Thread: finding differences
    Nov 2023
    finding differences
    Hi All,
    I need some help with VBA macro to find the differences raw value between two sheets (version 1 & version 2)
    thanks in advance!
    https://www.youtube.com/watch?v=zHJPliWS9FQ&lc=Ugz39PGfytiMUCmTPTl4AaABAg. 91d_Pbzklsp9zfGbIr8hgW
    https://www.youtube.com/watch?v=zHJPliWS9FQ&lc=UgwbcybM8fXnaIK-Y3B4AaABAg.97WIeYeaIeh9zfsJvc21iq
    https://www.youtube.com/watch?v=vSjTzhoJFdk&lc=UgzTC8V4jCzDHbmfCHF4AaABAg. 9zaUSUoUUYs9zciSZa959d
    https://www.youtube.com/watch?v=vSjTzhoJFdk&lc=UgzTC8V4jCzDHbmfCHF4AaABAg. 9zaUSUoUUYs9zckCo1tvPO
    https://www.youtube.com/watch?v=vSjTzhoJFdk&lc=UgwMsgdKKlhr2YPpxXl4AaABAg
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgwTUdEgR4bdt6crKXF4AaABAg. 9xmkXGSciKJ9xonTti2sIx
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgwWw16qBFX39JCRRm54AaABAg. 9xnskBhPnmb9xoq3mGxu_b
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgybZfNJd3l4FokX3cV4AaABAg. 9xm_ufqOILb9xooIlv5PLY
    https://www.youtube.com/watch?v=XQAIYCT4f8Q&lc=UgyWm8nL7syjhiHtpBF4AaABAg. 9xmt8i0IsEr9y3FT9Y9FeM
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg. 9zYoeePv8sZ9zYqog9KZ5B
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=Ugy_RiNN_kAqUvZ8W994AaABAg. 9xhyRrsUUOM9zYlZPKdOpm
    Hello hussain66,
    Welcome to ExcelFox
    Your question is a bit short and undetailed. So we don’t know exactly what help you need.
    Here is a very simple VBA macro that might work for you.
    It goes through the cell items in the used range of the first worksheet. It goes through in the typical conventional way of all columns in a row , then down to the next row , and so on, until all cells used in the used range in the first worksheet are considered. Say for example you had used 2 columns and 3 rows, then it loops through the cells like this
    1 2
    3 4
    5 6
    That number sequence is also is the Item( ) number of the cells
    At each of the 6 loopings, it checks to see if there is a difference in the corresponding Cells in the used ranges in the first two worksheets. If there is a difference then the cell will be highlighted in yellow.
    In this simple example, in order for it to work, the used ranges would need to be the same in both worksheets.
    Sub QuickCommparison() '   https://www.excelfox.com/forum/showt...ll=1#post23871
    Dim ArCel As Range
        For Cnt = 1 To ThisWorkbook.Worksheets.Item(1).UsedRange.Cells.Count
            If ThisWorkbook.Worksheets.Item(1).UsedRange.Item(Cnt).Value <> ThisWorkbook.Worksheets.Item(2).UsedRange.Item(Cnt).Value Then Let ThisWorkbook.Worksheets.Item(1).UsedRange.Item(Cnt).Interior.Color = 65535
    By the way, there may very likely be some built in ways or other Add-Ins or many other ways to check differences in worksheets without the use of VBA. ( I am not personally familiar with much outside VBA )
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=UgxsozCmRd3RAmIPO5B4AaABAg. 9fxrOrrvTln9g9wr8mv2CS
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=UgyT1lo2YMUyZ50bLeR4AaABAg. 9fz3_oaiUeK9g96yGbAX4t
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=UgyT1lo2YMUyZ50bLeR4AaABAg. 9fz3_oaiUeK9g7lhoX-ar5
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=Ugw6zxOMtNCfmdllKQl4AaABAg. 9g9wJCunNRa9gJGhDZ4RI2
  1. finding first blank row
    Last Post: 12-31-2013, 05:34 PM
  2. I'm Finding Formulas Really Hard
    By flyinghigher2011 in forum Excel Help
    Last Post: 07-29-2013, 11:35 AM
  3. Compare two worksheets and List Differences
    Last Post: 11-02-2011, 10:03 PM
  4. Finding highest value in array
    Last Post: 06-24-2011, 03:59 AM
    Last Post: 04-03-2011, 08:25 PM
