00X0
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=UgyOGlCElBSbfPIzerF4AaABAg. 9hrehNPPnBu9ht4us7TtPr
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=UgwHjKXf3ELkU4u4j254AaABAg. 9hr503K8PDg9ht5mfLcgpR
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugw1-OyZiDDxCHM2Rmp4AaABAg.9hqzs_MlQu-9ht5xNvQueN
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugygb0YiLOI7fG1zQSx4AaABAg
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugygb0YiLOI7fG1zQSx4AaABAg. 9htWqRrSIfP9i-fyT84gqd
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugygb0YiLOI7fG1zQSx4AaABAg. 9htWqRrSIfP9i-kIDl-3C9
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz0Uy2bCSCTb1W-0_14AaABAg.9htChVuaX9W9i57J9GEOUB
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz0Uy2bCSCTb1W-0_14AaABAg.9htChVuaX9W9i58MGeM8Lg
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz0Uy2bCSCTb1W-0_14AaABAg.9htChVuaX9W9i59prk5atY
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=UgwaWs6XDXdQybNb8tZ4AaABAg. 9i5yTldIQBn9i7NB1gjyBk
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=UgxV9eNHvztLfFBGsvZ4AaABAg. 9i5jEuidRs99i7NUtNNy1v
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugx2zSXUtmLBSDoNWph4AaABAg. 9i3IA0y4fqp9i7NySrZamd
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9i7Qs8kxEqH
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9i7TqGQYqTz
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAJSNws8Zz
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAJvZ6kmlx
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAK0g1dU7i
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAKCDqNmnF
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAKHVSTGHy
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAKSBKPcJ6
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAKgL6lrcT
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAKlts8hKZ
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAKrX7UPP0
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugz4oMZ09MKcExYlWf94AaABAg. 9hwsCHaKX6A9iAL5MSjWpA
  1. INDEX formula not working
    By SaburaZera in forum Excel Help
    Last Post: 02-03-2015, 08:29 AM
  2. HTML (Again!) arrOut()=Index(arrIn(),Rws(),Clms()
    Last Post: 08-23-2014, 02:27 AM
  3. Staffing Scheduling HELP Match/Index
    By mgelston in forum Excel Help
    Last Post: 06-20-2013, 01:09 AM
  4. VBA Trick of the Week :: Slicing an Array Without Loop - Application.Index
    Last Post: 06-12-2013, 04:40 PM
  5. Index Sheets with Shapes and Hyperlink
    By TomyLee in forum Excel Help
    Last Post: 09-04-2012, 10:52 PM
