Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 156
Thread: P2P Cloud DVR remote Access via a (remote) PC Using Guarding Vision PC Client Software
  1. #51
    Working Examples 2b) -B- Cloud P2P remote access if you know the password and username of Sannce register
    This is post #51 in Thread.
    Links
    https://excelfox.com/forum/showthrea...ll=1#post15937
    https://excelfox.com/forum/showthread.php/2769-P2P-Cloud-DVR-remote-Access-via-a-(remote)-PC-Using-Guarding-Vision-PC-Client-Software?p=15937&viewfull=1#post15937
    https://excelfox.com/forum/showthrea...age6#post15937 https://excelfox.com/forum/showthread.php/2769-P2P-Cloud-DVR-remote-Access-via-a-(remote)-PC-Using-Guarding-Vision-PC-Client-Software/page6#post15937
    These are shortened summarised notes of specific worked examples. Missing information can be found in full detail in the main previous notes.
    Example of 2b) -B- Cloud P2P remote access if you know the password and username of Sannce registered account holding DVR P2P relevant information
    Main Thread notes: https://excelfox.com/forum/showthrea...ll=1#post15918
    A fairly new standard Windows 10 PC
    I installed the software, Gaurding Vision, from a personal stored .exe file
    An icon appeared as expected. https://i.postimg.cc/V6mq3PGg/Icon-a...s-expected.jpg - I double clicked on it, which brought me the usual warning asking me if I wanted to let the program do what it wanted to do. I clicked yes
    By the first launch I get a window to [FONT=Courier New]Register Administrator [/FONT ]. https://i.postimg.cc/N018Jj4L/Regist...ftware-run.jpg I can use any name and password which must not be, ( but can be ), that used on any other computer. It is only used to get access to the software client on this particular computer. For convenience and ease of remembering, I use the same name and password that I have been using throughout all tutorial work. Furthermore, I check the box to Enable Auto.login, just for convenience,
    https://i.postimg.cc/VNyBWCX3/Regist...inistrator.jpg
    DocAElstein
    Gaudy.!*
    Note that both the username and password are case sensitive.
    I get offered a help wizard in first use. So far I have always ignored this, https://i.postimg.cc/T35Jb95V/Ignore-Help-wizzard.jpg and close it
    A couple of things we note on this fist GUI view, is
    _ We just two Main Tabs, Control Panel and Device Management https://i.postimg.cc/PrRMNcJf/First-GUI-view.jpg
    ¬ _ We are currently looking at Device Management, and by default a Device has been added. It goes by the name of simply Device , which is a bit misleading, as really this is indicating the simple local LAN type device ( our way (ii) in previous discussions ). We should think more logically that we have just the options , Upgrade Server and + Add New Device type: Effectively on opening the software has automatically clicked on + Add New Device type and made a device type of the simple way (ii) LAN local PC access
    We want a P2P device type, so we
    _ click on + Add New Device type , and select a Cloud P2P device https://i.postimg.cc/Hsx2YHpP/Add-Ne...2-P-Device.jpg
    https://i.postimg.cc/8kw4gsV6/Cloud-P2-P-Device-OK.jpg
    Which causes the device type to appear, https://i.postimg.cc/kGjvQYyc/Cloud-...pe-appears.jpg but its not actually selected, ( we are still looking at any locally connected Devices ). So we click on the Cloud P2P Device
    https://i.postimg.cc/L54VZFj5/click-...ype-window.jpg
    in the Device Type left window. Now the Cloud P2P Device in the Device Type left window becomes highlighted and some processing is done,
    https://i.postimg.cc/Kz2fxMzn/clicke...ype-window.jpg
    https://i.postimg.cc/htXprn67/Processing-is-done.jpg
    after which we are prompted to login. Important at this point is to select first the land in which our DVR is, https://i.postimg.cc/3wp1sBK8/Prompt...ember-land.jpg , after which select Login
    https://i.postimg.cc/WzSX91s0/Login.jpg
    To now login, we need to know the password and username of Sannce registered account holding DVR P2P relevant information. So we add this information and then hit login. ( The username is not case sensitive, but the password is )
    Some processing is done https://i.postimg.cc/htXprn67/Processing-is-done.jpg , and if successful, a small black window bottom right appears to indicate the success, and the Device Name and Serial No. of our DVR appears
    https://i.postimg.cc/Y9z39CGT/Importing-succeeded.jpg ,
    At this stage we are in Device Management but have finished managing the device.
    So now we hit the View tab at the top, https://i.postimg.cc/wBs46zkd/View-Main-View.jpg
    ( and thereafter we will have a large View Tab added )
    https://i.postimg.cc/4xyFSV7y/Main-View.jpg
    We are finished at this point.
    I am not too clear on what all the various view setting mean, but usually some random clicking around on the various View and Camera options will bring the thing into life. In particular, clicking refresh symbols seems to help get things going.
    https://i.postimg.cc/nVK5jHfF/Refresh-Symbol.jpg , https://i.postimg.cc/15JjBJzb/Refresh-Symbol.jpg , https://i.postimg.cc/3JKq2P3g/Refresh-Symbol.jpg
  2. #52
    lslfhlkshfhkhlkahfalhf
  3. #53
    Run Code Sub ExportByName() on data from last post
    Results for Updated master Worksheet
    Using Excel 2007 32 bit
    J
    K
    L
    M
    N
    O
    25
    24
    ABC24
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 MT1 MT2 MT3 MT4 02.Apr.2018 02.Apr.2018 Margaret
    26
    25
    ABC25
    $ 333.45
    99
    $ 33,011.55
    02.Apr.2018 Raghu
    27
    26
    ABC26
    $ 11.99
    $ 11.99
    02.Apr.2018 John
    28
    27
    ABC27
    $ 741.99
    101
    $ 74,940.99
    02.Apr.2018 Greg
    29
    28
    ABC28
    $ 55.00
    22
    $ 1,210.00
    30
    29
    ABC29
    $ 13.66
    $ 95.62
    02.Apr.2018 Raghu
    31
    30
    ABC30
    $ 12.99
    $ 64.95
    02.Apr.2018 John
    32
    31
    ABC31
    $ 8.51
    $ 102.12
    02.Apr.2018 Greg
    33
    32
    ABC32
    $ 7.22
    62
    $ 447.64
    34
    33
    ABC33
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 Raghu
    35
    34
    ABC34
    $ 333.45
    99
    $ 33,011.55
    02.Apr.2018 John
    36
    35
    ABC35
    $ 11.99
    $ 11.99
    02.Apr.2018 Greg
    37
    36
    ABC36
    $ 741.99
    101
    $ 74,940.99
    38
    37
    ABC37
    $ 55.00
    22
    $ 1,210.00
    02.Apr.2018 Raghu
    39
    38
    ABC38
    $ 13.66
    $ 95.62
    02.Apr.2018 John
    40
    39
    ABC39
    $ 12.99
    $ 64.95
    02.Apr.2018 Greg
    41
    40
    ABC40
    $ 8.51
    $ 102.12
    42
    41
    ABC41
    $ 7.22
    62
    $ 447.64
    02.Apr.2018 Raghu
    43
    42
    ABC42
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 John
    44
    43
    ABC43
    $ 333.45
    99
    $ 33,011.55
    02.Apr.2018 Greg
    45
    44
    ABC44
    $ 11.99
    $ 11.99
    46
    45
    ABC45
    $ 741.99
    101
    $ 74,940.99
    02.Apr.2018 Raghu
    47
    46
    ABC46
    $ 8.51
    $ 102.12
    02.Apr.2018
    John
    48
    47
    ABC47
    $ 7.22
    62
    $ 447.64
    02.Apr.2018
    Greg
    49
    48
    ABC48
    $ 3.99
    35
    $ 139.65
    02.Apr.2018
    Margaret
    50
    49
    ABC49
    $ 333.45
    99
    $ 33,011.55
    02.Apr.2018
    Raghu
    51
    50
    ABC50
    $ 11.99
    $ 11.99
    02.Apr.2018
    Raghu
    52
    53
    54
    Worksheet: OriginalData
    Corresponding updated data worksheets for updated master after running Sub ExportByName() for the second time after new data was added
    41
    ABC41
    $ 7.22
    62
    $ 447.64
    02.Apr.2018 Raghu
    45
    ABC45
    $ 741.99
    101
    $ 74,940.99
    02.Apr.2018 Raghu
    49
    ABC49 $ 333.45
    99
    $ 33,011.55 02.Apr.2018 Raghu
    50
    ABC50 $ 11.99
    $ 11.99 02.Apr.2018 Raghu
    Worksheet: Tabelle1
    40
    ABC40
    $ 8.51
    $ 102.12
    44
    ABC44
    $ 11.99
    $ 11.99
    48
    ABC48 $ 3.99
    35
    $ 139.65 02.Apr.2018 Margaret
    Worksheet: Tabelle1
    38
    ABC38
    $ 13.66
    $ 95.62
    02.Apr.2018 John
    42
    ABC42
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 John
    46
    ABC46 $ 8.51
    $ 102.12 02.Apr.2018 John
    Worksheet: Tabelle1
    39
    ABC39
    $ 12.99
    $ 64.95
    02.Apr.2018 Greg
    43
    ABC43
    $ 333.45
    99
    $ 33,011.55
    02.Apr.2018 Greg
    47
    ABC47 $ 7.22
    62
    $ 447.64 02.Apr.2018 Greg
    Worksheet: Tabelle1
    Data Files just before second consolidation
    15
    ABC15
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 GT1 GT2 GT3 GT4 02.Apr.2018 02.Apr.2018 Greg
    19
    ABC19
    $ 55.00
    22
    $ 1,210.00
    23
    ABC23
    $ 7.22
    62
    $ 447.64
    02.Apr.2018 GT1 GT2 GT3 GT4 02.Apr.2018 Greg
    27
    ABC27
    $ 741.99
    101
    $ 74,940.99
    31
    ABC31
    $ 8.51
    $ 102.12
    35
    ABC35
    $ 11.99
    $ 11.99
    39
    ABC39
    $ 12.99
    $ 64.95
    02.Apr.2018 Greg
    Worksheet: Tabelle1
    18
    ABC18
    $ 741.99
    101
    $ 74,940.99
    02.Apr.2018 JT1 JT2 JT3 JT4 02.Apr.2018 02.Apr.2018 John
    22
    ABC22
    $ 8.51
    $ 102.12
    26
    ABC26
    $ 11.99
    $ 11.99
    02.Apr.2018 JT1 JT2 JT3 JT4 02.Apr.2018 John
    30
    ABC30
    $ 12.99
    $ 64.95
    34
    ABC34
    $ 333.45
    99
    $ 33,011.55
    38
    ABC38
    $ 13.66
    $ 95.62
    42
    ABC42
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 John
    Worksheet: Tabelle1
    28
    ABC28
    $ 55.00
    22
    $ 1,210.00
    32
    ABC32
    $ 7.22
    62
    $ 447.64
    02.Apr.2018 MT1 MT2 MT3 MT4 02.Apr.2018 Margaret
    36
    ABC36
    $ 741.99
    101
    $ 74,940.99
    40
    ABC40
    $ 8.51
    $ 102.12
    44
    ABC44
    $ 11.99
    $ 11.99
    Worksheet: Tabelle1
    17
    ABC17
    $ 11.99
    $ 11.99
    02.Apr.2018 RT1 RT2 RT3 RT4
    02. Apr 18
    02.Apr.2018 Raghu
    21
    ABC21
    $ 12.99
    $ 64.95
    02. Apr 18
    Raghu
    25
    ABC25
    $ 333.45
    99
    $ 33,011.55
    02. Apr 18
    Raghu
    29
    ABC29
    $ 13.66
    $ 95.62
    02. Apr 18
    Raghu
    33
    ABC33
    $ 3.99
    35
    $ 139.65
    02. Apr 18
    Raghu
    37
    ABC37
    $ 55.00
    22
    $ 1,210.00
    02. Apr 18
    Raghu
    41
    ABC41
    $ 7.22
    62
    $ 447.64
    02. Apr 18
    Raghu
    45
    ABC45
    $ 741.99
    101
    $ 74,940.99
    02. Apr 18
    Raghu
    49
    ABC49 $ 333.45
    99
    $ 33,011.55 02.Apr.2018 RT1 RT2 RT3 RT4
    02. Apr 18
    Raghu
    50
    ABC50 $ 11.99
    Worksheet: Tabelle1
    Final results for first half of master File after second consolidation
    J
    K
    L
    M
    N
    O
    S No
    Item
    Price
    Qty
    Total
    Distributed
    Task1
    Task2
    Task3
    Task4
    Completed
    Consolidated
    Comments
    Team Member
    Checked
    ABC01
    $ 55.00
    22
    $ 1,210.00
    02.Apr.2018 RT1 RT2 RT3 RT4 02.04.2018 02.Apr.2018 Raghu
    ABC02
    $ 13.66
    $ 95.62
    ABC03
    $ 12.99
    $ 64.95
    ABC04
    $ 8.51
    $ 102.12
    ABC05
    $ 7.22
    62
    $ 447.64
    ABC06
    $ 3.99
    35
    $ 139.65
    ABC07
    $ 333.45
    99
    $ 33,011.55
    ABC08
    $ 11.99
    $ 11.99
    ABC09
    $ 741.99
    101
    $ 74,940.99
    ABC10
    $ 55.00
    22
    $ 1,210.00
    ABC11
    $ 13.66
    $ 95.62
    13
    ABC12
    $ 12.99
    $ 64.95
    14
    13
    ABC13
    $ 8.51
    $ 102.12
    15
    14
    ABC14
    $ 7.22
    62
    $ 447.64
    16
    15
    ABC15
    $ 3.99
    35
    $ 139.65
    17
    16
    ABC16
    $ 333.45
    99
    $ 33,011.55
    18
    17
    ABC17
    $ 11.99
    $ 11.99
    19
    18
    ABC18
    $ 741.99
    101
    $ 74,940.99
    20
    19
    ABC19
    $ 55.00
    22
    $ 1,210.00
    21
    20
    ABC20
    $ 13.66
    $ 95.62
    22
    21
    ABC21
    $ 12.99
    $ 64.95
    23
    22
    ABC22
    $ 8.51
    $ 102.12
    24
    23
    ABC23
    $ 7.22
    62
    $ 447.64
    25
    24
    ABC24
    $ 3.99
    35
    $ 139.65
    26
    25
    ABC25
    $ 333.45
    99
    $ 33,011.55
    Second half of master worksheet after final second consolidation
    J
    K
    L
    M
    N
    O
    25
    24
    ABC24
    $ 3.99
    35
    $ 139.65
    26
    25
    ABC25
    $ 333.45
    99
    $ 33,011.55
    27
    26
    ABC26
    $ 11.99
    $ 11.99
    28
    27
    ABC27
    $ 741.99
    101
    $ 74,940.99
    29
    28
    ABC28
    $ 55.00
    22
    $ 1,210.00
    30
    29
    ABC29
    $ 13.66
    $ 95.62
    31
    30
    ABC30
    $ 12.99
    $ 64.95
    32
    31
    ABC31
    $ 8.51
    $ 102.12
    33
    32
    ABC32
    $ 7.22
    62
    $ 447.64
    34
    33
    ABC33
    $ 3.99
    35
    $ 139.65
    35
    34
    ABC34
    $ 333.45
    99
    $ 33,011.55
    36
    35
    ABC35
    $ 11.99
    $ 11.99
    37
    36
    ABC36
    $ 741.99
    101
    $ 74,940.99
    38
    37
    ABC37
    $ 55.00
    22
    $ 1,210.00
    39
    38
    ABC38
    $ 13.66
    $ 95.62
    40
    39
    ABC39
    $ 12.99
    $ 64.95
    02.Apr.2018 Greg
    41
    40
    ABC40
    $ 8.51
    $ 102.12
    42
    41
    ABC41
    $ 7.22
    62
    $ 447.64
    43
    42
    ABC42
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 John
    44
    43
    ABC43
    $ 333.45
    99
    $ 33,011.55
    02.Apr.2018 Greg
    45
    44
    ABC44
    $ 11.99
    $ 11.99
    46
    45
    ABC45
    $ 741.99
    101
    $ 74,940.99
    47
    46
    ABC46
    $ 8.51
    $ 102.12
    02.Apr.2018
    John
    48
    47
    ABC47
    $ 7.22
    62
    $ 447.64
    02.Apr.2018
    Greg
    49
    48
    ABC48
    $ 3.99
    35
    $ 139.65
    02.Apr.2018
    Margaret
    50
    49
    ABC49
    $ 333.45
    99
    $ 33,011.55
    02.Apr.2018
    51
    50
    ABC50
    $ 11.99
    $ 11.99
    02.Apr.2018
    Raghu
    52
    Data files after final (second) consolidation:
    15
    ABC15
    $ 3.99
    35
    $ 139.65
    19
    ABC19
    $ 55.00
    22
    $ 1,210.00
    23
    ABC23
    $ 7.22
    62
    $ 447.64
    27
    ABC27
    $ 741.99
    101
    $ 74,940.99
    31
    ABC31
    $ 8.51
    $ 102.12
    35
    ABC35
    $ 11.99
    $ 11.99
    39
    ABC39
    $ 12.99
    $ 64.95
    02.Apr.2018 Greg
    Worksheet: Tabelle1
    J
    K
    L
    M
    N
    O
    37
    ABC37
    $ 55.00
    22
    $ 1,210.00
    02. Apr 18
    02.Apr.2018 Raghu
    41
    ABC41
    $ 7.22
    62
    $ 447.64
    02. Apr 18
    02.Apr.2018 Raghu
    13
    45
    ABC45
    $ 741.99
    101
    $ 74,940.99
    02. Apr 18
    02.Apr.2018 Raghu
    14
    49
    ABC49
    333.45 €
    99
    33,011.55 €
    02. Apr 18
    02.Apr.2018 Raghu
    15
    50
    ABC50
    11.99 €
    11.99 €
    02.Apr.2018 Raghu
    16
    Worksheet: Tabelle1
    28
    ABC28
    $ 55.00
    22
    $ 1,210.00
    32
    ABC32
    $ 7.22
    62
    $ 447.64
    36
    ABC36
    $ 741.99
    101
    $ 74,940.99
    40
    ABC40
    $ 8.51
    $ 102.12
    44
    ABC44
    $ 11.99
    $ 11.99
    48
    ABC48
    3.99 €
    35
    139.65 €
    Worksheet: Tabelle1
    26
    ABC26
    $ 11.99
    $ 11.99
    30
    ABC30
    $ 12.99
    $ 64.95
    34
    ABC34
    $ 333.45
    99
    $ 33,011.55
    38
    ABC38
    $ 13.66
    $ 95.62
    42
    ABC42
    $ 3.99
    35
    $ 139.65
    02.Apr.2018 John
    Worksheet: Tabelle1
    Code for anwser to this Thread:
    http://www.excelfox.com/forum/showth...e-folder/page2
    Sub consolidateToo() '   http://www.excelfox.com/forum/showthread.php/2238-Copy-data-from-Unique-files-into-Masterfile-all-the-files-in-the-same-folder?p=10595#post10595
    Rem 1 ThisWorkbook Info
    Dim MWs1 As Worksheet: Set MWs1 = ThisWorkbook.Worksheets.Item(1) 'Worksheets("OriginalData")
    Dim DtaFName As String: Let DtaFName = VBA.Dir(ThisWorkbook.Path & "\" & "*.xlsx") ' Search criteria set to all Files with .xlsx extension in the same Folder as this workbook, Dir returns first file name that fits criteria
    Dim LrMWs1 As Long: Let LrMWs1 = MWs1.Range("A" & MWs1.Rows.Count & "").End(xlUp).Row
    Rem 2 main Loop for all data files
        Do While DtaFName <> "" ' ==========================================
         Workbooks.Open filename:=ThisWorkbook.Path & "\" & DtaFName
        Dim WBDta As Workbook: Set WBDta = ActiveWorkbook
        Dim WBDtaWs1 As Worksheet: Set WBDtaWs1 = WBDta.Worksheets.Item(1) ' use variable to reference the first worksheet ( counting tabs from the left ) of last opened and therefore active( to be seen ) file
        Dim arrIn() As Variant: Let arrIn() = WBDtaWs1.Range("A1").CurrentRegion.Value
        '2a) loop for all data rows, copy data from completed rows to master file, ( add date to inputed data array '_-##)
        Dim Rw As Long ' --------------------------------
            For Rw = 2 To UBound(arrIn(), 1) ' loop through "rows" in data array
                If arrIn(Rw, 11) <> Empty And arrIn(Rw, 12) = Empty Then ' Condition for completed work not yet consolidated
                 Dim arrCsDte(1 To 1, 1 To 7) As String: Let arrCsDte(1, 1) = arrIn(Rw, 7): arrCsDte(1, 2) = arrIn(Rw, 8): arrCsDte(1, 3) = arrIn(Rw, 9): arrCsDte(1, 4) = arrIn(Rw, 10): arrCsDte(1, 5) = arrIn(Rw, 11): arrCsDte(1, 6) = Format(Date, "dd.mmm.yyyy"): arrCsDte(1, 7) = arrIn(Rw, 13) ' 7 "columns" of data to be added to master file
                 MWs1.Range("A2:A" & LrMWs1 & "").Find(what:=arrIn(Rw, 1), After:=MWs1.Range("A2"), LookIn:=xlValues, Lookat:=xlWhole, searchorder:=xlByRows, searchdirection:=xlNext).Offset(0, 6).Resize(1, 7) = arrCsDte() ' We look down the first column in the master file to find the cell comtaining the   S No   We apply the offest property to thast cell to get across to column G and then the resize property gives us the range of 7 columns to which we may apply the values in the array filled for the row data
                 Let arrIn(Rw, 12) = arrCsDte(1, 6) '(Put the current date in the array made from data range        '_-##)
                Else ' Datá row is completed and consolidated , so nothing to do for this row
            Next Rw ' End loop for all data rows --------
        '2b) Update and close current data workbook
         Let WBDtaWs1.Range("A1").Resize(UBound(arrIn(), 1), UBound(arrIn(), 2)).Value = arrIn() ' reassign the values from the input data array back to the range as this now has the consolidated date in it
         WBDta.Close savechanges:=True
        '2c Serch for next data file name
         Let DtaFName = VBA.Dir() ' Unqualified Dir returns next found file with previos search criteria, but only returns each file name once
        Loop ' Do While DtaFName <> "" again ==============================
    Checked Library Infomation Excel 2003 Excel 2007 Excel 2010
    Some sample data for other Posts and Threads:
    http://www.eileenslounge.com/viewtopic.php?f=30&t=29652
    Using this code:
     Sub Its() ' snb 2017
    Dim It As Variant
      For Each It In ThisWorkbook.VBProject.References
      Dim strIts As String
       Let strIts = strIts & "Description:" & vbTab & It.Description & vbCr & "Name:" & vbTab & vbTab & It.Name & vbCr & "Buitin:" & vbTab & vbTab & It.BuiltIn & vbCr & "Minor:" & vbTab & vbTab & It.minor & vbCr & "Major:" & vbTab & vbTab & It.major & vbCr & "FullPath:" & vbTab & vbTab & It.fullpath & vbCr & "GUID:" & vbTab & vbTab & It.GUID & vbCr & "Type:" & vbTab & vbTab & It.Type & vbCr & "Isbroken:" & vbTab & vbTab & It.isbroken & vbCr & vbCr
      Next It
    Debug.Print strIts ' From  VB Editor Ctrl+g  to get Immediate Window from which info can be copied
    Here some results. ( If anyone passing has other Excel versions and would like to pass on what the code above gives, then that would be nice, thanks )
    Excel 2007
    Description:    Visual Basic For Applications
    Buitin:     Wahr
    Minor:      0
    Major:      4
    FullPath:       C:\Program Files\Common Files\Microsoft Shared\VBA\VBA6\VBE6.DLL
    GUID:       {000204EF-0000-0000-C000-000000000046}
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Excel 12.0 Object Library
    Buitin:     Wahr
    Minor:      6
    Major:      1
    FullPath:       C:\Program Files\Microsoft Office\Office12\EXCEL.EXE
    GUID:       {00020813-0000-0000-C000-000000000046}
    Type:       0
    Isbroken:       Falsch
    Description:    OLE Automation
    Buitin:     Falsch
    Minor:      0
    Major:      2
    FullPath:       C:\Windows\system32\stdole2.tlb
    GUID:       {00020430-0000-0000-C000-000000000046}
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Office 12.0 Object Library
    Buitin:     Falsch
    Minor:      4
    Major:      2
    FullPath:       C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSO.DLL
    GUID:       {2DF8D04C-5BFA-101B-BDE5-00AA0044DE52}
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Word 12.0 Object Library
    Buitin:     Falsch
    Minor:      4
    Major:      8
    FullPath:       C:\Program Files\Microsoft Office\Office12\MSWORD.OLB
    GUID:       {00020905-0000-0000-C000-000000000046}
    Type:       0
    Isbroken:       Falsch
    Excel 2003
    Buitin:     Wahr
    Minor:      0
    Major:      4
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Excel 11.0 Object Library
    Buitin:     Wahr
    Minor:      5
    Major:      1
    FullPath:       C:\Program Files\Microsoft Office\OFFICE11\EXCEL.EXE
    Type:       0
    Isbroken:       Falsch
    Buitin:     Falsch
    Minor:      0
    Major:      2
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Office 11.0 Object Library
    Buitin:     Falsch
    Minor:      3
    Major:      2
    FullPath:       C:\Program Files\Common Files\Microsoft Shared\OFFICE11\MSO.DLL
    Type:       0
    Isbroken:       Falsch
    Buitin:     Falsch
    Minor:      4
    Major:      8
    Type:       0
    Isbroken:       Falsch
    Excel 2010
    Buitin:     Wahr
    Minor:      1
    Major:      4
    FullPath:       C:\PROGRA~2\COMMON~1\MICROS~1\VBA\VBA7\VBE7.DLL
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Excel 14.0 Object Library
    Buitin:     Wahr
    Minor:      7
    Major:      1
    FullPath:       C:\Program Files (x86)\Microsoft Office\Office14\EXCEL.EXE
    Type:       0
    Isbroken:       Falsch
    Buitin:     Falsch
    Minor:      0
    Major:      2
    FullPath:       C:\Windows\SysWOW64\stdole2.tlb
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Office 14.0 Object Library
    Buitin:     Falsch
    Minor:      5
    Major:      2
    FullPath:       C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE14\MSO.DLL
    Type:       0
    Isbroken:       Falsch
    Description:    Microsoft Word 14.0 Object Library
    Buitin:     Falsch
    Minor:      5
    Major:      8
    FullPath:       C:\Program Files (x86)\Microsoft Office\Office14\MSWORD.OLB
    Type:       0
    Isbroken:       Falsch
  1. Replies: 5
    Last Post: 06-10-2019, 10:14 PM
  2. Replies: 18
  3. Replies: 19
  4. Testing Posts, Internet, Forum Software
    Last Post: 12-23-2018, 04:46 PM
  5. Replies: 17
