Thread: problem hilighting or editing within the EXCEL CONTENTS BOX of the FORMULA BAR
    Feb 2022
    When I first open a spreadsheet and click on a cell of interest, the cell's content appears in the EXCEL CONTENTS BOX of the FORMULA BAR, as I would expect. I can then move my cursor to a place within this 'edit box' and highlight the portion of the cell that I want to make bold, underline, italicize, change color, etc...with no difficulty. However, lately, I can no longer do this (i.e., when I click on a cell and go up to the 'edit box' the cursor can ONLY be placed at the end of the cell's content and I cannot left-click and highlight the cell's contents at all to edit it as I used to be able to. I am, however, able to backspace and hit the spacebar or start typing, but highlighting is not available.
    Also, sometimes the cursor is on top of a character and it is not clear if I am about to edit the character before or after it!?!
    There is plenty of cpu and ram available so that's not the issue. If I close and reopen the spreadsheet that sometimes corrects my problem, so it does prove that the cell is not corrupt.
    Thanks in advance to all who reply.
    Dan
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6BSa173Z
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6-64Xpgl
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ms39yjd
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ZXJwRCM
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4Pr15NUt
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4I83JelY
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HABa3tnAjhZU
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HABa3KswxL3c
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=UgyBXFxnVWT3pqtdqPx4AaABAg
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=Ugi53h84LUm5bHgCoAEC.7-H0Z7-COoGABZFQ8vjEvY
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABZ8N9O-O8p
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgxREWxgx2z2Lza_0st4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgyikSWvlxbWS24NBeR4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgwNiH4hhyrd2UjDK8d4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HAAf952WoUti
    https://www.youtube.com/watch?v=hz4vb48wzMM&lc=Ugy2N3gvXBNrvWpojqR4AaABAg
    https://www.youtube.com/watch?v=dKM8ZScbic8&lc=UgycSz2aeeww0HF2pd54AaABAg. 9TZfqpV4v619VXmfikvDnB
    Hello bromberg
    Welcome to ExcelFox
    I have never seen that problem
    Just a couple of things I can suggest.
    _1) Have you expanded the formula edit box thing. ( There is something to click on, and then you can drag the bottom up and down:
    ) Possibly that might reveal something in the cell that you wernt expecting.
    _2 The only other thing I can suggest is if you can upload a small workbook that is exhibiting the problem ( remove any sensitive data ) , then me or someone could try in our Excel so that we might at least be able to say if the problem is in the Workbook or your Excel. ( I also have some coding that I could use to check if you have got any strange “invisible” characters in your cells: There are often characters in a text that you don’t see, but they might cause strange effects ( https://excelfox.com/forum/showthrea...ts-of-a-string )
    P.S If you have not done it before, uploading a file here is not as simple as it should be. Here are some notes on it:
    attachments : https://excelfox.com/forum/showthrea...ll=1#post11279
    https://excelfox.com/forum/showthrea...ll=1#post15589
  1. Formula Editor/Bar in UserForm TextBox?
    By xtinct2 in forum Excel Help
    Last Post: 05-23-2017, 12:35 AM
  2. Replies: 8
    Last Post: 08-17-2013, 02:42 PM
  3. Replies: 8
    Last Post: 05-21-2013, 06:34 AM
  4. Adding Scroll bar to image box in vba
    Last Post: 12-13-2011, 09:47 PM
  5. Hide Ribbon and Formula Bar
    Last Post: 04-21-2011, 07:03 PM
