Details underneath:
SANNCE Model:DN81F
System:PAL
Power:DC 12V – 2A
SN:PO-170905-000030
www.sanncegroup.com
MADE IN CHINA
Testing Excel and Sannce 1080N and Computer CMS Software Sannce1 Okt2020 LinkFix
Testing ( https://excelfox.com/forum/showthrea...kt2020-LinkFix )
1 Juni 2019 01.06.2019 1st July 2019
Notes to be edited later
Notizen, die später bearbeitet werden sollen
Friday 31 may 2019
Hi ( Firstly, let me say.. - I am English, so my German is not to good )
Computer is Acer Aspire 4810TZG lap top connected to a Television via extended monitor option… ( http://www.excelfox.com/forum/showth...ll=1#post11167 ) . So I am using two monitors - http://i.imgur.com/WZc3LQJ.jpg , http://i.imgur.com/QMln86E.jpg , http://i.imgur.com/sCMCmQX.jpg ,
http://i.imgur.com/Ou60oYL.jpg
Hallo (Erstens, lassen Sie mich sagen .. - Ich bin Engländer, damit mein Deutsch nicht zu gut ist)
Der Computer ist ein Acer Aspire 4810TZG-Laptop, der über eine erweiterte Monitoroption mit einem Fernseher verbunden ist
( http://www.excelfox.com/forum/showth...ll=1#post11167 ) . Also benutze ich zwei Monitore - http://i.imgur.com/WZc3LQJ.jpg , http://i.imgur.com/QMln86E.jpg , http://i.imgur.com/sCMCmQX.jpg ,
This is the story so far.
I wanted to connect via internet to my computer
The cameras and Receiver are all working fine. They have been working fine for many days
I tried to follow this:
https://www.youtube.com/watch?v=6APBN6fqUKA
But I got these errors
http://i.imgur.com/gFIEPFl.jpg
http://i.imgur.com/OJGMwOc.jpg
So I tried to follow this:
https://www.youtube.com/watch?v=_iD8YUYhZ4E
I got no where with that.
I experimented and after many hours suddenly somehow something worked. But I have no idea how. I got this:
http://i.imgur.com/YxEUoVU.jpg
But then I restarted my computer and I only get this now:
http://i.imgur.com/9nMYDsi.jpg
!!!!! – see solution for Blank Monitor Screen in next post, Post #2 http://www.excelfox.com/forum/showth...ull=1#post8797
!!!!! - Siehe Lösung für Leerer Bildschirm angezeigt im nächsten Beitrag , Post #2 http://www.excelfox.com/forum/showth...ull=1#post8797
Das ist die Geschichte bis jetzt.
Ich wollte über das Internet eine Verbindung zu meinem Computer herstellen
Die Kameras und der Receiver funktionieren alle einwandfrei. Sie haben seit vielen Tagen gut funktioniert. Sie arbeiten immer noch
Ich habe versucht, dies zu befolgen:
Aber ich habe diese Fehler bekommen
Also habe ich versucht, dies zu befolgen:
Das war nichts.
Ich experimentierte und nach vielen Stunden funktionierte plötzlich irgendwie etwas. Aber ich habe keine Ahnung wie. Ich hatte folgendes:
Aber dann habe ich meinen Computer neu gestartet und das bekomme ich erst jetzt:
Saturday, 1 June, 2019
I had another go with a
Acer Aspire 6530G lap Top ( Operating System Windows 7 )
and a
Acer Aspire X3200 Computer ( Operating System Vista )
The following steps seem to consistently be successful currently. But they come from trial and error. I can find no detailed or simple to follow instructions. So I am making and sharing my own
The CMS Software disc is small!!
One immediate problem is that a small disc is supplied. It is about 8cm Diameter in size. Most nowadays seem to be about 12cm. If your lucky , your computer might be able to read that. Some of mine could. Some of mine could not.
So I tried to make a copy on a 12cm standard available ( 4.7GB) DVD.
Firstly, I put the supplied 8cm DVR-AN in a computer that was able to read it. I copied it in its entirety to a Folder on the desktop. I assumed it was a simple file, and therefore able to be copied in the simplest way. I am assuming it is not some special sort of instillation disc, but I am not sure…
I removed the 8cm DVR-AN, and in the same disc drive put a new 12cm standard available ( 4.7GB) DVD.
It seems that nobody is quite sure anymore how and what copying/ Burning to a disc is all about.. ( http://www.eileenslounge.com/viewtop...=25735#p200052 ) , and it varies with system and computer, but I double clicked on the DVD disc as showing in the Window explorer , and after a few steps appeared to have some sort of copy of the disc. I expect this will be different every time you try to do it. It is one of those annoying inconstant things designed to keep a lot of computer professionals in a job and off the streets.
1 DoubleClick on Virgin DVD 4_7GB and ____.JPG : http://i.imgur.com/uGMySRS.jpg
2 Some sort of initialising Burning.JPG : http://i.imgur.com/97EIoyJ.jpg
3 Did not work.JPG : http://i.imgur.com/g5ysg6a.jpg
On my computer, I have sometimes had better success with any sort of copying to a DVD, when using the “Sending on” option, rather than a simple Save or Copy/Paste option…
3 RightClick SendOn Disdrive.JPG : http://i.imgur.com/G66IQcl.jpg
4 Burn Maybe.JPG : http://i.imgur.com/XHNFCPH.jpg
5 Burn Maybe.JPG : http://i.imgur.com/aZKVRgw.jpg
6 Burn Maybe Discdrive making noise.JPG : http://i.imgur.com/Q5ACWpr.jpg
7 Burn Maybe Discdrive making noise Almost finished.JPG : http://i.imgur.com/mNMP5no.jpg
At the end of the copying/burning process, the DVD was thrown out. I pushed it back in, ( 8 Put it back in.JPG : http://i.imgur.com/pzpqKAM.jpg ) , to take a look at it. It appears to have similar information and format to the original 8cm DVR-AN
10 what is in it.JPGs : http://i.imgur.com/PEgz1v3.jpg
http://i.imgur.com/hzLCYrY.jpg
http://i.imgur.com/gMJnV1I.jpg
http://i.imgur.com/6jDikt4.jpg
An important content is the .exe file, which is what would typically be run ( usually by double clicking on, or opening somehow ) , to start an instillation process
14 what is in it exe.JPG : http://i.imgur.com/tRNCUrX.jpg , http://i.imgur.com/WGeDiAx.jpg
CMS Software instillation on a computer.
( Using either the supplied small disc, or the DVD copy which I made )
For example, I placed the made DVD in a computer that would not accept the small supplied disc.
15 Put that in another computer.JPG : http://i.imgur.com/XW0FEH5.jpg
16 Put that in another computer and open.JPG : http://i.imgur.com/H2dCIbX.jpg
17 looks like CMS copy is there.JPG : http://i.imgur.com/XiHqtdz.jpg
Important is to find the .exe file and to double click on it
18 Looks like all incl exe is there.JPG : http://i.imgur.com/uONucbb.jpg , http://i.imgur.com/XiHqtdz.jpg
Usually then a typical Instillation process will take place. Windows come up, which you should read. Usually you will simply need to click OK or Continue or similar, and after the Instillation is complete, a typical feature will be a short cut Icon in your desktop, which is used to double click on to start the program running.
Install.JPGs : http://i.imgur.com/zHVXbWh.jpg , http://i.imgur.com/v0oH14R.jpg , http://i.imgur.com/otZ5og0.jpg
, http://i.imgur.com/9JFq2Dh.jpg ,
25 Install Finish.JPG : http://i.imgur.com/9JFq2Dh.jpg
26 Icon.JPG : http://i.imgur.com/4TrwmWC.jpg
Samstag, 1. Juni 2019
Ich hatte einen anderen Versuch mit einem
Acer Aspire 6530G Laptop (Betriebssystem Windows 7)
und ein
Acer Aspire X3200 Computer (Betriebssystem Vista)
Die folgenden Schritte scheinen derzeit durchgehend erfolgreich zu sein. Aber sie kommen aus „Versuch und Irrtum“/ Experimentieren. Ich kann keine detaillierten oder einfach zu befolgenden Anweisungen finden. Also mache und teile ich meine eigenen Notizen
Die CMS-Software-CD ist klein !!
Ein unmittelbares Problem ist, dass eine kleine CD mitgeliefert wird. Es ist ca. 8cm Durchmesser groß. Die meisten scheinen ungefähr 12cm zu sein. Wenn Sie Glück haben, kann Ihr Computer kleinerer CDs möglicherweise lesen. Einige von meinen könnten. Einige von mieinen konnten nicht.
Also habe ich versucht, eine Kopie auf eine 12-cm-Standard-DVD (4,7 GB) zu erstellen.
Zuerst habe ich den mitgelieferten 8-cm-DVR-AN in einen Computer gesteckt, der ihn lesen konnte. Ich habe es vollständig in einen Ordner auf dem Desktop kopiert. Ich ging davon aus, dass es sich um eine einfache Datei handelt, die auf einfachste Weise kopiert werden kann. Ich gehe davon aus, dass es sich nicht um eine spezielle Art von Instillationsscheibe handelt, aber ich bin mir nicht sicher ...
Ich habe den 8-cm-DVR-AN entfernt und in das gleiche Laufwerk eine neue 12-cm-Standard-DVD (4,7 GB) eingelegt.
Es scheint, dass niemand mehr genau weiß, wie und worum es beim Kopieren / Brennen auf eine Disc geht, (Http://www.eileenslounge.com/viewtop...=25735#p200052), und dies hängt vom System und vom Computer ab , aber ich habe die DVD doppelt angeklickt, als sie im Fenster-Explorer angezeigt wurde, und nach ein paar Schritten schien es eine Art Kopie der DVD zu geben. Ich gehe davon aus, dass dies bei jedem Versuch anders sein wird. Es ist eine dieser nervigen, unbeständigen Dinge, die als beschäftigungstherapie für Computerfachleute scheint zu sein.
Auf meinem Computer hatte ich manchmal bessere Erfolge beim Kopieren auf eine DVD, wenn ich die Option „Senden an“ anstelle einer einfachen Option „Speichern“ oder „Kopieren / Einfügen“ verwendete.…
Am Ende des Kopier- / Brennvorgangs wurde die DVD ausgeworfen. Ich habe es zurückgeschoben, ( 8 Put it back in.JPG : http://i.imgur.com/pzpqKAM.jpg ) , um es anzusehen. Es scheint ähnliche Informationen und Formate wie der ursprüngliche 8-cm-DVR-AN zu haben
Ein wichtiger Inhalt ist die ,exe -Datei, die normalerweise ausgeführt wird (normalerweise durch Doppelklicken oder Öffnen), um einen Instillationsprozess zu starten
Installation der CMS-Software auf einem Computer .
(Verwenden Sie entweder die mitgelieferte kleine Disc oder die von mir erstellte DVD-Kopie.)
Zum Beispiel habe ich die erstellte DVD in einen Computer eingelegt, der die mitgelieferte kleine Disc nicht akzeptiert..
Wichtig ist, die .exe-Datei zu finden und darauf zu doppelklicken
In der Regel findet dann ein typischer Instillationsprozess statt. Es erscheint Windows, das Sie lesen sollten. Normalerweise müssen Sie nur auf OK oder Weiter oder Ähnliches klicken. Nach Abschluss der Instillation ist eine typische Funktion ein Verknüpfungssymbol auf Ihrem Desktop, mit dem Sie das Programm durch Doppelklicken starten können..
ref
https://vod.ebay.de/vod/FetchOrderDe...=2061615296011
https://www.ebay.de/itm/323782698418...r=512776720689
