Results 1 to 10 of 11
Thread: Excel and XP Operating System Tests (Internet Router connection problems)
    Some notes in support of these Threads
    https://www.dsl-forum.de/threads/251...line-verbunden
    http://www.eileenslounge.com/viewtopic.php?f=21&t=37237
    https://telekomhilft.telekom.de/t5/T.../true#M1390641
    https://telekomhilft.telekom.de/t5/T.../true#M1394485
    The main problem is explained here: http://www.eileenslounge.com/viewtop...288546#p288546
    Here a bit of info about the “working” and not working XP machines
    “WorkingWPA”
    Non working WPA
    So it looks like Service pack 2 don’t work.
    WPA or WPA2
    It’s all to do with some secret coding / encryption. As time went on they got it more safer / more sophisticated,
    I expect when you send stuff across the air with the WLAN, then you want to try and prevent people tapping into you
    The older XP don’t know about the newer WPA2
    I did have a quick fiddle with various security settings on my computers, but that mostly just got me in a mess. But I did not really look at that in any great detail.
    My older router had written on the back WPA/WPA2 . The simple short term solution to my problem seemed to mainly to be changing something in the routers settings:
  1. Replies: 3
    Last Post: 11-17-2019, 11:08 PM
  3. Table Tests. And Thread Copy Tests No Reply needed
  4. VBA Trick of the Week: Range to Recordset Without Making Connection
    Last Post: 07-11-2013, 06:21 PM
  5. Get standard GMT time from the system using vba.
    Last Post: 09-13-2012, 05:21 AM
