Results 1 to 7 of 7
Thread: VBA : Insert Pictures With Multiple Select Picture & Consecutive Placing
    Sep 2013
    Cross posted
    http://www.eileenslounge.com/viewtop...292701#p292701
    hi expert..
    this macro code below working properly to insert picture from a folder with one by one select picture
    i want to modified so macro work with criteria:
    1. can insert picture from a folder with multiple select picture and insert to multiple cell at once
    2. pictures can inserted automatically consecutive/sequentially placing into target cell (target cell are random) with name of file picture are random --> (main option)
    3. if point #2 impossible to do it , to insert automatically consecutive can use name of file picture or based on name pictures like e.g. photo1, photo2,photo3, photo4, or whatever name's file picture etc....> (secondary option)
    here code
    Sub InsertPicture()    Const cBorder As Double = 5     ' << change as required
        Dim vPicture As Variant, pic As Shape
        vPicture = Application.GetOpenFilename("Pictures (*.gif; *.jpg; *.jpeg; *.tif), *.gif; *.jpg; *.jpeg; *.tif", , "Select Picture to Import")
        If vPicture = False Then Exit Sub
       Set pic = ActiveSheet.Shapes.AddPicture(Filename:=vPicture, LinkToFile:=False, SaveWithDocument:=True, _
                    Left:=ActiveCell.MergeArea.Left + cBorder, Top:=ActiveCell.MergeArea.Top + cBorder, Width:=-1, Height:=-1)
        With pic
            .LockAspectRatio = False       ' << change as required
             If Not .LockAspectRatio Then
                .Width = ActiveCell.MergeArea.Width - (2 * cBorder)
                .Height = ActiveCell.MergeArea.Height - (2 * cBorder)
                If .Width >= .Height Then
            .Placement = xlMoveAndSize
        Set pic = Nothing
    any help, greatly appreciated..
    susanto
    I can’t help you with a full solution because I have no experience inserting pictures. (Maybe someone else may help more later)
    But I can show you again how we can loop to repeat something for more than one file in a folder
    Example
    On my desktop, I have a folder, I did give it a name
    Picture Example Folder
    , its full path and file name is
    C:\Users\Elston\Desktop\Picture Example Folder
    https://i.postimg.cc/7b8WngcR/Pictur...My-Desktop.jpg
    I have two possibilities
    _ 1 One by one select picture. I must do this macro two times
    '        https://excelfox.com/forum/showthread.php/2781-VBA-Insert-Pictures-With-Multiple-Select-Picture-amp-Consecutive-Placing   https://bettersolutions.com/vba/files-directories/application-getopen.htm     https://docs.microsoft.com/de-de/office/vba/api/excel.application.getopenfilename
    Sub DoItTwoTimesForTwoFiles()
    ' let vPicture = Application.GetOpenFilename("Pictures (*.gif; *.jpg; *.jpeg; *.tif), *.gif; *.jpg; *.jpeg; *.tif", , "Select Picture to Import")
    ' Let vPicture = Application.GetOpenFilename(FileFilter:="Pictures (*.gif; *.jpg; *.jpeg; *.tif), *.gif; *.jpg; *.jpeg; *.tif", FilterIndex:=1, Title:="Select Picture to Import")
    Let vPicture = Application.GetOpenFilename(FileFilter:="Pictures gif ,*.gif," & "Pictures jpg ,*.jpg," & "Pictures jpeg ,*.jpeg," & "Pictures tif ,*.tif,", FilterIndex:=2, Title:="Select Picture to Import", MultiSelect:=False)
    MsgBox prompt:="The picture, you did selected it, the full path and file name it is " & vPicture
    _ 2 I can do this macro just once and it will select all file
    Sub DoItLoopy()
    Dim Path As String
     Let Path = "C:\Users\Elston\Desktop\Picture Example Folder" '  CHANGE TO SUIT
    Dim FileName As String
     Let FileName = Dir(Path & "\*", vbNormal)
        Do While FileName <> ""
        Dim FullPathAndFileName As String
         Let FullPathAndFileName = Path & "\" & FileName
        MsgBox prompt:="The picture, it was selected, the full path and file name it is " & FullPathAndFileName
        ' You can do other things here for each file
         Let FileName = Dir
        Loop
    Sep 2013
    hi Alan, thank you but i can't see photos..
    i have run with your all code
    i have suite path file location but still not working
    after running that code, showing
    Quote Originally Posted by muhammad susanto View Post
    Yes, that is what should happen, - That is what my macro does.
    Did you understand this?
    …..But I can show you again how we can loop to repeat something for more than one file in a folder
    My macro shows you how to select all files in a folder.
    I did not give you a full solution.
    My macro will give you all your file path and file name. It loops for every file. That is what you need. Now you put the other coding here:
    Sub DoItLoopy()
    Dim Path As String
         '   MsgBox prompt:="The picture, it was selected, the full path and file name it is " & FullPathAndFileName
        ' Put other coding here. It can be done on every file
         Let FileName = Dir
        Loop
    Sep 2013
    hi Alan, thank you but i am still confuse how to combine your code into my code
    like in post #1, with my code i can't select all pictures from 1 folder to inserted..
    second problem, after can select all pictures, the picture should be placement into multiple cell with sequence
    the macro is not original from me...i found it and actually i'm newbie about macro.
    You should not think of it as …. combine Alan code into muhammad code … that wont work. That’s wrong.
    Correct is: combine muhammad code into Alan code
    __Do While
    __Dim FullPathAndFileName As String
    __ Let FullPathAndFileName = Path & "" & FileName
    ___ muhammad code here
    __Loop
    That is a looping code section. It is done 2 times if you have two files, 3 times if you have three file, 4 times if you have 4 files, 5 times if you have 5 files, 6 times ……….etc.
    Each time it is done, my FullPathAndFileName = your vPicture
    In my example it would have looped 2 times because I had two files in my folder, Picture Example Folder, ( https://i.postimg.cc/7b8WngcR/Pictur...My-Desktop.jpg )
    I do not think it is possible to explain this any easier. That is very very simple and most very basic looping programming understanding.
    But I cannot tell you exactly what coding to put here, because I do not know how to do coding that involves inserting pictures. I have no experience inserting pictures.
    Somebody else will need to help you if you are unable yourself to proceed further.
    ( For somebody else to help you, it might be easier for them to help you if you explain in more full detail of your requirements and include some sample files )
    P.S.
    .. actually i'm newbie about macro.
    You have been doing macro for at least 9 years already . I have been doing macros for 6 years only. So I am super newbie
    Sep 2013
    hi expert..
    maybe my attachment new file make more clear & easy , now my target photos in cell C16, E16, G16, I16
  1. Replies: 3
    Last Post: 07-09-2020, 02:17 AM
  2. Replies: 0
    Last Post: 07-08-2020, 07:43 PM
  3. Macro To Browse&Select File and import Specific Data
    By madeinnorway in forum Excel Help
    Last Post: 09-20-2019, 01:24 AM
  4. Insert Different Picture into Multiple Sheets
    By muhammad susanto in forum Excel Help
    Last Post: 08-28-2018, 12:01 PM
  5. Insert Picture in a Cell UDF
    Last Post: 12-07-2012, 04:49 PM
